Dear all,
This isn't a code or electrical issue, it's a mechanical issue with the Braccio Robot. Sorry for the long explanation, just want to make sure everything is included.
I've recently received a TinkerKit Braccio Robot and shield for my Arduino Uno. I've assembled it and followed the manual (no problems there). Now I've connected everything, loaded the example sketch "testBraccio90" which sets the robot to it's "Initial Position", or "Safety Position". As per the manual, this is the first thing to do after assembly, and I've done exactly that. Now, my problem is as follows:
The robot is not set to the correct position after the sketch is ran (which per the manual can be expected), and I want to realign the servo motors so that the robot is set in the correct position (also according to the manual). But; how to realign all the arms without disassembling most of the already assembled robot? My conclusion for now is that the motors should have been set to their initial position before mounting, since the mounting process made sure the mechanical position was correct.
So, has anyone ever realigned the servo motors on a Braccio Robot after assembly?
Thanks in advance for any pointers. All the best!
