The u8g2.firstPage() function call is not needed when initializing the display.
// Initialize the displays
void DisplayInit() {
for (int i = 0; i < 2; i++) {
tcaselect(i); // Loop through each connected displays on the I2C buses
//u8g2.firstPage();
u8g2.begin(); // Initialize display
Scanning...
Unknown error at address 0x01
Unknown error at address 0x02
Unknown error at address 0x03
Unknown error at address 0x04
Unknown error at address 0x05
Unknown error at address 0x06
Unknown error at address 0x07
Unknown error at address 0x08
Unknown error at address 0x09
Unknown error at address 0x0A
Unknown error at address 0x0B
Unknown error at address 0x0C
Unknown error at address 0x0D
Unknown error at address 0x0E
Unknown error at address 0x0F
Unknown error at address 0x10
Unknown error at address 0x11
Unknown error at address 0x78
Unknown error at address 0x79
Unknown error at address 0x7A
Unknown error at address 0x7B
Unknown error at address 0x7C
Unknown error at address 0x7D
Unknown error at address 0x7E
No I2C devices found
3 dots for simpilfication, also fixed the connection issue.
This is the I2C scanner i used:
#include <Wire.h>
while (!Serial);
Serial.println("\nI2C Scanner");
byte error, address;
int nDevices;
Serial.println("Scanning...");
nDevices = 0;
for (address = 1; address < 127; address++) {
// The i2c_scanner uses the return value of
// the Write.endTransmisstion to see if
// a device did acknowledge to the address.
Wire.beginTransmission(address);
error = Wire.endTransmission();
if (error == 0) {
Serial.print("I2C device found at address 0x");
if (address < 16)
Serial.print("0");
Serial.print(address, HEX);
Serial.println(" !");
nDevices++;
} else if (error == 4) {
Serial.print("Unknown error at address 0x");
if (address < 16)
Serial.print("0");
Serial.println(address, HEX);
if (nDevices == 0)
Serial.println("No I2C devices found\n");
Serial.println("Done\n");
delay(5000); // wait 5 seconds for the next I2C scan
TMP117 I²C 0,1°C-precise tempereature-sensor on I²C-Bus 0
SHT31 I²C temperature and humidity sensor on I²C-Bus1
GY21 I²C temperature and humidity sensor on I²C-Bus 2
I used this modified I2C-Scanner adpated to use with an ESP32
// MACRO-START * MACRO-START * MACRO-START * MACRO-START * MACRO-START * MACRO-START *
// a detailed explanation how these macros work is given in this tutorial
// https://forum.arduino.cc/t/comfortable-serial-debug-output-short-to-write-fixed-text-name-and-content-of-any-variable-code-example/888298
#define dbg(myFixedText, variableName) \
Serial.print( F(#myFixedText " " #variableName"=") ); \
Serial.println(variableName);
#define dbgi(myFixedText, variableName,timeInterval) \
static unsigned long intervalStartTime; \
if ( millis() - intervalStartTime >= timeInterval ){ \
intervalStartTime = millis(); \
Serial.println(variableName); \
#define dbgc(myFixedText, variableName) \
static long lastState; \
if ( lastState != variableName ){ \
Serial.print( F(#myFixedText " " #variableName" changed from ") ); \
Serial.print(lastState); \
Serial.print( F(" to ") ); \
lastState = variableName; \
#define dbgcf(myFixedText, variableName) \
static float lastState; \
// MACRO-END * MACRO-END * MACRO-END * MACRO-END * MACRO-END * MACRO-END * MACRO-END *
// i2c_scanner
// Version 1
// This program (or code that looks like it)
// can be found in many places.
// For example on the Arduino.cc forum.
// The original author is not know.
// Version 2, Juni 2012, Using Arduino 1.0.1
// Adapted to be as simple as possible by Arduino.cc user Krodal
// Version 3, Feb 26 2013
// V3 by louarnold
// Version 4, March 3, 2013, Using Arduino 1.0.3
// by Arduino.cc user Krodal.
// Changes by louarnold removed.
// Scanning addresses changed from 0...127 to 1...119,
// according to the i2c scanner by Nick Gammon
// https://www.gammon.com.au/forum/?id=10896
// Version 5, March 28, 2013
// As version 4, but address scans now to 127.
// A sensor seems to use address 120.
// Version 6, November 27, 2015.
// Added waiting for the Leonardo serial communication.
// This sketch tests the standard 7-bit addresses
// Devices with higher bit address might not be seen properly.
#include <Wire.h>
#define I2C_SDA 21
#define I2C_SCL 22
void TCA9548A(uint8_t p_busNr) {
Wire.beginTransmission(0x70); // TCA9548A address is 0x70
Wire.write(1 << p_busNr); // send byte to select bus
void scanTheI2C_Bus() {
int nDevices = 0;
for (byte address = 1; address < 127; ++address) {
byte error = Wire.endTransmission();
if (error == 0) {
if (address < 16) {
Serial.print("0");
++nDevices;
if (address < 16) {
Serial.print("0");
if (nDevices == 0) {
Serial.println("done\n");
//Wire.begin();
Wire.begin(I2C_SDA, I2C_SCL);
while (!Serial); // Leonardo: wait for serial monitor
TCA9548A(0);
Serial.println("Scanning... Bus 0");
scanTheI2C_Bus();
TCA9548A(1);
Serial.println("Scanning... Bus 1");
scanTheI2C_Bus();
TCA9548A(2);
Serial.println("Scanning... Bus 2");
scanTheI2C_Bus();
delay(5000); // Wait 5 seconds for next scan
and I get this printed to the serial monitor
Scanning... Bus 0
I2C device found at address 0x48 !
I2C device found at address 0x70 !
done
Scanning... Bus 1
I2C device found at address 0x44 !
done
Scanning... Bus 2
I2C device found at address 0x40 !
done
0x70 is the multiplexer itself
the other adresses are the sensors
I would have been astonished if it would have not worked.
Such a multiplexer must work this way:
connect pins towards the microcontroller to 1 of 8 buses
and then behave like there is no multiplexer.
Otherwise it would not work
You made a generalised saying "I2C scan code can't be used with multiplexer"
Yes you are partially right. I started with the "standard" I2C scan code. It worked too.
It was just scanning the bus 0. Because this is what the multiplexer is set to as default value after powerup.
The serial printing is
Scanning... Bus 0
done
Then - like I wrote - I modified the code to switch the multiplexer to the different bus-channels
To me the important thing is: Now it is specified and described how to make it work with a TCA9548A 8 channel I2C-multiplexer.
I just soldered them, you can see the pics above, still same issues.
Also i tried the I2C scanner you provided and gave me this output:
Scanning... Bus 0
I2C device found at address 0x3C !
done
Scanning... Bus 1
done
Scanning... Bus 2
done
On Bus 0
0x3C OLED-display found at adress 3C
0x70 multiplexer found at adress 70
On Bus 1
On Bus 2
So the I2C-devices are recognised
This is a unprecise description
to eliminate each and every room for mis-interpretation you should describe the watched behaviour very precise and in detail
You can try to safe time by posting quick
which as you can see will waste time because of asking back for the details
