Having issues with my Arduino UNO/Ethernet W5500 combo. I'm trying to run the DhcpAddressPrinter sketch example. I've updated the MAC address in the sketch to be whats shown on the sticker on the shield. I am getting the following message... 'Failed to configure Ethernet using DHCP'. Please help.
I have been having similar problems with an EthernetSheildV1 see post #6
often takes 2 or 3 resets of Ethernet board to get DHCH to respond then everything works OK
tried Ethernet V2 and v3 libraries - same problem
I was thinking it was a problem with my old EthernetSheildV1 not working with modern routers
Confirmed the above - using an old router the Ethernetshield works OK
try the WebClient example. it has enhanced diagnostics
What do yo you have in Ethernet.begin(mac, ip); ?
If you use
Ethernet.begin(mac); and connect your shield to a DHCP router, DHCP router give ip adress after a minute or so.
you can get your given IP adress by using:
Serial.print("Server running at ");
Serial.println(Ethernet.localIP());
If you use Ethernet.begin(mac, ip); and give a spesific IP adress, your shield will get that. This ip adress must correlate to your LAN and pc network card setup.
Thanks for the response. I was able to make a bit of progress yesterday... turns out if you don't have a router (connecting directly from shield to PC), you need a crossover cable.
The PC I'm having to use is not connected to the internet.
I'm suspecting that because I am not using a router, the examples with 'DHCP' will not work.
So I tried using the AdvancedChatServer sketch example... I've updated the sketch as follows:
IPAddress ip(192, 168, 0, 2);
IPAddress myDns(192, 168, 1, 1);
IPAddress gateway(192, 168, 1, 1);
IPAddress subnet(255, 255, 255, 0);
Then input the following into Windows Ethernet Properties:
IP Address: 192.168.0.1
Subnet mask: 255.255.255.0
Default Gateway: blank
Preferred DNS server: 8.8.8.8
Alternate DNS server: 8.8.4.4
Uploaded the sketch... I get the following statement in the COM window:
Chat server address: 192.168.0.2
Upon opening a telnet session, I get the following:
We have a new client
But when I type in the CMD window I am not getting anything in return in the COM window. Any ideas on why that might be?
Thanks,
Rob
After looking thru the code, with my limited experience ;-)... I was able to determine that the text is not echoed back to the Arduino COM window, but rather to other open client windows. Needless to say... I got it to work!!
Another update... added router and everything works great!!
Hi! I am also a novice with network type things. Could you walk through how you got this working connecting directly to the PC? I cannot find the IP address of the Arduino/shield. I tried to follow your process and run the Advanced Chat script, but I only see the "Chat server address:..." message in the COM window with the arbitrary IP that I set in the script. However, when I open a browser and try to open that IP, I get nothing. Thank you!!
Yeah… that part was a bit frustrating for me too. If you are going directly to the PC from the Ethernet shield (ie… NO ROUTER), then you need a cross-over cable. You also need to specify the IP address in your Arduino sketch… Ethernet.begin(mac, ip)…. DHCP will not work because there is no router. Hope this makes sense.
