Can you power the the arudino through a cnc shield?
currently have things working on my bench top.. next to set it up to run from a battery.. .the two pins for voltage into the Arduino are filled from the cnc shield. I was wondering if anyone knows if the shield has a 5v input that pass through to the arduino?
Here's my set up
in the upper right are pins labled 5v and gnd
and in upper left
I don't want to do trial and error and fry something by connecting power into an output
Thanks in advance,
Keith
Yes, the shield diagram knows that:
Note that you must use a stabilized DC 5V source for that. You can't power the Arduino from screw terminal in the lower left in your photo.
The source:
Be aware that you should not connect both external 5V and USB power at the same time when using an Uno or Mega.
