Wrong character
hi all
Im trying to duplicate this project, where i can measure capacitor, resistors and so on but there are a few wrong characters in it.
Appericate your help
Project: https://maker.pro/arduino/projects/diy-super-simple-electronic-component-tester
My screen: Fun-Pic-20240507-082808471 hosted at ImgBB — ImgBB
the code is too long to put in here but its in the project
Welcome to the forum
Most users here will not want to register with another site in order to see your code
No matter how long it is, please post it here. If it consists of multiple files then attach the zip file to a new post
sorry i forgot a regestration is needed for the download of the code
I found this site to share the code : Untitled file — Codefile
Zip file: https://fileport.io/edm6FzRKEEDW
Start by removing stuff from the sketch until you have a minimal sketch leftover that demonstrates the problem. Then upload it here. Also specify what the exact nature of the problem is.
Heed what @UKHeliBob said above - if you want help, provide information in an easily accessible way. There will be very few people willing to register elsewhere to see your big pile of code so they can start looking for an unclearly defined problem.
The project is already made by someone , which can be seen on this youtube video
I made the exact setup and uploaded the code.
When i measure on a resistor it should show like 10 Ω but instead it shows 10 É
Thats the same issue with measuring on other components as capacitors and so on.
Issue showed here:
The code is consist of 180000 character and this forum does only allow up to 120000, so it means alot of stripping of the code, which i like to avoid if i can , maybe i should share it in two messages
PART 1
  /--------------------oOOo-(_)-oOOo---------------------\
  |    Transistor Tester for Arduino (version 1.08a)     |
  |  based on code: Karl-Heinz Kubbeler (version 1.08k)  |
  |                            Oooo                      |
  \--------------------oooO----(   )---------------------/
                        \ (    (_/
                         \_)                            */
#include <avr/io.h>
#include <util/delay.h>
#include <avr/sleep.h>
#include <stdlib.h>
#include <string.h>
#include <avr/eeprom.h>
#include <avr/pgmspace.h>
#include <avr/wdt.h>
#include <avr/interrupt.h>
#include <math.h>
#include <stdint.h>
#include <avr/power.h>
//#define LCD1602
//#define LCD_I2C
//#define NOK5110
//#define OLED096
#define OLED_I2C
#ifdef LCD_I2C
  #ifndef LCD1602
    #define LCD1602
  #endif
#endif
#ifdef OLED_I2C
  #ifndef OLED096
    #define OLED096
  #endif
#endif
#ifdef LCD1602
  #ifdef LCD_I2C
    #include <Wire.h>
  #else
    #include <LiquidCrystal.h>
  #endif
#endif
#ifdef NOK5110
  #include <SPI.h>
  #include <Adafruit_GFX.h>
  #include <Adafruit_PCD8544.h>
#endif
#ifdef OLED096
  #include <SPI.h>
  #include <Wire.h>
  #include <Adafruit_SSD1306.h>
#endif
// ******** config options for your Semiconductor tester
// Every changing of this Makefile will result in new compiling the whole
// programs, if you call make or make upload.
#define MCU atmega328p
#define F_CPU 16000000UL
// Select your language:
// Available languages are: LANG_ENGLISH, LANG_GERMAN, LANG_POLISH, LANG_CZECH, LANG_SLOVAK, LANG_SLOVENE,
//                          LANG_DUTCH, LANG_BRASIL, LANG_RUSSIAN, LANG_UKRAINIAN
#define LANG_ENGLISH
// The LCD_CYRILLIC option is necessary, if you have a display with cyrillic characterset.
// This lcd-display don't have a character for Ohm and for u (micro).
// Russian language requires a LCD controller with russian characterset and option LCD_CYRILLIC!
#define LCD_CYRILLIC
// The LCD_DOGM option must be set for support of the DOG-M type of LCD modules with ST7036 controller.
// For this LCD type the contrast must be set with software command.
//#define LCD_DOGM
// Option STRIP_GRID_BOARD selects different board-layout, do not set for standard board!
// The connection of LCD is totally different for both versions.
//#define STRIP_GRID_BOARD
// The WITH_SELFTEST option enables selftest function (only for mega168 or mega328).
//#define WITH_SELFTEST
// AUTO_CAL will enable the autocalibration of zero offset of capacity measurement and
// also the port output resistance values will be find out in SELFTEST section.
// With a external capacitor a additionally correction of reference voltage is figured out for
// low capacity measurement and also for the AUTOSCALE_ADC measurement.
// The AUTO_CAL option is only selectable for mega168 and mega328.
//#define AUTO_CAL
// FREQUENCY_50HZ enables a 50 Hz frequency generator for up to one minute at the end of selftests.
//#define FREQUENCY_50HZ
// The WITH_AUTO_REF option enables reading of internal REF-voltage to get factors for the Capacity measuring.
#define WITH_AUTO_REF
// REF_C_KORR corrects the reference Voltage for capacity measurement (<40uF) and has mV units.
// Greater values gives lower capacity results.
#define REF_C_KORR 12
// REF_L_KORR corrects the reference Voltage for inductance measurement and has mV units.
#define REF_L_KORR 40
// C_H_KORR defines a correction of 0.1% units for big capacitor measurement.
// Positive values will reduce measurement results.
#define C_H_KORR 0
// The WITH_UART option enables the software UART (TTL level output at Pin PC3, 26).
// If the option is deselected, PC3 can be used as external voltage input with a
// 10:1 resistor divider.
//#define WITH_UART
// The CAP_EMPTY_LEVEL  defines the empty voltage level for capacitors in mV.
// Choose a higher value, if your Tester reports "Cell!" by unloading capacitors.
#define CAP_EMPTY_LEVEL 4
// The AUTOSCALE_ADC option enables the autoscale ADC (ADC use VCC and Bandgap Ref).
#define AUTOSCALE_ADC
#define REF_R_KORR 3
// The ESR_ZERO value define the zero value of ESR measurement (units = 0.01 Ohm).
//#define ESR_ZERO 29
#define ESR_ZERO 20
// NO_AREF_CAP tells your Software, that you have no Capacitor installed at pin AREF (21).
// This enables a shorter wait-time for AUTOSCALE_ADC function.
// A capacitor with 1nF can be used with the option NO_AREF_CAP set.
#define NO_AREF_CAP
// The OP_MHZ option tells the software the Operating Frequency of your ATmega.
// OP_MHZ 16
// Restart from sleep mode will be delayed for 16384 clock tics with crystal mode.
// Operation with the internal RC-Generator or external clock will delay the restart by only 6 clock tics.
// You must specify this with "#define RESTART_DELAY_TICS=6", if you don't use the crystal mode.
//#define RESTART_DELAY_TICS 6
// The USE_EEPROM option specify where you wish to locate fix text and tables.
// If USE_EEPROM is unset, program memory (flash) is taken for fix text and tables.
//#define USE_EEPROM
// Setting EBC_STYPE will select the old style to present the order of Transistor connection (EBC=...).
// Omitting the option will select the 123=... style.  Every point is replaced by a character identifying
// type of connected transistor pin (B=Base, E=Emitter, C=Collector, G=Gate, S=Source, D=Drain).
// If you select EBC_STYLE=321 , the style will be 321=... , the inverted order to the 123=... style.
//#define EBC_STYLE
//#define EBC_STYLE 321
// Setting of NO_NANO avoids the use of n as prefix for Farad (nF), the mikro prefix is used insted (uF).
//#define NO_NANO
// The PULLUP_DISABLE option disable the pull-up Resistors of IO-Ports.
// To use this option a external pull-up Resistor (10k to 30k)
// from Pin 13 to VCC must be installed!
#define PULLUP_DISABLE
// The ANZ_MESS option specifies, how often an ADC value is read and accumulated.
// Possible values of ANZ_MESS are 5 to 200.
