Arduino Uno Project 7 | Keyboard Instrument
Hi, I am currently doing project 7, my code is perfectly fine (I think). However, only the bottom two buttons work and the top two don't. I'm terribly sorry if I come of as rude or have a bad question formatting, this is my first post ever! So any feedback would be appreciated :slight_smile:
(I'm not sure how to post code, but I think it's like this?)
int notes[] = {262, 294, 330, 349};
  int keyVal = analogRead(A0);
  Serial.println(keyVal);
  if(keyVal == 1023)
    tone(8, notes[0]);
  else if(keyVal >= 990 && keyVal <= 1010) {
    tone(8, notes[1]);
  else if(keyVal >= 505 && keyVal <= 515) {
    tone(8, notes[2]);
  else if(keyVal >= 5 && keyVal <= 10) {
    tone(8, notes[3]);
  else {
    noTone(8);
Check serial monitor. What value do you see printed when you press the buttons that don't work?
Going from left to right:
Button 1: 6-10
Button 2: 510-511
Button 3: 0
Button 4: 0
Thanks for reaching out PaulRB!
Swap the pushbuttons around. Any difference?
No, there was no difference I checked with a multi meter and all the push buttons were in working order, I did fix it, it seems there was something wrong with the bread board because when I was checking connections with a multimeter, it was not making a sound so I moved the pushbuttons and wires and bit and it was working!
Thank you for your help and support PaulRB!
This type of 4-pin pushbutton can have problems in breadboards. Their pins are very short, and depending on the internal design of the breadboard, you may not always get a good connection.
Some style push buttons don't have long enough / straight enough leads to fit a breadboard properly, so they can be a problem - the leads are bent to grip a 1.6mm thick PCB so it doesn't fall out when the PCB in inverted.
