arduinoOTA upload to UNO R4 WiFi fails: "no upload port provided"
Continuing the discussion from UNO R4 WiFi OTA With IDE:
Dear Forum Members and Arduino Team, I'm new to this platform and hope for some help. As I didn't want top open up a new post/topic, I hope it is ok to post my question here as it is sort of relevant to the subject above.
I have followed now above steps, read hundreds of posts, and with help of AI, I even managed to get my Arduino UNO R4 Wifi, hooked up to a power-bank, to even connect on the code to my local Wifi and print out the IP to the attached OLED display. So far so good, and whilst I was over the Moon getting this far, I am now stuck on as it seems to be the last hurdle to transfer code via Arduino IDE 2.3.6. code to the board via OTA.
I can see the board in the selection and I can see the port (Network) with IP address 192.168.1.58 in the selection.
But yet what works so well with the USB-C connection fails with the try of sending the code via WiFi to the board.
This is the last error - hurdle - Failed uploading: no upload port provided
I checked with my Firewall and I can exclude any ports to be blocked.
AI is at its end, and I hope you have perhaps an idea why it still fails to compile?!
Would there a way to specifically designate a port to the process?
Or is this just the final meassure of the Arduino developers to block OTA and have it only available via there cloud server as that works perfectly fine.
Appreciate any idea,
KR
Sebastjan`
#include <SPI.h>
#include <WiFiS3.h>
#include <ArduinoOTA.h>
#include "arduino_secrets.h"
// OLED Libraries
#include <Wire.h>
#include <Adafruit_GFX.h>
#include <Adafruit_SSD1306.h>
char ssid[] = SECRET_SSID;
char pass[] = SECRET_PASS;
int status = WL_IDLE_STATUS;
bool isConnected = false;
// OLED parameters
#define SCREEN_WIDTH 128
#define SCREEN_HEIGHT 64
#define OLED_RESET -1
Adafruit_SSD1306 display(SCREEN_WIDTH, SCREEN_HEIGHT, &Wire, OLED_RESET);
  pinMode(LED_BUILTIN, OUTPUT);
  // Initialize the OLED display
  // Use a different I2C address (0x3D) if needed, based on your module
  if (!display.begin(SSD1306_SWITCHCAPVCC, 0x3C)) {
    // This part runs if the display is not found.
    // We can't print, so we blink the LED indefinitely.
    while (true) {
      digitalWrite(LED_BUILTIN, HIGH);
      delay(250);
      digitalWrite(LED_BUILTIN, LOW);
      delay(250);
  // Initial display setup
  display.clearDisplay();
  display.setTextSize(1);
  display.setTextColor(WHITE);
  display.setCursor(0, 0);
  display.println("Connecting WiFi...");
  display.display();
  // Check for WiFi shield presence
  if (WiFi.status() == WL_NO_SHIELD) {
    while (true) {
      delay(100);
      delay(100);
  // Initiate the connection attempt
  WiFi.begin(ssid, pass);
  // Wait for a valid IP address. The loop now has a timeout to prevent an infinite block.
  int max_attempts = 30; // 30 attempts with 1-second delay = 30 seconds max wait
  int attempts = 0;
  while (WiFi.status() != WL_CONNECTED || WiFi.localIP() == IPAddress(0, 0, 0, 0)) {
    display.print("."); // Show progress on the OLED
    display.display();
    delay(1000); // Wait for a second
    attempts++;
    if(attempts >= max_attempts){
      break; // Exit the loop if it takes too long
  // Check if connection was successful
  if (WiFi.status() == WL_CONNECTED) {
    isConnected = true;
    ArduinoOTA.begin(WiFi.localIP(), "Arduino", "Password", InternalStorage);
    display.println("Connected!");
    display.println();
    display.println("IP:");
    display.println(WiFi.localIP());
    display.display();
    display.println("Connection Failed.");
    display.display();
  if (isConnected) {
    ArduinoOTA.handle();
Hi @Brezel-Tiger
Did you perform this step of the ArduinoOTA installation instructions?:
https://github.com/JAndrassy/ArduinoOTA/tree/master#:~:text=and%20STM32%20boards%2C-,platform.local.txt%20from%20extras%20folder%20has%20to%20be%20copied%20into%20boards%20package%20installation%20folder,-.%20For%20nRF5%20details
For Uno R4, RP2040, nRF5 and STM32 boards, platform.local.txt from extras folder has to be copied into boards package installation folder.
Yes, but doing so is only necessary in the case where Arduino IDE is not able discover the "network" protocol port produced by the board due to a quirk of your system's network configuration. Since you are able to select the "network" port from Arduino IDE's Tools > Port menu, there is no reason to do this and hardcoding the port would actually be a downgrade.
Take off the tinfoil hat!
You really need to be careful about this type of reasoning. Getting into the habit of jumping to conspiracy theories without any evidence at all is incredibly harmful to your cognitive capabilities. This will actually make you vulnerable to the very sort of manipulation that conspiracy theorists claim to be concerned about.
Thanks for your quick feedback...
Yes I did ade the suggested platform.local.txt file in the designated folder.
This was an important requirement indeed to get this far.
As for the port and designating itvn the code, I understand it would be a downgrade...
However it could though also resolve the issue , perhaps worth a try.
And in aspect to your suggestion of me wearing a tin foil...well I came to this idea as there is a basic plan I can purchase which supports OTA updates..whilst not having a monthly or annual plan does not include this option. Hence my question.
Tell me is that OTA inclusion they refer to limited to their IDE and cloud function or general program feature that can be unlocked with the right coding.
I was wondering if I try to replicate my progress on a Windows PC,if I might have more luck and the code I wrote might fully work there.
I figure right or wrong that the port to be used is 3232?
I will try to hard code it and see if it might work.
I report back.
Thanks for your feedback again.
KR
Sebastjan
I'm going to ask you to provide the full verbose output from an upload.
:red_exclamation_mark: This procedure is not intended to solve the problem. The purpose is to gather more information.
Please do this:
  1. Select File > Preferences... (or Arduino IDE > Settings... for macOS users) from the Arduino IDE menus.
    The "Preferences" dialog will open.
  2. Check the box next to Show verbose output during: โ˜ compile in the "Preferences" dialog.
  3. Check the box next to Show verbose output during: โ˜ upload.
  4. Click the "OK" button.
    The "Preferences" dialog will close.
  5. Attempt an upload, as you did before.
  6. Wait for the upload to fail.
  7. You will see an "Upload error: ..." notification at the bottom right corner of the Arduino IDE window. Click the "COPY ERROR MESSAGES" button on that notification.
  8. Open a reply here on this forum topic by clicking the "Reply" button.
  9. Click the <CODE/> icon on the post composer toolbar.
    This will add the forum's code block markup (```) to your reply to make sure the error messages are correctly formatted.
  10. Press the Ctrl+V keyboard shortcut (Command+V for macOS users).
    This will paste the error output from the upload into the code block.
  11. Move the cursor outside of the code block markup before you add any additional text to your reply.
  12. Click the "Reply" button to publish the post.
In case the output is longer than the forum software will allow to be added to a post, you can instead save it to a .txt file and then attach that file to a reply here.
Click here for attachment instructions
  1. Open any text editor program.
  2. Paste the copied output into the text editor.
  3. Save the file in .txt format.
  4. Open a reply here on this forum topic by clicking the "Reply" button.
  5. Click the "Upload" icon (Upload icon) on the post composer toolbar:
    The "Open" dialog will open.
  6. Select the .txt file you saved from the "Open" dialog.
  7. Click the "Open" button.
    The dialog will close.
  8. Click the "Reply" button to publish the post.
Alternatively, instead of using the "Upload" icon on the post composer toolbar as described in steps (5) - (7) above, you can simply drag and drop the .txt file onto the post composer field to attach it.
Despite the use of the general "OTA" (over the air) term in both, the upload method being discussed here is completely different from the Arduino Cloud IoT OTA uploads feature.
The method being discussed here is used to upload to a board over the local network.
The OTA feature provided by Arduino Cloud is used to upload over the Internet to devices anywhere in the world, with the security systems that are required to safely expose a device's firmware update capability to the Internet.
The Arduino Cloud feature, as it is implemented on Arduino Cloud specifically, relies on the secure storage of the compiled sketch binary distribution file on the Arduino Cloud server, and so can only be used in combination with an Arduino Cloud account. However, I believe that you could use the general system independently from Arduino Cloud if you were to host the compiled sketch binary distribution file on some other web server on the Internet.