#define ANZ_MESS 25
// The POWER_OFF option enables the power off function, otherwise loop measurements infinitely
// until power is disconnected with a ON/OFF switch (#define POWER_OFF).
// If you have the tester without the power off transistors, you can deselect POWER_OFF .
// If you have NOT selected the POWER_OFF option with the transistors installed,
// you can stop measuring by holding the key several seconds after a result is
// displayed. After releasing the key, the tester will be shut off by timeout.
// Otherwise you can also specify, after how many measurements without found part
// the tester will shut down (#define POWER_OFF=5).
// The tester will also shut down with found part,
// but successfull measurements are allowed double of the specified number.
// You can specify up to 255 empty measurements (#define POWER_OFF=255).
//#define POWER_OFF 5
//#define POWER_OFF
// Option BAT_CHECK enables the Battery Voltage Check, otherwise the SW Version is displayed instead of Bat.
// BAT_CHECK should be set for battery powered tester version.
//#define BAT_CHECK
// The BAT_OUT option enables Battery Voltage Output on LCD (if BAT_CHECK is selected).
// If your 9V supply has a diode installed, use the BAT_OUT=600 form to specify the
// threshold voltage of your diode to adjust the output value.
// This threshold level is added to LCD-output and does not affect the voltage checking levels.
//#define BAT_OUT 150
// To adjust the warning-level and poor-level of battery check to the capability of a
// low drop voltage regulator, you can specify the Option BAT_POOR=5400 .
// The unit for this option value is 1mV , 5400 means a poor level of 5.4V.
// The warning level is 0.8V higher than the specified poor level (>5.3V).
// The warning level is 0.4V higher than the specified poor level (>2.9V, <=5.3V).
// The warning level is 0.2V higher than the specified poor level (>1.3V, <=2.9V).
// The warning level is 0.1V higher than the specified poor level (<=1.3V).
// Setting the poor level to low values is not recommended for rechargeable Batteries,
// because this increase the danger for deep discharge!!
#define BAT_POOR 6400
// The sleep mode of the ATmega168 or ATmega328 is normally used by the software to save current.
// You can inhibit this with the option INHIBIT_SLEEP_MODE .
//#define INHIBIT_SLEEP_MODE
// ******** end of selectable options
// ########  Configuration
#ifndef ADC_PORT
//#define DebugOut 3		// if set, output of voltages of resistor measurements in row 2,3,4
//#define DebugOut 4		// if set, output of voltages of Diode measurement in row 3+4
//#define DebugOut 5		// if set, output of Transistor checks in row 2+3
//#define DebugOut 10		// if set, output of capacity measurements (ReadCapacity) in row 3+4
  Port, that is directly connected to the probes.
  This Port must have an ADC-Input  (ATmega8:  PORTC).
  The lower pins of this Port must be used for measurements.
  Please don't change the definitions of TP1, TP2 and TP3!
  The TPREF pin can be connected with a 2.5V precision voltage reference
  The TPext can be used with a 10:1 resistor divider as external voltage probe up to 50V
#define ADC_PORT PORTC
#define ADC_DDR DDRC
#define ADC_PIN PINC
#define TP1 0
#define TP2 1
#define TP3 2
#define TPext 3
// Port pin for 2.5V precision reference used for VCC check (optional)
#define TPREF 4
// Port pin for Battery voltage measuring
#define TPBAT 5
  exact values of used resistors (Ohm).
  The standard value for R_L is 680 Ohm, for R_H 470kOhm.
  To calibrate your tester the resistor-values can be adjusted:
#define R_L_VAL 6800          // standard value 680 Ohm, multiplied by 10 for 0.1 Ohm resolution
//#define R_L_VAL 6690        // this will be define a 669 Ohm
#define R_H_VAL 47000         // standard value 470000 Ohm, multiplied by 10, divided by 100
//#define R_H_VAL 47900       // this will be define a 479000 Ohm, divided by 100
#define R_DDR DDRB
#define R_PORT PORTB
  Port for the Test resistors
  The Resistors must be connected to the lower 6 Pins of the Port in following sequence:
  RLx = 680R-resistor for Test-Pin x
  RHx = 470k-resistor for Test-Pin x
  RL1 an Pin 0
  RH1 an Pin 1
  RL2 an Pin 2
  RH2 an Pin 3
  RL3 an Pin 4
  RH3 an Pin 5
#define ON_DDR DDRD
#define ON_PORT PORTD
#define ON_PIN_REG PIND
#define ON_PIN 18               // Pin, must be switched to high to switch power on
#ifdef STRIP_GRID_BOARD
// Strip Grid board version
  #define RST_PIN 0             // Pin, is switched to low, if push button is pressed
#else
// normal layout version
  #define RST_PIN 17            // Pin, is switched to low, if push button is pressed
#endif
// Port(s) / Pins for LCD
  // special Layout for strip grid board
  #define HW_LCD_EN_PORT         PORTD
  #define HW_LCD_EN_PIN          5
  #define HW_LCD_RS_PORT         PORTD
  #define HW_LCD_RS_PIN          7
  #define HW_LCD_B4_PORT         PORTD
  #define HW_LCD_B4_PIN          4
  #define HW_LCD_B5_PORT         PORTD
  #define HW_LCD_B5_PIN          3
  #define HW_LCD_B6_PORT         PORTD
  #define HW_LCD_B6_PIN          2
  #define HW_LCD_B7_PORT         PORTD
  #define HW_LCD_B7_PIN          1
#else
  // normal Layout
  #define HW_LCD_EN_PIN          6
  #define HW_LCD_B4_PIN          5
  #define HW_LCD_B5_PIN          4
  #define HW_LCD_B6_PIN          3
  #define HW_LCD_B7_PIN          2
#endif
// U_VCC defines the VCC Voltage of the ATmega in mV units
#define U_VCC 5000
// integer factors are used to change the ADC-value to mV resolution in ReadADC !
// With the option NO_CAP_HOLD_TIME you specify, that capacitor loaded with 680 Ohm resistor will not
// be tested to hold the voltage same time as load time.
// Otherwise (without this option) the voltage drop during load time is compensated to avoid displaying
// too much capacity for capacitors with internal parallel resistance.
// #define NO_CAP_HOLD_TIME
// U_SCALE can be set to 4 for better resolution of ReadADC function for resistor measurement
#define U_SCALE 4
// R_ANZ_MESS can be set to a higher number of measurements (up to 200) for resistor measurement
#define R_ANZ_MESS 190
// Watchdog
//#define WDT_enabled
  If you remove the "#define WDT_enabled" , the Watchdog will not be activated.
  This is only for Test or debugging usefull.
  For normal operation please activate the Watchdog !
