ho isolato la lettura dell'adc
#include <avr/io.h>
#include <stdlib.h>
#include "Transistortester.h"
#include "Makefile.h" //J-L
extern struct ADCconfig_t{
uint8_t Samples; // number of ADC samples to take
uint8_t RefFlag; // save Reference type VCC of IntRef
uint16_t U_Bandgap; // Reference Voltage in mV
uint16_t U_AVCC; // Voltage of AVCC
} ADCconfig;
#ifdef INHIBIT_SLEEP_MODE
// #define StartADCwait() ADCSRA = (1<<ADSC) | (1<<ADEN) | (1<<ADIF) | AUTO_CLOCK_DIV; /* enable ADC and start */
#define StartADCwait() ADCSRA = (1<<ADSC)|(1<<ADEN)|(1<<ADIF)|AUTO_CLOCK_DIV; /* Start conversion */\
while (ADCSRA & (1 << ADSC)); /* wait until conversion is done */
#else
#define StartADCwait() ADCSRA = (1<<ADEN) | (1<<ADIF) | (1<<ADIE) | AUTO_CLOCK_DIV; /*enable ADC and Interrupt */\
set_sleep_mode(SLEEP_MODE_ADC);\
sleep_mode(); /* Start ADC, return, if ADC has finished */
#endif
/* ReadADC takes ADCconfig.Samples ADC reads and build a sum of the data */
/* One ADC read take a time period about 112us. */
/* So 25 ADC reads take more than 2.8ms time. */
/* for resistor and other measurements 190 ADC reads are done with more than 21ms */
unsigned int ReadADC (uint8_t Probe) {
unsigned int U; /* return value (mV) */
uint8_t samples; /* loop counter */
unsigned long Value; /* ADC value */
Probe |= (1 << REFS0); /* use internal reference anyway */
#ifdef AUTOSCALE_ADC
get_sample:
#endif /* AUTOSCALE_ADC */
#if (PROCESSOR_TYP == 644) || (PROCESSOR_TYP == 1280)
if (Probe & (1 << REFS1)) Probe &= ~(1<<REFS0); /* ATmega640/1280/2560 1.1V Reference with REFS0=0 */
#endif
ADMUX = Probe; /* set input channel and U reference */
/* if voltage reference changes, wait for voltage stabilization */
if ((Probe & (1<<REFS1)) != ADCconfig.RefFlag) {
// Reference is switched, delay depends on NO_AREF_CAP option
ADCconfig.RefFlag = (Probe & (1<<REFS1)); // save new reference state
#ifdef NO_AREF_CAP
wait100us(); /* time for voltage stabilization */
#else
wait_about10ms(); /* time for voltage stabilization */
#endif
// allways do one dummy read of ADC, 112us
StartADCwait(); /* start ADC and wait */
/* * sample ADC readings */
Value = 0UL; /* reset sampling variable */
samples = 0; /* number of samples to take */
while (samples < ADCconfig.Samples) /* take samples */ {
Value += ADCW; /* add ADC reading */
/* auto-switch voltage reference for low readings */
if ((samples == 4) && (ADCconfig.U_Bandgap > 255) && ((uint16_t)Value < 1024) && !(Probe & (1<<REFS1))) {
Probe |= (1 << REFS1); /* select internal bandgap reference */
goto get_sample; /* re-run sampling */
#endif
samples++; /* one more done */
} /* end while */
/* * convert ADC reading to voltage * - single sample: U = ADC reading * U_ref / 1024 */
/* get voltage of reference used */
if (Probe & (1 << REFS1)) U = ADCconfig.U_Bandgap; /* bandgap reference */
else U = ADCconfig.U_AVCC; /* Vcc reference */
#else
#endif
/* convert to voltage; */
Value *= U; /* ADC readings * U_ref */
Value /= 1023; /* / 1024 for 10bit ADC */
/* de-sample to get average voltage */
Value /= ADCconfig.Samples;
U = (unsigned int)Value;
return U;
// return ((unsigned int)(Value / (1023 * (unsigned long)ADCconfig.Samples)));
unsigned int W5msReadADC (uint8_t Probe) {
wait_about5ms();
return (ReadADC(Probe));
unsigned int W10msReadADC (uint8_t Probe) {
wait_about10ms();
unsigned int W20msReadADC (uint8_t Probe) {
wait_about20ms();
uint16_t unsigned_diff(uint16_t v1, uint16_t v2)
if (v1 > v2) return (v1 - v2);
else return (0);
uint16_t abs_diff(uint16_t v1, uint16_t v2)
else return (v2 - v1);
uint16_t vcc_diff(uint16_t v2)
return unsigned_diff(ADCconfig.U_AVCC, v2);
// if (ADCconfig.U_AVCC > v2) return (ADCconfig.U_AVCC - v2);
// else return (0);
qui il calcolo della resistenza, il numero di campioni e' definito nella direttiva
R_ANZ_MESS (massimo 200). Io uso 190.
