hi evryone
i am new on this forum.
i've the at90s8515 atmel microprocessor.
i want build an Arduino.
can you tell me what modification do in this file for make compatible to arduino duemilanove? :-/
please response me .
thanks
hi evryone
thanks
Please help
The AT90S8515 is an "old-style" (one of the very first) AVR microcontrollers, and it does not have the SPM instruction or the ability to self-program its own flash memory, which is necessary for a bootloader-based environment like Arduino to operate properly. Basically, you can't use an 90S8515 without a specific "device programmer" module, and one of those is comparable in price to a full Arduino (even the cheaper versions will likely cost as much as an Arduino clone.)
There is a newer AVR that is similar to the 90s8515 (ATmega8515), but except for pins it has less capabilities than even the older Arduino chips (like the ATmega8) Arduino variants like Sanguino (http://sanguino.cc) that use a 40-pin chip seem to have settled on the ATmega644.
Basically, you can't use an 90S8515 without a specific "device programmer" module.
what is device programmer :-/
A piece of hardware that goes between your computer and a micrcontroller chip or board that allows programs to be loaded into the chip. Typically these will support many different microcontroller chips, each with many options, and they're aimed at EE and CS engineers. They'll consequently be much more complicated to use than an Arduino.
Examples include The Atmel STK-500 and the Adafruit USBtinyISP
i use this : SI Prog schematics
is it valid? :-/ it is a ponyprog serial programmer
Yes, that should work for programming a 90s8515.
In THEORY, it should be possible to slightly modify the arduino environment so that it can download to other chips via an external programmer (anything supported by the AVRdude utility, I guess, by modifying hardware/boards.txt, plus the core libraries.) In reality, if you can do that then you don't have much need for the arduino environment in the first place...
where can i download the arduino environment?
so i must modify the Arduino software Library :-?
Is it that difficult to buy an Arduino platform? You can get pre-programmed chips for around $5. As it appears that you are still a noob I would buy a full Arduino platform which is between $20 and $30. It will save you a bunch of headaches.
hello
Mike Perks
for you it is possible to bay but for me no, because i dont live in America
but i live in Asia
Did you check the distributors in Asia. Even if you buy in the USA, air shipping to Asia can be fairly cheap.
i know but when you convert money it is 200% expensive ;).
