Hello!
Very interesting thermostat you get. Have a question. As I understand it 18b20 address must be specified manually in the sketch, how to connect the sensor to a different address, without flashing?
Please read there:
Is this code source work if I only copy/pastre to my enc28j60 ethenet shield?
Does this thermostat can send email if the temperature range is below or under the value I preset?
Im very interrested to reproduce this thing, it's awsome! thanks for sharing and let me know!
It could be cool to share an HOW TO for beginners like me ![]()
I think that e-mail can send only arduino mega 2560, arduino uno insufficient memory, if you want to supplement the program
http://www.lucadentella.it/en/2012/12/16/enc28j60-e-arduino-12/, https://raw.github.com/lucadentella/enc28j60_tutorial/master/_12_SkebbySMS/_12_SkebbySMS.ino
SMTP protocol problems · Issue #65 · njh/EtherCard · GitHub
http://forum.jeelabs.net/comment/9920#comment-9920
Okay i think that would help.
I'm realy bad in programming, My project is to take the entire web temperature fo enc28j60 code and modify it to send email when the value is under or over the preset.
Thanks for help and shared links!
You really need a more powerful Arduino with more RAM (mega2560) or can try http://ksduino.org, http://open.sen.se/, https://www.thingspeak.com/ http://exosite.com/products/portals cloud. Ksduino and http://www.pushingbox.com/ support ENC28J60.
alvydas001:
You really need a more powerful Arduino with more RAM (mega2560) or can try ksduino.org, http://open.sen.se/, https://www.thingspeak.com/ http://exosite.com/products/portals cloud. Ksduino and http://www.pushingbox.com/ support ENC28J60.
Duemilanove + ethernetshield enc28j60 should be a great setup?
The full terms of reference in the scene!
Otherwise, there is nothing you will not respond.
alvydas001:
Sry for my bad english... I don't understand.... :<
My English is very bad, too ![]()
have to say what you wish to do so, must complete the task conditions, it is difficult to advise otherwise.
Speak French?
Okay, so I have the code right here :
#include "etherShield.h"
// please modify the following two lines. mac and ip have to be unique
// in your local area network. You can not have the same numbers in
// two devices:
static uint8_t mymac[6] = {0x54,0x55,0x58,0x10,0x00,0x24};
static uint8_t myip[4] = {192,168,1,15};
static char baseurl[]="http://192.168.1.15/";
static uint16_t mywwwport =80; // listen port for tcp/www (max range 1-254)
// or on a different port:
//static char baseurl[]="http://10.0.0.24:88/";
//static uint16_t mywwwport =88; // listen port for tcp/www (max range 1-254)
#define BUFFER_SIZE 500
static uint8_t buf[BUFFER_SIZE+1];
#define STR_BUFFER_SIZE 22
static char strbuf[STR_BUFFER_SIZE+1];
EtherShield es=EtherShield();
// prepare the webpage by writing the data to the tcp send buffer
uint16_t print_webpage(uint8_t *buf);
int8_t analyse_cmd(char *str);
// get current temperature
#define TEMP_PIN 3
void getCurrentTemp( int *sign, int *whole, int *fract);
void setup(){
/*initialize enc28j60*/
es.ES_enc28j60Init(mymac);
es.ES_enc28j60clkout(2); // change clkout from 6.25MHz to 12.5MHz
delay(10);
/* Magjack leds configuration, see enc28j60 datasheet, page 11 */
// LEDA=greed LEDB=yellow
// 0x880 is PHLCON LEDB=on, LEDA=on
// enc28j60PhyWrite(PHLCON,0b0000 1000 1000 00 00);
es.ES_enc28j60PhyWrite(PHLCON,0x880);
// 0x990 is PHLCON LEDB=off, LEDA=off
// enc28j60PhyWrite(PHLCON,0b0000 1001 1001 00 00);
es.ES_enc28j60PhyWrite(PHLCON,0x990);
// 0x476 is PHLCON LEDA=links status, LEDB=receive/transmit
// enc28j60PhyWrite(PHLCON,0b0000 0100 0111 01 10);
es.ES_enc28j60PhyWrite(PHLCON,0x476);
delay(100);
//init the ethernet/ip layer:
es.ES_init_ip_arp_udp_tcp(mymac,myip,80);
// initialize DS18B20 datapin
digitalWrite(TEMP_PIN, LOW);
pinMode(TEMP_PIN, INPUT); // sets the digital pin as input (logic 1)
void loop(){
uint16_t plen, dat_p;
int8_t cmd;
plen = es.ES_enc28j60PacketReceive(BUFFER_SIZE, buf);
/*plen will ne unequal to zero if there is a valid packet (without crc error) */
if(plen!=0){
// arp is broadcast if unknown but a host may also verify the mac address by sending it to a unicast address.
