Arduino with Software Serial and At Commands
I need some help with my code, I already use the Hterm program to test my gsm module - Sim800l and it works correctly with this At commands, but when I try run the code with the At commands on my Arduino Uno something goes wrong and it doesn't work.
Here's the code:
#include <SoftwareSerial.h>
SoftwareSerial mySerial(10, 11); // RX, TX
  while (!Serial) {
    ; // wait for serial port to connect. Needed for native USB port only
  // set the data rate for the SoftwareSerial port
  mySerial.begin(9600);
  mySerial.write("AT \n");
  delay(100);
  Serial.write(mySerial.read());
  mySerial.write("AT+CREG? \n");
   delay(50);
  if (mySerial.available()) {
  mySerial.write("AT+CIPSHUT \n");
  delay(50);
    Serial.write(mySerial.read()+"\n");
 mySerial.write("AT+CGATT=1 \n");
  delay(50);
  mySerial.write("AT+SAPBR=3,1,\"CONTYPE\",\"GPRS\" \n");
  delay(50);
  mySerial.write("AT+SAPBR=3,1,\"APN\",\"myconnection\" \n");
  delay(50);
  mySerial.write("AT+SAPBR=1,1 \n");
  delay(50);
  mySerial.write("AT+HTTPINIT \n");
  delay(50);
  mySerial.write("AT+HTTPPARA=\"CID\",1 \n");
  delay(50);
  mySerial.write("AT+HTTPPARA=\"URL\",\"http://*****/api/v1/***/*****\" \n");
  delay(50);
  mySerial.write("AT+HTTPDATA=100,10000\n");
  delay(50);
    mySerial.write("username=*****&password=******&");
  delay(50);
  mySerial.write("AT+HTTPACTION=1 \n");
  delay(50);
    mySerial.write("AT+HTTPTERM \n");
  delay(50);
  if (Serial.available()) {
    mySerial.write(Serial.read());
here's what happens:
AT
OK
AT+CREG?
+CREG: 0,1
OK
AT+CIPSHUT
SHUT OK
AT+CGAAAA
OK
Please Help
Thanks
Serial.read() returns only a single byte. What happens if you call it in a loop, i.e. while (Serial.available())?
Thanks apparently it works :slight_smile:
