Hello all!
I have been doing projects on the wemosD1R32 board for some time, in which I had to 'translate' the examples and redefine the pins in the code so that they match the correct pins on the board, but this time I am trying to read an SD card with the ethernet module shield, but I always receive the SD card initialization failure message, I think it is due to the SPI pins, on the Arduino Uno board they are pins 10-13 but on Wemos they are pins GPI05-23-19-18. The problem is that I can't find how to set the correct pins, since they are not included in the code, but are used from the SPI.h library. Is there any way to modify them?
SD card basic file example
This example shows how to create and destroy an SD card file
The circuit:
SD card attached to SPI bus as follows:
** MOSI - pin 11
** MISO - pin 12
** CLK - pin 13
** CS - pin 4 (for MKRZero SD: SDCARD_SS_PIN)
created Nov 2010
by David A. Mellis
modified 9 Apr 2012
by Tom Igoe
This example code is in the public domain.
#include <SPI.h>
#include <SD.h>
File myFile;
while (!Serial) {
; // wait for serial port to connect. Needed for native USB port only
Serial.print("Initializing SD card...");
if (!SD.begin(4)) {
Serial.println("initialization failed!");
while (1);
Serial.println("initialization done.");
if (SD.exists("example.txt")) {
Serial.println("example.txt exists.");
Serial.println("example.txt doesn't exist.");
// open a new file and immediately close it:
Serial.println("Creating example.txt...");
myFile = SD.open("example.txt", FILE_WRITE);
myFile.close();
// Check to see if the file exists:
// delete the file:
Serial.println("Removing example.txt...");
SD.remove("example.txt");
// nothing happens after setup finishes.
This code works perfect on Arduino Uno + Ethernet shield, but does not work with Wemos board...
Any ideas or suggestions?
Thanks so much!
