Sketch uses 9424 bytes (29%) of program storage space. Maximum is 32256 bytes.
Global variables use 327 bytes (15%) of dynamic memory, leaving 1721 bytes for local variables. Maximum is 2048 bytes.
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0xcd
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0xcd
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0xcd
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0xcd
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0xcd
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0xcd
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0xcd
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0xcd
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0xcd
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0xcd
Failed uploading: uploading error: exit status 1
Which Arduino are you using ?
an Uno, but I think it's like a with CH340G
I installed it but the error is still popping up, shld I be using arduino Uno as board?
Why would you select any other type of board in the IDE, if that is what you mean
cuz it's not arduino?
But it is a clone of it
Which board had you selected in the IDE when you got the error ?
arduino uno
Which port was selected ?
COM3?
tried COM4 too
That implies that you had tried at least one other port
Which port does Windows create when you plug in the board ?
there's an alternative Com4 for c-type, also tried that
Ok, whatever that means, but unless Windows creates a COM port when you plug in the board the upload will never work
it does
Let me ask the same question a different way
What is the name of the port that Windows creates when you plug in the board ?
I have three USB ports, when i plug into one it creates- USB SERIAL CH340 (COM5)
when I plug into the other one it creates-USB SERIAL CH340 (COM4)
and last one creates- USB SERIAL CH340 (COM3)
yes
When you see COM3 in the Device manager, can you select IDE >> TOOLS >> PORT >> COM3... or is there no COM3?
