Hi, I have programmed the Arduino Uno with Adafruit LSM9DS1 Accelerometer. Everything was working fine, then I wanted to upload the program again to the board and I got a lot of errors.
#include <Wire.h> // for I2C
#include <Adafruit_LSM9DS1.h>
#include <Adafruit_sensor.h>
// Magnetometer and accelerometer-giroscope subsystems addresses for i2c
#define LSM9DS1_M D1
#define LSM9DS1_AG D2
unsigned long tmeas, tlast;
unsigned int delta;
// Instantiate the IMU
Adafruit_LSM9DS1 imu = Adafruit_LSM9DS1();
Serial.begin(2000000);
imu.settings.device.commInterface = IMU_MODE_I2C;
imu.settings.device.agAddress = LSM9DS1_AG;
imu.settings.device.mAddress = LSM9DS1_M;
imu.settings.gyro.enabled = false;
imu.settings.mag.enabled = false;
imu.settings.temp.enabled = false;
// [scale] sets the full-scale range of the accelerometer.
// accel scale can be 2, 4, 8, or 16
imu.settings.accel.scale = 8;
// [sampleRate] sets the output data rate (ODR) of the
// accelerometer. ONLY APPLICABLE WHEN THE GYROSCOPE IS
// DISABLED! Otherwise accel sample rate = gyro sample rate.
// accel sample rate can be 1-6
// 1 = 10 Hz 4 = 238 Hz
// 2 = 50 Hz 5 = 476 Hz
// 3 = 119 Hz 6 = 952 Hz
imu.settings.accel.sampleRate = 6;
// [bandwidth] sets the anti-aliasing filter bandwidth.
// Accel cutoff frequeuncy can be any value between -1 - 3.
// -1 = bandwidth determined by sample rate
// 0 = 408 Hz 2 = 105 Hz
// 1 = 211 Hz 3 = 50 Hz
imu.settings.accel.bandwidth = 0;
imu.settings.accel.highResEnable = true;
// [highResBandwidth] sets the LP cutoff frequency of
// the accelerometer if it's in high-res mode.
// can be any value between 0-3
// LP cutoff is set to a factor of sample rate ODR output data rate
// 0 = ODR/50 2 = ODR/9
// 1 = ODR/100 3 = ODR/400
imu.settings.accel.highResBandwidth = 0;
do {
// Serial.println("Failed to communicate with LSM9DS1.");
} while (!imu.begin());
tlast = micros();
if ( imu.accelAvailable() ){
imu.readAccel();
tmeas = micros();
delta = tmeas -tlast;
tlast = tmeas;
// 16 bit signed integers -32768 to 32767
Serial.print(imu.ax);
Serial.print(" ");
Serial.print(imu.ay);
Serial.print(" ");
Serial.print(imu.az);
Serial.print(" ");
Serial.println(delta);
} // end if
// imu.readGyro();
// Serial.print(imu.gx);
// Serial.print(" ");
// Serial.print(imu.gy);
// Serial.print(imu.gz);
// Serial.println("");
// imu.readMag();
// Serial.print(imu.mx);
// Serial.print(imu.my);
// Serial.print(imu.mz);
The errors that I get are as follows:
C:\dyn-phantom\src\mcu\wearable_belt\acceleroreader\acceleroreader.ino: In function 'void setup()':
acceleroreader:17:7: error: 'class Adafruit_LSM9DS1' has no member named 'settings'
acceleroreader:17:39: error: 'IMU_MODE_I2C' was not declared in this scope
C:\dyn-phantom\src\mcu\wearable_belt\acceleroreader\acceleroreader.ino:17:39: note: suggested alternative: 'LB_MODE_2'
LB_MODE_2
acceleroreader:18:7: error: 'class Adafruit_LSM9DS1' has no member named 'settings'
acceleroreader:6:20: error: 'D2' was not declared in this scope
C:\dyn-phantom\src\mcu\wearable_belt\acceleroreader\acceleroreader.ino:18:35: note: in expansion of macro 'LSM9DS1_AG'
C:\dyn-phantom\src\mcu\wearable_belt\acceleroreader\acceleroreader.ino:6:20: note: suggested alternative: 'A2'
acceleroreader:19:7: error: 'class Adafruit_LSM9DS1' has no member named 'settings'
acceleroreader:5:19: error: 'D1' was not declared in this scope
C:\dyn-phantom\src\mcu\wearable_belt\acceleroreader\acceleroreader.ino:19:34: note: in expansion of macro 'LSM9DS1_M'
C:\dyn-phantom\src\mcu\wearable_belt\acceleroreader\acceleroreader.ino:5:19: note: suggested alternative: 'A1'
acceleroreader:20:7: error: 'class Adafruit_LSM9DS1' has no member named 'settings'
acceleroreader:21:7: error: 'class Adafruit_LSM9DS1' has no member named 'settings'
acceleroreader:22:7: error: 'class Adafruit_LSM9DS1' has no member named 'settings'
acceleroreader:26:7: error: 'class Adafruit_LSM9DS1' has no member named 'settings'
acceleroreader:34:7: error: 'class Adafruit_LSM9DS1' has no member named 'settings'
acceleroreader:40:7: error: 'class Adafruit_LSM9DS1' has no member named 'settings'
acceleroreader:42:7: error: 'class Adafruit_LSM9DS1' has no member named 'settings'
acceleroreader:49:7: error: 'class Adafruit_LSM9DS1' has no member named 'settings'
C:\dyn-phantom\src\mcu\wearable_belt\acceleroreader\acceleroreader.ino: In function 'void loop()':
acceleroreader:60:12: error: 'class Adafruit_LSM9DS1' has no member named 'accelAvailable'; did you mean 'accelData'?
accelData
acceleroreader:66:20: error: 'class Adafruit_LSM9DS1' has no member named 'ax'
acceleroreader:68:20: error: 'class Adafruit_LSM9DS1' has no member named 'ay'
acceleroreader:70:20: error: 'class Adafruit_LSM9DS1' has no member named 'az'
exit status 1
Can it be the problem with library? I have reinstalled them, but the problem remains the same.
Help.