#include <avr/io.h>
#include <stdlib.h>
void GetResistance(uint8_t HighPin, uint8_t LowPin)
Function for checking the resistance of a component with the following pin assignment
parameters:
HighPin: Pin, which will be switched to VCC at the beginning
LowPin: Pin, which will be switch to GND at the beginning
struct {
unsigned int hp1;
unsigned int hp2;
unsigned int lp1;
unsigned int lp2;
unsigned int tp1;
unsigned int tp2;
}adc;
uint8_t LoPinRL; // mask to switch the LowPin with R_L
uint8_t LoPinRH; // mask to switch the LowPin with R_H
uint8_t HiPinRL; // mask to switch the HighPin with R_L
uint8_t HiPinRH; // mask to switch the HighPin with R_H
uint8_t LoADCp; // mask to switch the ADC port LowPin
uint8_t HiADCp; // mask to switch the ADC port HighPin
#if FLASHEND > 0x1fff
uint8_t ii; // temporary variable
int udiff;
#endif
unsigned long lrx1;
unsigned long lirx1;
unsigned long lirx2;
const uint8_t *addr;
uint8_t resnum;
switch HighPin directls to VCC
switch R_L port for LowPin to GND
TristatePin remains switched to input , no action required
wdt_reset();
addr = &PinRLRHADCtab[LowPin-TP_MIN]; // address of the combined RL / RH / ADC pin table
LoPinRL = pgm_read_byte(addr); // instruction for LowPin R_L
#if (((PIN_RL1 + 1) != PIN_RH1) || ((PIN_RL2 + 1) != PIN_RH2) || ((PIN_RL3 + 1) != PIN_RH3))
addr += 3; // address of PinRHtab[LowPin]
LoPinRH = pgm_read_byte(addr); // instruction for LowPin R_H
#else
LoPinRH = (LoPinRL + LoPinRL);
#endif
addr += 3; // address of PinADCtab[LowPin]
LoADCp = pgm_read_byte(addr); // instruction for ADC Low-Pin, including | TXD_VAL
addr = &PinRLRHADCtab[HighPin-TP_MIN];
HiPinRL = pgm_read_byte(addr); // instruction for HighPin R_L
addr += 3; // address of PinRLtab[HighPin]
HiPinRH = pgm_read_byte(addr); // instruction for HighPin R_H
#else
HiPinRH = (HiPinRL + HiPinRL);
#endif
addr += 3; // address of PinADCtab[HighPin]
HiADCp = pgm_read_byte(addr); // instruction for ADC High-Pin, including | TXD_VAL
// Search for resistors
if ((ptrans.count + ntrans.count) > 0) {
return; // no resistors are searched, if transistors are detected
resnum = (LowPin - TP_MIN + HighPin - TP_MIN - 1); // resistor-Number 0:1 = 0, 0:2 = 1, 1:2 = 2
// resistor measurement
wdt_reset();
// U_SCALE can be set to 4 for better resolution of ReadADC result
#if U_SCALE != 1
ADCconfig.U_AVCC = (adc_vcc_reference * U_SCALE); // scale to higher resolution, mV scale is not required
ADCconfig.U_Bandgap = (adc_internal_reference * U_SCALE);
#endif
#if R_ANZ_MESS != ANZ_MESS
ADCconfig.Samples = R_ANZ_MESS; // switch to special number of repetitions
#endif
#define MAX_REPEAT (700 / (5 + R_ANZ_MESS/8))
for (ii=0; ii<NumOfDiodes; ii++) {
