Today I opened a new yun out of the box. And i was measuring the onboard 5v/gnd pin. I tried every power supply I have and all of them supply steady 5v. But when I measure the 5v/gnd pin, its fluctuate between 4.3v and 4.5v. Is this normal?
I also try feeding power using the Vin pin, but also around no 5v from the 5v pin.
I left my other 2nd yun some where else, so I cant double check it on another one.
First of all i noticed in the schematic that there is a schottky diode placed between VIN pin and VDD, and an other between VDD and 5V pin of the board.
This could lead to a series of problems, because of voltage dropout induced by those diodes.
In particular:
1 - Voltage instability, because the voltage drop is current-depending, so it will not be stable, but could fall or raise depending on the current absorbed in the moment
2 - Diffente voltage between components: some components would receive some millivolts more or less
3 - Inaccuracy in sensors reading, because many analog sensors output a voltage that is proportional to the VCC supplied (for example the ACS715)
my 2 cents:
Voltage instability with temperature.
AR9331 no effect by Voltage instability since it power by 3.3 V.
Shield is power by 5.0 V which has 2 diodes and lowest voltage.
4.48 volt is normal but might cause some shield fail.
Its good to know the 5v pin isnt reliable, nothing disastrous but very annoying needing a separate power supply and then if you use the Vin port; to regulate/protect it.
What does this actually mean with respect to attaching sensors and actuators to the Yun?
I guess you need to take these lower voltages into account? What would be a solution if e.g. The 4.4v would be out of spec for some sensors or actuators?
I really think arduino needs to rethink this design.
I have 4.5V on my 5V pin. As I use a sensor working on 5V +-5% (http://www.lem.com/docs/products/ltsr%2025-np.pdf) which is not working as expected I have another possible issue to investigate :~
My current problem is that I am making a shield with external power (isn't yun perfect for mobile apps?). As the USB connector is different and the pins behave different I require electronics beyond my knowledge to switch between Arduino boards.
So simply testing with a Uno that has 5V on its pin is ruled out as well.
So please Arduino team fix this in the next release
If you're feeling adventurous you can remove the diode that's next to the VIN pin and short its two pads together. My analog readings are much better now.
I have same issue with my yun powered through VIN using a LM7805.
The rest of my circuit (sensors, ...) is on a breadboard. Do you recommend powering the breadboard using the clean 5V coming from LM7805 or using 5V pin of the Arduino with ~4.4V ?
I would use your external 5V to power at least your external sensors, since they will likely use that as a voltage reference as well. I needed to read values from external current sensors whose output is based on the 5V as reference. So both my Yun's ADCs and my external sensors needed to have exactly the same 5VIN.
cblue:
Hello,
I found this issue today with a Yun powered by an Apple 12w charger. 4.5-4.6 volts with nothing plugged in. Once I add a level shifter, RTC and lux detector (all mounted in turn on a proto board) that falls to 4.4v and when I try to connect an LED strip the voltage drops to 3.8v which is too low for my LED strip, which requires 4v minimum, so nothing lights up.
I guess I'll run a jump lead from the USB side of the diode up to my proto board. I wasted a good couple of hours on this today thinking I'd got some kind of fault; this problem doesn't occur using the Leonardo which showed 5.1v with everything except the LEDs connected, and 4.8v with the LEDs connected as well.
Definitely a design flaw; if there is a good reason for supplying 4.5v to the Yun, at least drive the shield 5v line from the supply ahead of the diode...
