Hello i have some problems with my arduino uno on windows 8.1 pro . I followed exactly all steps but i cant even upload the blink . I watched tons of tutorials on how to fix it but nothing works . This is the error message
Sketch uses 1,030 bytes (3%) of program storage space. Maximum is 32,256 bytes.
Global variables use 9 bytes (0%) of dynamic memory, leaving 2,039 bytes for local variables. Maximum is 2,048 bytes.
avrdude: ser_open(): can't open device "\.\COM5": The system cannot find the file specified.
Tried other COM but doesnt work either . If someone can explain me the situation
THX
This is other error message when i change COM
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x2e
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x2e
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0x2e
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0x2e
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0x2e
Problem uploading to board. See http://www.arduino.cc/en/Guide/Troubleshooting#upload for suggestions.
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0x2e
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0x2e
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0x2e
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0x2e
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0x2e
Mm, all the topic's here today are a bit the same.
Open device manager on you computer. Probably there's a device with a ! under ports or unknown devices. You have to install the driver of the UNO. Depending on where you bought it (original or clone) you need to download them. So which Arduino did you buy? linkssssss