// ########  End of configuration
#if R_ANZ_MESS < ANZ_MESS
  #undef R_ANZ_MESS
  #define R_ANZ_MESS ANZ_MESS
#endif
#if U_SCALE < 0
  // limit U_SCALE
  #undef U_SCALE
  #define U_SCALE 1
#endif
#if U_SCALE > 4
  // limit U_SCALE
  #undef U_SCALE
  #define U_SCALE 4
#endif
#ifndef REF_L_KORR
  #define REF_L_KORR 50
#endif
// the following definitions specify where to load external data from: EEprom or flash
#ifdef USE_EEPROM
  #define MEM_TEXT EEMEM
  #if E2END > 0X1FF
    #define MEM2_TEXT EEMEM
    #define MEM2_read_byte(a)  eeprom_read_byte(a)
    #define MEM2_read_word(a)  eeprom_read_word(a)
    #define lcd_fix2_string(a)  lcd_fix_string(a)
  #else
    #define MEM2_TEXT PROGMEM
    #define MEM2_read_byte(a)  pgm_read_byte(a)
    #define MEM2_read_word(a)  pgm_read_word(a)
    #define lcd_fix2_string(a)  lcd_pgm_string(a)
    #define use_lcd_pgm
  #endif
  #define MEM_read_word(a)  eeprom_read_word(a)
  #define MEM_read_byte(a)  eeprom_read_byte(a)
#else
  #define MEM_TEXT PROGMEM
  #define MEM_read_word(a)  pgm_read_word(a)
  #define MEM_read_byte(a)  pgm_read_byte(a)
  #define use_lcd_pgm
#endif
// RH_OFFSET : systematic offset of resistor measurement with RH (470k)
// resolution is 0.1 Ohm, 3500 defines a offset of 350 Ohm
#define RH_OFFSET 3500
// TP2_CAP_OFFSET is a additionally offset for TP2 capacity measurements in pF units
#define TP2_CAP_OFFSET 2
// CABLE_CAP defines the capacity (pF) of 12cm cable with clip at the terminal pins
#define CABLE_CAP 3
// select the right Processor Typ
#if defined(__AVR_ATmega48__)
  #define PROCESSOR_TYP 168
#elif defined(__AVR_ATmega48P__)
#elif defined(__AVR_ATmega88__)
#elif defined(__AVR_ATmega88P__)
#elif defined(__AVR_ATmega168__)
#elif defined(__AVR_ATmega168P__)
#elif defined(__AVR_ATmega328__)
  #define PROCESSOR_TYP 328
#elif defined(__AVR_ATmega328P__)
#elif defined(__AVR_ATmega640__)
  #define PROCESSOR_TYP 1280
#elif defined(__AVR_ATmega1280__)
#elif defined(__AVR_ATmega2560__)
#else
  #define PROCESSOR_TYP 8
#endif
// automatic selection of right call type
#if FLASHEND > 0X1FFF
  #define ACALL call
#else
  #define ACALL rcall
#endif
// automatic selection of option and parameters for different AVRs
#if PROCESSOR_TYP == 168
  #define MCU_STATUS_REG MCUCR
  #define ADC_COMP_CONTROL ADCSRB
  #define TI1_INT_FLAGS TIFR1
  #define DEFAULT_BAND_GAP 1070
  #define DEFAULT_RH_FAKT  884      // mega328 1070 mV
  // LONG_HFE  activates computation of current amplification factor with long variables
  #define LONG_HFE
  // COMMON_COLLECTOR activates measurement of current amplification factor in common collector circuit  (Emitter follower)
  #define COMMON_COLLECTOR
  #define MEGA168A 17
  #define MEGA168PA 18
  // Pin resistor values of ATmega168
  //#define PIN_RM 196
  //#define PIN_RP 225
  #define PIN_RM 190
  #define PIN_RP 220
  // CC0 defines the capacity of empty terminal pins 1 & 3 without cable
  #define CC0 36
  // Slew rate correction  val += COMP_SLEW1 / (val + COMP_SLEW2)
  #define COMP_SLEW1 4000
  #define COMP_SLEW2 220
  #define C_NULL CC0+CABLE_CAP+(COMP_SLEW1 / (CC0 + CABLE_CAP + COMP_SLEW2))
  #define MUX_INT_REF 0x0e	// channel number of internal 1.1 V
#elif PROCESSOR_TYP == 328
  #define LONG_HFE
  #define PIN_RM 200
  #define PIN_RP 220
  #define CC0 36
  #define COMP_SLEW2 180
#elif PROCESSOR_TYP == 1280
  #define LONG_HFE
  #define PIN_RM 200
  #define PIN_RP 220
  #define CC0 36
  #define MUX_INT_REF 0x1e	/* channel number of internal 1.1 V */
#else
//                   ATmega8
  #define MCU_STATUS_REG MCUCSR
  #define ADC_COMP_CONTROL SFIOR
  #define DEFAULT_BAND_GAP 1298		//mega8 1298 mV
  #define DEFAULT_RH_FAKT  740      // mega8 1250 mV
  #define LONG_HFE
  #define PIN_RM 196
  #define PIN_RP 240
  #define CC0 27
  #define COMP_SLEW1 0
  #define COMP_SLEW2 33
  #define MUX_INT_REF 0x0e	/* channel number of internal 1.1 V */
  #ifndef INHIBIT_SLEEP_MODE
    #define INHIBIT_SLEEP_MODE	/* do not use the sleep mode of ATmega */
  #endif
#endif
#if PROCESSOR_TYP == 8
  // 2.54V reference voltage + correction (fix for ATmega8)
  #ifdef AUTO_CAL
    #define ADC_internal_reference (2560 + (int8_t)eeprom_read_byte((uint8_t *)&RefDiff))
  #else
    #define ADC_internal_reference (2560 + REF_R_KORR)
  #endif
#else
  // all other processors use a 1.1V reference
  #ifdef AUTO_CAL
    #define ADC_internal_reference (ref_mv + (int8_t)eeprom_read_byte((uint8_t *)&RefDiff))
  #else
    #define ADC_internal_reference (ref_mv + REF_R_KORR)
  #endif
#endif
#ifndef REF_R_KORR
  #define REF_R_KORR 0
#endif
#ifndef REF_C_KORR
  #define REF_C_KORR 0
#endif
#define LONG_WAIT_TIME 28000
#define SHORT_WAIT_TIME 5000
#ifdef POWER_OFF
  // if POWER OFF function is selected, wait 14s
  // if POWER_OFF with parameter > 2, wait only 5s before repeating
  #if (POWER_OFF+0) > 2
    #define OFF_WAIT_TIME SHORT_WAIT_TIME
  #else
    #define OFF_WAIT_TIME LONG_WAIT_TIME
  #endif
#else
  // if POWER OFF function is not selected, wait 14s before repeat measurement
#endif
// defines for the selection of a correctly  ADC-Clock
// will match for 1MHz, 2MHz, 4MHz, 8MHz and 16MHz
// ADC-Clock can be 125000 or 250000
// 250 kHz is out of the full accuracy specification!
// clock divider is 4, when CPU_Clock==1MHz and ADC_Clock==250kHz
// clock divider is 128, when CPU_Clock==16MHz and ADC_Clock==125kHz
#define F_ADC 125000
//#define F_ADC 250000
#if F_CPU/F_ADC == 2
  #define AUTO_CLOCK_DIV (1<<ADPS0)
#endif
#if F_CPU/F_ADC == 4
  #define AUTO_CLOCK_DIV (1<<ADPS1)
#endif
#if F_CPU/F_ADC == 8
  #define AUTO_CLOCK_DIV (1<<ADPS1) | (1<<ADPS0)
#endif
#if F_CPU/F_ADC == 16
  #define AUTO_CLOCK_DIV (1<<ADPS2)
#endif
#if F_CPU/F_ADC == 32
  #define AUTO_CLOCK_DIV (1<<ADPS2) | (1<<ADPS0)
#endif
#if F_CPU/F_ADC == 64
  #define AUTO_CLOCK_DIV (1<<ADPS2) | (1<<ADPS1)
#endif
#if F_CPU/F_ADC == 128
  #define AUTO_CLOCK_DIV (1<<ADPS2) | (1<<ADPS1) | (1<<ADPS0)
#endif
#define F_ADC_F 500000
#if F_CPU/F_ADC_F == 2
  #define FAST_CLOCK_DIV (1<<ADPS0)
#endif
#if F_CPU/F_ADC_F == 4
  #define FAST_CLOCK_DIV (1<<ADPS1)
#endif
#if F_CPU/F_ADC_F == 8
  #define FAST_CLOCK_DIV (1<<ADPS1) | (1<<ADPS0)
#endif
#if F_CPU/F_ADC_F == 16
  #define FAST_CLOCK_DIV (1<<ADPS2)
#endif
#if F_CPU/F_ADC_F == 32
  #define FAST_CLOCK_DIV (1<<ADPS2) | (1<<ADPS0)
#endif
#if F_CPU/F_ADC_F == 64
  #define FAST_CLOCK_DIV (1<<ADPS2) | (1<<ADPS1)
#endif
#if F_CPU/F_ADC_F == 128
  #define FAST_CLOCK_DIV (1<<ADPS2) | (1<<ADPS1) | (1<<ADPS0)
#endif
#ifndef PIN_RP
  #define PIN_RP  220           // estimated internal resistance PORT to VCC
                                // will only be used, if not set before in config.h
#endif
#ifndef PIN_RM
  #define PIN_RM  190           // estimated internal resistance PORT to GND
#endif
// defines for the WITH_UART option
With define SWUART_INVERT you can specify, if the software-UART operates normal or invers.
in the normal mode the UART sends with usual logik level (Low = 0; High = 1).
