here is the logs...
Error: Exit status 2
/usr/local/bin/arduino-cli compile --fqbn esp32:esp32:esp32doit-devkit1:DebugLevel=none,FlashFreq=80,UploadSpeed=921600 --libraries /home/builder/opt/libraries/latest --build-cache-path /tmp --output-dir /tmp/621414458/build --build-path /tmp/arduino-build-B04EE2083656C0332FBA4519FD05D098 /tmp/621414458/Science_Fair_Project_feb20a
Sketch uses 1109361 bytes (84%) of program storage space. Maximum is 1310720 bytes.
Global variables use 51408 bytes (15%) of dynamic memory, leaving 276272 bytes for local variables. Maximum is 327680 bytes.
Upload started
Programming with: Serial
Flashing with command:C:/Users/admin/.arduino-create/esp32/esptool_py/4.2.1/esptool.exe --chip esp32 --port COM3 --baud 921600 --before default_reset --after hard_reset write_flash -z --flash_mode dio --flash_freq 80m --flash_size 4MB 0x1000 C:/Users/admin/AppData/Local/Temp/extrafiles416523612/Science_Fair_Project_feb20a.bootloader.bin 0x8000 C:/Users/admin/AppData/Local/Temp/extrafiles416523612/Science_Fair_Project_feb20a.partitions.bin 0xe000 C:/Users/admin/AppData/Local/Temp/extrafiles416523612/tools/partitions/boot_app0.bin 0x10000 C:/Users/admin/AppData/Local/Temp/arduino-create-agent703676337/Science_Fair_Project_feb20a.bin
esptool.py v4.2.1
Serial port COM3
Connecting......................................
A fatal error occurred: Failed to connect to ESP32: No serial data received.
For troubleshooting steps visit: Troubleshooting - ESP32 - — esptool latest documentation
Please help
