Arduino Uno R3 compatibility with Arduino Cloud
Just purchased an Arduino Uno R3 board not too long ago but having a lot of compatibility issues when setting up.
I have Arduino code prepared and all the necessary parts for the project being built but experiencing compatibility issues with the main Arduino board.
Even when the board is connected as a third party device and the device is recognized, other forms of compatibility issues arises and modules do not sync.
Assistance would be appreciated.
Hi @fabiyij2. The Uno is not compatible with Arduino IoT Cloud, so this is the normal and expected result.
These are the boards listed as compatible with Arduino IoT Cloud:
You can use the Uno with Arduino Web Editor if you like:
Or you can use it with the desktop Arduino IDE:
I am still having server issue when using the web editor, also modules connecting to the Arduino board are not responding even with the lights on the board indicating it is connected
I can see from your screenshot that there was at least one successful compilation. So I think this was maybe an intermittent issue. Please try it again now to see whether the problem has already been resolved.
Please post your full sketch.
  1. Do an Auto Format on your code by pressing Ctrl+B. This will make it easier for you to spot bugs and make it easier for us to read.
  2. Click on the window that contains your sketch code.
  3. Press Ctrl+A. This will select all the text.
  4. Press Ctrl+C. This will copy the selected text to the clipboard.
  5. In a forum reply here, click on the reply field.
  6. Click the </> icon on the post composer toolbar. This will add the forum's code block markup (```) to your reply to make sure the error messages are correctly formatted.
    Code block
  7. Press Ctrl+V. This will paste the compilation output into the code block.
  8. Move the cursor outside of the code block markup before you add any additional text to your reply.
  9. Repeat the above process if your sketch has multiple tabs.
  10. Click the Reply button to post the output.
When your code requires a library that's not included with the Arduino IDE please post a link (using the chain links icon on the forum toolbar to make it clickable) to where you downloaded that library from or if you installed it using Library Manager Libraries > Library Manager) then say so and state the full name of the library.
#include <SPI.h>
#include <MFRC522.h>
#define SS_PIN 10
#define RST_PIN 9
#define LED_G 5 //define green LED pin
#define LED_R 4 //define red LED
#define RELAY 3 //relay pin
#define BUZZER 2 //buzzer pin
#define ACCESS_DELAY 2000
#define DENIED_DELAY 1000
MFRC522 mfrc522(SS_PIN, RST_PIN); // Create MFRC522 instance.
Serial.begin(9600); // Initiate a serial communication
SPI.begin(); // Initiate SPI bus
mfrc522.PCD_Init(); // Initiate MFRC522
pinMode(LED_G, OUTPUT);
pinMode(LED_R, OUTPUT);
pinMode(RELAY, OUTPUT);
pinMode(BUZZER, OUTPUT);
noTone(BUZZER);
digitalWrite(RELAY, LOW);
Serial.println("Put your card to the reader...");
// Look for new cards
if ( ! mfrc522.PICC_IsNewCardPresent())
return;
// Select one of the cards
if ( ! mfrc522.PICC_ReadCardSerial())
return;
//Show UID on serial monitor
Serial.print("UID tag :");
String content= "";
byte letter;
for (byte i = 0; i < mfrc522.uid.size; i++)
Serial.print(mfrc522.uid.uidByte[i] < 0x10 ? " 0" : " ");
Serial.print(mfrc522.uid.uidByte[i], HEX);
content.concat(String(mfrc522.uid.uidByte[i] < 0x10 ? " 0" : " "));
content.concat(String(mfrc522.uid.uidByte[i], HEX));
Serial.print("Message : ");
content.toUpperCase();
if (content.substring(1) == "83 23 38 BB") //change here the UID of the card/cards that you want to give access
Serial.println("Authorized access");
digitalWrite(RELAY, HIGH);
digitalWrite(LED_G, HIGH);
delay(ACCESS_DELAY);
digitalWrite(LED_G, LOW);
else {
Serial.println(" Access denied");
digitalWrite(LED_R, HIGH);
tone(BUZZER, 300);
delay(DENIED_DELAY);
digitalWrite(LED_R, LOW);
noTone(BUZZER);
#include <SPI.h>
#define SS_PIN 10
#define RST_PIN 9
noTone(BUZZER);
return;
return;
String content= "";
byte letter;
else {
tone(BUZZER, 300);
noTone(BUZZER);
**type or paste code here**
Everything between this: /* and this */ is a comment, and thus ignored by the compiler. There is a large amount of code in the sketch you posted that is commented out in this manner. After removing the commented code, we can see that the actual code of the sketch looks like this:
This code will not compile. If if did compile, it would not do anything. So the description of its behavior:
is normal and expected.
You can learn how to use the MFRC522 library by studying its example sketches.
#include <SPI.h>
#define SS_PIN 10
#define RST_PIN 9
noTone(BUZZER);
return;
return;
String content= "";
byte letter;
else {
tone(BUZZER, 300);
noTone(BUZZER);
I should have spotted that really.
Thank you for your assistance.
You're welcome. Best wishes for success with your Arduino endeavors!