You can use this mode for direct connection to a uC, or a level converter like MAX232.
With invers mode the UART sends with invers logik (Low = 1, High = 0).
This is the level of a standard RS232 port of a PC.
In most cases the output of the software UART can so be connected to the RxD of a PC.
The specification say, that level -3V to 3V is unspecified, but in most cases it works.
Is a simple but unclean solution.
Is SWUART_INVERT defined, the UART works is inverse mode
//#define SWUART_INVERT
#define TxD 3	  // TxD-Pin of Software-UART; must be at Port C !
#ifdef WITH_UART
  #define TXD_MSK (1<<TxD)
#else
  #define TXD_MSK 0xF8
#endif
#ifdef SWUART_INVERT
  #define TXD_VAL 0
#else
  #define TXD_VAL TXD_MSK
#endif
#ifdef INHIBIT_SLEEP_MODE
  // save memory, do not use the sleep mode
  #define wait_about5ms() wait5ms()
  #define wait_about10ms() wait10ms()
  #define wait_about20ms() wait20ms()
  #define wait_about30ms() wait30ms()
  #define wait_about50ms() wait50ms()
  #define wait_about100ms() wait100ms()
  #define wait_about200ms() wait200ms()
  #define wait_about300ms() wait300ms()
  #define wait_about400ms() wait400ms()
  #define wait_about500ms() wait500ms()
  #define wait_about1s() wait1s()
  #define wait_about2s() wait2s()
  #define wait_about3s() wait3s()
  #define wait_about4s() wait4s()
#else
  // use sleep mode to save current for user interface
  #define wait_about5ms() sleep_5ms(1)
  #define wait_about10ms() sleep_5ms(2)
  #define wait_about20ms() sleep_5ms(4)
  #define wait_about30ms() sleep_5ms(6)
  #define wait_about50ms() sleep_5ms(10)
  #define wait_about100ms() sleep_5ms(20)
  #define wait_about200ms() sleep_5ms(40)
  #define wait_about300ms() sleep_5ms(60)
  #define wait_about400ms() sleep_5ms(80)
  #define wait_about500ms() sleep_5ms(100)
  #define wait_about1s() sleep_5ms(200)
  #define wait_about2s() sleep_5ms(400)
  #define wait_about3s() sleep_5ms(600)
  #define wait_about4s() sleep_5ms(800)
#endif
#undef AUTO_RH
#ifdef WITH_AUTO_REF
  #define AUTO_RH
#else
  #ifdef AUTO_CAL
    #define AUTO_RH
  #endif
#endif
#undef CHECK_CALL
#ifdef WITH_SELFTEST
  // AutoCheck Function is needed
  #define CHECK_CALL
#endif
#ifdef AUTO_CAL
  #define CHECK_CALL
  #define RR680PL resis680pl
  #define RR680MI resis680mi
  #define RRpinPL pin_rpl
  #define RRpinMI pin_rmi
#else
  #define RR680PL (R_L_VAL + PIN_RP)
  #define RR680MI (R_L_VAL + PIN_RM)
  #define RRpinPL (PIN_RP)
  #define RRpinMI (PIN_RM)
#endif
#ifndef ESR_ZERO
  // define a default zero value for ESR measurement (0.01 Ohm units)
  #define ESR_ZERO 20
#endif
#ifndef RESTART_DELAY_TICS
  // define the processor restart delay for crystal oscillator 16K
  // only set, if no preset (Makefile) exists.
  #define RESTART_DELAY_TICS 16384
  // for ceramic oscillator 258 or 1024 Clock tics can be selected with fuses
  // for external oscillator or RC-oscillator is only a delay of 6 clock tics.
#endif
// with EBC_STYLE you can select the Pin-description in EBC= style instead of 123=??? style
//#define EBC_STYLE
#if EBC_STYLE == 123
  // unset the option for the 123 selection, since this style is default.
  #undef EBC_STYLE
#endif
#if defined(NOK5110) || defined(OLED096)
  #define LCD_CHAR_DIODE1 0x91
  #define LCD_CHAR_DIODE2 0x92
  #define LCD_CHAR_CAP    0x93
  #define LCD_CHAR_RESIS1 0x94
  #define LCD_CHAR_RESIS2 0x95
  #define LCD_CHAR_OMEGA  0x90
  #define LCD_CHAR_U      0xB5
#else
  // self build characters
  #define LCD_CHAR_DIODE1  1      // Diode-Icon; will be generated as custom character
  #define LCD_CHAR_DIODE2  2      // Diode-Icon; will be generated as custom character
  #define LCD_CHAR_CAP 3          // Capacitor-Icon;  will be generated as custom character
  // numbers of RESIS1 and RESIS2 are swapped for OLED display, which shows a corrupt RESIS1 character otherwise ???
  #define LCD_CHAR_RESIS1 7       // Resistor left part will be generated as custom character
  #define LCD_CHAR_RESIS2 6       // Resistor right part will be generated as custom character
  #ifdef LCD_CYRILLIC
    #define LCD_CHAR_OMEGA  4       // Omega-character
    #define LCD_CHAR_U  5           // micro-character
  #else
    #define LCD_CHAR_OMEGA  244     // Omega-character
    #define LCD_CHAR_U  228         // micro-character
  #endif
  #ifdef LCD_DOGM
    #undef LCD_CHAR_OMEGA
    #define LCD_CHAR_OMEGA 0x1e     // Omega-character for DOGM module
    #undef LCD_CHAR_U
    #define LCD_CHAR_U  5           // micro-character for DOGM module loadable
  #endif
  #define LCD_CHAR_DEGREE 0xdf      // Character for degree
#endif
#endif  // #ifndef ADC_PORT
// the hFE (B) can be determined with common collector and common emitter circuit
// with more than 16K both methodes are possible
#ifdef COMMON_COLLECTOR
  #if FLASHEND > 0x3fff
    #define COMMON_EMITTER
  #endif
#else
#endif
#define MAIN_C
#if defined (MAIN_C)
  #define COMMON
  The voltage at a capacitor grows with  Uc = VCC * (1 - e**(-t/T))
  The voltage 1.3V is reached at  t = -ln(3.7/5)*T  = 0.3011*T .
  Time constant is  T = R * C ; also
  C = T / R
  for the resistor 470 kOhm  is C = t / (0.3011 * 470000)
  H_Fakt = 707/100 for a result in pF units.
// Big Capacities (>50uF) are measured with up to 500 load-pulses with the 680 Ohm resistor.
// Each  of this load-puls has an length of 10ms. After every load-pulse the voltage of the
// capacitor is measured. If the voltage is more than 300mV, the capacity is computed by
// interpolating the corresponding values of the table RLtab and multiply that with the number
// of load pulses (*10).