The open source tools for generating the binary distribution file are available here:
The open source Arduino library code for implementing the Arduino Cloud style of OTA upload capability in the sketch is available here:
I am not knowledgeable in the low level details of how the Arduino Cloud style of OTA upload works (I am not involved in that area of work for Arduino), so I won't be capable of providing any meaningful assistance with such an endeavor, but some of the other forum helpers may be able to help. You should be aware that this is likely to be significantly more complex than the local OTA upload method under discussion in this forum topic (and certainly more complex than the "turnkey" feature provided by Arduino Cloud), so you should expect a challenge if you decide to go that route.
Although in the case of a problem with "network" port discovery is often system-specific, the problem you are encountering now will not be solved by changing to a different PC. I recommend sticking with your current PC since it is already able to discover the port.
Thanks for having a glanz at this, and I can see now more clear the OTA distinction Arduino cloud is offering to what I am trying.
Below the full output of the upload attempt....
Thanks for your ongoing help.
FQBN: arduino:renesas_uno:unor4wifi
Using board 'unor4wifi' from platform in folder: /Users/sb-mbp/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.5.1
Using core 'arduino' from platform in folder: /Users/sb-mbp/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.5.1
Detecting libraries used...
/Users/sb-mbp/Library/Arduino15/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-g++ -c -w -Os -g3 -fno-use-cxa-atexit -fno-rtti -fno-exceptions -nostdlib -DF_CPU=48000000 -DNO_USB -DBACKTRACE_SUPPORT -DARDUINO_UNOR4_WIFI -std=gnu++17 -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsigned-char -ffunction-sections -fdata-sections -fmessage-length=0 -fno-builtin -w -x c++ -E -CC -DARDUINO=10607 -DPROJECT_NAME="/Users/sb-mbp/Library/Caches/arduino/sketches/31EF15719FDADD509946EC9FBD9C5732/OTA_TEST.ino" -DARDUINO_UNOWIFIR4 -DARDUINO_ARCH_RENESAS_UNO -DARDUINO_ARCH_RENESAS -DARDUINO_FSP -D_XOPEN_SOURCE=700 -mthumb @/Users/sb-mbp/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.5.1/variants/UNOWIFIR4/defines.txt -DCFG_TUSB_MCU=OPT_MCU_RAXXX -I/Users/sb-mbp/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.5.1/cores/arduino/tinyusb -I/Users/sb-mbp/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.5.1/cores/arduino/api/deprecated -I/Users/sb-mbp/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.5.1/cores/arduino/api/deprecated-avr-comp -I/Users/sb-mbp/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.5.1/cores/arduino -I/Users/sb-mbp/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.5.1/variants/UNOWIFIR4 -iprefix/Users/sb-mbp/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.5.1 @/Users/sb-mbp/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.5.1/variants/UNOWIFIR4/includes.txt /Users/sb-mbp/Library/Caches/arduino/sketches/31EF15719FDADD509946EC9FBD9C5732/sketch/OTA_TEST.ino.cpp -o /dev/null
Alternatives for SPI.h: [SPI]
ResolveLibrary(SPI.h)
  -> candidates: [SPI]
/Users/sb-mbp/Library/Arduino15/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-g++ -c -w -Os -g3 -fno-use-cxa-atexit -fno-rtti -fno-exceptions -nostdlib -DF_CPU=48000000 -DNO_USB -DBACKTRACE_SUPPORT -DARDUINO_UNOR4_WIFI -std=gnu++17 -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsigned-char -ffunction-sections -fdata-sections -fmessage-length=0 -fno-builtin -w -x c++ -E -CC -DARDUINO=10607 -DPROJECT_NAME="/Users/sb-mbp/Library/Caches/arduino/sketches/31EF15719FDADD509946EC9FBD9C5732/OTA_TEST.ino" -DARDUINO_UNOWIFIR4 -DARDUINO_ARCH_RENESAS_UNO -DARDUINO_ARCH_RENESAS -DARDUINO_FSP -D_XOPEN_SOURCE=700 -mthumb @/Users/sb-mbp/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.5.1/variants/UNOWIFIR4/defines.txt -DCFG_TUSB_MCU=OPT_MCU_RAXXX -I/Users/sb-mbp/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.5.1/cores/arduino/tinyusb -I/Users/sb-mbp/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.5.1/cores/arduino/api/deprecated -I/Users/sb-mbp/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.5.1/cores/arduino/api/deprecated-avr-comp -I/Users/sb-mbp/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.5.1/cores/arduino -I/Users/sb-mbp/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.5.1/variants/UNOWIFIR4 -I/Users/sb-mbp/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.5.1/libraries/SPI -iprefix/Users/sb-mbp/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.5.1 @/Users/sb-mbp/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.5.1/variants/UNOWIFIR4/includes.txt /Users/sb-mbp/Library/Caches/arduino/sketches/31EF15719FDADD509946EC9FBD9C5732/sketch/OTA_TEST.ino.cpp -o /dev/null
Alternatives for WiFiS3.h: [WiFiS3@0.0.0]
ResolveLibrary(WiFiS3.h)
  -> candidates: [WiFiS3@0.0.0]
/Users/sb-mbp/Library/Arduino15/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-g++ -c -w -Os -g3 -fno-use-cxa-atexit -fno-rtti -fno-exceptions -nostdlib -DF_CPU=48000000 -DNO_USB -DBACKTRACE_SUPPORT -DARDUINO_UNOR4_WIFI -std=gnu++17 -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsigned-char -ffunction-sections -fdata-sections -fmessage-length=0 -fno-builtin -w -x c++ -E -CC -DARDUINO=10607 -DPROJECT_NAME="/Users/sb-mbp/Library/Caches/arduino/sketches/31EF15719FDADD509946EC9FBD9C5732/OTA_TEST.ino" -DARDUINO_UNOWIFIR4 -DARDUINO_ARCH_RENESAS_UNO -DARDUINO_ARCH_RENESAS -DARDUINO_FSP -D_XOPEN_SOURCE=700 -mthumb @/Users/sb-mbp/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.5.1/variants/UNOWIFIR4/defines.txt -DCFG_TUSB_MCU=OPT_MCU_RAXXX -I/Users/sb-mbp/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.5.1/cores/arduino/tinyusb -I/Users/sb-mbp/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.5.1/cores/arduino/api/deprecated -I/Users/sb-mbp/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.5.1/cores/arduino/api/deprecated-avr-comp -I/Users/sb-mbp/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.5.1/cores/arduino -I/Users/sb-mbp/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.5.1/variants/UNOWIFIR4 -I/Users/sb-mbp/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.5.1/libraries/SPI -I/Users/sb-mbp/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.5.1/libraries/WiFiS3/src -iprefix/Users/sb-mbp/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.5.1 @/Users/sb-mbp/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.5.1/variants/UNOWIFIR4/includes.txt /Users/sb-mbp/Library/Caches/arduino/sketches/31EF15719FDADD509946EC9FBD9C5732/sketch/OTA_TEST.ino.cpp -o /dev/null
Alternatives for ArduinoOTA.h: [ArduinoOTA@1.1.0]
ResolveLibrary(ArduinoOTA.h)
  -> candidates: [ArduinoOTA@1.1.0]
/Users/sb-mbp/Library/Arduino15/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-g++ -c -w -Os -g3 -fno-use-cxa-atexit -fno-rtti -fno-exceptions -nostdlib -DF_CPU=48000000 -DNO_USB -DBACKTRACE_SUPPORT -DARDUINO_UNOR4_WIFI -std=gnu++17 -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsigned-char -ffunction-sections -fdata-sections -fmessage-length=0 -fno-builtin -w -x c++ -E -CC -DARDUINO=10607 -DPROJECT_NAME="/Users/sb-mbp/Library/Caches/arduino/sketches/31EF15719FDADD509946EC9FBD9C5732/OTA_TEST.ino" -DARDUINO_UNOWIFIR4 -DARDUINO_ARCH_RENESAS_UNO -DARDUINO_ARCH_RENESAS -DARDUINO_FSP -D_XOPEN_SOURCE=700 -mthumb @/Users/sb-mbp/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.5.1/variants/UNOWIFIR4/defines.txt -DCFG_TUSB_MCU=OPT_MCU_RAXXX -I/Users/sb-mbp/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.5.1/cores/arduino/tinyusb -I/Users/sb-mbp/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.5.1/cores/arduino/api/deprecated -I/Users/sb-mbp/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.5.1/cores/arduino/api/deprecated-avr-comp -I/Users/sb-mbp/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.5.1/cores/arduino -I/Users/sb-mbp/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.5.1/variants/UNOWIFIR4 -I/Users/sb-mbp/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.5.1/libraries/SPI -I/Users/sb-mbp/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.5.1/libraries/WiFiS3/src -I/Users/sb-mbp/Documents/Arduino/libraries/ArduinoOTA/src -iprefix/Users/sb-mbp/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.5.1 @/Users/sb-mbp/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.5.1/variants/UNOWIFIR4/includes.txt /Users/sb-mbp/Library/Caches/arduino/sketches/31EF15719FDADD509946EC9FBD9C5732/sketch/OTA_TEST.ino.cpp -o /dev/null