// never search a resistor at the same place, where a diode is detected
if ((diodes.Anode[ii] + diodes.Cathode[ii]) == (HighPin + LowPin)) goto testend;
#endif
ADC_PORT = TXD_VAL;
ADC_DDR = LoADCp | TXD_MSK; //switch Low-Pin to output (GND)
R_DDR = HiPinRL; //switch R_L port for High-Pin to output (VCC)
R_PORT = HiPinRL;
adc.hp2 = 0;
for (ii=1;ii<MAX_REPEAT;ii++) {
// wait until voltage is stable
adc.tp1 = W5msReadADC(LowPin); // low-voltage at Rx with load
adc.hp1 = ReadADC(HighPin); // voltage at resistor Rx with R_L
udiff = adc.hp1 - adc.hp2;
if (udiff < 0) udiff = -udiff;
if (udiff < 3) break;
adc.hp2 = adc.hp1;
wdt_reset();
if (ii == MAX_REPEAT) {
#if (DEBUG_OUT == 1)
lcd_data('a');
#endif
goto testend;
#else
#endif
if (adc.tp1 > adc.hp1) {
adc.tp1 = adc.hp1;
R_PORT = 0;
R_DDR = HiPinRH; //switch R_H port for High-Pin to output (GND)
adc.hp2 = W5msReadADC(HighPin); // read voltage, should be down
if (adc.hp2 > (20*U_SCALE)) {
// if resistor, voltage should be down
lcd_data('b');
#endif
goto testend;
R_PORT = HiPinRH; //switch R_H for High-Pin to VCC
adc.hp2 = W5msReadADC(HighPin); // voltage at resistor Rx with R_H
ADC_DDR = HiADCp | TXD_MSK; //switch High-Pin to output
ADC_PORT = HiADCp; //switch High-Pin to VCC
R_PORT = 0;
R_DDR = LoPinRL; //switch R_L for Low-Pin to GND
adc.lp2 = 0;
// L--RL--RyyX--H
adc.tp2 = W5msReadADC(HighPin); //high voltage with load
adc.lp1 = ReadADC(LowPin); //voltage at the other end of Rx
udiff = adc.lp1 - adc.lp2;
adc.lp2 = adc.lp1;
wdt_reset();
lcd_data('c');
#endif
goto testend;
#else
#endif
if (adc.tp2 < adc.lp1) {
adc.tp2 = adc.lp1;
// L--RH--RX--H
R_DDR = LoPinRH; //switch R_H for Low-Pin to GND
adc.lp2 = W5msReadADC(LowPin);
if((adc.hp1 < (4400*U_SCALE)) && (adc.hp2 > (97*U_SCALE))) {
//voltage break down isn't insufficient
lcd_data('d');
#endif
goto testend;
// if((adc.hp2 + (adc.hp2 / 61)) < adc.hp1)
if (adc.hp2 < (4972*U_SCALE)) {
// voltage breaks down with low test current and it is not nearly shorted => resistor
// if (adc.lp1 < 120) // take measurement with R_H
if (adc.lp1 < (169*U_SCALE)) { // take measurement with R_H
if (adc.lp2 < (38*U_SCALE)) {
// measurement > 60MOhm too big resistance
lcd_data('e');
#endif
goto testend;
// two measurements with R_H resistors (470k) are made:
// lirx1 (measurement at HighPin)
lirx1 = (unsigned long)((unsigned int)R_H_VAL) * (unsigned long)adc.hp2 / vcc_diff(adc.hp2);
// lirx2 (measurement at LowPin)
lirx2 = (unsigned long)((unsigned int)R_H_VAL) * (unsigned long)vcc_diff(adc.lp2) / adc.lp2;
#define U_INT_LIMIT (990*U_SCALE) // 1V switch limit in ReadADC for atmega family
#ifdef __AVR_ATmega8__
#define FAKT_LOW 2 //resolution is about twice as good
#else
#define FAKT_LOW 4 //resolution is about four times better
