Saludos
Encontré el siguiente código que genera distintos intervalos de tiempo representados en Led sin ocupar Delay.
Pero lo quise modificar sin muchos resultados, mi idea es poder hacer variar el o los tiempos que están asignados.
Simple Timer
This sketch is a simple way to execute functions at different time intervals.
class Timer
private:
unsigned long lastTime; // the latest time had doing Func( )
void (*Func) (void);
void (*backupFunc) (void); // backup Func for start( )
unsigned long T_int; // interval in ms, can be set as in us (optional)
public:
Timer(void (*userFunc)(), unsigned long T, int isTinUs=0)
Func = backupFunc = userFunc; // save the function pointer
T_int = T * 1000;
if(isTinUs !=0) T_int = T; // T is in micro second as per unit
lastTime = 0; // initialization should be in constructor
lastTime = -T_int; // compatible with Original version
void check()
if( Func == 0 ) return; // no function pointer
unsigned long _micros = micros( ); // Local variable could be in Register
// Note that ( _micros = micros() < Time) means ( _micros = ( micros() < Time ) )
// BTW, check roll over is actually NOT NECESSARY; by tsaiwn@cs.nctu.edu.tw
if (_micros - lastTime >= T_int)
lastTime = _micros; // latest time doing Func( )
Func();
}// check(
void start( ) { // first run of doing Func( )
if(Func == 0) Func = backupFunc; // restore after .stop( )
lastTime = micros( ); // latest time doing Func( )
Func(); // First run
} // start(
void stop( ) { // stop the scheduled Func (userFunc)
Func = 0; // set as NULL
} // stop(
Timer T1(Blink1, 88000, 38); // 88000us (NOT ms) since 38 is NOT 0
Timer T2(Blink2, 1000); // 1000ms
Timer T3(Blink3, 2000); // 2000ms
pinMode(13, OUTPUT);
pinMode(11, OUTPUT);
pinMode(9, OUTPUT);
T1.start( ) ; // optional to use the .start( ) function
delay(2568); // On Purpose for you to compare T1 vs. T2, T3
T1.check();
T2.check();
T3.check();
void Blink1()
digitalWrite(13, !digitalRead(13));
void Blink2()
digitalWrite(9, !digitalRead(9));
void Blink3()
digitalWrite(11, !digitalRead(11));
Por ejemplo cree una llamada de función (disculpen la ignorancia, pero no sé si se llama así)
desde el "void loop" de esta forma:
sensorValue =analogRead(sensorPin);
sensorValue= map(sensorValue,0,1023,3600,1);
T2.change_time(sensorValue, 0);
//Timer T2(Blink2, sensorValue);
T1.check();
T2.check();
T3.check();
y la función la puse antes de terminar el "class Timer"
void change_time(unsigned long T, int isTinUs=0)
//Func = backupFunc = userFunc; // save the function pointer
T_int = T * 1000;
Serial.println(T);
Bueno en resumen no funciono, el led queda pegado mientras los otros led trabajan de acuerdo a los tiempos asignados, también quise llamar la clase Timer desde el Void loop y tampoco tuve resultados positivos.
Favor, me podrían indicar en que estoy equivocado?
De antemano, gracias
