I have an Arduino Uni Rev3, an Arduino WiFi Shield and a TFT LCD Screen.
The WiFi Shield and the TFT Screen works prefectly with the Arduino, if only one is connected.
If I connect both, the Arduino won't power up until I disconnect the TFT (by removing the screen or at least the GND).
Is there any way to connect both the shield and the screen to the Uno?
I'm using my laptop as a power source. I'll try a wall charger and report back.
I assume, that the WiFi shield and the TFT should work without any magic (like redefining the pins), if there is enough power.
I've just tried your solution with a Voltcraft adapter (9 V DC, 1000 mA). Unfortunately nothing has changed. My laptop signals with the "device disconnected" tone immediately I complete the circuit (eg. plugging in the 5V cable). As soon as I remove the TFT from the circuit, the Arduino Uno-WiFi Shield reconnects.
What can be the problem? Can the TFT use the same pins as the WiFi Shield? If not, can I redefine the used pins?