#endif
if (adc.hp2 < U_INT_LIMIT) {
lrx1 = (lirx1*FAKT_LOW + lirx2) / (FAKT_LOW+1); //weighted average of both R_H measurements
} else if (adc.lp2 < U_INT_LIMIT){
lrx1 = (lirx2*FAKT_LOW + lirx1) / (FAKT_LOW+1); //weighted average of both R_H measurements
} else
#endif
lrx1 = (lirx1 + lirx2) / 2; //average of both R_H measurements
lrx1 *= 100;
lrx1 += RH_OFFSET; // add constant for correction of systematic error
// two measurements with R_L resistors (680) are made:
adc.hp1 = adc.tp1; //diff negativ is illegal
lirx1 =(unsigned long)RR680PL * (unsigned long)unsigned_diff(adc.hp1, adc.tp1) / vcc_diff(adc.hp1);
adc.lp1 = adc.tp2; //diff negativ is illegal
// lirx2 (Measurement at LowPin)
lirx2 =(unsigned long)RR680MI * (unsigned long)unsigned_diff(adc.tp2, adc.lp1) / adc.lp1;
if (adc.hp1 < U_INT_LIMIT) {
lrx1 = (lirx1*FAKT_LOW + lirx2) / (FAKT_LOW+1); //weighted average of both R_L measurements
} else if (adc.lp1 < U_INT_LIMIT) {
lrx1 = (lirx2*FAKT_LOW + lirx1) / (FAKT_LOW+1); //weighted average of both R_L measurements
} else
#endif
lrx1 = (lirx1 + lirx2) / 2; //average of both R_L measurements
// measurement is finished, lrx1 is the resistance value of one direction
if(PartFound < PART_TRANSISTOR) {
if (ResistorChecked[resnum] != 0) {
// must be measurement with inverse polarity
// resolution is 0.1 Ohm, 1 Ohm = 10 !
lirx1 = (labs((long)lrx1 - (long)ResistorVal[resnum]) * 10) / (lrx1 + ResistorVal[resnum] + 100);
if (lirx1 > 0) {
// mismatch of the two measurements
// ResistorsFound--; // this one isn't a resistor
// goto testend; // <10% mismatch
lcd_line3();
DisplayValue(lrx1,-1,' ',4);
DisplayValue(ResistorVal[resnum],-1,' ',4);
#endif
// resistor has the same value in both directions
if (PartFound < PART_DIODE) {
PartFound = PART_RESISTOR; // only mark as resistor, if no other part found
ResistorChecked[resnum] = 2; // mark as checked in both direction
ResistorList[ResistorsFound] = resnum; // save number of this resistor
ResistorsFound++; // 1 more resistor found
goto testend;
} else { // resistor is never checked before
// must be a new one with other pins
ResistorVal[resnum] = lrx1; // save register value
ResistorChecked[resnum] = 1; // is checked in one direction
} // end ResistorChecked[] != 0
} /* end if (PartFound < PART_TRANSISTOR) */
testend: // end of resistor measurement
#if U_SCALE != 1
ADCconfig.U_AVCC = adc_vcc_reference; // scale to higher resolution, mV scale is not required
ADCconfig.U_Bandgap = adc_internal_reference; // set back to normal resolution
#endif
ADCconfig.Samples = ANZ_MESS; // switch back to standard number of repetition
#endif
return;
} // end GetResistance()
Spero di non aver fatto casini, a quest'ora crollo dal sonno
