arduinoOTA file not found when uploading a sketch via network
Failed uploading: cannot execute upload tool: exec: "{runtime.tools.arduinoOTA.path}/bin/arduinoOTA": file does not exist
I tried following the advice here: R4 OTA update errors - UNO R4 / UNO R4 WiFi - Arduino Forum
I copied the renesas platform.local.txt next to platform.txt in ~renesas_uno/1.2.1 but now I get this error
Here's the verbose output:
FQBN: arduino:renesas_uno:unor4wifi
Using board 'unor4wifi' from platform in folder: C:\Users\npcuser\AppData\Local\Arduino15\packages\arduino\hardware\renesas_uno\1.2.1
Using core 'arduino' from platform in folder: C:\Users\npcuser\AppData\Local\Arduino15\packages\arduino\hardware\renesas_uno\1.2.1
Detecting libraries used...
C:\Users\npcuser\AppData\Local\Arduino15\packages\arduino\tools\arm-none-eabi-gcc\7-2017q4/bin/arm-none-eabi-g++ -c -w -Os -g3 -fno-use-cxa-atexit -fno-rtti -fno-exceptions -nostdlib -DF_CPU=48000000 -DNO_USB -DBACKTRACE_SUPPORT -DARDUINO_UNOR4_WIFI -std=gnu++17 -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsigned-char -ffunction-sections -fdata-sections -fmessage-length=0 -fno-builtin -w -x c++ -E -CC -DARDUINO=10607 -DPROJECT_NAME="C:\Users\npcuser\AppData\Local\Temp\arduino\sketches\30A8FE9E53CBB56EB012380315ACA3D0/sketch_sep11a.ino" -DARDUINO_UNOWIFIR4 -DARDUINO_ARCH_RENESAS_UNO -DARDUINO_ARCH_RENESAS -DARDUINO_FSP -D_XOPEN_SOURCE=700 -mthumb @C:\Users\npcuser\AppData\Local\Arduino15\packages\arduino\hardware\renesas_uno\1.2.1\variants\UNOWIFIR4/defines.txt -DCFG_TUSB_MCU=OPT_MCU_RAXXX -IC:\Users\npcuser\AppData\Local\Arduino15\packages\arduino\hardware\renesas_uno\1.2.1\cores\arduino/tinyusb -IC:\Users\npcuser\AppData\Local\Arduino15\packages\arduino\hardware\renesas_uno\1.2.1\cores\arduino/api/deprecated -IC:\Users\npcuser\AppData\Local\Arduino15\packages\arduino\hardware\renesas_uno\1.2.1\cores\arduino/api/deprecated-avr-comp -IC:\Users\npcuser\AppData\Local\Arduino15\packages\arduino\hardware\renesas_uno\1.2.1\cores\arduino -IC:\Users\npcuser\AppData\Local\Arduino15\packages\arduino\hardware\renesas_uno\1.2.1\variants\UNOWIFIR4 -iprefixC:\Users\npcuser\AppData\Local\Arduino15\packages\arduino\hardware\renesas_uno\1.2.1 @C:\Users\npcuser\AppData\Local\Arduino15\packages\arduino\hardware\renesas_uno\1.2.1\variants\UNOWIFIR4/includes.txt C:\Users\npcuser\AppData\Local\Temp\arduino\sketches\30A8FE9E53CBB56EB012380315ACA3D0\sketch\sketch_sep11a.ino.cpp -o nul
Alternatives for WiFiS3.h: [WiFiS3@0.0.0]
ResolveLibrary(WiFiS3.h)
  -> candidates: [WiFiS3@0.0.0]
C:\Users\npcuser\AppData\Local\Arduino15\packages\arduino\tools\arm-none-eabi-gcc\7-2017q4/bin/arm-none-eabi-g++ -c -w -Os -g3 -fno-use-cxa-atexit -fno-rtti -fno-exceptions -nostdlib -DF_CPU=48000000 -DNO_USB -DBACKTRACE_SUPPORT -DARDUINO_UNOR4_WIFI -std=gnu++17 -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsigned-char -ffunction-sections -fdata-sections -fmessage-length=0 -fno-builtin -w -x c++ -E -CC -DARDUINO=10607 -DPROJECT_NAME="C:\Users\npcuser\AppData\Local\Temp\arduino\sketches\30A8FE9E53CBB56EB012380315ACA3D0/sketch_sep11a.ino" -DARDUINO_UNOWIFIR4 -DARDUINO_ARCH_RENESAS_UNO -DARDUINO_ARCH_RENESAS -DARDUINO_FSP -D_XOPEN_SOURCE=700 -mthumb @C:\Users\npcuser\AppData\Local\Arduino15\packages\arduino\hardware\renesas_uno\1.2.1\variants\UNOWIFIR4/defines.txt -DCFG_TUSB_MCU=OPT_MCU_RAXXX -IC:\Users\npcuser\AppData\Local\Arduino15\packages\arduino\hardware\renesas_uno\1.2.1\cores\arduino/tinyusb -IC:\Users\npcuser\AppData\Local\Arduino15\packages\arduino\hardware\renesas_uno\1.2.1\cores\arduino/api/deprecated -IC:\Users\npcuser\AppData\Local\Arduino15\packages\arduino\hardware\renesas_uno\1.2.1\cores\arduino/api/deprecated-avr-comp -IC:\Users\npcuser\AppData\Local\Arduino15\packages\arduino\hardware\renesas_uno\1.2.1\cores\arduino -IC:\Users\npcuser\AppData\Local\Arduino15\packages\arduino\hardware\renesas_uno\1.2.1\variants\UNOWIFIR4 -IC:\Users\npcuser\AppData\Local\Arduino15\packages\arduino\hardware\renesas_uno\1.2.1\libraries\WiFiS3\src -iprefixC:\Users\npcuser\AppData\Local\Arduino15\packages\arduino\hardware\renesas_uno\1.2.1 @C:\Users\npcuser\AppData\Local\Arduino15\packages\arduino\hardware\renesas_uno\1.2.1\variants\UNOWIFIR4/includes.txt C:\Users\npcuser\AppData\Local\Temp\arduino\sketches\30A8FE9E53CBB56EB012380315ACA3D0\sketch\sketch_sep11a.ino.cpp -o nul
Alternatives for ArduinoOTA.h: [ArduinoOTA@1.1.0]
ResolveLibrary(ArduinoOTA.h)
  -> candidates: [ArduinoOTA@1.1.0]
C:\Users\npcuser\AppData\Local\Arduino15\packages\arduino\tools\arm-none-eabi-gcc\7-2017q4/bin/arm-none-eabi-g++ -c -w -Os -g3 -fno-use-cxa-atexit -fno-rtti -fno-exceptions -nostdlib -DF_CPU=48000000 -DNO_USB -DBACKTRACE_SUPPORT -DARDUINO_UNOR4_WIFI -std=gnu++17 -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsigned-char -ffunction-sections -fdata-sections -fmessage-length=0 -fno-builtin -w -x c++ -E -CC -DARDUINO=10607 -DPROJECT_NAME="C:\Users\npcuser\AppData\Local\Temp\arduino\sketches\30A8FE9E53CBB56EB012380315ACA3D0/sketch_sep11a.ino" -DARDUINO_UNOWIFIR4 -DARDUINO_ARCH_RENESAS_UNO -DARDUINO_ARCH_RENESAS -DARDUINO_FSP -D_XOPEN_SOURCE=700 -mthumb @C:\Users\npcuser\AppData\Local\Arduino15\packages\arduino\hardware\renesas_uno\1.2.1\variants\UNOWIFIR4/defines.txt -DCFG_TUSB_MCU=OPT_MCU_RAXXX -IC:\Users\npcuser\AppData\Local\Arduino15\packages\arduino\hardware\renesas_uno\1.2.1\cores\arduino/tinyusb -IC:\Users\npcuser\AppData\Local\Arduino15\packages\arduino\hardware\renesas_uno\1.2.1\cores\arduino/api/deprecated -IC:\Users\npcuser\AppData\Local\Arduino15\packages\arduino\hardware\renesas_uno\1.2.1\cores\arduino/api/deprecated-avr-comp -IC:\Users\npcuser\AppData\Local\Arduino15\packages\arduino\hardware\renesas_uno\1.2.1\cores\arduino -IC:\Users\npcuser\AppData\Local\Arduino15\packages\arduino\hardware\renesas_uno\1.2.1\variants\UNOWIFIR4 -IC:\Users\npcuser\AppData\Local\Arduino15\packages\arduino\hardware\renesas_uno\1.2.1\libraries\WiFiS3\src -IC:\Users\npcuser\Documents\Arduino\libraries\ArduinoOTA\src -iprefixC:\Users\npcuser\AppData\Local\Arduino15\packages\arduino\hardware\renesas_uno\1.2.1 @C:\Users\npcuser\AppData\Local\Arduino15\packages\arduino\hardware\renesas_uno\1.2.1\variants\UNOWIFIR4/includes.txt C:\Users\npcuser\AppData\Local\Temp\arduino\sketches\30A8FE9E53CBB56EB012380315ACA3D0\sketch\sketch_sep11a.ino.cpp -o nul