Alternatives for Wire.h: [Wire]
ResolveLibrary(Wire.h)
  -> candidates: [Wire]
/Users/sb-mbp/Library/Arduino15/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-g++ -c -w -Os -g3 -fno-use-cxa-atexit -fno-rtti -fno-exceptions -nostdlib -DF_CPU=48000000 -DNO_USB -DBACKTRACE_SUPPORT -DARDUINO_UNOR4_WIFI -std=gnu++17 -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsigned-char -ffunction-sections -fdata-sections -fmessage-length=0 -fno-builtin -w -x c++ -E -CC -DARDUINO=10607 -DPROJECT_NAME="/Users/sb-mbp/Library/Caches/arduino/sketches/31EF15719FDADD509946EC9FBD9C5732/OTA_TEST.ino" -DARDUINO_UNOWIFIR4 -DARDUINO_ARCH_RENESAS_UNO -DARDUINO_ARCH_RENESAS -DARDUINO_FSP -D_XOPEN_SOURCE=700 -mthumb @/Users/sb-mbp/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.5.1/variants/UNOWIFIR4/defines.txt -DCFG_TUSB_MCU=OPT_MCU_RAXXX -I/Users/sb-mbp/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.5.1/cores/arduino/tinyusb -I/Users/sb-mbp/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.5.1/cores/arduino/api/deprecated -I/Users/sb-mbp/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.5.1/cores/arduino/api/deprecated-avr-comp -I/Users/sb-mbp/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.5.1/cores/arduino -I/Users/sb-mbp/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.5.1/variants/UNOWIFIR4 -I/Users/sb-mbp/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.5.1/libraries/SPI -I/Users/sb-mbp/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.5.1/libraries/WiFiS3/src -I/Users/sb-mbp/Documents/Arduino/libraries/ArduinoOTA/src -I/Users/sb-mbp/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.5.1/libraries/Wire -iprefix/Users/sb-mbp/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.5.1 @/Users/sb-mbp/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.5.1/variants/UNOWIFIR4/includes.txt /Users/sb-mbp/Library/Caches/arduino/sketches/31EF15719FDADD509946EC9FBD9C5732/sketch/OTA_TEST.ino.cpp -o /dev/null
Alternatives for Adafruit_GFX.h: [Adafruit GFX Library@1.12.2]
ResolveLibrary(Adafruit_GFX.h)
  -> candidates: [Adafruit GFX Library@1.12.2]
/Users/sb-mbp/Library/Arduino15/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-g++ -c -w -Os -g3 -fno-use-cxa-atexit -fno-rtti -fno-exceptions -nostdlib -DF_CPU=48000000 -DNO_USB -DBACKTRACE_SUPPORT -DARDUINO_UNOR4_WIFI -std=gnu++17 -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsigned-char -ffunction-sections -fdata-sections -fmessage-length=0 -fno-builtin -w -x c++ -E -CC -DARDUINO=10607 -DPROJECT_NAME="/Users/sb-mbp/Library/Caches/arduino/sketches/31EF15719FDADD509946EC9FBD9C5732/OTA_TEST.ino" -DARDUINO_UNOWIFIR4 -DARDUINO_ARCH_RENESAS_UNO -DARDUINO_ARCH_RENESAS -DARDUINO_FSP -D_XOPEN_SOURCE=700 -mthumb @/Users/sb-mbp/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.5.1/variants/UNOWIFIR4/defines.txt -DCFG_TUSB_MCU=OPT_MCU_RAXXX -I/Users/sb-mbp/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.5.1/cores/arduino/tinyusb -I/Users/sb-mbp/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.5.1/cores/arduino/api/deprecated -I/Users/sb-mbp/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.5.1/cores/arduino/api/deprecated-avr-comp -I/Users/sb-mbp/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.5.1/cores/arduino -I/Users/sb-mbp/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.5.1/variants/UNOWIFIR4 -I/Users/sb-mbp/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.5.1/libraries/SPI -I/Users/sb-mbp/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.5.1/libraries/WiFiS3/src -I/Users/sb-mbp/Documents/Arduino/libraries/ArduinoOTA/src -I/Users/sb-mbp/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.5.1/libraries/Wire -I/Users/sb-mbp/Documents/Arduino/libraries/Adafruit_GFX_Library -iprefix/Users/sb-mbp/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.5.1 @/Users/sb-mbp/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.5.1/variants/UNOWIFIR4/includes.txt /Users/sb-mbp/Library/Caches/arduino/sketches/31EF15719FDADD509946EC9FBD9C5732/sketch/OTA_TEST.ino.cpp -o /dev/null
Alternatives for Adafruit_I2CDevice.h: [Adafruit BusIO@1.17.3]
ResolveLibrary(Adafruit_I2CDevice.h)
  -> candidates: [Adafruit BusIO@1.17.3]
/Users/sb-mbp/Library/Arduino15/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-g++ -c -w -Os -g3 -fno-use-cxa-atexit -fno-rtti -fno-exceptions -nostdlib -DF_CPU=48000000 -DNO_USB -DBACKTRACE_SUPPORT -DARDUINO_UNOR4_WIFI -std=gnu++17 -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsigned-char -ffunction-sections -fdata-sections -fmessage-length=0 -fno-builtin -w -x c++ -E -CC -DARDUINO=10607 -DPROJECT_NAME="/Users/sb-mbp/Library/Caches/arduino/sketches/31EF15719FDADD509946EC9FBD9C5732/OTA_TEST.ino" -DARDUINO_UNOWIFIR4 -DARDUINO_ARCH_RENESAS_UNO -DARDUINO_ARCH_RENESAS -DARDUINO_FSP -D_XOPEN_SOURCE=700 -mthumb @/Users/sb-mbp/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.5.1/variants/UNOWIFIR4/defines.txt -DCFG_TUSB_MCU=OPT_MCU_RAXXX -I/Users/sb-mbp/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.5.1/cores/arduino/tinyusb -I/Users/sb-mbp/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.5.1/cores/arduino/api/deprecated -I/Users/sb-mbp/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.5.1/cores/arduino/api/deprecated-avr-comp -I/Users/sb-mbp/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.5.1/cores/arduino -I/Users/sb-mbp/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.5.1/variants/UNOWIFIR4 -I/Users/sb-mbp/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.5.1/libraries/SPI -I/Users/sb-mbp/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.5.1/libraries/WiFiS3/src -I/Users/sb-mbp/Documents/Arduino/libraries/ArduinoOTA/src -I/Users/sb-mbp/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.5.1/libraries/Wire -I/Users/sb-mbp/Documents/Arduino/libraries/Adafruit_GFX_Library -I/Users/sb-mbp/Documents/Arduino/libraries/Adafruit_BusIO -iprefix/Users/sb-mbp/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.5.1 @/Users/sb-mbp/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.5.1/variants/UNOWIFIR4/includes.txt /Users/sb-mbp/Library/Caches/arduino/sketches/31EF15719FDADD509946EC9FBD9C5732/sketch/OTA_TEST.ino.cpp -o /dev/null
Alternatives for Adafruit_SSD1306.h: [Adafruit SSD1306@2.5.15]
ResolveLibrary(Adafruit_SSD1306.h)
  -> candidates: [Adafruit SSD1306@2.5.15]
