My arduino uno has been not uploading anything to the board but it used to upload i searched online and nothing has worked if u know a reasoning of this your help is needed and for those who want to know the error code the error code is
Sketch uses 866 bytes (2%) of program storage space. Maximum is 32256 bytes.
Global variables use 9 bytes (0%) of dynamic memory, leaving 2039 bytes for local variables. Maximum is 2048 bytes.
"C:\Users\Khali\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/bin/avrdude" "-CC:\Users\Khali\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf" -v -patmega328p -carduino "-PCOM5" -b115200 -D "-Uflash:w:C:\Users\Khali\AppData\Local\Temp\arduino\sketches\41F4005959FC243F357736552C6DD4DC/sketch_jan23a.ino.hex:i"
avrdude: Version 6.3-20190619
Copyright (c) 2007-2014 Joerg Wunsch
System wide configuration file is "C:\Users\Khali\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf"
Using Port : COM5
Using Programmer : arduino
Overriding Baud Rate : 115200
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x15
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x15
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0x15
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0x15
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0x15
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0x15
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0x15
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0x15
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0x15
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0x15
avrdude done. Thank you.
Failed uploading: uploading error: exit status 1/>
Check the tools menu and be sure you have the correct board selected. If it is a Nano you may have to select the old boot loader. Be sure nothing is connected on the serial pins for the monitor. If that does not work disconnect everything and start with the blink sketch.
What do you have connected to your UNO, there should be nothing on pins 0 and 1 they are used for serial communications with your terminal. They are defined as serial pins because of the asynchronous communication they do for your sketch.
Is the TX light on? If so you probably have a serial flood.
Take these steps:
Power off the board completely
Remove the USB cable
Hold down the Reset button
keep it held down (or, run a jumper wire from the RESET pin to the GND pin).
Still holding down Reset reconnect the USB cable.
Start uploading a sketch that does not have this problem (I use the Blink sketch).
When you see the Receive light blink, release the Reset button
Note: I have seen this happen several times when I flood the serial output. An indication is the tx light is stuck on. You may have to try this several times. If this does not work power down everything and start up the way described above.
Have a look at the headers; there is a pin next to the 3.3V pin.
The red button is also connected to the reset pin.
What is the serial-to-usb converter on your board; it's the chip closest to the USB connector. If it's not the CH340, you can run the loopback test and report here.
What happens when you press and release the reset button? You should get a few flashes in quick succession on the L-LED before the loaded sketch starts. If the loaded sketch is the factory installed blink, the L-LED will then change to the 1 second on / on second off; we're interested in what happens before that (the quick flashes).
I've moved your topic to a more suitable location on the forum.
when i do that the error code still shows up and the lights tx lights up and the L lights up in a few flashes
```Sketch uses 2308 bytes (7%) of program storage space. Maximum is 32256 bytes.
Global variables use 188 bytes (9%) of dynamic memory, leaving 1860 bytes for local variables. Maximum is 2048 bytes.
"C:\Users\Khali\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/bin/avrdude" "-CC:\Users\Khali\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf" -v -patmega328p -carduino "-PCOM5" -b115200 -D "-Uflash:w:C:\Users\Khali\AppData\Local\Temp\arduino\sketches\06E0BA1EA5E7538BD098A5492C925C96/sketch_jan18a.ino.hex:i"
Using Port : COM5
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0xdf
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0xdf
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0xdf
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0xdf
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0xdf
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0xdf
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0xdf
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0xdf
avrdude: ser_recv(): read error: The I/O operation has been aborted because of either a thread exit or an application request.
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0xdf
avrdude: ser_send(): write error: sorry no info avail
avrdude: ser_recv(): read error: The device does not recognize the command.
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0xdf
avrdude: ser_drain(): read error: The device does not recognize the command.
This error might be caused by having the wrong port selected from the Tools > Port menu in Arduino IDE.
Please perform this experiment to verify that the port you have selected is your Arduino board:
With official boards, the port will be labeled with the board name in the menu (e.g., "COM42 (Arduino Uno)"). In this case, you can be fairly confident that you have identified the port. Select that port from the menu and try uploading again.
With some cheap derivative boards the port will not be labeled. You can positively identify the port using this procedure:
Disconnect the USB cable of the Arduino board from your computer.
Select Tools > Port from the Arduino IDE menus.
Take note of the ports, if any, listed in the menu.
Close the Tools menu. The ports list is only updated when the Tools menu is re-opened, so this step is essential.
Connect the Arduino board to your computer with a USB cable.
Select Tools > Port from the Arduino IDE menus. - If a new port is listed in the menu, that is the port of your Arduino board.
If the upload still fails, or if no new port appeared after you plugged the Arduino board into your computer, add a reply here to let us know and we'll investigate the problem further.
Please don't hijack threads @vrbat . I have merged your posts from where you hijacked the other user's topic to the dedicated topic you created here.
Hijacking is against the Arduino forum rules. The reason is that it may sidetrack the discussion, even preventing the creator of the topic from getting the assistance they need. It also reduces your own chances of getting assistance.