Using cached library dependencies for file: C:\Users\npcuser\AppData\Local\Arduino15\packages\arduino\hardware\renesas_uno\1.2.1\libraries\WiFiS3\src\Modem.cpp
Using cached library dependencies for file: C:\Users\npcuser\AppData\Local\Arduino15\packages\arduino\hardware\renesas_uno\1.2.1\libraries\WiFiS3\src\StringHelpers.cpp
Using cached library dependencies for file: C:\Users\npcuser\AppData\Local\Arduino15\packages\arduino\hardware\renesas_uno\1.2.1\libraries\WiFiS3\src\WiFi.cpp
Using cached library dependencies for file: C:\Users\npcuser\AppData\Local\Arduino15\packages\arduino\hardware\renesas_uno\1.2.1\libraries\WiFiS3\src\WiFiClient.cpp
Using cached library dependencies for file: C:\Users\npcuser\AppData\Local\Arduino15\packages\arduino\hardware\renesas_uno\1.2.1\libraries\WiFiS3\src\WiFiFileSystem.cpp
Using cached library dependencies for file: C:\Users\npcuser\AppData\Local\Arduino15\packages\arduino\hardware\renesas_uno\1.2.1\libraries\WiFiS3\src\WiFiSSLClient.cpp
Using cached library dependencies for file: C:\Users\npcuser\AppData\Local\Arduino15\packages\arduino\hardware\renesas_uno\1.2.1\libraries\WiFiS3\src\WiFiServer.cpp
Using cached library dependencies for file: C:\Users\npcuser\AppData\Local\Arduino15\packages\arduino\hardware\renesas_uno\1.2.1\libraries\WiFiS3\src\WiFiUdp.cpp
Using cached library dependencies for file: C:\Users\npcuser\Documents\Arduino\libraries\ArduinoOTA\src\InternalStorage.cpp
Using cached library dependencies for file: C:\Users\npcuser\Documents\Arduino\libraries\ArduinoOTA\src\InternalStorageAVR.cpp
Using cached library dependencies for file: C:\Users\npcuser\Documents\Arduino\libraries\ArduinoOTA\src\InternalStorageESP.cpp
Using cached library dependencies for file: C:\Users\npcuser\Documents\Arduino\libraries\ArduinoOTA\src\InternalStorageRP2.cpp
Using cached library dependencies for file: C:\Users\npcuser\Documents\Arduino\libraries\ArduinoOTA\src\InternalStorageRenesas.cpp
Using cached library dependencies for file: C:\Users\npcuser\Documents\Arduino\libraries\ArduinoOTA\src\InternalStorageSTM32.cpp
Using cached library dependencies for file: C:\Users\npcuser\Documents\Arduino\libraries\ArduinoOTA\src\OTAStorage.cpp
Using cached library dependencies for file: C:\Users\npcuser\Documents\Arduino\libraries\ArduinoOTA\src\WiFiOTA.cpp
Using cached library dependencies for file: C:\Users\npcuser\Documents\Arduino\libraries\ArduinoOTA\src\utility\r_flash_lp_cf.c
Using cached library dependencies for file: C:\Users\npcuser\Documents\Arduino\libraries\ArduinoOTA\src\utility\rp2_flash_boot.c
Using cached library dependencies for file: C:\Users\npcuser\Documents\Arduino\libraries\ArduinoOTA\src\utility\stm32_flash_boot.c
Generating function prototypes...