/Users/sb-mbp/Library/Arduino15/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-g++ -c -w -Os -g3 -fno-use-cxa-atexit -fno-rtti -fno-exceptions -nostdlib -DF_CPU=48000000 -DNO_USB -DBACKTRACE_SUPPORT -DARDUINO_UNOR4_WIFI -std=gnu++17 -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsigned-char -ffunction-sections -fdata-sections -fmessage-length=0 -fno-builtin -w -x c++ -E -CC -DARDUINO=10607 -DPROJECT_NAME="/Users/sb-mbp/Library/Caches/arduino/sketches/31EF15719FDADD509946EC9FBD9C5732/OTA_TEST.ino" -DARDUINO_UNOWIFIR4 -DARDUINO_ARCH_RENESAS_UNO -DARDUINO_ARCH_RENESAS -DARDUINO_FSP -D_XOPEN_SOURCE=700 -mthumb @/Users/sb-mbp/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.5.1/variants/UNOWIFIR4/defines.txt -DCFG_TUSB_MCU=OPT_MCU_RAXXX -I/Users/sb-mbp/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.5.1/cores/arduino/tinyusb -I/Users/sb-mbp/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.5.1/cores/arduino/api/deprecated -I/Users/sb-mbp/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.5.1/cores/arduino/api/deprecated-avr-comp -I/Users/sb-mbp/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.5.1/cores/arduino -I/Users/sb-mbp/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.5.1/variants/UNOWIFIR4 -I/Users/sb-mbp/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.5.1/libraries/SPI -I/Users/sb-mbp/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.5.1/libraries/WiFiS3/src -I/Users/sb-mbp/Documents/Arduino/libraries/ArduinoOTA/src -I/Users/sb-mbp/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.5.1/libraries/Wire -I/Users/sb-mbp/Documents/Arduino/libraries/Adafruit_GFX_Library -I/Users/sb-mbp/Documents/Arduino/libraries/Adafruit_BusIO -I/Users/sb-mbp/Documents/Arduino/libraries/Adafruit_SSD1306 -iprefix/Users/sb-mbp/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.5.1 @/Users/sb-mbp/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.5.1/variants/UNOWIFIR4/includes.txt /Users/sb-mbp/Library/Caches/arduino/sketches/31EF15719FDADD509946EC9FBD9C5732/sketch/OTA_TEST.ino.cpp -o /dev/null
Using cached library dependencies for file: /Users/sb-mbp/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.5.1/libraries/SPI/SPI.cpp
Using cached library dependencies for file: /Users/sb-mbp/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.5.1/libraries/WiFiS3/src/Modem.cpp
Using cached library dependencies for file: /Users/sb-mbp/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.5.1/libraries/WiFiS3/src/StringHelpers.cpp
Using cached library dependencies for file: /Users/sb-mbp/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.5.1/libraries/WiFiS3/src/WiFi.cpp
Using cached library dependencies for file: /Users/sb-mbp/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.5.1/libraries/WiFiS3/src/WiFiClient.cpp
Using cached library dependencies for file: /Users/sb-mbp/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.5.1/libraries/WiFiS3/src/WiFiFileSystem.cpp
Using cached library dependencies for file: /Users/sb-mbp/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.5.1/libraries/WiFiS3/src/WiFiSSLClient.cpp
Using cached library dependencies for file: /Users/sb-mbp/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.5.1/libraries/WiFiS3/src/WiFiServer.cpp
Using cached library dependencies for file: /Users/sb-mbp/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.5.1/libraries/WiFiS3/src/WiFiUdp.cpp
Using cached library dependencies for file: /Users/sb-mbp/Documents/Arduino/libraries/ArduinoOTA/src/InternalStorage.cpp
Using cached library dependencies for file: /Users/sb-mbp/Documents/Arduino/libraries/ArduinoOTA/src/InternalStorageAVR.cpp
Using cached library dependencies for file: /Users/sb-mbp/Documents/Arduino/libraries/ArduinoOTA/src/InternalStorageESP.cpp
Using cached library dependencies for file: /Users/sb-mbp/Documents/Arduino/libraries/ArduinoOTA/src/InternalStorageRP2.cpp
Using cached library dependencies for file: /Users/sb-mbp/Documents/Arduino/libraries/ArduinoOTA/src/InternalStorageRenesas.cpp
Using cached library dependencies for file: /Users/sb-mbp/Documents/Arduino/libraries/ArduinoOTA/src/InternalStorageSTM32.cpp
Using cached library dependencies for file: /Users/sb-mbp/Documents/Arduino/libraries/ArduinoOTA/src/OTAStorage.cpp
Using cached library dependencies for file: /Users/sb-mbp/Documents/Arduino/libraries/ArduinoOTA/src/WiFiOTA.cpp
Using cached library dependencies for file: /Users/sb-mbp/Documents/Arduino/libraries/ArduinoOTA/src/utility/r_flash_lp_cf.c
Using cached library dependencies for file: /Users/sb-mbp/Documents/Arduino/libraries/ArduinoOTA/src/utility/rp2_flash_boot.c
Using cached library dependencies for file: /Users/sb-mbp/Documents/Arduino/libraries/ArduinoOTA/src/utility/stm32_flash_boot.c
Using cached library dependencies for file: /Users/sb-mbp/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.5.1/libraries/Wire/Wire.cpp
Using cached library dependencies for file: /Users/sb-mbp/Documents/Arduino/libraries/Adafruit_GFX_Library/Adafruit_GFX.cpp
Using cached library dependencies for file: /Users/sb-mbp/Documents/Arduino/libraries/Adafruit_GFX_Library/Adafruit_GrayOLED.cpp
Using cached library dependencies for file: /Users/sb-mbp/Documents/Arduino/libraries/Adafruit_GFX_Library/Adafruit_SPITFT.cpp
Using cached library dependencies for file: /Users/sb-mbp/Documents/Arduino/libraries/Adafruit_GFX_Library/glcdfont.c
Using cached library dependencies for file: /Users/sb-mbp/Documents/Arduino/libraries/Adafruit_BusIO/Adafruit_BusIO_Register.cpp
Using cached library dependencies for file: /Users/sb-mbp/Documents/Arduino/libraries/Adafruit_BusIO/Adafruit_GenericDevice.cpp
Using cached library dependencies for file: /Users/sb-mbp/Documents/Arduino/libraries/Adafruit_BusIO/Adafruit_I2CDevice.cpp
Using cached library dependencies for file: /Users/sb-mbp/Documents/Arduino/libraries/Adafruit_BusIO/Adafruit_SPIDevice.cpp
Using cached library dependencies for file: /Users/sb-mbp/Documents/Arduino/libraries/Adafruit_SSD1306/Adafruit_SSD1306.cpp
Generating function prototypes...
/Users/sb-mbp/Library/Arduino15/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-g++ -c -w -Os -g3 -fno-use-cxa-atexit -fno-rtti -fno-exceptions -nostdlib -DF_CPU=48000000 -DNO_USB -DBACKTRACE_SUPPORT -DARDUINO_UNOR4_WIFI -std=gnu++17 -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsigned-char -ffunction-sections -fdata-sections -fmessage-length=0 -fno-builtin -w -x c++ -E -CC -DARDUINO=10607 -DPROJECT_NAME="/Users/sb-mbp/Library/Caches/arduino/sketches/31EF15719FDADD509946EC9FBD9C5732/OTA_TEST.ino" -DARDUINO_UNOWIFIR4 -DARDUINO_ARCH_RENESAS_UNO -DARDUINO_ARCH_RENESAS -DARDUINO_FSP -D_XOPEN_SOURCE=700 -mthumb @/Users/sb-mbp/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.5.1/variants/UNOWIFIR4/defines.txt -DCFG_TUSB_MCU=OPT_MCU_RAXXX -I/Users/sb-mbp/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.5.1/cores/arduino/tinyusb -I/Users/sb-mbp/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.5.1/cores/arduino/api/deprecated -I/Users/sb-mbp/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.5.1/cores/arduino/api/deprecated-avr-comp -I/Users/sb-mbp/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.5.1/cores/arduino -I/Users/sb-mbp/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.5.1/variants/UNOWIFIR4 -I/Users/sb-mbp/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.5.1/libraries/SPI -I/Users/sb-mbp/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.5.1/libraries/WiFiS3/src -I/Users/sb-mbp/Documents/Arduino/libraries/ArduinoOTA/src -I/Users/sb-mbp/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.5.1/libraries/Wire -I/Users/sb-mbp/Documents/Arduino/libraries/Adafruit_GFX_Library -I/Users/sb-mbp/Documents/Arduino/libraries/Adafruit_BusIO -I/Users/sb-mbp/Documents/Arduino/libraries/Adafruit_SSD1306 -iprefix/Users/sb-mbp/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.5.1 @/Users/sb-mbp/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.5.1/variants/UNOWIFIR4/includes.txt /Users/sb-mbp/Library/Caches/arduino/sketches/31EF15719FDADD509946EC9FBD9C5732/sketch/OTA_TEST.ino.cpp -o /private/var/folders/51/98w_1x6j7qgg6ly1tx699n0r0000gp/T/1749796786/sketch_merged.cpp
/Users/sb-mbp/Library/Arduino15/packages/builtin/tools/ctags/5.8-arduino11/ctags -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives /private/var/folders/51/98w_1x6j7qgg6ly1tx699n0r0000gp/T/1749796786/sketch_merged.cpp
Compiling sketch...
