ARDUINO UNO WITH WIFI SHIELD
I can connect to my wifi router. I want to ping 1 IP inside the network and if i have a successfull reply i want to have a LED set to ON. It is possible to do that with ARDUINO UNO & ARDUINO WIFI SHIELD?
This is for monitoring if a device fails. Please help
yes it is possible
Juraj:
yes it is possible
can you help me with the code?
the shield is original Arduino WiFi Shield with HDG204? this one Accessories — Arduino Official Store ?
yes, is the original
the use the WiFi library and see the examples of the WiFi library in IDE Examples menu
I already dit it, but there is no example for this. I just want after a successfull PING to light a LED, there is no example for Arduino wifi shield
ping is handled by the shield and is not forwarded to sketch. Ping a Specific Port - Server Fault
you can start WiFiServer on port 23 and talk to it with telnet client
I did the example with wifi server... and its ok, i can ping the arduino, but this is not the think that i want to build
I want to ping from arduino wifi shield to my windows server and if PING is successfull, then return a value in arduino and to set a pin of arduino to HIGH, so i will be able to light the LED.
billarvan:
you can't send ping from sketch. the library handles only TCP and UDP
Is any chance to do that with other shield?
billarvan:
WiFi101 has WiFi.ping() WiFi101 - Arduino Reference
Overview | Adafruit WINC1500 WiFi Shield for Arduino | Adafruit Learning System
esp8266 arduino core has ESP8266Ping library
Thanks, i ll try it
