Hello,
I need help with my Arduino UNO Q on Windows. The board is not being recognized correctly, and no COM port appears in the Arduino IDE or in Device Manager.
The last sketch that worked correctly in the Arduino IDE was the Blink LED example. After that, the board stopped being recognized properly and no COM port appears anymore.
What I already tried
- Different USB cables
- Different USB ports
- Checking Device Manager
- Jumper recovery procedure with Arduino CLI
Jumper / recovery process I tried
I followed the jumper recovery procedure for the UNO Q:
- Disconnected the board from USB
- Placed the jumper on the recovery pins
- Reconnected the board to the PC
- Tried the recovery / flashing process
- Removed the jumper
- Reconnected the board normally
Has anyone found another solution for this specific issue on Windows?
Welcome
Sorry you are having problems, but from here it appears you are not the only one. Many times the CH340 and windows drivers have problems. I come from a Linux background and I have not experienced the problems.
Common issues with the CH340:
- Some very old operating systems need drivers
- Some counterfeit or marginal chips behave poorly
- USB cables are often the real problem
- Noise or poor grounding can cause disconnects
- Some boards have weak reset circuitry
- High current surges can collapse USB voltage
In my case under Linux Mint the CH340 normally works out of the box. You can load a trial version of Linux Mint and try it without changing your hard drive. If you like it you can go to a duel boot system. Be sure important stuff is backed up and even better if you can use that old PC that is collecting dust you can give it a new life.
Hi @gilshultz. @smarciniegas is using the Arduino UNO Q board. This board does not have a WCH CH340 USB chip. It instead uses the Analogix ANX7625 bridge chip.
As your UNO Q board is not recognized by PC/Windows, there is no way you can proceed with "flashing process" as in the middle of process you will see the message: waiting for EDL device to respond and keeps waiting there.
So, connect your board with PC and check that you are hearing the dong sound.
The UNO Q is not just a simple gadget to play with; it offers tremendous opportunities to learn many things. I did not know before so many things about ANX7625 chip which I know now by virtue of UNO Q. UNO Q is is a great platform!
How many years they took to finish the Arduino UNO Q projcet starting from idea to field release and how many developers (hardware, software, testing, and documentation) were involved in the project?