C:\Users\npcuser\AppData\Local\Arduino15\packages\arduino\tools\arm-none-eabi-gcc\7-2017q4/bin/arm-none-eabi-g++ -c -w -Os -g3 -fno-use-cxa-atexit -fno-rtti -fno-exceptions -nostdlib -DF_CPU=48000000 -DNO_USB -DBACKTRACE_SUPPORT -DARDUINO_UNOR4_WIFI -std=gnu++17 -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsigned-char -ffunction-sections -fdata-sections -fmessage-length=0 -fno-builtin -w -x c++ -E -CC -DARDUINO=10607 -DPROJECT_NAME="C:\Users\npcuser\AppData\Local\Temp\arduino\sketches\30A8FE9E53CBB56EB012380315ACA3D0/sketch_sep11a.ino" -DARDUINO_UNOWIFIR4 -DARDUINO_ARCH_RENESAS_UNO -DARDUINO_ARCH_RENESAS -DARDUINO_FSP -D_XOPEN_SOURCE=700 -mthumb @C:\Users\npcuser\AppData\Local\Arduino15\packages\arduino\hardware\renesas_uno\1.2.1\variants\UNOWIFIR4/defines.txt -DCFG_TUSB_MCU=OPT_MCU_RAXXX -IC:\Users\npcuser\AppData\Local\Arduino15\packages\arduino\hardware\renesas_uno\1.2.1\cores\arduino/tinyusb -IC:\Users\npcuser\AppData\Local\Arduino15\packages\arduino\hardware\renesas_uno\1.2.1\cores\arduino/api/deprecated -IC:\Users\npcuser\AppData\Local\Arduino15\packages\arduino\hardware\renesas_uno\1.2.1\cores\arduino/api/deprecated-avr-comp -IC:\Users\npcuser\AppData\Local\Arduino15\packages\arduino\hardware\renesas_uno\1.2.1\cores\arduino -IC:\Users\npcuser\AppData\Local\Arduino15\packages\arduino\hardware\renesas_uno\1.2.1\variants\UNOWIFIR4 -IC:\Users\npcuser\AppData\Local\Arduino15\packages\arduino\hardware\renesas_uno\1.2.1\libraries\WiFiS3\src -IC:\Users\npcuser\Documents\Arduino\libraries\ArduinoOTA\src -iprefixC:\Users\npcuser\AppData\Local\Arduino15\packages\arduino\hardware\renesas_uno\1.2.1 @C:\Users\npcuser\AppData\Local\Arduino15\packages\arduino\hardware\renesas_uno\1.2.1\variants\UNOWIFIR4/includes.txt C:\Users\npcuser\AppData\Local\Temp\arduino\sketches\30A8FE9E53CBB56EB012380315ACA3D0\sketch\sketch_sep11a.ino.cpp -o C:\Users\npcuser\AppData\Local\Temp\1234638633\sketch_merged.cpp
C:\Users\npcuser\AppData\Local\Arduino15\packages\builtin\tools\ctags\5.8-arduino11/ctags -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives C:\Users\npcuser\AppData\Local\Temp\1234638633\sketch_merged.cpp
Compiling sketch...
"C:\\Users\\npcuser\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\7-2017q4/bin/arm-none-eabi-g++" -c -w -Os -g3 -fno-use-cxa-atexit -fno-rtti -fno-exceptions -MMD -nostdlib -DF_CPU=48000000 -DNO_USB -DBACKTRACE_SUPPORT -DARDUINO_UNOR4_WIFI -MMD -std=gnu++17 -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsigned-char -ffunction-sections -fdata-sections -fmessage-length=0 -fno-builtin -DARDUINO=10607 "-DPROJECT_NAME=\"C:\\Users\\npcuser\\AppData\\Local\\Temp\\arduino\\sketches\\30A8FE9E53CBB56EB012380315ACA3D0/sketch_sep11a.ino\"" -DARDUINO_UNOWIFIR4 -DARDUINO_ARCH_RENESAS_UNO -DARDUINO_ARCH_RENESAS -DARDUINO_FSP -D_XOPEN_SOURCE=700 -mthumb "@C:\\Users\\npcuser\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\renesas_uno\\1.2.1\\variants\\UNOWIFIR4/defines.txt" -DCFG_TUSB_MCU=OPT_MCU_RAXXX "-IC:\\Users\\npcuser\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\renesas_uno\\1.2.1\\cores\\arduino/tinyusb" "-IC:\\Users\\npcuser\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\renesas_uno\\1.2.1\\cores\\arduino/api/deprecated" "-IC:\\Users\\npcuser\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\renesas_uno\\1.2.1\\cores\\arduino/api/deprecated-avr-comp" "-IC:\\Users\\npcuser\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\renesas_uno\\1.2.1\\cores\\arduino" "-IC:\\Users\\npcuser\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\renesas_uno\\1.2.1\\variants\\UNOWIFIR4" "-IC:\\Users\\npcuser\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\renesas_uno\\1.2.1\\libraries\\WiFiS3\\src" "-IC:\\Users\\npcuser\\Documents\\Arduino\\libraries\\ArduinoOTA\\src" "-iprefixC:\\Users\\npcuser\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\renesas_uno\\1.2.1" "@C:\\Users\\npcuser\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\renesas_uno\\1.2.1\\variants\\UNOWIFIR4/includes.txt" "C:\\Users\\npcuser\\AppData\\Local\\Temp\\arduino\\sketches\\30A8FE9E53CBB56EB012380315ACA3D0\\sketch\\sketch_sep11a.ino.cpp" -o "C:\\Users\\npcuser\\AppData\\Local\\Temp\\arduino\\sketches\\30A8FE9E53CBB56EB012380315ACA3D0\\sketch\\sketch_sep11a.ino.cpp.o"
Compiling libraries...
Compiling library "WiFiS3"
Using previously compiled file: C:\Users\npcuser\AppData\Local\Temp\arduino\sketches\30A8FE9E53CBB56EB012380315ACA3D0\libraries\WiFiS3\StringHelpers.cpp.o
Using previously compiled file: C:\Users\npcuser\AppData\Local\Temp\arduino\sketches\30A8FE9E53CBB56EB012380315ACA3D0\libraries\WiFiS3\WiFiServer.cpp.o
Using previously compiled file: C:\Users\npcuser\AppData\Local\Temp\arduino\sketches\30A8FE9E53CBB56EB012380315ACA3D0\libraries\WiFiS3\Modem.cpp.o
Using previously compiled file: C:\Users\npcuser\AppData\Local\Temp\arduino\sketches\30A8FE9E53CBB56EB012380315ACA3D0\libraries\WiFiS3\WiFiClient.cpp.o
Using previously compiled file: C:\Users\npcuser\AppData\Local\Temp\arduino\sketches\30A8FE9E53CBB56EB012380315ACA3D0\libraries\WiFiS3\WiFiUdp.cpp.o
Using previously compiled file: C:\Users\npcuser\AppData\Local\Temp\arduino\sketches\30A8FE9E53CBB56EB012380315ACA3D0\libraries\WiFiS3\WiFiFileSystem.cpp.o
Using previously compiled file: C:\Users\npcuser\AppData\Local\Temp\arduino\sketches\30A8FE9E53CBB56EB012380315ACA3D0\libraries\WiFiS3\WiFiSSLClient.cpp.o
Using previously compiled file: C:\Users\npcuser\AppData\Local\Temp\arduino\sketches\30A8FE9E53CBB56EB012380315ACA3D0\libraries\WiFiS3\WiFi.cpp.o
Compiling library "ArduinoOTA"
Using previously compiled file: C:\Users\npcuser\AppData\Local\Temp\arduino\sketches\30A8FE9E53CBB56EB012380315ACA3D0\libraries\ArduinoOTA\InternalStorage.cpp.o
Using previously compiled file: C:\Users\npcuser\AppData\Local\Temp\arduino\sketches\30A8FE9E53CBB56EB012380315ACA3D0\libraries\ArduinoOTA\utility\rp2_flash_boot.c.o
Using previously compiled file: C:\Users\npcuser\AppData\Local\Temp\arduino\sketches\30A8FE9E53CBB56EB012380315ACA3D0\libraries\ArduinoOTA\InternalStorageRP2.cpp.o
Using previously compiled file: C:\Users\npcuser\AppData\Local\Temp\arduino\sketches\30A8FE9E53CBB56EB012380315ACA3D0\libraries\ArduinoOTA\InternalStorageSTM32.cpp.o
Using previously compiled file: C:\Users\npcuser\AppData\Local\Temp\arduino\sketches\30A8FE9E53CBB56EB012380315ACA3D0\libraries\ArduinoOTA\InternalStorageESP.cpp.o
Using previously compiled file: C:\Users\npcuser\AppData\Local\Temp\arduino\sketches\30A8FE9E53CBB56EB012380315ACA3D0\libraries\ArduinoOTA\utility\stm32_flash_boot.c.o
Using previously compiled file: C:\Users\npcuser\AppData\Local\Temp\arduino\sketches\30A8FE9E53CBB56EB012380315ACA3D0\libraries\ArduinoOTA\utility\r_flash_lp_cf.c.o
Using previously compiled file: C:\Users\npcuser\AppData\Local\Temp\arduino\sketches\30A8FE9E53CBB56EB012380315ACA3D0\libraries\ArduinoOTA\InternalStorageAVR.cpp.o
Using previously compiled file: C:\Users\npcuser\AppData\Local\Temp\arduino\sketches\30A8FE9E53CBB56EB012380315ACA3D0\libraries\ArduinoOTA\OTAStorage.cpp.o
Using previously compiled file: C:\Users\npcuser\AppData\Local\Temp\arduino\sketches\30A8FE9E53CBB56EB012380315ACA3D0\libraries\ArduinoOTA\WiFiOTA.cpp.o
Using previously compiled file: C:\Users\npcuser\AppData\Local\Temp\arduino\sketches\30A8FE9E53CBB56EB012380315ACA3D0\libraries\ArduinoOTA\InternalStorageRenesas.cpp.o
Using previously compiled file: C:\Users\npcuser\AppData\Local\Temp\arduino\sketches\30A8FE9E53CBB56EB012380315ACA3D0\libraries\ArduinoOTA\ArduinoOTA.a
Compiling core...