// Widerstand 680 Ohm                300   325   350   375   400   425   450   475   500   525   550   575   600   625   650   675   700   725   750   775   800   825   850   875   900   925   950   975  1000  1025  1050  1075  1100  1125  1150  1175  1200  1225  1250  1275  1300  1325  1350  1375  1400  mV
const uint16_t RLtab[] MEM_TEXT = {22447,20665,19138,17815,16657,15635,14727,13914,13182,12520,11918,11369,10865,10401, 9973, 9577, 9209, 8866, 8546, 8247, 7966, 7702, 7454, 7220, 6999, 6789, 6591, 6403, 6224, 6054, 5892, 5738, 5590, 5449, 5314, 5185, 5061, 4942, 4828, 4718, 4613, 4511, 4413, 4319, 4228};
#if FLASHEND > 0x1fff
  //                                {0, 1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13, 14, 15, 16, 17, 18, 19, 20, 21, 22, 23, 24, 25, 26, 27, 28, 29, 30, 31, 32, 33, 34, 35, 36, 37, 38, 39, 40, 41, 42, 43, 44, 45, 46, 47, 48, 49, 50, 51, 52, 53, 54, 55, 56, 57, 58, 59, 60, 61, 62, 63,  64,  65,  66,  67,  68,  69,  70,  71,  72,  73,  74,  75,  76,  77,  78,  79,  80,  81,  82,  83,  84,  85,  86,  87,  88,  89,  90,  91 };
  const uint16_t LogTab[] PROGMEM = {0, 20, 41, 62, 83, 105, 128, 151, 174, 198, 223, 248, 274, 301, 329, 357, 386, 416, 446, 478, 511, 545, 580, 616, 654, 693, 734, 777, 821, 868, 916, 968, 1022, 1079, 1139, 1204, 1273, 1347, 1427, 1514, 1609, 1715, 1833, 1966, 2120, 2303, 2526 };
#endif
#ifdef AUTO_RH
  // resistor  470000 Ohm      1000 1050 1100 1150 1200 1250 1300 1350 1400  mV
  const uint16_t RHtab[] PROGMEM = { 954, 903, 856, 814, 775, 740, 707, 676, 648};
#endif
// with integer factors the ADC-value will be changed to mV resolution in ReadADC !
// all if statements are corrected to the mV resolution.
// Strings in PROGMEM or in EEprom
#if defined(LANG_GERMAN)		// deutsch
   const unsigned char TestRunning[] MEM_TEXT = "Testen...";
   const unsigned char BatWeak[] MEM_TEXT = "gering";
   const unsigned char BatEmpty[] MEM_TEXT = "leer!";
   const unsigned char TestFailed2[] MEM_TEXT = "defektes ";
   const unsigned char Component[] MEM_TEXT = "Bauteil";
//   const unsigned char Diode[] MEM_TEXT = "Diode: ";
   const unsigned char Triac[] MEM_TEXT = "Triac";
   const unsigned char Thyristor[] MEM_TEXT = "Thyristor";
   const unsigned char Unknown[] MEM_TEXT = " unbek.";
   const unsigned char TestFailed1[] MEM_TEXT = "Kein,unbek. oder";
   const unsigned char OrBroken[] MEM_TEXT = "oder defekt ";
   const unsigned char TestTimedOut[] MEM_TEXT = "Timeout!";
   #define Cathode_char 'K'
   const unsigned char SELFTEST[] MEM_TEXT = "Selbsttest ..";
   const unsigned char RELPROBE[] MEM_TEXT = "isolate Probe!";
   const unsigned char ATE[] MEM_TEXT = "Test Ende";
 #endif
#endif
#if defined(LANG_ENGLISH)		// english
  const unsigned char TestRunning[] MEM_TEXT = "testing...";
  const unsigned char BatWeak[] MEM_TEXT = "weak";
  const unsigned char BatEmpty[] MEM_TEXT = "empty!";
  const unsigned char TestFailed2[] MEM_TEXT = "damaged ";
  const unsigned char Component[] MEM_TEXT = "part";
  //const unsigned char Diode[] MEM_TEXT = "Diode: ";
  const unsigned char Unknown[] MEM_TEXT = " unknown";
  const unsigned char TestFailed1[] MEM_TEXT = "No, unknown, or";
  const unsigned char OrBroken[] MEM_TEXT = "or damaged ";
  #define Cathode_char 'C'
    const unsigned char SELFTEST[] MEM_TEXT = "Selftest mode..";
    const unsigned char ATE[] MEM_TEXT = "Test End";
  #endif
#endif
// Strings, which are not dependent of any language
const unsigned char Bat_str[] MEM_TEXT = "Bat. ";
const unsigned char OK_str[] MEM_TEXT = "OK";
const unsigned char mosfet_str[] MEM_TEXT = "-MOS";
const unsigned char jfet_str[] MEM_TEXT = "JFET";
const unsigned char GateCap_str[] MEM_TEXT = "C=";
const unsigned char hfe_str[] MEM_TEXT ="B=";
const unsigned char NPN_str[] MEM_TEXT = "NPN ";
const unsigned char PNP_str[] MEM_TEXT = "PNP ";
#ifndef EBC_STYLE
  const unsigned char N123_str[] MEM_TEXT = " 123=";
  //const unsigned char N123_str[] MEM_TEXT = " Pin=";
#else
  #if EBC_STYLE == 321
    const unsigned char N321_str[] MEM_TEXT = " 321=";
  #endif
#endif
const unsigned char Uf_str[] MEM_TEXT = "Uf=";
const unsigned char vt_str[] MEM_TEXT = " Vt=";
const unsigned char Vgs_str[] MEM_TEXT = "@Vgs=";
const unsigned char CapZeich[] MEM_TEXT = {'-',LCD_CHAR_CAP,'-',0};
const unsigned char Cell_str[] MEM_TEXT = "Cell!";
const unsigned char VCC_str[] MEM_TEXT = "VCC=";
  const unsigned char ESR_str[] MEM_TEXT = " ESR=";
  const unsigned char VLOSS_str[] MEM_TEXT = " Vloss=";
  const unsigned char Lis_str[] MEM_TEXT = "L=";
  const unsigned char Ir_str[] MEM_TEXT = "  Ir=";
  #ifndef WITH_UART
    //#define WITH_VEXT
  #endif
#else
  #ifndef BAT_CHECK
    #ifndef WITH_UART
      //#define WITH_VEXT
    #endif
  #endif
#endif
#ifdef WITH_VEXT
  const unsigned char Vext_str[] MEM_TEXT = "Vext=";
  #define LCD_CLEAR
#endif
const unsigned char VERSION_str[] MEM2_TEXT = "Ttester 1.08.4";
const unsigned char AnKat[] MEM_TEXT = {'-', LCD_CHAR_DIODE1, '-',0};
const unsigned char KatAn[] MEM_TEXT = {'-', LCD_CHAR_DIODE2, '-',0};
const unsigned char Diodes[] MEM_TEXT = {'*',LCD_CHAR_DIODE1, ' ', ' ',0};
const unsigned char Resistor_str[] MEM_TEXT = {'-', LCD_CHAR_RESIS1, LCD_CHAR_RESIS2,'-',0};
  const unsigned char URefT[] MEM2_TEXT = "Ref=";
  const unsigned char RHfakt[] MEM2_TEXT = "RHf=";
  const unsigned char RH1L[] MEM_TEXT = "RH-";
  const unsigned char RH1H[] MEM_TEXT = "RH+";
  const unsigned char RLRL[] MEM_TEXT = "+RL- 12 13 23";
  const unsigned char RHRH[] MEM_TEXT = "+RH- 12 13 23";
  const unsigned char RHRL[] MEM_TEXT = "RH/RL";
  const unsigned char R0_str[] MEM2_TEXT = "R0=";
  #define LCD_CLEAR
#endif
#ifdef CHECK_CALL
  const unsigned char RIHI[] MEM_TEXT = "Ri_Hi=";
  const unsigned char RILO[] MEM_TEXT = "Ri_Lo=";
  const unsigned char C0_str[] MEM_TEXT = "C0 ";
