Arduino uno wifi rev2 : failed connection to mysql
Hello guys from the forum,
as by object, I have a problem with my Arduino uno wifi rev2, with which I would like
connect (from local) to the mysql database of Xampp that runs virtually in my pc...
I have successfully followed the following guide up to point n 6
From point n 7, I made some changes and I can’t connect:
The error generated by Arduino is:
"failed connection"
I modified the Arduino code to fit it from the Ethernet shield to my wifi.
So to solve the case, I have a few specific questions:
  1. Depends on mysql settings and php files ?
  2. Depends on sketch code ?
  3. What changes should I make?
Thanks for everything
 #include <SPI.h>
#include <WiFiNINA.h>
#include "arduino_secrets.h"
///////please enter your sensitive data in the Secret tab/arduino_secrets.h
char ssid[] = SECRET_SSID;        // your network SSID (name)
char pass[] = SECRET_PASS;    // your network password (use for WPA, or use as key for WEP)
int keyIndex = 0;            // your network key index number (needed only for WEP)
WiFiClient client;
int status = WL_IDLE_STATUS;
int    HTTP_PORT   = 80;
String HTTP_METHOD = "GET";
char   HOST_NAME[] = "192.168.1.3"; // change to your PC's IP address
String PATH_NAME   = "/insert_temp.php";
String queryString = "?temperature=29.1";
  //Initialize serial and wait for port to open:
  while (!Serial) {
    ; // wait for serial port to connect. Needed for native USB port only
  // check for the WiFi module:
  if (WiFi.status() == WL_NO_MODULE) {
    Serial.println("Communication with WiFi module failed!");
    // don't continue
    while (true);
  String fv = WiFi.firmwareVersion();
  if (fv < WIFI_FIRMWARE_LATEST_VERSION) {
    Serial.println("Please upgrade the firmware");
  // attempt to connect to WiFi network:
  while (status != WL_CONNECTED) {
    Serial.print("Attempting to connect to SSID: ");
    Serial.println(ssid);
    // Connect to WPA/WPA2 network. Change this line if using open or WEP network:
    status = WiFi.begin(ssid, pass);
    // wait 10 seconds for connection:
    delay(10000);
  Serial.println("Connected to WiFi");
  printWifiStatus();
  // connect to web server on port 80:
  if(client.connect(HOST_NAME, HTTP_PORT)) {
    // if connected:
    Serial.println("Connected to server");
    // make a HTTP request:
    // send HTTP header
    client.println(HTTP_METHOD + " " + PATH_NAME + queryString + " HTTP/1.1");
    client.println("Host: " + String(HOST_NAME));
    client.println("Connection: close");
    client.println(); // end HTTP header
    while(client.connected()) {
      if(client.available()){
        // read an incoming byte from the server and print it to serial monitor:
        char c = client.read();
        Serial.print(c);
    // the server's disconnected, stop the client:
    client.stop();
    Serial.println("disconnected");
  } else {// if not connected:
    Serial.println("connection failed");
  // if there are incoming bytes available
  // from the server, read them and print them:
   while (client.available()) {
    Serial.write(c);
  // if the server's disconnected, stop the client:
  if (!client.connected()) {
    Serial.println("disconnecting from server.");
    client.stop();
    // do nothing forevermore:
    while (true);
void printWifiStatus() {
  // print the SSID of the network you're attached to:
  Serial.print("SSID: ");
  Serial.println(WiFi.SSID());
  // print your board's IP address:
  IPAddress ip = WiFi.localIP();
  Serial.print("IP Address: ");
  Serial.println(ip);
  // print the received signal strength:
  long rssi = WiFi.RSSI();
  Serial.print("signal strength (RSSI):");
  Serial.print(rssi);
  Serial.println(" dBm");
The problem may come from:
  • Arduino code (WiFi part) => Check a simple example for WiFi to test it it can connect to your LAN/WLAN network
  • Apache Web Server on your PC => Check if the Apache web server on your PC works by accessing the page via a web browser.
Thank you.
Arduino works and connects well to the network; I verified.
The problem is the second one you described:
  • The Apache web server on my PC works fine accessing the page through a browser when I input data from the URL.
  • It doesn't work when I send data from Arduino.
Is this IP address of your PC ?
Yes
192.168.1.3 Is IP address of my PC
192.168.1.2 Is IP address of my Arduino
Case solved! It was an issue with the Arduino and Apache firewall settings on Windows 10. Thanks sport
Hi, relating to your question. how did you solve the refused connection error. I am trying to make my Arduino uno wifi send accelerometer data to firibase. Use code tags to format code for the forum..
#include <ArduinoMqttClient.h>
  Project: Send Data to Firebase Using Arduino Uno WiFi Rev2
  Board: Arduino Uno WiFi Rev2
  External libraries:
  - Arduino_LSM6DS3 by Arduino V1.0.0
  - Firebase Arduino based on WiFiNINA by Mobizt V1.1.4
#include <Arduino_LSM6DS3.h>
#include <Firebase_Arduino_WiFiNINA.h>
#define FIREBASE_HOST "monad001-5dd6c.firebaseio.com"
#define FIREBASE_AUTH "S9awemPMCrkiEovjxtLKAlrrWnUzTDTU538wfrjt"
#define WIFI_SSID "pure1727"
#define WIFI_PASSWORD "84123769"
#define DATABASE_URL "https://monad001-5dd6c-default-rtdb.firebaseio.com/"
FirebaseData firebaseData;
String path = "/IMU_LSM6DS3";
String jsonStr;
  Serial.print("Initialize IMU sensor...");
  if (!IMU.begin()) {
    Serial.println(" failed!");
    while (1);
  Serial.println(" done");
  Serial.print("Accelerometer sample rate = ");
  Serial.print(IMU.accelerationSampleRate());
  Serial.println(" Hz");
  Serial.print("Connecting to WiFi...");
    status = WiFi.begin(WIFI_SSID, WIFI_PASSWORD);
    Serial.print(".");
    delay(300);
  Serial.print(" IP: ");
  Firebase.begin(FIREBASE_HOST, FIREBASE_AUTH, WIFI_SSID, WIFI_PASSWORD);
  Firebase.reconnectWiFi(true);
  float x, y, z;
  // Read IMU acceleration data
  if (IMU.accelerationAvailable()) {
    IMU.readAcceleration(x, y, z);
    // Send data to Firebase with specific path
    if (Firebase.setFloat(firebaseData, path + "/1-setFloat/X", x)) {
      Serial.println(firebaseData.dataPath() + " = " + x);
    if (Firebase.setFloat(firebaseData, path + "/1-setFloat/Y", y)) {
      Serial.println(firebaseData.dataPath() + " = " + y);
    if (Firebase.setFloat(firebaseData, path + "/1-setFloat/Z", z)) {
      Serial.println(firebaseData.dataPath() + " = " + z);
    // Push data using pushJSON
    jsonStr = "{\"X\":" + String(x,6) + ",\"Y\":" + String(y,6) + ",\"Z\":" + String(z,6) + "}";
    if (Firebase.pushJSON(firebaseData, path + "/2-pushJSON", jsonStr)) {
      Serial.println(firebaseData.dataPath() + " = " + firebaseData.pushName());
    else {
      Serial.println("Error: " + firebaseData.errorReason());
    delay(2000);
