Arduino Uno R4 Wifi Recognized as ESP32 devices
I just got the new R4 wifi and went to IoT then downloaded their connectivity software and downloaded the drivers. moments later I realized I couldn't connect to the device anymore and the RX LED was blinking non-stop. I have attempted to reset my computer and tried some of the other recommendations on some of the other forms but i have had no such luck. I have had my device be recognized as ESP32-S3-USB-OTG, ESP32-S3-Box, LOLIN S3, Adafruit QT Py ESP32-C3, and more. The reset button doesn't work, and when I unplug the power and plug it back in it just goes back to blinking the RX light.
When I also try to do the uno4wifi-update-windows.zip. and unzip and run the update file, i just get this error.
Cannot enumerate, try direct open
No board connected
Cannot put the board in ESP mode. (via 'unor4wifi-reboot')
Press any key to continue . . .
Then i press a key and it closes the program.
I have also tried uploading blink and pressing reset button multiple times with no progress. I also tried a jumper connection on the bottom left 2 pins just below the SCL and SDA markers - this did actually get the RX LED to stop blinking but still wasn't making it be recognized by anything.
Please help!
Currently, I am running on a rog Zephyrus G14 Laptop with Windows 11. Any help on fixing my bricked device would be greatly appreciated. I literally just bought it.
Take look at the " Troubleshooting" section of UNO R4 WiFi updater script and do the steps correctly.
Hi just as a little disclaimer at the start i am very new. When i tried to do the steps i got stuck at step 4: From the root folder of the downloaded .zip file run" bin\espflash write-bin -b 115200 0x0 firmware\UNOR4-WIFI-S3-0.2.0-rc1.bin. I tried to find a location to run this in but CMD doesn't seem to find the code although it is unzipped and i can't seem to find a arduino terminal where i can use this command. Help would be greatly appriciated :slight_smile:
Hi @tristan078. I apologize for the confusion. There is an error in those instructions.
I'll provide higher quality instructions you can follow:
  1. Disconnect the USB cable of the UNO R4 WiFi board from your computer.
  2. Use a jumper wire to connect these two pins ("DOWNLOAD" and "GND") on the 2x3 male header that is near the USB socket on the UNO R4 WiFi board:
    πŸ“·
    Arduino - CC BY-SA 4.0 (cropped)
  3. Connect the UNO R4 WiFi board to your computer with a USB cable.
  4. Open the release page for the latest version of the firmware in your web browser:
    https://github.com/arduino/uno-r4-wifi-usb-bridge/releases/latest
  5. Click the "unor4wifi-update-windows.zip" download link under the "Assets" section of the release page:
  6. Wait for the download to finish.
  7. Extract the downloaded file.
  8. Start Windows "File Explorer".
  9. Open the unor4wifi-update-windows folder that was created when you extracted the downloaded unor4wifi-update-windows.zip file at the previous step in the instructions.
  10. In the folder listing of the unor4wifi-update-windows folder, hold the Shift key while clicking the right hand button on the mouse.
  11. From the context menu, click "Open PowerShell window here".
    Windows PowerShell will now open.
  12. Type the following command at the Windows PowerShell window command prompt:
    bin\espflash write-bin -b 115200 0x0 (Get-Item .\firmware\UNOR4-WIFI-S3-*.bin).FullName
  13. Press the Enter key.
  14. The PowerShell window might now show a list of the serial ports present on your computer.
    For example:
    Start flashing firmware
    [2023-07-11T06:39:09Z INFO ] Detected 2 serial ports
    [2023-07-11T06:39:09Z INFO ] Ports which match a known common dev board are highlighted
    [2023-07-11T06:39:09Z INFO ] Please select a port
    ❯ COM1
      COM42- USB Serial Device (COM42)
    If so, use the ↓ key on your keyboard to select the port of the UNO R4 WiFi board from the list, and then press the Enter key.
  15. The terminal window will now show the following prompt:
    ? Remember this serial port for future use? (y/n) β€Ί
    Press the N key on your keyboard.
  16. The flashing process should now start. Wait for it to finish, as indicated by output that looks something like this:
    Chip type:         esp32s3 (revision v0.1)
    Crystal frequency: 40MHz
    Flash size:        8MB
    Features:          WiFi, BLE
    MAC address:       dc:54:75:c4:c6:54
    [00:00:15] [========================================]      826/826     0x0
  17. Disconnect the USB cable of the UNO R4 WiFi board from your computer.
    :exclamation: It is essential to perform this step.
  18. Disconnect the jumper wire you added at step (2) of the instructions.
  19. Connect the UNO R4 WiFi board to your computer with the USB cable again.
The board should now be recognized correctly in Arduino IDE once again.
Please let me know if you have any questions or problems while following those instructions.
It works now, thank you for for very detailed instructions!
You are welcome. I'm glad it is working now.
I have submitted a correction for the error in the instructions you followed originally:
I just tried this process and nothing is executing when I hit enter (step 13) windows 10. I have been trying to update firmware for a few days on and off to try and use the Cloud program and it just fails every time I try.
Hi @joeboots.
Is there an error message when you do that? If so, please post the full and exact text of the message in a reply here.
Just want to add here(had the same problem too) incase someone might have the problem I had, On Step13, if it says Get-Item : Cannot find path 'C:\Users\Administrator\Downloads\unor4wifi-update-windows\firmware' because it does not exist. simply click the folder 'unor4wifi-update-windows' again and repeat Step 9.
For Step 12, I restarted my PC, unplugged and plugged by usb and magically worked(dont know how lol) worked for me, might work for ye too ^^
Thank you, this just fixed my r4 with the same problem.
Arduino Uno R4 WiFi Recovery: From "ESP32S3 CAM LCD" Back to Working Board
How I solved the Problem:
After a failed firmware update via Arduino IDE/Browser, my Arduino Uno R4 WiFi was recognized as "ESP32S3 CAM LCD" in Device Manager. Normal firmware update tools no longer worked - board was essentially "bricked".
Solution - Hardware Reset + espflash:
1. Download GitHub Tool:
2. Perform Hardware Reset:
  • Disconnect board from PC
  • Connect GND and Download pins (6-pin header next to USB-C) with jumper wire and shown above.
  • Reconnect board to PC while jumper is still connected
  • Wait 5 seconds, then remove jumper
3. espflash Command:
  • Open PowerShell in extracted folder
  • Identify correct COM port in Device Manager
  • Command: .\bin\espflash.exe write-bin -p COM7 0x0 firmware\UNOR4-WIFI-S3-0.5.2.bin
4. Success: After 1-2 minutes of firmware flashing β†’ disconnect/reconnect board β†’ Now recognized as "Arduino Uno R4 WiFi" again!
Result:
Both "dead" boards are fully functional again. Arduino IDE recognizes them normally, WiFi works with firmware 0.5.2.
Tip: If you get write-flash errors, use write-bin instead - newer espflash versions have changed syntax.
Hope for all other "bricked" R4 WiFi boards! :rocket:
εΎˆδΈι”™γ€‚
