Arduino Uno R3 (with Atmega 16U2) and macOS 10.11 not working
Hello world :),
so I have the newest Arduino IDE (1.8.5) installed and the newest release of Arduino AVR Boards 1.6.21.
My OS: macOS 10.11.6 Hackintosh (clover bootloader). Usually I only use Nano's china clones with an CH340 USB-Serial chip, I have installed the wch driver and it worked fine ! My Nano's have the newest bootloader (Arduino AVR Boards 1.6.21).
And now the really annoying problem: I recently ordered Elegoo Uno R3 boards, they have the original 16U2 chip for USB-Serial, no FTDI and no CH340 it's a Atmega 16U2. And of course nothing works.. When I connect the Elegoo Uno to the mac (over the USB cable), it will show up in the system report - > USB as Arduino, but the IDE won't found it. Sometimes it will be found by the IDE, but when i click upload (the Blink sketch) it print following:
avrdude: Version 6.3, compiled on Jan 17 2017 at 12:01:35
         Copyright (c) 2007-2014 Joerg Wunsch
         System wide configuration file is "/Users/USERNAME/Library/Arduino15/packages/arduino/tools/avrdude/6.3.0-arduino9/etc/avrdude.conf"
         User configuration file is "/Users/USERNAME/.avrduderc"
         User configuration file does not exist or is not a regular file, skipping
         Using Port                    : /dev/cu.usbmodem5D21
         Using Programmer              : arduino
         Overriding Baud Rate          : 115200
         AVR Part                      : ATmega328P
         Chip Erase delay              : 9000 us
         PAGEL                         : PD7
         BS2                           : PC2
         RESET disposition             : dedicated
         RETRY pulse                   : SCK
         serial program mode           : yes
         parallel program mode         : yes
         Timeout                       : 200
         StabDelay                     : 100
         CmdexeDelay                   : 25
         SyncLoops                     : 32
         ByteDelay                     : 0
         PollIndex                     : 3
         PollValue                     : 0x53
         Memory Detail                 :
                                  Block Poll               Page                       Polled
           Memory Type Mode Delay Size  Indx Paged  Size   Size #Pages MinW  MaxW   ReadBack
           eeprom        65    20     4    0 no       1024    4      0  3600  3600 0xff 0xff
           flash         65     6   128    0 yes     32768  128    256  4500  4500 0xff 0xff
           lfuse          0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
           hfuse          0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
           efuse          0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
           lock           0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
           calibration    0     0     0    0 no          1    0      0     0     0 0x00 0x00
           signature      0     0     0    0 no          3    0      0     0     0 0x00 0x00
         Programmer Type : Arduino
         Description     : Arduino
         Hardware Version: 3
         Firmware Version: 4.444305
         Vtarget         : 322122183.2 V
         Varef           : 49804.8 V
         Oscillator      : 548.816 Hz
         SCK period      : 3495249366.4 us
avrdude: initialization failed, rc=-1
         Double check connections and try again, or use -F to override
         this check.
avrdude done.  Thank you.
So it receives the board information, but then the programmer does not respond, then he responds again and then not, a back and forth. I have already made it by repeatedly clicking that the program has been uploaded.
Now the possible sources of error:
USB cable
Atmega328
Atmega16U2
My thought: something with the auto reset
Sidenote: I also update the 328 and 16U2(over DFU and USBasp) bootloader with an USBasp, no success (the bootloaders have been uploaded successfully, but I still can't upload a sketch)
Now the things I tried:
Other USB cable -> no success
Upload bootloader to the 328 -> success, program it via an TTL adapter over RX TX -> success, the led start blinking.
Upload bootloader to the 16U2 -> success, but simultaneously not an success, because the bootloader was uploaded successfully, but I still can't upload a sketch.
I read read read over 5 hours now, and the only helpful articles were:
Same problem as me, he has/had an hackintosh with 10.11.06
He he did it with an update of the USB drivers via MultiBeast (hackintosh driver installer) I also try it with no success (I also know that their is now driver for the 16U2, because normally there are built in CDC/ACM drivers, exception windows.)
Arduino IDE serial ports not working on EL Capitan OSX
A big Github thread, with no real solution.
The 80% solution
That gave me the idea to test it in a virtual windows machine and surprise surprise it worked, it uploaded without any errors (that I did not figure it out sooner, my fault).
So now i know that the usb cable, the 328, the 16U2 are fully working and nothing is damaged, the only thing that is not working is my mac. Sometimes the UNO's are not recognized. Sometimes the sketch is only uploaded to 90 percent, then the board does respond. The Nano's are fully woking, I thought maybe the CH340 driver for the NANO's make problems ?
So because of that my mac have problems with the UNO boards.
Honestly after that, I have no idea, I just want it to work.