if(es.ES_eth_type_is_arp_and_my_ip(buf,plen)){
es.ES_make_arp_answer_from_request(buf);
return;
// check if ip packets are for us:
if(es.ES_eth_type_is_ip_and_my_ip(buf,plen)==0){
return;
if(buf[IP_PROTO_P]==IP_PROTO_ICMP_V && buf[ICMP_TYPE_P]==ICMP_TYPE_ECHOREQUEST_V){
es.ES_make_echo_reply_from_request(buf,plen);
return;
// tcp port www start, compare only the lower byte
if (buf[IP_PROTO_P]==IP_PROTO_TCP_V&&buf[TCP_DST_PORT_H_P]==0&&buf[TCP_DST_PORT_L_P]==mywwwport){
if (buf[TCP_FLAGS_P] & TCP_FLAGS_SYN_V){
es.ES_make_tcp_synack_from_syn(buf); // make_tcp_synack_from_syn does already send the syn,ack
return;
if (buf[TCP_FLAGS_P] & TCP_FLAGS_ACK_V){
es.ES_init_len_info(buf); // init some data structures
dat_p=es.ES_get_tcp_data_pointer();
if (dat_p==0){ // we can possibly have no data, just ack:
if (buf[TCP_FLAGS_P] & TCP_FLAGS_FIN_V){
es.ES_make_tcp_ack_from_any(buf);
return;
if (strncmp("GET ",(char *)&(buf[dat_p]),4)!=0){
// head, post and other methods for possible status codes see:
// http://www.w3.org/Protocols/rfc2616/rfc2616-sec10.html
plen=es.ES_fill_tcp_data_p(buf,0,PSTR("HTTP/1.0 200 OK\r\nContent-Type: text/html\r\n\r\n<h1>200 OK</h1>"));
goto SENDTCP;
if (strncmp("/ ",(char *)&(buf[dat_p+4]),2)==0){
plen=print_webpage(buf);
goto SENDTCP;
cmd=analyse_cmd((char *)&(buf[dat_p+5]));
if (cmd==1){
SENDTCP: es.ES_make_tcp_ack_from_any(buf); // send ack for http get
es.ES_make_tcp_ack_with_data(buf,plen); // send data
// The returned value is stored in the global var strbuf
uint8_t find_key_val(char *str,char *key)
uint8_t found=0;
uint8_t i=0;
char *kp;
kp=key;
while(*str && *str!=' ' && found==0){
if (*str == *kp){
kp++;
if (*kp == '\0'){
str++;
kp=key;
if (*str == '='){
found=1;
}else{
kp=key;
str++;
if (found==1){
// copy the value to a buffer and terminate it with '\0'
while(*str && *str!=' ' && *str!='&' && i<STR_BUFFER_SIZE){
strbuf[i]=*str;
i++;
str++;
strbuf[i]='\0';
return(found);
int8_t r=-1;
if (find_key_val(str,"cmd")){
if (*strbuf < 0x3a && *strbuf > 0x2f){
// is a ASCII number, return it
r=(*strbuf-0x30);
return r;
char temp_string[10];
int i=0;
//char *temp_string="100";
uint16_t plen;
getCurrentTemp(temp_string);
plen=es.ES_fill_tcp_data_p(buf,0,PSTR("HTTP/1.0 200 OK\r\nContent-Type: text/html\r\n\r\n"));
plen=es.ES_fill_tcp_data_p(buf,plen,PSTR("<center><p><h1>Welcome to Arduino Ethernet Shield V1.0 </h1></p> "));
plen=es.ES_fill_tcp_data_p(buf,plen,PSTR("<hr>
<form METHOD=get action=\""));
plen=es.ES_fill_tcp_data(buf,plen,baseurl);
plen=es.ES_fill_tcp_data_p(buf,plen,PSTR("\">"));
plen=es.ES_fill_tcp_data_p(buf,plen,PSTR("<h2> Current Temperature is </h2> "));
plen=es.ES_fill_tcp_data_p(buf,plen,PSTR("<h1><font color=\"#00FF00\"> "));
while (temp_string[i]) {
