when i connect my ethernet shield i see on Serial Monitor 'No internet connection' i try connecting to a power bank instead of usb PC power and changed ethernet cable nothing helps. maybe there is something very simple to make it work or to make it function? I am new to this so any help would be appricated.
Then the ethernet connection is working perfectly. There is something wrong with the messaging to the router. Where did you get the procedure to connect to the internet?
The IP address I left as it’s on the op, I did change on my end.
I thought the issue was different I need to open a new topic, is it best to continue on the old post? Please bear patience with me since I am new to this universe I might to these sorta mistake and thank you for your advice.
My pc is fully connected to internet and working. I check my router information and I see the ip of my Ethernet shield display including the port it is connected to and one thing I notice odd is only green led glows on the shield and router port. I try connecting different ports it’s the same result. Feels like something is blocking from reaching to internet.
Is there a way to hard rest the whole boards? Like completely wipe out all data?
Is that two LEDs on two devices or one LED on one of the devices?
I agree. Networks have built-in security so hacking takes effort. You probably are facing an unsuccessful network setup with your shield.
I am certain the router has a factory-reset sequence... but then you need the administrator password to re-enter the router. Sometimes it is admin sometimes administrator sometimes <CR> sometimes it is the company name... you should find the answer to that before resetting the router.
1 led on the router 1 led on ethernet shield which is lightgreent/lightyellow one. usuall orange and light green blick on both end of the devices, is it normal for Arduino ethernet?
I didnt meant the rounter, more the Ethernet shield or the UNO board, is there a way to hard reset so if there is anything software related it will go away?
Please do not restore the factory defaults on the router, you will lose all internet access and have to reconfigure your router.
If you have internet access from your PC via the router then I doubt there's a problem with your router.
As @J-M-L asked in post #8, is that IP address on your subnet? If not then it won't work. If you answered this then I missed it.
All that tells you is that the electrical connection is working and data can pass, it doesn't tell you anything about the integrity of that data or whether the router can do anything with it.
it doesnt show any information on Serial Monitor, i tried removing ethernet cable and connecting. Both options show nothing so i guess my hardware it broken?
I was already getting ready to buy original boards, since the problem could be other brands. Does usually both led suppose to blink or is it normal only yellow to blink? Also could it be other brand boards cause these problems? This is my 2nd set of boards. Uno + Ethernet shield.
