In windows11 when I try to debug my code in ArduineIDE 2.3.2 I obtain the message:
"OpenOCD: GDB Server Quit Unexpectedly. See gdb-server output for more details."
In windows10 was OK, so why it does not work in windows11 ?
Firewall was unblocked for ArduineIDE in windows11.
Error: A serious error occurred with gdb, unable to continue or interrupt We may not be able to recover from this point. You can try continuing or ending session. Must address root cause though
In output window:
FQBN: arduino:samd:arduino_zero_edbg
Using board 'arduino_zero_edbg' from platform in folder: C:\Users\ludom\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.8.14
Using core 'arduino' from platform in folder: C:\Users\ludom\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.8.14
Info : auto-selecting first available session transport "swd". To override use 'transport select '.
none separate
adapter speed: 400 kHz
cortex_m reset_config sysresetreq
Info : Listening on port 50008 for tcl connections
Info : Listening on port 50009 for telnet connections
Error: unable to open CMSIS-DAP device 0x3eb:0x2157
I moved your topic to an appropriate forum category @zom123.
In the future, please take some time to pick the forum category that best suits the subject of your topic. There is an "About the _____ category" topic at the top of each category that explains its purpose.
@zom123 I moved your topic to the IDE 2.x, as you should have been able to see by looking at it:
We shouldn't have to put your topics in the appropriate place. The volunteers who maintain this forum have plenty enough work to do dealing with all the evil spammers.
If you are competent enough to be working with Arduino, surely you are competent enough to be able to look through the list of forum categories and pick one that isn't labeled "DO NOT USE!". Yet this is the third topic you have put in the Uncategorized category, increasing the workload on the forum maintainers. You need to start being more responsible in your behavior here on the forum. If you can't do that, an account suspension is in your future.
OK. But, sorry, I seems to me, the classification into this category is misleading, because the main problem is not the IDE but Windows 11 and GDB server.
Yes, we don't create a specific forum category for every one of the thousands of niche subjects that someone might post about.
You must pick the most appropriate of the available forum categories. If you don't find a perfect category, pick the one that seems best. As long as you make a reasonable decision, we aren't going to be upset. But the Uncategorized category is never a reasonable decision (we created it specifically to help us identify the many lazy people like you who clutter up our forum and make a lot of unnecessary work for the volunteer maintainers by not making even the slightest effort to pick an appropriate category), so we will get very upset if you pick that category.
