Hi, I'm having problems with my Arduino Q. I installed the application, but it doesn't recognize the device. I'm working from Windows 10.
Hello.
I also own an Arduino Q and it definitely takes a bit of patience first getting it started.
1.) make sure you have a proper USBC data cable
2.) when the board starts up did it do the fancy LED dance?
3.) did you install Arduino app lab?
4.) does windows beep as if you plugged something in when connecting your Q?
If it does check device manager and find your Arduino Q. You may need to update some driver files. I run mine on windows 11 but I do have a windows 10 computer around if you need more help.
1. Connect the UNO Q wit your PC using USB-C/USB-A data cable.
2. Check that you have heard a dong sound indicating that UNO Q has been recognized by Windows.
3. Open Device Manager and then expand the Ports to see that UNO Q as been assigned a (virtual) COMX Port.
4. Use IDE 2.x.x, select Arduino UNO Q Board and COMX port.
5. Upload the following sketch and check that LED3_R (Fig-1, LED-BUINTIN) blinks at 1-sec interval.
Figure-1:
#include <Arduino_RouterBridge.h>
Bridge.begin();
Monitor.begin();
delay(5000);
pinMode(LED_BUILTIN, OUTPUT);
digitalWrite(LED_BUILTIN, LOW); // active LOW; turn LED on
delay(1000); //1000 ms
digitalWrite(LED_BUILTIN, HIGH); // active low,LED off
delay(1000); // wait for a second
6. Install App Lab interface. Run the Blink LED application. Check that the same LED (LED3_R) blinks.
Thanks. The problem was the USB-C Data cables, I had the data cable for my mobile phone and the one I used with other Arduinos.
I got a 10Gbps cable and it worked perfectly.
