ArduinoSound.h plus MKRZero - do you need to use an I2S breakout board?
Hello
I have downloaded the ArduinoSound.h library and am looking to base a program off the WavePlayer example
The WavePlayer example uses an I2S amp breakout board, but I would think this would be possible without that breakout board using the DAC on the MKRZERO? I can't tell from the ArduinoAudio.h documentation if this is possible.
WavePlayback here:
 This reads a wave file from an SD card and plays it using the I2S interface to
 a MAX08357 I2S Amp Breakout board.
 Circuit:
 * Arduino/Genuino Zero, MKRZero or MKR1000 board
 * SD breakout or shield connected
 * MAX08357:
   * GND connected GND
   * VIN connected 5V
   * LRC connected to pin 0 (Zero) or pin 3 (MKR1000, MKRZero)
   * BCLK connected to pin 1 (Zero) or pin 2 (MKR1000, MKRZero)
   * DIN connected to pin 9 (Zero) or pin A6 (MKR1000, MKRZero)
 created 15 November 2016
 by Sandeep Mistry
#include <SD.h>
#include <ArduinoSound.h>
// filename of wave file to play
const char filename[] = "MUSIC.WAV";
// variable representing the Wave File
SDWaveFile waveFile;
  while (!Serial) {
    ; // wait for serial port to connect. Needed for native USB port only
  // setup the SD card, depending on your shield of breakout board
  // you may need to pass a pin number in begin for SS
  Serial.print("Initializing SD card...");
  if (!SD.begin()) {
    Serial.println("initialization failed!");
    return;
  Serial.println("initialization done.");
  // create a SDWaveFile
  waveFile = SDWaveFile(filename);
  // check if the WaveFile is valid
  if (!waveFile) {
    Serial.println("wave file is invalid!");
    while (1); // do nothing
  // print out some info. about the wave file
  Serial.print("Bits per sample = ");
  Serial.println(waveFile.bitsPerSample());
  long channels = waveFile.channels();
  Serial.print("Channels = ");
  Serial.println(channels);
  long sampleRate = waveFile.sampleRate();
  Serial.print("Sample rate = ");
  Serial.print(sampleRate);
  Serial.println(" Hz");
  long duration = waveFile.duration();
  Serial.print("Duration = ");
  Serial.print(duration);
  Serial.println(" seconds");
  // adjust the playback volume
  AudioOutI2S.volume(5);
  // check if the I2S output can play the wave file
  if (!AudioOutI2S.canPlay(waveFile)) {
    Serial.println("unable to play wave file using I2S!");
  // start playback
  Serial.println("starting playback");
  AudioOutI2S.play(waveFile);
  // check if playback is still going on
  if (!AudioOutI2S.isPlaying()) {
    // playback has stopped
    Serial.println("playback stopped");
The reason I am trying to use the ArduinoSound.h library with MKRZero instead of AudioZero.h is that I can't seem to stop or skip files. I saw other code examples that are able to compare if audio is playing and then either stop playback or do another function, but I am finding that the only way after starting playback of a file with AudioZero.h to either skip or stop playback is to wait for that file to finish playing.
I'll include that code as well:
  Simple Audio Player for Arduino Zero
 Demonstrates the use of the Audio library for the Arduino Zero
 Hardware required :
 * Arduino shield with a SD card on CS4
 * A sound file named "test.wav" in the root directory of the SD card
 * An audio amplifier to connect to the DAC0 and ground
 * A speaker to connect to the audio amplifier
 Arturo Guadalupi <a.guadalupi@arduino.cc>
 Angelo Scialabba <a.scialabba@arduino.cc>
 Claudio Indellicati <c.indellicati@arduino.cc>
 This example code is in the public domain
 https://www.arduino.cc/en/Tutorial/SimpleAudioPlayerZero
#include <SD.h>
#include <SPI.h>
#include <AudioZero.h>
//global variables, define input pins
#define Play 7
#define Stop 8
#define Next 6
#define Previous 9
volatile bool playStatus = 0;
volatile bool stopStatus = 0;
volatile bool nextStatus = 0;
volatile bool prevStatus = 0;
File wav;
File root;
int count = 0;
  // debug output at 115200 baud
  SD.begin(SS_PIN);
  // setup SD-card
  if(!SD.begin(28)) {
    Serial.println(" failed!!");
    while(true);
  Serial.println(" done.");
  //set input pins, assign interrupts and ISRs
  //when buttons go high, play, stop, prev, or next will happen
  pinMode(Play, INPUT);
  attachInterrupt(digitalPinToInterrupt(Play), playStateRead, HIGH);
  pinMode(Stop, INPUT);
  attachInterrupt(digitalPinToInterrupt(Stop), stopStateRead, HIGH);
  pinMode(Next, INPUT);
  pinMode(Previous, INPUT);
  // open wave file from sdcard
  Serial.print("play status is ");
  Serial.println(playStatus);
  //File root = SD.open("/");
  // 44100kHz stereo => 88200 sample rate
  if (playStatus == 1){
    AudioZero.begin(44100);
    if (!root) {
    // if the file didn't open, print an error and stop
      Serial.println("error opening ");
      Serial.print(root.name());
      while (true);
  playWavs(root, count);
 // Serial.println(count);
  //else{
    //AudioZero.end();
int playWavs(File dir, int place){
  while (playStatus == 1){
  wav = dir.openNextFile();
    if (!wav || stopStatus == 1){
      wav.close();
      if (wav.isDirectory()){
      Serial.println(wav.name());
      else{
    Serial.print("Playing ");
    AudioZero.play(wav);
      wav.close();
    /*place++;
    Serial.print("the place is ");
    Serial.println(place);
    return place;*/
  return count;
void playStateRead(){
  playStatus = 1;
  stopStatus = 0;
  Serial.println("play button pressed");
  return;
void stopStateRead(){
  stopStatus = 1;
  playStatus = 0;
  Serial.println("stop button pressed");
  return;
OK so looking at ArduinoSound.h it says pretty clearly that it is for I2S, so i understand that now.
In regards to my issue with the AudioZero.h library, I added a global unsigned long variable, and before calling AudioZero.play() function I store the size of the file in that variable, and then when I want to skip to the next file instead of calling file.close() I call file.seek(filesize).
