I cant seem to find any documentation about this error the arduino_secrets.h file is correct,
this is just the standard OTA example
Please do not post pictures of code and error messages
Post the full sketch and full error message here, using code tags for both
OTA
This sketch demonstrates how to make an OTA Update on the UNO R4 WiFi.
Upload the sketch and wait for the invasion!
#include "WiFiS3.h"
#include "OTAUpdate.h"
#include "root_ca.h"
#include "arduino_secrets.h"
char ssid[] = SECRET_SSID; // your network SSID (name)
char pass[] = SECRET_PASS; // your network password (use for WPA, or use as key for WEP)
int status = WL_IDLE_STATUS;
OTAUpdate ota;
static char const OTA_FILE_LOCATION[] = "https://downloads.arduino.cc/ota/UNOR4WIFI_Animation.ota";
//Initialize serial and wait for port to open:
while (!Serial) {
; // wait for serial port to connect. Needed for native USB port only
// check for the Wi-Fi module:
if (WiFi.status() == WL_NO_MODULE) {
Serial.println("Communication with Wi-Fi module failed!");
// don't continue
while (true);
String fv = WiFi.firmwareVersion();
if (fv < WIFI_FIRMWARE_LATEST_VERSION) {
Serial.println("Please upgrade the firmware");
// attempt to connect to Wi-Fi network:
while (status != WL_CONNECTED) {
Serial.print("Attempting to connect to SSID: ");
Serial.println(ssid);
// Connect to WPA/WPA2 network. Change this line if using open or WEP network:
status = WiFi.begin(ssid, pass);
// wait 1 seconds for connection:
printWiFiStatus();
int ret = ota.begin("/update.bin");
if(ret != OTAUpdate::OTA_ERROR_NONE) {
Serial.println("ota.begin() error: ");
Serial.println((int)ret);
return;
ret = ota.setCACert(root_ca);
Serial.println("ota.setCACert() error: ");
return;
int ota_size = ota.download(OTA_FILE_LOCATION, "/update.bin");
if(ota_size <= 0) {
Serial.println("ota.download() error: ");
Serial.println(ota_size);
return;
ret = ota.verify();
Serial.println("ota.verify() error: ");
return;
ret = ota.update("/update.bin");
Serial.println("ota.update() error: ");
return;
void printWiFiStatus() {
// print the SSID of the network you're attached to:
Serial.print("SSID: ");
Serial.println(WiFi.SSID());
// print your board's IP address:
IPAddress ip = WiFi.localIP();
Serial.print("IP Address: ");
Serial.println(ip);
// print the received signal strength:
long rssi = WiFi.RSSI();
Serial.print("signal strength (RSSI):");
Serial.print(rssi);
Serial.println(" dBm");
wj��O���E (853834) uart: uart_get_buffered_data_len(1342): uart driver error
E (856267) uart: uart_get_buffered_data_len(1342): uart driver error
