For Arduino Zero board with ATMEL SAMD21G18 Microcontroller, what is the maximum speed or baud rate for its serial (UART) Interface?
I looked at the data sheet for this MCU and according to the baud-rate calculation Table (attached) with an internal clock speed of 48Mhz, it shows it can support up to 3Mbps.... is this number correct? does any one try this baud rate with the MCU?
The Arduino code uses a relatively trivial algorithm to set the uart baud rate; I don't see any reason that it wouldn't support the full speed listed in the datasheet. Note that running async comm at 3Mbps is a bit risky from a hardware/drive/wiring perspective...