Using previously compiled file: C:\Users\npcuser\AppData\Local\Temp\arduino\sketches\30A8FE9E53CBB56EB012380315ACA3D0\core\tmp_gen_c_files\pin_data.c.o
Using previously compiled file: C:\Users\npcuser\AppData\Local\Temp\arduino\sketches\30A8FE9E53CBB56EB012380315ACA3D0\core\tmp_gen_c_files\common_data.c.o
Using previously compiled file: C:\Users\npcuser\AppData\Local\Temp\arduino\sketches\30A8FE9E53CBB56EB012380315ACA3D0\core\variant.cpp.o
Using previously compiled file: C:\Users\npcuser\AppData\Local\Temp\arduino\sketches\30A8FE9E53CBB56EB012380315ACA3D0\core\tmp_gen_c_files\main.c.o
Using precompiled core: C:\Users\npcuser\AppData\Local\Temp\arduino\cores\arduino_renesas_uno_unor4wifi_7ca94850d9e2beacb5360be6245f0144\core.a
Linking everything together...
"C:\\Users\\npcuser\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\7-2017q4/bin/arm-none-eabi-g++" -Wl,--gc-sections --specs=nosys.specs -w -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -o "C:\\Users\\npcuser\\AppData\\Local\\Temp\\arduino\\sketches\\30A8FE9E53CBB56EB012380315ACA3D0/sketch_sep11a.ino.elf" "-LC:\\Users\\npcuser\\AppData\\Local\\Temp\\arduino\\sketches\\30A8FE9E53CBB56EB012380315ACA3D0" "-LC:\\Users\\npcuser\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\renesas_uno\\1.2.1\\variants\\UNOWIFIR4" "-TC:\\Users\\npcuser\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\renesas_uno\\1.2.1\\variants\\UNOWIFIR4/fsp.ld" "C:\\Users\\npcuser\\AppData\\Local\\Temp\\arduino\\sketches\\30A8FE9E53CBB56EB012380315ACA3D0\\sketch\\sketch_sep11a.ino.cpp.o" "C:\\Users\\npcuser\\AppData\\Local\\Temp\\arduino\\sketches\\30A8FE9E53CBB56EB012380315ACA3D0\\libraries\\WiFiS3\\Modem.cpp.o" "C:\\Users\\npcuser\\AppData\\Local\\Temp\\arduino\\sketches\\30A8FE9E53CBB56EB012380315ACA3D0\\libraries\\WiFiS3\\StringHelpers.cpp.o" "C:\\Users\\npcuser\\AppData\\Local\\Temp\\arduino\\sketches\\30A8FE9E53CBB56EB012380315ACA3D0\\libraries\\WiFiS3\\WiFi.cpp.o" "C:\\Users\\npcuser\\AppData\\Local\\Temp\\arduino\\sketches\\30A8FE9E53CBB56EB012380315ACA3D0\\libraries\\WiFiS3\\WiFiClient.cpp.o" "C:\\Users\\npcuser\\AppData\\Local\\Temp\\arduino\\sketches\\30A8FE9E53CBB56EB012380315ACA3D0\\libraries\\WiFiS3\\WiFiFileSystem.cpp.o" "C:\\Users\\npcuser\\AppData\\Local\\Temp\\arduino\\sketches\\30A8FE9E53CBB56EB012380315ACA3D0\\libraries\\WiFiS3\\WiFiSSLClient.cpp.o" "C:\\Users\\npcuser\\AppData\\Local\\Temp\\arduino\\sketches\\30A8FE9E53CBB56EB012380315ACA3D0\\libraries\\WiFiS3\\WiFiServer.cpp.o" "C:\\Users\\npcuser\\AppData\\Local\\Temp\\arduino\\sketches\\30A8FE9E53CBB56EB012380315ACA3D0\\libraries\\WiFiS3\\WiFiUdp.cpp.o" "C:\\Users\\npcuser\\AppData\\Local\\Temp\\arduino\\sketches\\30A8FE9E53CBB56EB012380315ACA3D0\\libraries\\ArduinoOTA\\ArduinoOTA.a" "C:\\Users\\npcuser\\AppData\\Local\\Temp\\arduino\\sketches\\30A8FE9E53CBB56EB012380315