  const unsigned char T50HZ[] MEM_TEXT = " 50Hz";
#endif
#ifdef AUTO_CAL
  const unsigned char MinCap_str[] MEM2_TEXT = " >100nF";
  const unsigned char REF_C_str[] MEM2_TEXT = "REF_C=";
  const unsigned char REF_R_str[] MEM2_TEXT = "REF_R=";
#endif
#ifdef DebugOut
  #define LCD_CLEAR
#endif
const unsigned char DiodeIcon1[] MEM_TEXT = { 0x11, 0x19, 0x1d, 0x1f, 0x1d, 0x19, 0x11, 0x00 }; // Diode-Icon Anode left
const unsigned char DiodeIcon2[] MEM_TEXT = { 0x11, 0x13, 0x17, 0x1f, 0x17, 0x13, 0x11, 0x00 }; // Diode-Icon Anode right
const unsigned char CapIcon[]    MEM_TEXT = { 0x1b, 0x1b, 0x1b, 0x1b, 0x1b, 0x1b, 0x1b, 0x00 }; // Capacitor Icon
const unsigned char ResIcon1[]   MEM_TEXT = { 0x00, 0x0f, 0x08, 0x18, 0x08, 0x0f, 0x00, 0x00 }; // Resistor Icon1 left
const unsigned char ResIcon2[]   MEM_TEXT = { 0x00, 0x1e, 0x02, 0x03, 0x02, 0x1e, 0x00, 0x00 }; // Resistor Icon2 right
const unsigned char OmegaIcon[]  MEM_TEXT = { 0x00, 0x00, 0x0e, 0x11, 0x11, 0x0a, 0x1b, 0x00 }; // Omega Icon
const unsigned char MicroIcon[]  MEM_TEXT = { 0x00, 0x00, 0x0a, 0x0a, 0x0a, 0x0e, 0x09, 0x10 }; // Micro Icon
const unsigned char PinRLtab[] PROGMEM = { (1<<(TP1*2)), (1<<(TP2*2)), (1<<(TP3*2))};  // Table of commands to switch the  R-L resistors Pin 0,1,2
const unsigned char PinADCtab[] PROGMEM = { (1<<TP1), (1<<TP2), (1<<TP3)};  // Table of commands to switch the ADC-Pins 0,1,2
// generate Omega- and u-character as Custom-character, if these characters has a number of loadable type
#if LCD_CHAR_OMEGA < 8
  const unsigned char CyrillicOmegaIcon[] MEM_TEXT = {0,0,14,17,17,10,27,0};	// Omega
#endif
#if LCD_CHAR_U < 8
  const unsigned char CyrillicMuIcon[] MEM_TEXT = {0,17,17,17,19,29,16,16};	// micro
#endif
#ifdef AUTO_CAL
  //const uint16_t R680pl EEMEM = R_L_VAL+PIN_RP;	// total resistor to VCC
  //const uint16_t R680mi EEMEM = R_L_VAL+PIN_RM;	// total resistor to GND
  const int8_t RefDiff EEMEM = REF_R_KORR;		// correction of internal Reference Voltage
#endif
const uint8_t PrefixTab[] MEM_TEXT = { 'p','n',LCD_CHAR_U,'m',0,'k','M'};  // p,n,u,m,-,k,M
#ifdef AUTO_CAL
  //const uint16_t cap_null EEMEM = C_NULL;	// Zero offset of capacity measurement
  const int16_t ref_offset EEMEM = REF_C_KORR;	// default correction of internal reference voltage for capacity measurement
  // LoPin:HiPin                        2:1    3:1    1:2                    :     3:2                   1:3    2:3
  const uint8_t c_zero_tab[] EEMEM = { C_NULL,C_NULL,C_NULL+TP2_CAP_OFFSET,C_NULL,C_NULL+TP2_CAP_OFFSET,C_NULL,C_NULL }; // table of zero offsets
#endif
const uint8_t EE_ESR_ZEROtab[] PROGMEM = {ESR_ZERO, ESR_ZERO, ESR_ZERO, ESR_ZERO};	// zero offset of ESR measurement
// End of EEPROM-Strings
// Multiplier for capacity measurement with R_H (470KOhm)
unsigned int RHmultip = DEFAULT_RH_FAKT;
#else
  // no MAIN_C
  #define COMMON extern
    extern const unsigned char SELFTEST[] MEM_TEXT;
    extern const unsigned char RELPROBE[] MEM_TEXT;
    extern const unsigned char ATE[] MEM_TEXT;
  #endif
  #ifdef AUTO_CAL
    //extern uint16_t R680pl;
    //extern uint16_t R680mi;
    extern int8_t RefDiff;
    extern uint16_t ref_offset;
    extern uint8_t c_zero_tab[];
  #endif
  extern const uint8_t EE_ESR_ZEROtab[] EEMEM;	// zero offset of ESR measurement
  extern const uint16_t RLtab[];
    extern uint16_t LogTab[];
    extern const unsigned char ESR_str[];
  #endif
  #ifdef AUTO_RH
    extern const uint16_t RHtab[];
  #endif
  extern const unsigned char PinRLtab[];
  extern const unsigned char PinADCtab[];
  extern unsigned int RHmultip;
#endif  // MAIN_C
struct Diode_t {
  uint8_t Anode;
  uint8_t Cathode;
  unsigned int Voltage;
COMMON struct Diode_t diodes[6];
COMMON uint8_t NumOfDiodes;
COMMON struct {
  unsigned long hfe[2];		// current amplification factor
  unsigned int uBE[2];		// B-E-voltage of the Transistor
  uint8_t b,c,e;		// pins of the Transistor
}trans;
COMMON unsigned int gthvoltage;	// Gate-threshold voltage
COMMON uint8_t PartReady;	// part detection is finished
COMMON uint8_t PartMode;
COMMON uint8_t tmpval, tmpval2;
COMMON unsigned int ref_mv;     // Reference-voltage  in mV units
COMMON struct resis_t{
  unsigned long rx;		// value of resistor RX
    unsigned long lx;		// inductance 10uH or 100uH
    int8_t lpre;		// prefix for inductance
  #endif
  uint8_t ra,rb;		// Pins of RX
  uint8_t rt;			// Tristate-Pin (inactive)
} resis[3];
COMMON uint8_t ResistorsFound;	// Number of found resistors
COMMON uint8_t ii;		// multipurpose counter
COMMON struct cap_t {
  unsigned long cval;		// capacitor value
  unsigned long cval_max;	// capacitor with maximum value
  union t_combi{
  unsigned long dw;		// capacity value without corrections
  uint16_t w[2];
  } cval_uncorrected;
    unsigned int esr;		// serial resistance of C in 0.01 Ohm
    unsigned int v_loss;	// voltage loss 0.1%
  #endif
  uint8_t ca, cb;		// pins of capacitor
  int8_t cpre;			// Prefix for capacitor value  -12=p, -9=n, -6=u, -3=m
  int8_t cpre_max;		// Prefix of the biggest capacitor
} cap;
  // with sleep mode we need a global ovcnt16
  COMMON volatile uint16_t ovcnt16;
  COMMON volatile uint8_t unfinished;
#endif
COMMON int16_t load_diff;	// difference voltage of loaded capacitor and internal reference
COMMON uint8_t WithReference;	// Marker for found precision voltage reference = 1
COMMON uint8_t PartFound;	// the found part
COMMON char outval[12];		// String for ASCII-outpu
COMMON uint8_t empty_count;	// counter for max count of empty measurements
COMMON uint8_t mess_count;	// counter for max count of nonempty measurements
COMMON struct ADCconfig_t {
  uint8_t Samples;		// number of ADC samples to take
  uint8_t RefFlag;		// save Reference type VCC of IntRef
  uint16_t U_Bandgap;		// Reference Voltage in mV
  uint16_t U_AVCC;		// Voltage of AVCC
} ADCconfig;
#ifdef AUTO_CAL
