Hello, I'm having a problem with the Arduino Uno Knock Lock project. When I power up the project, the red LED turns on but the Servo Motor will not move without help. It also makes these weird twitching motions and makes some weird noises. Whenever I tap the piezo it just makes bigger twitchy motions, and nothing happens when I touch the button. I have tested all the components and have rechecked/written the code twice, as well as checking the (component placement? wiring design?) multiple times. I have no idea what the problem could be.
Thanks so much for any help.
Here's the code:
[/code]
#include <Servo.h>
Servo myServo;
const int piezo = A0;
const int switchPin = 2;
const int yellowLed = 3;
const int greenLed = 4;
const int redLed = 5;
int knockVal;
int switchVal;
const int quietKnock = 10;
const int loudKnock = 100;
boolean locked = false;
int numberOfKnocks = 0;
myServo.attach(9);
pinMode (yellowLed, OUTPUT);
pinMode (redLed, OUTPUT);
pinMode (greenLed, OUTPUT);
pinMode (switchPin, INPUT);
digitalWrite(greenLed, HIGH);
myServo.write(0);
Serial.println("The box is unlocked!");
if(locked == false){
switchVal = digitalRead(switchPin);
if(switchVal == HIGH){
locked = true;
digitalWrite(greenLed, LOW);
digitalWrite(redLed, HIGH);
myServo.write(90);
Serial.println("The box is locked!");
delay (1000);
if(locked == true){
knockVal = analogRead(piezo);
if(numberOfKnocks < 3 && knockVal > 0){
if(checkForKnock(knockVal) == true){
numberOfKnocks++;
Serial.print(3-numberOfKnocks);
Serial.println(" more knocks to go");
if(numberOfKnocks >= 3){
locked = false;
myServo.write(0);
delay(20);
digitalWrite(redLed, LOW);
numberOfKnocks = 0;
boolean checkForKnock(int value){
if(value > quietKnock && value <loudKnock){
digitalWrite(yellowLed, HIGH);
delay (50);
digitalWrite(yellowLed, LOW);
Serial.print("Valid knock of value ");
Serial.println(value);
return true;
else {
Serial.print("Bad knock value ");
return false;
[/code]