ACA3D0\\core\\tmp_gen_c_files\\common_data.c.o" "C:\\Users\\npcuser\\AppData\\Local\\Temp\\arduino\\sketches\\30A8FE9E53CBB56EB012380315ACA3D0\\core\\tmp_gen_c_files\\main.c.o" "C:\\Users\\npcuser\\AppData\\Local\\Temp\\arduino\\sketches\\30A8FE9E53CBB56EB012380315ACA3D0\\core\\tmp_gen_c_files\\pin_data.c.o" "C:\\Users\\npcuser\\AppData\\Local\\Temp\\arduino\\sketches\\30A8FE9E53CBB56EB012380315ACA3D0\\core\\variant.cpp.o" -Wl,--whole-archive -Wl,--start-group "C:\\Users\\npcuser\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\renesas_uno\\1.2.1\\variants\\UNOWIFIR4/libs/libfsp.a" "C:\\Users\\npcuser\\AppData\\Local\\Temp\\arduino\\sketches\\30A8FE9E53CBB56EB012380315ACA3D0/..\\..\\cores\\arduino_renesas_uno_unor4wifi_7ca94850d9e2beacb5360be6245f0144\\core.a" -Wl,--no-whole-archive --specs=nano.specs -lstdc++ -lsupc++ -lm -lc -lgcc -lnosys -Wl,--end-group "-Wl,-Map,C:\\Users\\npcuser\\AppData\\Local\\Temp\\arduino\\sketches\\30A8FE9E53CBB56EB012380315ACA3D0/sketch_sep11a.ino.map"
"C:\\Users\\npcuser\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\7-2017q4/bin/arm-none-eabi-objcopy" -O binary -j .text -j .data "C:\\Users\\npcuser\\AppData\\Local\\Temp\\arduino\\sketches\\30A8FE9E53CBB56EB012380315ACA3D0/sketch_sep11a.ino.elf" "C:\\Users\\npcuser\\AppData\\Local\\Temp\\arduino\\sketches\\30A8FE9E53CBB56EB012380315ACA3D0/sketch_sep11a.ino.bin"
"C:\\Users\\npcuser\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\7-2017q4/bin/arm-none-eabi-objcopy" -O ihex -j .text -j .data "C:\\Users\\npcuser\\AppData\\Local\\Temp\\arduino\\sketches\\30A8FE9E53CBB56EB012380315ACA3D0/sketch_sep11a.ino.elf" "C:\\Users\\npcuser\\AppData\\Local\\Temp\\arduino\\sketches\\30A8FE9E53CBB56EB012380315ACA3D0/sketch_sep11a.ino.hex"
Using library WiFiS3 at version 0.0.0 in folder: C:\Users\npcuser\AppData\Local\Arduino15\packages\arduino\hardware\renesas_uno\1.2.1\libraries\WiFiS3
Using library ArduinoOTA at version 1.1.0 in folder: C:\Users\npcuser\Documents\Arduino\libraries\ArduinoOTA
"C:\\Users\\npcuser\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\7-2017q4/bin/arm-none-eabi-size" -A "C:\\Users\\npcuser\\AppData\\Local\\Temp\\arduino\\sketches\\30A8FE9E53CBB56EB012380315ACA3D0/sketch_sep11a.ino.elf"
Sketch uses 74672 bytes (28%) of program storage space. Maximum is 262144 bytes.
Global variables use 9816 bytes (29%) of dynamic memory, leaving 22952 bytes for local variables. Maximum is 32768 bytes.
"{runtime.tools.arduinoOTA.path}/bin/arduinoOTA" -address "" -port 65280 -username IoT -password "" -sketch "C:\Users\npcuser\AppData\Local\Temp\arduino\sketches\30A8FE9E53CBB56EB012380315ACA3D0/sketch_sep11a.ino.bin" -upload /sketch -b
Any help would be appreciated
it is not installed with the Uno R4 platform. Install the AVR or SAMD platform in Boards Manager and it will install the upload tool
