I Uninstall the re-install it. however During the installation when i reached the step to select the required file, after selection of the Arduino.inf the pop up windows appear, stating.
"the folder specified doesn't contain a compatible software driver for your device. if the folder contains a driver, make sure it is designed to work with windows for 32-bit systems"
yes the below are mentioned in the .inf file
%zero.edbg.name%=DriverInstall, USB\VID_03EB&PID_2157&MI_01
%zero.sketch.name%=DriverInstall, USB\VID_2341&PID_804D&MI_00
%zero.bootloader.name%=DriverInstall, USB\VID_2341&PID_004D
still i am having the problem
