Arduino Uno Wifi Rev2
Hello,
I have Arduino Uno Wifi Rev2.
I succesfully connected to my wifi.
Now I'm trying to connect it to mysql server.
I have Raspberry Pi and I have installed apache, mysql and phpmyadmin and they work correctfully.
Here is my code:
#include <WiFiNINA.h>                  // Use this for WiFi instead of Ethernet.h
#include <MySQL_Connection.h>
#include <MySQL_Cursor.h>
#include "arduino_secrets.h"
///////please enter your sensitive data in the Secret tab/arduino_secrets.h
char ssid[] = SECRET_SSID;        // your network SSID (name)
int status = WL_IDLE_STATUS;     // the Wifi radio's status
//byte mac_addr[] = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED };
IPAddress server_addr(192,168,43,219);  // IP of the MySQL *server* here
char user[] = "root";              // MySQL user login username
char password[] = "testing123";        // MySQL user login password
WiFiClient client;            // Use this for WiFi instead of EthernetClient
MySQL_Connection conn((Client *)&client);
  // Begin WiFi section
  int status = WiFi.begin(ssid);
  if ( status != WL_CONNECTED) {
    Serial.println("Couldn't get a wifi connection");
    while(true);
  // print out info about the connection:
  else {
    Serial.println("Connected to network");
    IPAddress ip = WiFi.localIP();
    Serial.print("My IP address is: ");
    Serial.println(ip);
  // End WiFi section
  Serial.println("Connecting...");
  if (conn.connect(server_addr, 3306, user, password)) {
    Serial.println("Connected");
    Serial.println("Connection failed.");
  conn.close();
  delay(2000);
and in arduino_secrets it's: #define SECRET_SSID "ASUSWeb" (my wifi)
How can I check, does this really connect to my mysql and how can I make it to write some content in some database? I create database called "test".
Thank you for your replies!
Forget the Arduino for a moment. What commands would you use to write to a MySQL table if you were doing it manually ? What commands would you use to read from the table ?
Maybe look at some of the examples here: GitHub - ChuckBell/MySQL_Connector_Arduino: Database connector library for using MySQL with your Arduino projects. . I guess basic_select.
