Hey Arduino Team,
Just wanted to know if the UNO Q is compatible with the CNC Shield, i.e. the below image:
What voltage does the Uno Q use for its digital and analogue pins ?
What voltage does the CNC shield use for its pins ?
CNC will take 12 volts, but the pins from Arduino to shield just for logic is 5v
The voltage of the UNO Q i/o is 3.3v
I have driven these modules with a teensy which are 3.3v also, and it worked.
All the shield's pin uses digital I/O so it should be ok.
Yes, it works I tested it with UNO Q now, Thanx
