Hello,
I have an Arduino Uno R3 chip: ATMEGA328P-PU. About 30 seconds after powering the arduino the chip gets extremely hot. When it is powered, the power ON LED is green, and stays green. I can't load anything to the board, and when I hit the reset button, nothing blinks. Nothing else in the board is hot, just the chip. Also note that I currently have nothing connected to the board, just the USB to my laptop. Even when I try AC power, it still gets very hot. I have even tried to upload a blank code, which normally uploads but does nothing, it takes a little while, and then I receive this error message:
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x0d
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x0d
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0x0d
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0x0d
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0x0d
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0x0d
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0x0d
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0x0d
Problem uploading to board. See http://www.arduino.cc/en/Guide/Troubleshooting#upload for suggestions.
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0x0d
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0x0d
Has anyone had any of these signs? And if so, did you conclude that your board or just the chip was the problem? How did you fix this issue?
Thank you in advance for your help and time.
