Hello,
I am currently facing a problem where the Arduino Uno voltage regulator would become very hot. This problem only occurs when an ethernet shield is connected to the board. The voltage input is 12VDC external power supply. However, when powered by a usb port, the voltage regulator does not overheat even when the ethernet shield is connected.
Is there a solution for this problem?
Thanks in advance.