/Users/sb-mbp/Library/Arduino15/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-g++ -c -Os -g3 -fno-use-cxa-atexit -fno-rtti -fno-exceptions -MMD -nostdlib -DF_CPU=48000000 -DNO_USB -DBACKTRACE_SUPPORT -DARDUINO_UNOR4_WIFI -MMD -std=gnu++17 -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsigned-char -ffunction-sections -fdata-sections -fmessage-length=0 -fno-builtin -DARDUINO=10607 "-DPROJECT_NAME=\"/Users/sb-mbp/Library/Caches/arduino/sketches/31EF15719FDADD509946EC9FBD9C5732/OTA_TEST.ino\"" -DARDUINO_UNOWIFIR4 -DARDUINO_ARCH_RENESAS_UNO -DARDUINO_ARCH_RENESAS -DARDUINO_FSP -D_XOPEN_SOURCE=700 -mthumb @/Users/sb-mbp/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.5.1/variants/UNOWIFIR4/defines.txt -DCFG_TUSB_MCU=OPT_MCU_RAXXX -I/Users/sb-mbp/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.5.1/cores/arduino/tinyusb -I/Users/sb-mbp/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.5.1/cores/arduino/api/deprecated -I/Users/sb-mbp/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.5.1/cores/arduino/api/deprecated-avr-comp -I/Users/sb-mbp/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.5.1/cores/arduino -I/Users/sb-mbp/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.5.1/variants/UNOWIFIR4 -I/Users/sb-mbp/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.5.1/libraries/SPI -I/Users/sb-mbp/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.5.1/libraries/WiFiS3/src -I/Users/sb-mbp/Documents/Arduino/libraries/ArduinoOTA/src -I/Users/sb-mbp/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.5.1/libraries/Wire -I/Users/sb-mbp/Documents/Arduino/libraries/Adafruit_GFX_Library -I/Users/sb-mbp/Documents/Arduino/libraries/Adafruit_BusIO -I/Users/sb-mbp/Documents/Arduino/libraries/Adafruit_SSD1306 -iprefix/Users/sb-mbp/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.5.1 @/Users/sb-mbp/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.5.1/variants/UNOWIFIR4/includes.txt /Users/sb-mbp/Library/Caches/arduino/sketches/31EF15719FDADD509946EC9FBD9C5732/sketch/OTA_TEST.ino.cpp -o /Users/sb-mbp/Library/Caches/arduino/sketches/31EF15719FDADD509946EC9FBD9C5732/sketch/OTA_TEST.ino.cpp.o
Compiling libraries...
Compiling library "SPI"
Using previously compiled file: /Users/sb-mbp/Library/Caches/arduino/sketches/31EF15719FDADD509946EC9FBD9C5732/libraries/SPI/SPI.cpp.o
Compiling library "WiFiS3"
Using previously compiled file: /Users/sb-mbp/Library/Caches/arduino/sketches/31EF15719FDADD509946EC9FBD9C5732/libraries/WiFiS3/StringHelpers.cpp.o
Using previously compiled file: /Users/sb-mbp/Library/Caches/arduino/sketches/31EF15719FDADD509946EC9FBD9C5732/libraries/WiFiS3/Modem.cpp.o
Using previously compiled file: /Users/sb-mbp/Library/Caches/arduino/sketches/31EF15719FDADD509946EC9FBD9C5732/libraries/WiFiS3/WiFiFileSystem.cpp.o
Using previously compiled file: /Users/sb-mbp/Library/Caches/arduino/sketches/31EF15719FDADD509946EC9FBD9C5732/libraries/WiFiS3/WiFi.cpp.o
Using previously compiled file: /Users/sb-mbp/Library/Caches/arduino/sketches/31EF15719FDADD509946EC9FBD9C5732/libraries/WiFiS3/WiFiClient.cpp.o
Using previously compiled file: /Users/sb-mbp/Library/Caches/arduino/sketches/31EF15719FDADD509946EC9FBD9C5732/libraries/WiFiS3/WiFiSSLClient.cpp.o
Using previously compiled file: /Users/sb-mbp/Library/Caches/arduino/sketches/31EF15719FDADD509946EC9FBD9C5732/libraries/WiFiS3/WiFiServer.cpp.o
Using previously compiled file: /Users/sb-mbp/Library/Caches/arduino/sketches/31EF15719FDADD509946EC9FBD9C5732/libraries/WiFiS3/WiFiUdp.cpp.o
Compiling library "ArduinoOTA"
Using previously compiled file: /Users/sb-mbp/Library/Caches/arduino/sketches/31EF15719FDADD509946EC9FBD9C5732/libraries/ArduinoOTA/InternalStorage.cpp.o
Using previously compiled file: /Users/sb-mbp/Library/Caches/arduino/sketches/31EF15719FDADD509946EC9FBD9C5732/libraries/ArduinoOTA/InternalStorageRP2.cpp.o
Using previously compiled file: /Users/sb-mbp/Library/Caches/arduino/sketches/31EF15719FDADD509946EC9FBD9C5732/libraries/ArduinoOTA/utility/r_flash_lp_cf.c.o
Using previously compiled file: /Users/sb-mbp/Library/Caches/arduino/sketches/31EF15719FDADD509946EC9FBD9C5732/libraries/ArduinoOTA/WiFiOTA.cpp.o
Using previously compiled file: /Users/sb-mbp/Library/Caches/arduino/sketches/31EF15719FDADD509946EC9FBD9C5732/libraries/ArduinoOTA/OTAStorage.cpp.o
Using previously compiled file: /Users/sb-mbp/Library/Caches/arduino/sketches/31EF15719FDADD509946EC9FBD9C5732/libraries/ArduinoOTA/InternalStorageRenesas.cpp.o
Using previously compiled file: /Users/sb-mbp/Library/Caches/arduino/sketches/31EF15719FDADD509946EC9FBD9C5732/libraries/ArduinoOTA/InternalStorageESP.cpp.o
Using previously compiled file: /Users/sb-mbp/Library/Caches/arduino/sketches/31EF15719FDADD509946EC9FBD9C5732/libraries/ArduinoOTA/InternalStorageSTM32.cpp.o
Using previously compiled file: /Users/sb-mbp/Library/Caches/arduino/sketches/31EF15719FDADD509946EC9FBD9C5732/libraries/ArduinoOTA/InternalStorageAVR.cpp.o
Using previously compiled file: /Users/sb-mbp/Library/Caches/arduino/sketches/31EF15719FDADD509946EC9FBD9C5732/libraries/ArduinoOTA/utility/stm32_flash_boot.c.o
Using previously compiled file: /Users/sb-mbp/Library/Caches/arduino/sketches/31EF15719FDADD509946EC9FBD9C5732/libraries/ArduinoOTA/utility/rp2_flash_boot.c.o
Using previously compiled file: /Users/sb-mbp/Library/Caches/arduino/sketches/31EF15719FDADD509946EC9FBD9C5732/libraries/ArduinoOTA/ArduinoOTA.a
Compiling library "Wire"
Using previously compiled file: /Users/sb-mbp/Library/Caches/arduino/sketches/31EF15719FDADD509946EC9FBD9C5732/libraries/Wire/Wire.cpp.o
Compiling library "Adafruit GFX Library"
Using previously compiled file: /Users/sb-mbp/Library/Caches/arduino/sketches/31EF15719FDADD509946EC9FBD9C5732/libraries/Adafruit_GFX_Library/glcdfont.c.o
Using previously compiled file: /Users/sb-mbp/Library/Caches/arduino/sketches/31EF15719FDADD509946EC9FBD9C5732/libraries/Adafruit_GFX_Library/Adafruit_GFX.cpp.o
Using previously compiled file: /Users/sb-mbp/Library/Caches/arduino/sketches/31EF15719FDADD509946EC9FBD9C5732/libraries/Adafruit_GFX_Library/Adafruit_GrayOLED.cpp.o
Using previously compiled file: /Users/sb-mbp/Library/Caches/arduino/sketches/31EF15719FDADD509946EC9FBD9C5732/libraries/Adafruit_GFX_Library/Adafruit_SPITFT.cpp.o
Compiling library "Adafruit BusIO"
Using previously compiled file: /Users/sb-mbp/Library/Caches/arduino/sketches/31EF15719FDADD509946EC9FBD9C5732/libraries/Adafruit_BusIO/Adafruit_GenericDevice.cpp.o
Using previously compiled file: /Users/sb-mbp/Library/Caches/arduino/sketches/31EF15719FDADD509946EC9FBD9C5732/libraries/Adafruit_BusIO/Adafruit_BusIO_Register.cpp.o
Using previously compiled file: /Users/sb-mbp/Library/Caches/arduino/sketches/31EF15719FDADD509946EC9FBD9C5732/libraries/Adafruit_BusIO/Adafruit_SPIDevice.cpp.o
Using previously compiled file: /Users/sb-mbp/Library/Caches/arduino/sketches/31EF15719FDADD509946EC9FBD9C5732/libraries/Adafruit_BusIO/Adafruit_I2CDevice.cpp.o
Compiling library "Adafruit SSD1306"
Using previously compiled file: /Users/sb-mbp/Library/Caches/arduino/sketches/31EF15719FDADD509946EC9FBD9C5732/libraries/Adafruit_SSD1306/Adafruit_SSD1306.cpp.o
Compiling core...
