After a few bonehead mistakes I have the Arduino interfaced to a CM17A "FireCracker".
The CM17A is a "serial" dongle that sends RF signals to X10 receivers which in turn send signals down the house wiring to control lights and appliances. It's relatively cheap (about 10USD on eBay).
After interfacing through a MAX3232 a nice surprise was that I didn't need it. So its just 3 wires from the Arduino to the RTS, DTR, and GND pins on a DB9 plugged into the CM17A.
For some, this might be a good safe way to control Mains. As I write, my whole house is blinking!
/* Arduino Interface to the CM17A Wireless X10 dongle. BroHogan 7/19/08
* The CM17A gets it power and data using only the RTS, CTS, & Gnd lines.
* A MAX232 is not req. (0/+5V work OK) If MAX232 IS used reverse all HIGHs & LOWS
* Signal RTS DTR Standby | '1' | Wait | '0' | Wait | '1' | Wait...
* Reset 0 0 _____________________ _____________________
* Logical '1' 1 0 RTS _| |_____|
* Logical '0' 0 1 ________ ___________________ ________
* Standby 1 1 DTR _| |_____| |_____|
* MINIMUM time for the '1', '0' and 'Wait' states is 0.5ms.
* At least one signal must be high to keep CM17A powered while transmitting.
* Each xmit is 40 bits -> "Header" 16 bits, "Data" 16 bits, "Footer" 8 bits
* CONNECTION: RTS -> DB9 pin 7. DTR -> DB9 pin 4. Gnd. -> DB9 pin 7.
#define RTS_pin 2 // RTS line for C17A - DB9 pin 7
#define DTR_pin 3 // DTR line for C17A - DB9 pin 4
#define BIT_DELAY 1 // ms delay between bits (0.5ms min.)
#define ON 0 // command for ON
#define OFF 1 // command for OFF
#define BRIGHT 2 // command for 20% brighten
#define DIM 3 // command for 20% dim
unsigned int houseCode[16] = {
0x6000, // A
0x7000, // B
0x4000, // C
0x5000, // D
0x8000, // E
0x9000, // F
0xA000, // G
0xB000, // H
0xE000, // I
0xF000, // J
0xC000, // K
0xD000, // L
0x0000, // M
0x1000, // N
0x2000, // O
0x3000, // P
unsigned int deviceCode[16] = {
0x0000, // 1
0x0010, // 2
0x0008, // 3
0x0018, // 4
0x0040, // 5
0x0050, // 6
0x0048, // 7
0x0058, // 8
0x0400, // 9
0x0410, // 10
0x0408, // 11
0x0418, // 12
0x0440, // 13
0x0450, // 14
0x0448, // 15
0x0458, // 16
unsigned int cmndCode[] = {
0x0000, // ON
0x0020, // OFF
0x0088, // 20% BRIGHT (0x00A8=5%)
0x0098, // 20% DIM (0x00B8=5%)
pinMode(RTS_pin,OUTPUT); // onboard LED
pinMode(DTR_pin,OUTPUT); // output pin of touch sensor
void loop(){ // Sample Commands
delay(2000);
xmitCM17A('D',4,OFF);
xmitCM17A('D',5,ON);
xmitCM17A('D',5,DIM);
xmitCM17A('D',5,OFF);
xmitCM17A('D',4,ON);
void xmitCM17A(char house, byte device, byte cmnd){
unsigned int dataBuff = 0;
byte messageBuff[5];
// Build Message by ORing the parts together. No device if Bright or Dim
if(cmnd == ON | cmnd == OFF){
dataBuff = (houseCode[house-'A'] | deviceCode[device-1] | cmndCode[cmnd]);
else dataBuff = houseCode[house-'A'] | cmndCode[cmnd];
// Build a string for the whole message . . .
messageBuff[0] = 0xD5; // Header byte 0 11010101 = 0xD5
messageBuff[1] = 0xAA; // Header byte 1 10101010 = 0xAA
messageBuff[2] = dataBuff >> 8; // MSB of dataBuff
messageBuff[3] = dataBuff & 0xFF; // LSB of dataBuff
messageBuff[4] = 0xAD; // Footer byte 10101101 = 0xAD
// Now send it out to CM17A . . .
digitalWrite(DTR_pin,LOW); // reset device - both low is power off
digitalWrite(RTS_pin,LOW);
delay(BIT_DELAY);
digitalWrite(DTR_pin,HIGH); // standby mode - supply power
digitalWrite(RTS_pin,HIGH);
delay(35); // need extra time for it to settle
for (byte i=0;i<5;i++){
for( byte mask = 0x80; mask; mask >>=1){
if( mask & messageBuff[i]) digitalWrite(DTR_pin,LOW); // 1 = RTS HIGH/DTR-LOW
else digitalWrite(RTS_pin,LOW); // 0 = DTR-HIGH/RTS-LOW
delay(BIT_DELAY); // delay between bits
digitalWrite(DTR_pin,HIGH); // wait state between bits
delay(BIT_DELAY);
delay(1000); // wait required before next xmit
Enjoy ![]()
