Try initializing the VirtualWire library before you initialize Timer1. You may find that your PWM works but VirtualWire doesn't. That would indicate that VirtualWire is using Timer1.
Thank you johnwasser, it is true, the VirtualWire library using Timer1. Do you have any solution? I searched out some body try to Converting VirtualWire from Timer1 to Timer2, seems no result. http://forum.arduino.cc/index.php?topic=309766.0
what will be then?
Could be OK if I get rid of VirtualWire library and use RadioHead?
Best
All the good 433mhz RF libraries use a timer, almost always timer1.
My suggestion would be to use different PWM pins. If you need more than 4 PWM pins and 433MHz RF, the atmega328p is not sufficient (328pb is, as it has more extra timers, as is mega2560, and boards based on 1284p)
Thank you groundFungus and DrAzzy, maybe my understood wrong, my motor driver need 14khz, and there is only timer1 is 16 bite, which control pin9 and 10. can I used timer1 and output at other pins? or can other timer give out ~14khz PWM?
The link groundFungus given is about MEGA, I am using UNO now.
Thank you septillion, I agree with you to shift to timer2 is a simplest way.
The code for set frequency of timer1 is:
// PWM output @ 14 kHz, only on pins 9 and 10.
// Output value should be between 0 and 571, inclusive.
void analogWrite14k(int pin, int value)
switch (pin) {
case 9:
OCR1A = value;
case 10:
OCR1B = value;
default:
// no other pin will work
// Configure Timer 1 for PWM @ 25 kHz.
TCCR1A = 0; // undo the configuration done by...
TCCR1B = 0; // ...the Arduino core library
TCNT1 = 0; // reset timer
TCCR1A = _BV(COM1A1) // non-inverted PWM on ch. A
| _BV(COM1B1) // same on ch; B
| _BV(WGM11); // mode 10: ph. correct PWM, TOP = ICR1
TCCR1B = _BV(WGM13) // ditto
| _BV(CS10); // prescaler = 1
ICR1 = 571; // TOP = 571
// Set the PWM pins as output.
pinMode( 9, OUTPUT);
pinMode(10, OUTPUT);
// Just an example:
analogWrite14k( 9, 110);
analogWrite14k(10, 210);
for (; ; // infinite loop
can you kindly show me how to modify it to timer2?
I modified the code to use timer 2 output PWM on pin3 and pin11 succeed and got 31 KHz output, not perfect for need of 14 KHz yet, good for testing timer2 only.
That is merged into my motor driver code works well , how to make it output 14KHz?
// PWM output @ 14 kHz, only on pins 3 and 11.
// Output value should be between 0 and 320, inclusive.
switch (pin) {
case 3:
OCR2A = value;
case 11:
OCR2B = value;
default:
// Configure Timer 2 for PWM @ 14 kHz.
TCCR2A = 0; // undo the configuration done by...
TCCR2B = 0; // ...the Arduino core library
TCNT2 = 0; // reset timer
TCCR2A = _BV(COM2A1) // non-inverted PWM on ch. A
| _BV(COM2B1) // same on ch; B
| _BV(WGM20); // mode 10: ph. correct PWM, TOP = ICR1
TCCR2B = _BV(WGM00) // ditto
ICR1 = 320; // TOP = 320
pinMode( 3, OUTPUT);
pinMode(11, OUTPUT);
// Just an example:
analogWrite14k( 3, 110);
analogWrite14k(11, 220);
for (;;) ; // infinite loop
When I changed: TCCR2B = (TCCR2B & 0b11111000) | 0x02; //3.92116 [kHz], I got 3.9 khz, no meet need but close to. The joystick not works well, seems the data missed up, the joystick has a very little movement , if move more the speed go down instead of go up as expected.
Thank you septillion, the motor driver need frequency: 10khz - 20 khz, I random selected 14khz.
I changed TCCR2A and TCCR2B some day and got the output double, the 3.9k becomes around 7khz, should be good enough. The thing is the joystick's moving range changed very small, I doubt maybe the data storage address conflict some where?
Thank you septillion, the large motor driver I put link is not the one I gonna use, the real one is in Chinese and I was told that need over 10Khz PWM frequency.