Using previously compiled file: /Users/sb-mbp/Library/Caches/arduino/sketches/31EF15719FDADD509946EC9FBD9C5732/core/tmp_gen_c_files/common_data.c.o
Using previously compiled file: /Users/sb-mbp/Library/Caches/arduino/sketches/31EF15719FDADD509946EC9FBD9C5732/core/tmp_gen_c_files/pin_data.c.o
Using previously compiled file: /Users/sb-mbp/Library/Caches/arduino/sketches/31EF15719FDADD509946EC9FBD9C5732/core/variant.cpp.o
Using previously compiled file: /Users/sb-mbp/Library/Caches/arduino/sketches/31EF15719FDADD509946EC9FBD9C5732/core/tmp_gen_c_files/main.c.o
Using precompiled core: /Users/sb-mbp/Library/Caches/arduino/cores/arduino_renesas_uno_unor4wifi_d5cc7ff8a07906d1e5442bb5cb8a169a/core.a
Linking everything together...
/Users/sb-mbp/Library/Arduino15/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-g++ -Wl,--gc-sections --specs=nosys.specs -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -o /Users/sb-mbp/Library/Caches/arduino/sketches/31EF15719FDADD509946EC9FBD9C5732/OTA_TEST.ino.elf -L/Users/sb-mbp/Library/Caches/arduino/sketches/31EF15719FDADD509946EC9FBD9C5732 -L/Users/sb-mbp/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.5.1/variants/UNOWIFIR4 -T/Users/sb-mbp/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.5.1/variants/UNOWIFIR4/fsp.ld /Users/sb-mbp/Library/Caches/arduino/sketches/31EF15719FDADD509946EC9FBD9C5732/sketch/OTA_TEST.ino.cpp.o /Users/sb-mbp/Library/Caches/arduino/sketches/31EF15719FDADD509946EC9FBD9C5732/libraries/SPI/SPI.cpp.o /Users/sb-mbp/Library/Caches/arduino/sketches/31EF15719FDADD509946EC9FBD9C5732/libraries/WiFiS3/Modem.cpp.o /Users/sb-mbp/Library/Caches/arduino/sketches/31EF15719FDADD509946EC9FBD9C5732/libraries/WiFiS3/StringHelpers.cpp.o /Users/sb-mbp/Library/Caches/arduino/sketches/31EF15719FDADD509946EC9FBD9C5732/libraries/WiFiS3/WiFi.cpp.o /Users/sb-mbp/Library/Caches/arduino/sketches/31EF15719FDADD509946EC9FBD9C5732/libraries/WiFiS3/WiFiClient.cpp.o /Users/sb-mbp/Library/Caches/arduino/sketches/31EF15719FDADD509946EC9FBD9C5732/libraries/WiFiS3/WiFiFileSystem.cpp.o /Users/sb-mbp/Library/Caches/arduino/sketches/31EF15719FDADD509946EC9FBD9C5732/libraries/WiFiS3/WiFiSSLClient.cpp.o /Users/sb-mbp/Library/Caches/arduino/sketches/31EF15719FDADD509946EC9FBD9C5732/libraries/WiFiS3/WiFiServer.cpp.o /Users/sb-mbp/Library/Caches/arduino/sketches/31EF15719FDADD509946EC9FBD9C5732/libraries/WiFiS3/WiFiUdp.cpp.o /Users/sb-mbp/Library/Caches/arduino/sketches/31EF15719FDADD509946EC9FBD9C5732/libraries/ArduinoOTA/ArduinoOTA.a /Users/sb-mbp/Library/Caches/arduino/sketches/31EF15719FDADD509946EC9FBD9C5732/libraries/Wire/Wire.cpp.o /Users/sb-mbp/Library/Caches/arduino/sketches/31EF15719FDADD509946EC9FBD9C5732/libraries/Adafruit_GFX_Library/Adafruit_GFX.cpp.o /Users/sb-mbp/Library/Caches/arduino/sketches/31EF15719FDADD509946EC9FBD9C5732/libraries/Adafruit_GFX_Library/Adafruit_GrayOLED.cpp.o /Users/sb-mbp/Library/Caches/arduino/sketches/31EF15719FDADD509946EC9FBD9C5732/libraries/Adafruit_GFX_Library/Adafruit_SPITFT.cpp.o /Users/sb-mbp/Library/Caches/arduino/sketches/31EF15719FDADD509946EC9FBD9C5732/libraries/Adafruit_GFX_Library/glcdfont.c.o /Users/sb-mbp/Library/Caches/arduino/sketches/31EF15719FDADD509946EC9FBD9C5732/libraries/Adafruit_BusIO/Adafruit_BusIO_Register.cpp.o /Users/sb-mbp/Library/Caches/arduino/sketches/31EF15719FDADD509946EC9FBD9C5732/libraries/Adafruit_BusIO/Adafruit_GenericDevice.cpp.o /Users/sb-mbp/Library/Caches/arduino/sketches/31EF15719FDADD509946EC9FBD9C5732/libraries/Adafruit_BusIO/Adafruit_I2CDevice.cpp.o /Users/sb-mbp/Library/Caches/arduino/sketches/31EF15719FDADD509946EC9FBD9C5732/libraries/Adafruit_BusIO/Adafruit_SPIDevice.cpp.o /Users/sb-mbp/Library/Caches/arduino/sketches/31EF15719FDADD509946EC9FBD9C5732/libraries/Adafruit_SSD1306/Adafruit_SSD1306.cpp.o /Users/sb-mbp/Library/Caches/arduino/sketches/31EF15719FDADD509946EC9FBD9C5732/core/tmp_gen_c_files/common_data.c.o /Users/sb-mbp/Library/Caches/arduino/sketches/31EF15719FDADD509946EC9FBD9C5732/core/tmp_gen_c_files/main.c.o /Users/sb-mbp/Library/Caches/arduino/sketches/31EF15719FDADD509946EC9FBD9C5732/core/tmp_gen_c_files/pin_data.c.o /Users/sb-mbp/Library/Caches/arduino/sketches/31EF15719FDADD509946EC9FBD9C5732/core/variant.cpp.o -Wl,--whole-archive -Wl,--start-group /Users/sb-mbp/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.5.1/variants/UNOWIFIR4/libs/libfsp.a /Users/sb-mbp/Library/Caches/arduino/sketches/31EF15719FDADD509946EC9FBD9C5732/../../cores/arduino_renesas_uno_unor4wifi_d5cc7ff8a07906d1e5442bb5cb8a169a/core.a -Wl,--no-whole-archive --specs=nano.specs -lstdc++ -lsupc++ -lm -lc -lgcc -lnosys -Wl,--end-group -Wl,-Map,/Users/sb-mbp/Library/Caches/arduino/sketches/31EF15719FDADD509946EC9FBD9C5732/OTA_TEST.ino.map
/Users/sb-mbp/Library/Arduino15/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-objcopy -O binary -j .text -j .data /Users/sb-mbp/Library/Caches/arduino/sketches/31EF15719FDADD509946EC9FBD9C5732/OTA_TEST.ino.elf /Users/sb-mbp/Library/Caches/arduino/sketches/31EF15719FDADD509946EC9FBD9C5732/OTA_TEST.ino.bin
/Users/sb-mbp/Library/Arduino15/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-objcopy -O ihex -j .text -j .data /Users/sb-mbp/Library/Caches/arduino/sketches/31EF15719FDADD509946EC9FBD9C5732/OTA_TEST.ino.elf /Users/sb-mbp/Library/Caches/arduino/sketches/31EF15719FDADD509946EC9FBD9C5732/OTA_TEST.ino.hex
Using library SPI in folder: /Users/sb-mbp/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.5.1/libraries/SPI (legacy)
Using library WiFiS3 at version 0.0.0 in folder: /Users/sb-mbp/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.5.1/libraries/WiFiS3
Using library ArduinoOTA at version 1.1.0 in folder: /Users/sb-mbp/Documents/Arduino/libraries/ArduinoOTA
Using library Wire in folder: /Users/sb-mbp/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.5.1/libraries/Wire (legacy)
Using library Adafruit GFX Library at version 1.12.2 in folder: /Users/sb-mbp/Documents/Arduino/libraries/Adafruit_GFX_Library
Using library Adafruit BusIO at version 1.17.3 in folder: /Users/sb-mbp/Documents/Arduino/libraries/Adafruit_BusIO
Using library Adafruit SSD1306 at version 2.5.15 in folder: /Users/sb-mbp/Documents/Arduino/libraries/Adafruit_SSD1306
/Users/sb-mbp/Library/Arduino15/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-size -A /Users/sb-mbp/Library/Caches/arduino/sketches/31EF15719FDADD509946EC9FBD9C5732/OTA_TEST.ino.elf
Sketch uses 88072 bytes (33%) of program storage space. Maximum is 262144 bytes.