  COMMON uint8_t pin_combination;	// coded Pin-combination  2:1,3:1,1:2,x:x,3:2,1:3,2:3
  COMMON uint16_t resis680pl;	// port output resistance + 680
  COMMON uint16_t resis680mi;	// port output resistance + 680
  COMMON uint16_t pin_rmi;	// port output resistance to GND side, 0.1 Ohm units
  COMMON uint16_t pin_rpl;	// port output resistance to VCC side, 0.1 Ohm units
#endif
#if POWER_OFF+0 > 1
  COMMON unsigned int display_time;	// display time of measurement in ms units
#endif
// definitions of parts
#define PART_NONE 0
#define PART_DIODE 1
#define PART_TRANSISTOR 2
#define PART_FET 3
#define PART_TRIAC 4
#define PART_THYRISTOR 5
#define PART_RESISTOR 6
#define PART_CAPACITOR 7
#define PART_CELL 8
// special definition for different parts
// FETs
#define PART_MODE_N_E_MOS 2
#define PART_MODE_P_E_MOS 3
#define PART_MODE_N_D_MOS 4
#define PART_MODE_P_D_MOS 5
#define PART_MODE_N_JFET 6
#define PART_MODE_P_JFET 7
// Bipolar
#define PART_MODE_NPN 1
#define PART_MODE_PNP 2
// wait functions
#define  wait5s()    delay(5000)
#define  wait4s()    delay(4000)
#define  wait3s()    delay(3000)
#define  wait2s()    delay(2000)
#define  wait1s()    delay(1000)
#define  wait500ms() delay(500)
#define  wait400ms() delay(400)
#define  wait300ms() delay(300)
#define  wait200ms() delay(200)
#define  wait100ms() delay(100)
#define  wait50ms()  delay(50)
#define  wait40ms()  delay(40)
#define  wait30ms()  delay(30)
#define  wait20ms()  delay(20)
#define  wait10ms()  delay(10)
#define  wait5ms()   delay(5)
#define  wait4ms()   delay(4)
#define  wait3ms()   delay(3)
#define  wait2ms()   delay(2)
#define  wait1ms()   delay(1)
#define  wait500us() delayMicroseconds(500)
#define  wait400us() delayMicroseconds(400)
#define  wait300us() delayMicroseconds(300)
#define  wait200us() delayMicroseconds(200)
#define  wait100us() delayMicroseconds(100)
#define  wait50us()  delayMicroseconds(50)
#define  wait40us()  delayMicroseconds(40)
#define  wait30us()  delayMicroseconds(30)
#define  wait20us()  delayMicroseconds(20)
#define  wait10us()  delayMicroseconds(10)
#define  wait5us()   delayMicroseconds(5)
#define  wait4us()   delayMicroseconds(4)
#define  wait3us()   delayMicroseconds(3)
#define  wait2us()   delayMicroseconds(2)
#define  wait1us()   delayMicroseconds(1)
// Interfacing of a HD44780 compatible LCD with 4-Bit-Interface mode
// LCD-commands
#define CMD_ClearDisplay         0x01
#define CMD_ReturnHome           0x02
#define CMD_SetEntryMode         0x04
#define CMD_SetDisplayAndCursor  0x08
#define CMD_SetIFOptions         0x20
#define CMD_SetCGRAMAddress      0x40    // for Custom character
#define CMD_SetDDRAMAddress      0x80    // set Cursor
#define CMD1_SetBias             0x10	 // set Bias (instruction table 1, DOGM)
#define CMD1_PowerControl        0x50	 // Power Control, set Contrast C5:C4 (instruction table 1, DOGM)
#define CMD1_FollowerControl     0x60	 // Follower Control, amplified ratio (instruction table 1, DOGM)
#define CMD1_SetContrast         0x70	 // set Contrast C3:C0 (instruction table 1, DOGM)
// Makros for LCD
#define lcd_line1() lcd_set_cursor(0,0)  // move to beginning of 1 row
#define lcd_line2() lcd_set_cursor(1,0)  // move to beginning of 2 row
#define lcd_line3() lcd_set_cursor(2,0)  // move to beginning of 3 row
#define lcd_line4() lcd_set_cursor(3,0)  // move to beginning of 4 row
#define uart_newline() Serial.println()
  // prepare sleep mode
  EMPTY_INTERRUPT(TIMER2_COMPA_vect);
  EMPTY_INTERRUPT(ADC_vect);
#endif
uint8_t tmp = 0;
//unsigned int PRR;
byte TestKey;
byte TestKeyPin = 17;  // A3
#ifdef LCD1602
  #ifdef LCD_I2C
    LiquidCrystal_I2C lcd(0x3F, 16, 2);
  #else
    LiquidCrystal lcd(7, 6, 5, 4, 3, 2);  // RS,E,D4,D5,D6,D7
  #endif
#endif
#ifdef NOK5110
  Adafruit_PCD8544 lcd = Adafruit_PCD8544(3, 4, 5, 6, 7);  // CLK,DIN,DC,CE,RST
#endif
#ifdef OLED096
  #ifdef OLED_I2C
   #define SCREEN_WIDTH 128 // OLED display width, in pixels
#define SCREEN_HEIGHT 64 // OLED display height, in pixels
    #define OLED_RESET 7
  Adafruit_SSD1306 display(SCREEN_WIDTH, SCREEN_HEIGHT, &Wire, OLED_RESET);
   // Adafruit_SSD1306 display(OLED_RESET);
  #else
    #define OLED_CLK   7   // D0
    #define OLED_MOSI  6   // D1
    #define OLED_RESET 5   // RES
    #define OLED_DC    4   // DC
    #define OLED_CS    3   // CS
    Adafruit_SSD1306 display(OLED_MOSI, OLED_CLK, OLED_DC, OLED_RESET, OLED_CS);
  #endif
#endif
// begin of transistortester program
  pinMode(TestKeyPin, INPUT);
  #ifdef LCD1602
    #ifdef LCD_I2C
      lcd.begin();
    #else
      lcd.begin(16,2);
    #endif
    lcd_pgm_custom_char(LCD_CHAR_DIODE1, DiodeIcon1);  // Custom-Character Diode symbol >|
    lcd_pgm_custom_char(LCD_CHAR_DIODE2, DiodeIcon2);  // Custom-Character Diode symbol |<
    lcd_pgm_custom_char(LCD_CHAR_CAP,    CapIcon);     // Custom-Character Capacitor symbol ||
    lcd_pgm_custom_char(LCD_CHAR_RESIS1, ResIcon1);    // Custom-Character Resistor symbol [
    lcd_pgm_custom_char(LCD_CHAR_RESIS2, ResIcon2);    // Custom-Character Resistor symbol ]
    lcd_pgm_custom_char(LCD_CHAR_OMEGA,  OmegaIcon);   // load Omega as Custom-Character
    lcd_pgm_custom_char(LCD_CHAR_U,      MicroIcon);   // load Micro as Custom-Character
    lcd.home();
    lcd_string("TransistorTester");
    lcd_set_cursor(1, 0);
    lcd_string("forArduino 1.08a");
  #endif
  #ifdef NOK5110
    lcd.begin();
    lcd.cp437(true);
    lcd.setContrast(40);
    lcd.clearDisplay();
  #endif
  #ifdef OLED096
    #ifdef OLED_I2C
      display.begin(SSD1306_SWITCHCAPVCC, 0x3C);
    #else
      display.begin(SSD1306_SWITCHCAPVCC);
    #endif
    display.cp437(true);
    display.clearDisplay();
    display.setTextColor(WHITE);
    display.setTextSize(1);
    display.setCursor(0,0);
  #endif
    lcd_string("Transistor");
    lcd_string("Tester");
    lcd_set_cursor(2, 0);
