Been searching trough these forums and I cannot find a solution to my problem.
I've seen people posting about the same problem, but without getting the problem solved.
So I will try again.
When I try to program the UNO I get this error:
stk500_getsync(): not in sync: resp=0x00
All the drivers should be installed correctly since I tried to reinstall them a few times.
One thing that might be worth mentioning is that I get the UNOrev3 instead of the UNO driver in the Device Manager(saw a guide where they had UNO instead of the rev3)
I'm using Windows 7 x64.
I also saw some pictures where they were burning the bootloader and I wonder, is it possible to do without cables and stuff?
arigatou:
That's what it says. I still get the stk500_getsync(): not in sync: resp=0x00 problem
When you connect the arduino, did it show some notification in your toolbar whether it is installed or not?
If so, have you check the COM used, MyComputer-->Manage-->Device Manager?
Guys,
I think I found something on this problem.
I have Arduino-1.0 installed but I am still using Arduino-0022 for some projects. If I run the Arduino 1.0 IDE and load the Blinky sketch, It works just fine. I have a sneaky suspicion that the boatloader software is not backward compatible. The later devices have the optiboot firmware and I am not sure that if there is some problem.
Can a Guru help us here please? Nick, Crossroads, anyone?
johniemoth:
I have the same problem, just bought an UNO R3 and checked eveything, please help
johniemoth:
Hi All, just solve it by changing the port from COM3 to COM4 ....
@johniemoth ... Please don't create 4 threads basically on the same subject. Some people help you on this one, some on another one, and it just wastes time. For example I only found out on the other thread your problem is solved, which you didn't say here.