Global variables use 12812 bytes (39%) of dynamic memory, leaving 19956 bytes for local variables. Maximum is 32768 bytes.
it look like you didnโ€™t enable the verbose output
There was no output unless I have done (clicked) something wrong....
Tell me and I retry....
Meanwhile I have played around with this situation further and figurer following out....
Let me know if this is correct or faulty in my thoughts.
(BTY - I am German so forgive my grammar and bad english)
The WiFiS3 library in the code is specifically designed to act as the communication bridge between the main Renesas chip and the ESP32-S3 Wi-Fi module,right?
It provides the functions that allow me to use Wi-Fi, such as WiFi.begin() and WiFi.localIP(), by communicating with the ESP32-S3 chip behind the scenes, right?
Could this be the problem why I don't get a port assigned back and why the OTA uploads to the Arduino Uno R4 Wifi don't work?
Meaning, would I need a modified WiFiS3 library to make progress?
The core issue with my OTA uploads is that the ArduinoOTA.begin() function in the WiFiS3 library requires a valid, assigned IP address. If my WiFi.begin() call fails to get an IP address, the board can't establish a network connection, and therefore, it can't listen for OTA updates, right?
My code has a timeout loop to wait for a valid IP address:
  int attempts = 0;
    display.print(".");
    display.display();
    attempts++;
...so if this loop reaches max_attempts without the WiFi.status() becoming WL_CONNECTED and a valid IP being assigned, my code will exit the loop and proceed to the else block:
    display.display();
In this scenario, isConnected remains false, and the ArduinoOTA.handle() function in the loop() is never called.
ERGO - without the ArduinoOTA.handle() being called, the board can't receive or process OTA updates, which is why my OTA uploads don't work and you don't see a port assigned.
The root cause is a failed Wi-Fi connection.
The OTA functionality itself is not the problem; it's a symptom of the Wi-Fi connection failure.
Hope this makes all sense, I am still amazed if you are able to make sense of it and follow me, I feel like I am learning here new things everytime I press upload :smiley:
your problem is with the IDE 2, not with the sketch or libraries. I hope Per (ptillisch) can help you
I'm going to ask you to provide some additional information that might help us to identify the problem.
Please do this:
  1. Close all Arduino IDE windows if the IDE is already running.
  2. Open macOS Launchpad.
  3. Type terminal in the "Search" field.
  4. Click on the "Terminal" icon.
    A "Terminal" window will open.
  5. Type the following command in the Terminal window:
    ls /Users/sb-mbp/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.5.1
  6. Press the Enter key.
  7. Press the Command+A keyboard shortcut.
    This will select all the text in the Terminal window.
  8. Press the Command+C keyboard shortcut.
    This will copy the selected text to the clipboard.
  9. Open a reply here on this forum topic by clicking the "Reply" button.
  10. Click the <CODE/> icon on the post composer toolbar.
    This will add the forum's code block markup (```) to your reply to make sure the output is correctly formatted.
  11. Press the Command+V keyboard shortcut.
    This will paste the output into the code block.
  12. Move the cursor outside of the code block markup before you add any additional text to your reply.
  13. Click the "Reply" button to publish the post.
Please let us know if you have any questions or problems while following those instructions.
below
Last login: Wed Sep 24 06:31:34 on console
SB-MBP@SB-MBP ~ % ls /Users/sb-mbp/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.5.1
LICENSE			debugger		post_install.bat
README.md		drivers			post_install.sh
boards.txt		installed.json		programmers.txt
bootloaders		libraries		svd
cores			platform.txt		variants
SB-MBP@SB-MBP ~ %
Hi Juraj, I have now 4 variation of code floating on my pc and two work with IP and no port and not getting Arduino OTA running, and two working with 0.0.0.0 IP return but Ardino OTA up and running.
I was thinking the same last night, what you mentioned and there are lots of other software solution out there, may be I should explore those with the code there and see if I get it to work with those.||Thanks
for Uno R4 WiFi your ready to use OTA options are only Arduino Cloud OTA and ArduinoOTA.
but you could try IDE 1
OK, we can see from this directory listing that, despite your claim to the contrary, you did not in fact place the platform.local.txt file in the "boards package installation folder" per the instructions in the ArduinoOTA library's documentation:
You must have put the file somewhere else. So put the file in the correct folder, which is at the following path on your hard drive:
:red_exclamation_mark: The /Users/sb-mbp/Library folder is hidden by default. You can make it visible by pressing the Command+Shift+. keyboard shortcut.
After that, restart Arduino IDE and then try uploading once again. Hopefully it will work as expected.
Must have missplaced it by error without noticing, thanks.
Question...I don't have the Arduino15 folder, is that normal since it is not a Windows machine?
I do have though this one where the file is placed...
I suppose this is wrong then...?
You do have it. This is proven by the fact that you were able to provide a directory listing of the contents of a subfolder:
The reason you don't think you have one is likely the thing I mentioned in my previous reply:
Yes, that is wrong. That is your Arduino sketchbook folder, where libraries are installed, and where you can store sketches.
Add a delay before the ArduinoOTA.begin(WiFi.localIP(), "Arduino", "password", InternalStorage); line in your sketch. I found a 1000 ms delay was sufficient:
Thanks will add tonight the delay.
And I reinstalled the IDE from the application folder rather the download folder.
Now I can see the Arduino15 folder and else. I hope I can let it sorted now. I report back. Thanks for all the support.
KR
Sebastjan
Good evening, on my side of the globe....
I sorted the correct installation out....
I placed the platform.local.txt as needed....
Latest Code now...
#include <SPI.h>
#include <WiFiS3.h>
// OLED Libraries
#include <Wire.h>
// OLED parameters
//  CONFIGURATION
const char* otaPassword = "Password";// OTA password
//---SETUP---
  // OLED init
    while (true) {
      delay(250);
      delay(250);
  display.display();
    while (true) {
      delay(750);
      delay(250);
 // Start WiFi
  //The loop now has a timeout to prevent an infinite block.
  int max_attempts = 15; // 15 attempts with 1-second delay = 15 seconds max wait
  int attempts = 0;
    display.display();
    attempts++;
    isConnected = true;
    ArduinoOTA.begin(WiFi.localIP(), "Arduino", otaPassword, InternalStorage);
    display.println();
    display.display();
    display.display();{}
//  LOOP
  if (isConnected) {
    ArduinoOTA.poll(); // UNO R4 WiFi requires poll() instead of handle()
  // Example: blink LED
Verbose....gives only one error now...
Failed uploading: cannot execute upload tool: fork/exec {runtime.tools.arduinoOTA.path}/bin/arduinoOTA: no such file or directory
I struggle to understand where this should be?
only ArduinoOTA folder I have I see here....
Any ideas what I am missing?
The Library is installed on the latest version.
Would I also need the Helper?
Board Manager installed...below screenshot - next post.
