Arduino Uno R4 Minima Stuck in Bootloader Mode (Orange LED Blinking)
Hello everyone,
I'm experiencing an issue with my Arduino Uno R4 Minima. After uploading a sketch using PlatformIO, the board is no longer recognized by my computer on either Windows or Linux. Here’s what I’ve observed and the steps I've taken so far:
  1. The green power LED is on, but there is only 100 mV on the 3.3V pin when the board is not in bootloader mode.
  2. When I double-click the reset button to enter bootloader mode, the orange LED blinks, and I can measure 3.3V on the 3.3V pin.
  3. In bootloader mode, the board appears in the dmesg output as "Santiago DFU," but I can't detect it in the Arduino IDE or in the device manager like before (Windows and Ubuntu). dfu-util -l give :'''
    Found DFU: [2341:0369] ver=0100, devnum=48, cfg=1, intf=0, path="1-2", alt=1, name="@DataFlash /0x08000000/81Kg", serial="380B253137323335C3C033324B572D3A"
    Found DFU: [2341:0369] ver=0100, devnum=48, cfg=1, intf=0, path="1-2", alt=0, name="@CodeFlash /0x00000000/8
    2Ka,120*2Kg", serial="380B253137323335C3C033324B572D3A"
  4. I attempted to flash the bootloader using dfu-util with the dfu_minima.hex file from the Arduino package directory on my system. The upload process completed without errors, but the board remains in bootloader mode, with the orange LED blinking continuously.
  5. I also tried uploading a basic Blink sketch in DFU mode using dfu-util, but the board still stays in bootloader mode after every attempt. Resetting or power cycling the board has no effect, and the orange LED keeps blinking.
Initially, the board was connected to multiple GPIOs set as input/output pins interfaced with other equipment. I performed a major update to the code, and although it worked perfectly in a previous iteration, I’m now wondering if there might be an interfacing issue. However, neither board shows signs of overheating.
Additionally, I have now tried two R4 boards connected to the same equipment, both resulting in the same issue of not being recognized by my computer. The steps described above were performed on my R4 board that is now unrecognized and completely disconnected from any other equipment—it’s only connected via USB at this point.
Unfortunately, I cannot share my code, as it is lengthy and private. Before investigating whether the cause is PlatformIO or an issue in my code, I’d like to know if there’s a way to recover these Arduino R4 boards. I find it strange that they no longer respond, yet the bootloader is still detectable.
Any suggestions on how to proceed would be greatly appreciated. Thank you in advance for your help!
You probably fixed your error by now but this is for the lone soul who comes across this post. Make sure you are using the correct USB cable. It needs to have a data line. I also had an R4 Minima (and ESP32-CAM) that were not recognised by Linux nor Windows 11 swapping the cable helped!