buf[TCP_CHECKSUM_L_P+3+plen]=temp_string[i++];
plen++;
plen=es.ES_fill_tcp_data_p(buf,plen,PSTR(" °C</font></h1>
plen=es.ES_fill_tcp_data_p(buf,plen,PSTR("<input type=hidden name=cmd value=1>"));
plen=es.ES_fill_tcp_data_p(buf,plen,PSTR("<input type=submit value=\"Get Temperature\"></form>"));
plen=es.ES_fill_tcp_data_p(buf,plen,PSTR("</center><hr> <p> V1.0 <a href=\"http://www.nuelectronics.com\">www.nuelectronics.com<a>"));
return(plen);
void OneWireReset(int Pin) // reset. Should improve to act as a presence pulse
digitalWrite(Pin, LOW);
pinMode(Pin, OUTPUT); // bring low for 500 us
delayMicroseconds(500);
pinMode(Pin, INPUT);
void OneWireOutByte(int Pin, byte d) // output byte d (least sig bit first).
byte n;
for(n=8; n!=0; n--)
if ((d & 0x01) == 1) // test least sig bit
delayMicroseconds(5);
delayMicroseconds(60);
d=d>>1; // now the next bit is in the least sig bit position.
byte OneWireInByte(int Pin) // read byte, least sig byte first
byte d, n, b;
for (n=0; n<8; n++)
b = digitalRead(Pin);
delayMicroseconds(50);
d = (d >> 1) | (b<<7); // shift d to right and insert b in most sig bit position
return(d);
void getCurrentTemp(char *temp)
int HighByte, LowByte, TReading, Tc_100, sign, whole, fract;
OneWireReset(TEMP_PIN);
OneWireOutByte(TEMP_PIN, 0xcc);
OneWireOutByte(TEMP_PIN, 0x44); // perform temperature conversion, strong pullup for one sec
OneWireOutByte(TEMP_PIN, 0xbe);
LowByte = OneWireInByte(TEMP_PIN);
HighByte = OneWireInByte(TEMP_PIN);
TReading = (HighByte << 8) + LowByte;
sign = TReading & 0x8000; // test most sig bit
if (sign) // negative
TReading = (TReading ^ 0xffff) + 1; // 2's comp
Tc_100 = (6 * TReading) + TReading / 4; // multiply by (100 * 0.0625) or 6.25
whole = Tc_100 / 100; // separate off the whole and fractional portions
fract = Tc_100 % 100;
if(sign) temp[0]='-';
else temp[0]='+';
if(whole/100==0)
temp[1] =' ';
temp[1]= whole/100+'0';
temp[2]= (whole-(whole/100)*100)/10 +'0' ;
temp[3]= whole-(whole/10)*10 +'0';
temp[4]='.';
temp[5]=fract/10 +'0';
temp[6]=fract-(fract/10)*10 +'0';
temp[7] = '\0';
why dont use DallasTemperatureControl library?
Dallas's librairy?
Btguillaume:
Dallas's librairy?
Yes, why don't use Dallas's library?
what's that I juste done a quick google's search, but nothing interrested....
can you explain what's that?
There's an Arduino library for "one wire" devices like the DS18B20.
Btguillaume:
what's that I juste done a quick google's search, but nothing interrested....can you explain what's that?
I mean this library:
http://milesburton.com/Dallas_Temperature_Control_Library
Hi everybody! I'm newbie and I want to make similar project. But I use Wiznet W5100 Ethernet Shield... So my question is how to change the code for the Arduino Ethernet Shield? ?an anybody help me?
