Hallo everyone,
I'm trying to run the DC motor with encoder quadrature. I use:
1.Arduino Uno
2. Motor Driver: Quad_Motor_Driver_Shield_for_Arduino_SKU_DRI0039-DFRobot
3. 4.4:1 Metal Gearmotor 25Dx48L mm LP 12V with 48 CPR Encoder Pololu - 4.4:1 Metal Gearmotor 25Dx60L mm LP 12V with 48 CPR Encoder (No End Cap)
This is my code:
boolean A,B;
//Input PWM
const int STEP = 11;
//Input Direction
const int DIR = 12;
byte state, statep;
float setpoint = 100; //Set velocity
double Kp = 0.5;
double Ki = 0.8;
double Kd = 0;
int PWM_val = 0; // (25% = 64; 50% = 127; 75% = 191; 100% = 255)
int speed_act = 0;
float motorSpeed = 0;
float motorSpeed_float = 0;
float count = 0; //set the counts of the encoder
unsigned long lastMilliPrint = 0; // loop timing
unsigned long lastMilli = 0; // loop timing
unsigned long lastMilliEncoder = 0; // loop timing
pinMode(2, INPUT_PULLUP);//encoder A pin
pinMode(3, INPUT_PULLUP);//encoder B pin
attachInterrupt(0,Achange,CHANGE);//interrupt pins for encoder
attachInterrupt(1,Achange,CHANGE);
pinMode(STEP, OUTPUT);
pinMode(DIR, OUTPUT);
void loop(){
if((millis()-lastMilliEncoder) >= 1000) {
lastMilliEncoder = millis();
getPosition();
if((millis()-lastMilliPrint) >= 500) {
lastMilliPrint = millis();
Serial.print("SP:"); Serial.print(setpoint );
Serial.print(" RPM:"); Serial.print(speed_act);
Serial.print(" PWM:"); Serial.print(PWM_val);
Serial.print("\n");
if((millis()-lastMilli) >= 100) {
lastMilli = millis();
PWM_val= updatePid(PWM_val, setpoint, speed_act); // compute PWM value
analogWrite(STEP, PWM_val); // send PWM to motor
void getPosition()
static float countAnt = 0; // last count
motorSpeed_float = ((count - countAnt)*60.0/211.2); // 48 pulses X 4.4 gear ratio = 211.2 counts per one rotate
speed_act = motorSpeed_float;
countAnt = count;
int updatePid(int command, int targetValue, int currentValue) { // compute PWM value
float pidTerm = 0; // PID correction
int error=0;
static int last_error=0;
error = abs(targetValue) - abs(currentValue);
pidTerm = (Kp * error) + (Kd * (error - last_error));
last_error = error;
return constrain(command + int(pidTerm), 0, 255);
void Achange() //these functions are for finding the encoder counts
A = digitalRead(2);
B = digitalRead(3);
if ((A==HIGH)&&(B==HIGH)) state = 1;
if ((A==HIGH)&&(B==LOW)) state = 2;
if ((A==LOW)&&(B==LOW)) state = 3;
if((A==LOW)&&(B==HIGH)) state = 4;
switch (state)
case 1:
if (statep == 2) count++;
if (statep == 4) count--;
case 2:
if (statep == 1) count--;
if (statep == 3) count++;
case 3:
if (statep == 2) count --;
if (statep == 4) count ++;
default:
if (statep == 1) count++;
if (statep == 3) count--;
statep = state;
It seems to me that the reading from the encoder is correct. However, now it works so that the engine rotates for a second and then stands for a second and then in a circle.