Appreciate your feedbacks, thanks.
KR
Sebastjan
====== LIMITED TO 3 replies o.0 ======
Update now is.....
Almost.... with USB-C upload NO PROLEM...
Without USB-C I can see the OTA running and the IP in the bottom left corner of the IDE saying connected...
BUT THEN....
out of the blue, it sometimes droppes off for now reason, and reconnects.
I checked in Terminal and pinged the board 192.168.1.58....
64 bytes from 192.168.1.58: icmp_seq=14 ttl=255 time=407.229 ms
64 bytes from 192.168.1.58: icmp_seq=15 ttl=255 time=201.857 ms
64 bytes from 192.168.1.58: icmp_seq=16 ttl=255 time=124.984 ms
Request timeout for icmp_seq 17
64 bytes from 192.168.1.58: icmp_seq=17 ttl=255 time=1031.641 ms
64 bytes from 192.168.1.58: icmp_seq=18 ttl=255 time=382.787 ms
There is randomly a timeout dropping the connection.
This, the intermittent connectivity I observe is almost certainly the root cause of the "Failed uploading: no upload port provided" error, gut feeling, when trying to use OTA.
Ideas?
I did some more digging.
As it works with the USB cable, the code functions stable and provides an IP incl. port 3232 number.
so my next logical step would be, since I have ruled out
code blocking, signal strength, and general USB power/cable issues (by trying multiple power sources/cables and testing nearby), the intermittent connection is almost certainly a network configuration issue specific to my Netgear Orbi.
I will for now keep developing the code and transmitting it with the USB-cable, and work on the side on that Network-Issue.
Thanks all.
OK, this is progress! The "arduinoOTA" referenced in the error message is a tool that performs the "OTA" upload. Despite having a similar name, this is completely separate from Juraj's "ArduinoOTA" library.
Normally all the tools that are required by a boards platform will be automatically installed via the Arduino IDE Boards Manager along with the platform. However, because the "Arduino UNO R4 Boards" platform that adds support to Arduino IDE for the UNO R4 WiFi board is not configured for OTA uploads, the developers of the platform did not specify a dependency on the tool.
This normally isn't a problem because the arduinoOTA tool is a dependency of the foundational "Arduino AVR Boards" platform, which Arduino IDE automatically installs. So the arduinoOTA tool is incidentally installed on most people's systems. I guess you uninstalled Arduino AVR Boards, and thus also uninstalled the arduinoOTA tool. The easiest way to get the tool back is to install the Arduino AVR Boards platform. I'll provide instructions you can follow to do that:
  1. Select Tools > Board > Boards Manager... from the Arduino IDE menus to open the "Boards Manager" view in the left side panel.
  2. Find the "Arduino AVR Boards" entry in the list of boards platforms.
  3. Click the "INSTALL" button at the bottom of the entry.
  4. Wait for the installation process to finish, as indicated by a notification at the bottom right corner of the Arduino IDE window:
    Successfully installed platform ...
After doing that, try the upload again. Hopefully this time everything will work as expected.
Here I am, a few days back, and I am close to growing a beard like Gandalf.
I finally, so I think, managed to upload the code via Arduino IDE 2.3.6 to my Arduino UNO R4 WiFi via ArduinoOTA.
Flawless, not at all and there are still some errors I will share below. But it seems to work and it has been a journey, fiddling around inside the platform.local.txt file, the code, and I don't want to even go there what I all had to check and sort out on my own Router (Home-Network).
I can recommend to anyone, ping the arduino (mine was on 192.168.1.58),
observe if you have high latencies and large fluctuations.
Observe and see if you have sudden connection drops within those pings.
I had these and they where issues of my own home-network and need to be overcome first to resolve the problem with no port available for the upload.
Once I have ironed those out, I had to change my code slightly, see blow and add a time delay to the platform.local.txt file.
See below the version that works for me.
Last remaining problem, as it seems now, is the ArduinoOTA.
Which I will tackle the next few days and report back.
But man, I am happy I can transfer now something to it.
 // Standard/Built-in Libraries:
#include <SPI.h>        // enables Serial Peripheral Interface
#include <WiFiS3.h>     // Handles ESP32-S3 onboard
// Specific/Utility Headers: // A hardware-specific file from an installed library
#include "InternalStorageRenesas.h" // OTA dependency placed near ArduinoOTA
// Secrets:
#include "arduino_secrets.h" // A user-created file in the same sketch folder
// OLED Libraries
#include <Wire.h>
#include <Adafruit_GFX.h> // OLED Libraries
#include <Adafruit_SSD1306.h> // OLED Libraries
// OLED parameters
//  CONFIGURATION
//---SETUP---
  // OLED init
    while (true) {
      delay(250);
      delay(250);
  display.display();
    while (true) {
      delay(750);
      delay(250);
 // Start WiFi
  int attempts = 0;
    display.display();
    attempts++;
    isConnected = true;
    display.println();
    display.print("IP:");
    display.print("Firmware:");
    display.println(WiFi.firmwareVersion());
    display.display();
//  LOOP
  if (isConnected) {
    // Always call poll() as frequently as possible
  // Example: blink LED using a timer instead of delay()
  static unsigned long lastBlink = 0;
  if (millis() - lastBlink >= 500) {
    digitalWrite(LED_BUILTIN, !digitalRead(LED_BUILTIN));
    lastBlink = millis();
Here the updated platform.local.txt file....
# This configuration file supports the general ArduinoOTA library https://github.com/jandrassy/ArduinoOTA
#IDE 1
tools.bossac.network_cmd={runtime.tools.arduinoOTA.path}/bin/arduinoOTA
tools.bossac.upload.network_pattern="{network_cmd}" -t 100 -address {serial.port} -port 65280 -username arduino -password "{network.password}" -sketch "{build.path}/{build.project_name}.bin" -upload /sketch -b
tools.dfu-util.network_cmd={runtime.tools.arduinoOTA.path}/bin/arduinoOTA
tools.dfu-util.upload.network_pattern="{network_cmd}" -address {serial.port} -port 65280 -username arduino -password "{network.password}" -sketch "{build.path}/{build.project_name}.bin" -upload /sketch -b
#IDE 2 - RE-ENABLED AND CORRECTED
upload.tool.network=arduino_ota
tools.arduino_ota.cmd={runtime.tools.arduinoOTA.path}/bin/arduinoOTA
tools.arduino_ota.upload.field.password=Password
tools.arduino_ota.upload.field.password.secret=true
tools.arduino_ota.upload.pattern="{cmd}" -t 100 -address "{serial.port}" -port 65280 -username arduino -password "{upload.field.password}" -sketch "{build.path}/{build.project_name}.bin" -upload /sketch -b
## arduinoOTA as programmer. add entries with {ip} into programmers.txt
tools.arduinoOTA.cmd={runtime.tools.arduinoOTA.path}/bin/arduinoOTA
tools.arduinoOTA.program.params.verbose=
tools.arduinoOTA.program.params.quiet=
tools.arduinoOTA.program.pattern="{cmd}" -t 100 -v -address {ip} -port 65280 -username arduino -password password -sketch "{build.path}/{build.project_name}.bin" -upload /sketch -b
Remaining error, verbose file...
FQBN.txt (296.9 KB)
I have isolated the problem!
The output clearly shows that the platform.local.txt file is now working correctly, but the underlying issue is a fatal error within the arduinoOTA tool itself on my specific macOS version.
Here is the key line demonstrating the successful configuration:
"/Users/sb-mbp/Library/Arduino15/packages/arduino/tools/arduinoOTA/1.3.0/bin/arduinoOTA" -t 100 -address "192.168.1.58" -port 65280 -username arduino -password "Password" -sketch "/Users/sb-mbp/Library/Caches/arduino/sketches/ABA440E62BE961167BFBD3DE5BC823BE/2_OTA_R4_solution_TEST.ino.bin" -upload /sketch -b
This proves to me,...
  1. The Arduino IDE is correctly reading my platform.local.txt.
  2. It is correctly building the full upload command.
  3. It is successfully substituting the IP address (192.168.1.58).
The error immediately following this command is:
fatal error: runtime: bsdthread_register error
This is an issue where the Go executable (arduinoOTA) cannot initialize necessary threading components in my macOS environment.
Since I have already reinstalled the boards core, which should have updated or fixed this tool, the issue is likely due to an incompatibility between the specific Go version used to compile the arduinoOTA tool and my older or specific macOS version.
Old, yes, time to upgrade to a new PC...:smiley:
