Arduino + XBOX360 Controller[RESOLVED]
This shows the joystick mechanism on the 360 controller. Assuming the 3-pinned component labeled "3810" is a potentiometer what is the best way for me to emulate one using the Arduino so that I can send my own controller movements to the main chip? I assume I will have to measure the resistance min and max and supply voltage before knowing exactly what I will need to do. What is the best approach?
I'll try to keep this updated as I progress on this project.
Looks just like the one on the Esplora.
Not to be rude but: and...?
PrescottJoule:
"the best way to emulate one"
The Esplora pots are also labeled "103", which suggests 10K, but they measure "1500 ohms" in circuit.
The pot is likely scaling a voltage.
With your voltmeter between Gnd and the pot wiper, you can determine the range.
Is your plan to effect pre-determined combinations of voltages in place of the joystick pots?
Sorry I didn't say so earlier- I'm using an UNO. My plan is to autonomously control the controller by interfacing the UNO with my laptop and desktop. I also might use it just to mess with friends (programming in aim assist type things)
Thanks
I mentioned the Esplora by way of comparison. I was messing about with mine, coincidentally, having some time on my hands this weekend. (Maybe it's what you're looking for, official versions can be found for around $25.)
Uno, autonomously controlling controllers, laptop/desktop, etc. - maybe you could fill in the blanks.
What I plan to do it hook the UNO up do my old 360 controller that I have disassembled. My sending the appropriate signals from the Arduino through the traces associated with a certain control I can fake it into receiving inputs. E.g. I send a high pulse through the trace associated with the A button from the UNO. The controller registers this as a press of A and my character jumps accordingly. By interfacing this with my laptop and Xbox the Arduino/Laptop can make decisions on what to do based on the environment the Xbox is simulating. Add in some primitive AI and you have a CPU character that can do very basic task in a game.
"Add in some primitive AI..."
Minor detail. :slight_smile:
Thanks, thats what I needed, for some reason a search was not pulling this up
I went with "Arduino PWM filter"
