Arduino with ultrasonic sensor and bluetooth
Hi everyone,I am beginner to arduino.Now i want to make a wsmart vaccum project with ultrasonic sensor and bluetooth control.Now I am facing two problems.
1.) My ultrasonic sensor always detect an obstacle although there is no any obstacle and move backward.
2.) My bluetooth connection will be disconnected automatically with smartphone when I give instruction from smartphone.
Can anyone help me.Here are the coding>Thank you and have a good day
/*obstacle avoiding,bluetooth control,voice control robot car.
   https://srituhobby.com
#include <Servo.h>
#include <AFMotor.h>
#define Echo A0
#define Trig A1
#define motor 10
#define Speed 170
#define spoint 103
char value;
int distance;
int Left;
int Right;
int L = 0;
int R = 0;
int L1 = 0;
int R1 = 0;
Servo servo;
AF_DCMotor M1(1);
AF_DCMotor M2(2);
AF_DCMotor M3(3);
AF_DCMotor M4(4);
  pinMode(Trig, OUTPUT);
  pinMode(Echo, INPUT);
  servo.attach(motor);
  M1.setSpeed(Speed);
  M2.setSpeed(Speed);
  M3.setSpeed(Speed);
  M4.setSpeed(Speed);
  //Obstacle();
  //Bluetoothcontrol();
  voicecontrol();
void Bluetoothcontrol() {
  if (Serial.available() > 0) {
    value = Serial.read();
    Serial.println(value);
  if (value == 'F') {
    forward();
  } else if (value == 'B') {
    backward();
  } else if (value == 'L') {
    left();
  } else if (value == 'R') {
    right();
  } else if (value == 'S') {
    Stop();
void Obstacle() {
  distance = ultrasonic();
  if (distance <= 12) {
    Stop();
    backward();
    delay(100);
    Stop();
    L = leftsee();
    servo.write(spoint);
    delay(800);
    R = rightsee();
    if (L < R) {
      right();
      Stop();
      delay(200);
    } else if (L > R) {
      left();
      Stop();
      delay(200);
    forward();
void voicecontrol() {
    if (value == '^') {
      forward();
    } else if (value == '-') {
      backward();
    } else if (value == '<') {
      L = leftsee();
      if (L >= 10 ) {
        left();
        Stop();
      } else if (L < 10) {
        Stop();
    } else if (value == '>') {
      R = rightsee();
      if (R >= 10 ) {
        right();
        Stop();
      } else if (R < 10) {
        Stop();
    } else if (value == '*') {
      Stop();
int ultrasonic() {
  digitalWrite(Trig, LOW);
  delayMicroseconds(4);
  digitalWrite(Trig, HIGH);
  delayMicroseconds(10);
  long t = pulseIn(Echo, HIGH);
  long cm = t / 29 / 2; //time convert distance
  return cm;
void forward() {
  M1.run(FORWARD);
  M2.run(FORWARD);
  M3.run(FORWARD);
  M4.run(FORWARD);
void backward() {
  M1.run(BACKWARD);
  M2.run(BACKWARD);
  M3.run(BACKWARD);
  M4.run(BACKWARD);
void right() {
  M1.run(BACKWARD);
  M2.run(BACKWARD);
  M3.run(FORWARD);
  M4.run(FORWARD);
void left() {
  M1.run(FORWARD);
  M2.run(FORWARD);
  M3.run(BACKWARD);
  M4.run(BACKWARD);
void Stop() {
  M1.run(RELEASE);
  M2.run(RELEASE);
  M3.run(RELEASE);
  M4.run(RELEASE);
int rightsee() {
  servo.write(20);
  delay(800);
  Left = ultrasonic();
  return Left;
int leftsee() {
  servo.write(180);
  delay(800);
  Right = ultrasonic();
  return Right;
The best way to proceed with a very challenging project like this is to get each part of the project working separately, then put the bits together one by one, testing as you go.
Since difficulty with the ultrasonic sensor is the first thing you mention, start with that. Countless tutorials can be found on line showing how to connect and use them.
I connect it just like the circuit diagram
