Ultrasonic sensor issue with arduino
Hi,everyone.I am the beginner of this forum.I want to ask my ultrasonic sensor seem like cant works as desired.I want to build an obstacle mode robot.In my case,the ultrasonic always sense an obstacle and do not move forward although there is not obstacle in front.Here are my circuit diagram and coding.
#include <Servo.h>
#include <AFMotor.h>
#define Echo A0
#define Trig A1
#define motor 10
#define Speed 170
#define spoint 103
char value;
int distance;
int Left;
int Right;
int L = 0;
int R = 0;
int L1 = 0;
int R1 = 0;
Servo servo;
AF_DCMotor M1(1);
AF_DCMotor M2(2);
AF_DCMotor M3(3);
AF_DCMotor M4(4);
  pinMode(Trig, OUTPUT);
  pinMode(Echo, INPUT);
  servo.attach(motor);
  M1.setSpeed(Speed);
  M2.setSpeed(Speed);
  M3.setSpeed(Speed);
  M4.setSpeed(Speed);
  Obstacle();
  //Bluetoothcontrol();
  //voicecontrol();
void Bluetoothcontrol() {
  if (Serial.available() > 0) {
    value = Serial.read();
    Serial.println(value);
  if (value == 'F') {
    forward();
  } else if (value == 'B') {
    backward();
  } else if (value == 'L') {
    left();
  } else if (value == 'R') {
    right();
  } else if (value == 'S') {
    Stop();
void Obstacle() {
  distance = ultrasonic();
  if (distance <= 12) {
    Stop();
    backward();
    delay(100);
    Stop();
    L = leftsee();
    servo.write(spoint);
    delay(800);
    R = rightsee();
    if (L < R) {
      right();
      Stop();
      delay(200);
    } else if (L > R) {
      left();
      Stop();
      delay(200);
    forward();
void voicecontrol() {
    if (value == '^') {
      forward();
    } else if (value == '-') {
      backward();
    } else if (value == '<') {
      L = leftsee();
      if (L >= 10 ) {
        left();
        Stop();
      } else if (L < 10) {
        Stop();
    } else if (value == '>') {
      R = rightsee();
      if (R >= 10 ) {
        right();
        Stop();
      } else if (R < 10) {
        Stop();
    } else if (value == '*') {
      Stop();
// Ultrasonic sensor distance reading function
int ultrasonic() {
  digitalWrite(Trig, LOW);
  delayMicroseconds(4);
  digitalWrite(Trig, HIGH);
  delayMicroseconds(10);
  long t = pulseIn(Echo, HIGH);
  long cm = t / 29 / 2; //time convert distance
  return cm;
void forward() {
  M1.run(FORWARD);
  M2.run(FORWARD);
  M3.run(FORWARD);
  M4.run(FORWARD);
void backward() {
  M1.run(BACKWARD);
  M2.run(BACKWARD);
  M3.run(BACKWARD);
  M4.run(BACKWARD);
void right() {
  M1.run(BACKWARD);
  M2.run(BACKWARD);
  M3.run(FORWARD);
  M4.run(FORWARD);
void left() {
  M1.run(FORWARD);
  M2.run(FORWARD);
  M3.run(BACKWARD);
  M4.run(BACKWARD);
void Stop() {
  M1.run(RELEASE);
  M2.run(RELEASE);
  M3.run(RELEASE);
  M4.run(RELEASE);
int rightsee() {
  servo.write(20);
  delay(800);
  Left = ultrasonic();
  return Left;
int leftsee() {
  servo.write(180);
  delay(800);
  Right = ultrasonic();
  return Right;
make your life simpler, test just the US sensor with a simple code and your function to see if it's working. unplug everything else (motors etc) and remove the code that is not used
I changed the function to return an unsigned long as per the maths and set the serial monitor's baud rate to 115200
#define Echo A0
#define Trig A1
unsigned long ultrasonic() {
  unsigned long t = pulseIn(Echo, HIGH);
  unsigned long cm = t / 29 / 2; //time convert distance
  return cm;
  Serial.println(ultrasonic());
  delay(250);
Try
Change:
if (distance <= 12)
To:
if ((distance <= 12) && (distance > 2))
@J-M-L mentioned testing individual parts of your kit. I made a page of many of these small tests. Here. Have fun.
after modify the code,the senor not working at all and all the wheel can be moving