    lcd_string("for Arduino");
    lcd_set_cursor(3, 0);
    lcd_string("1.08.004");
  #endif
  //ON_DDR = 0;
  //ON_PORT = 0;
  // switch on
  ON_DDR = (1<<ON_PIN);			// switch to output
  #ifdef PULLUP_DISABLE
    ON_PORT = (1<<ON_PIN); 		// switch power on
  #else
    ON_PORT = (1<<ON_PIN)|(1<<RST_PIN); 	// switch power on , enable internal Pullup for Start-Pin
  #endif
  // ADC-Init
  ADCSRA = (1<<ADEN) | AUTO_CLOCK_DIV;	// prescaler=8 or 64 (if 8Mhz clock)
  #ifdef __AVR_ATmega8__
    //#define WDRF_HOME MCU_STATUS_REG
    #define WDRF_HOME MCUCSR
  #else
    #define WDRF_HOME MCUSR
  #endif
  tmp = (WDRF_HOME & (1<<WDRF));	// save Watch Dog Flag
  WDRF_HOME &= ~(1<<WDRF);	 	// reset Watch Dog flag
  wdt_disable();			// disable Watch Dog
    // switch off unused Parts
    PRR = (1<<PRTWI) | (1<<PRTIM0) | (1<<PRSPI) | (1<<PRUSART0);
    DIDR0 = (1<<ADC5D) | (1<<ADC4D) | (1<<ADC3D);
    TCCR2A = (0<<WGM21) | (0<<WGM20);			// Counter 2 normal mode
    #if F_CPU <= 1000000UL
      TCCR2B = (1<<CS22) | (0<<CS21) | (1<<CS20);	// prescaler 128, 128us @ 1MHz
      #define T2_PERIOD 128
    #endif
    #if F_CPU == 2000000UL
      TCCR2B = (1<<CS22) | (1<<CS21) | (0<<CS20);	// prescaler 256, 128us @ 2MHz
    #endif
    #if F_CPU == 4000000UL
      TCCR2B = (1<<CS22) | (1<<CS21) | (0<<CS20);	// prescaler 256, 64us @ 2MHz
      #define T2_PERIOD 64
    #endif
    #if F_CPU >= 8000000UL
      TCCR2B = (1<<CS22) | (1<<CS21) | (1<<CS20);	// prescaler 1024, 128us @ 8MHz, 64us @ 16MHz
      #define T2_PERIOD (1024 / (F_CPU / 1000000UL));	// set to 128 or 64 us
    #endif
    sei();	// enable interrupts
  #endif
  //ADC_PORT = TXD_VAL;
  //ADC_DDR = TXD_MSK;
  if(tmp) {
    // check if Watchdog-Event
    // this happens, if the Watchdog is not reset for 2s
    // can happen, if any loop in the Program doen't finish.
    lcd_line1();
    lcd_fix_string(TestTimedOut);	// Output Timeout
    wait_about3s();			// wait for 3 s
    //ON_PORT = 0;			// shut off!
    //ON_DDR = (1<<ON_PIN);		// switch to GND
    //return;
      SFIOR = (1<<PUD);		// disable Pull-Up Resistors mega8
    #else
      MCUCR = (1<<PUD);		// disable Pull-Up Resistors mega168 family
    #endif
  #endif
  //DIDR0 = 0x3f;		// disable all Input register of ADC
  #if POWER_OFF+0 > 1
    // tester display time selection
    display_time = OFF_WAIT_TIME;		// LONG_WAIT_TIME for single mode, else SHORT_WAIT_TIME
    if (!(ON_PIN_REG & (1<<RST_PIN))) {
      // if power button is pressed ...
      wait_about300ms();			// wait to catch a long key press
        // check if power button is still pressed
        display_time = LONG_WAIT_TIME;		// ... set long time display anyway
  #else
    #define display_time OFF_WAIT_TIME
  #endif
  empty_count = 0;
  mess_count = 0;
  // Entry: if start key is pressed before shut down
start:
  #ifdef NOK5110
    lcd.display();
  #endif
  #ifdef OLED096
    display.display();
  #endif
  TestKey = 1;
  while(TestKey) {
    TestKey = digitalRead(TestKeyPin);
    delay(100);
  while(!TestKey) {
    delay(100);
  lcd_clear();
  delay(100);
  PartFound = PART_NONE;	// no part found
  NumOfDiodes = 0;		// Number of diodes = 0
  PartReady = 0;
  PartMode = 0;
  WithReference = 0;		// no precision reference voltage
  ADC_DDR = TXD_MSK;		// activate Software-UART
  ResistorsFound = 0;		// no resistors found
  cap.ca = 0;
  cap.cb = 0;
  #ifdef WITH_UART
    uart_newline();		// start of new measurement
  #endif
  ADCconfig.RefFlag = 0;
  Calibrate_UR();		// get Ref Voltages and Pin resistance
  lcd_line1();    // 1 row
  ADCconfig.U_Bandgap = ADC_internal_reference;  // set internal reference voltage for ADC
  #ifdef BAT_CHECK
    // Battery check is selected
    ReadADC(TPBAT);			// Dummy-Readout
    trans.uBE[0] = W5msReadADC(TPBAT); 	// with 5V reference
    lcd_fix_string(Bat_str);		// output: "Bat. "
    #ifdef BAT_OUT
      // display Battery voltage
      // The divisor to get the voltage in 0.01V units is ((10*33)/133) witch is about 2.4812
      // A good result can be get with multiply by 4 and divide by 10 (about 0.75%).
      //cap.cval = (trans.uBE[0]*4)/10+((BAT_OUT+5)/10); // usually output only 2 digits
      //DisplayValue(cap.cval,-2,'V',2);		// Display 2 Digits of this 10mV units
      cap.cval = (trans.uBE[0]*4)+BAT_OUT;		// usually output only 2 digits
      DisplayValue(cap.cval,-3,'V',2);			// Display 2 Digits of this 10mV units
      lcd_space();
    #endif
    #if (BAT_POOR > 12000)
      #warning "Battery POOR level is set very high!"
    #endif
    #if (BAT_POOR < 2500)
      #warning "Battery POOR level is set very low!"
    #endif
    #if (BAT_POOR > 5300)
      // use .8 V difference to Warn-Level
      #define WARN_LEVEL (((unsigned long)(BAT_POOR+800)*(unsigned long)33)/133)
    #elif (BAT_POOR > 3249)
      // less than 5.4 V only .4V difference to Warn-Level
      #define WARN_LEVEL (((unsigned long)(BAT_POOR+400)*(unsigned long)33)/133)
    #elif (BAT_POOR > 1299)
      // less than 2.9 V only .2V difference to Warn-Level
      #define WARN_LEVEL (((unsigned long)(BAT_POOR+200)*(unsigned long)33)/133)
    #else
      // less than 1.3 V only .1V difference to Warn-Level
      #define WARN_LEVEL (((unsigned long)(BAT_POOR+100)*(unsigned long)33)/133)
    #endif
    #define POOR_LEVEL (((unsigned long)(BAT_POOR)*(unsigned long)33)/133)
    // check the battery voltage
    if (trans.uBE[0] <  WARN_LEVEL) {
      // Vcc < 7,3V; show Warning
      if(trans.uBE[0] < POOR_LEVEL) {
        // Vcc <6,3V; no proper operation is possible
        lcd_fix_string(BatEmpty);	// Battery empty!
        wait_about2s();
        PORTD = 0;			// switch power off
        return;
      lcd_fix_string(BatWeak);		// Battery weak
    } else {                            // Battery-voltage OK
      lcd_fix_string(OK_str); 		// "OK"
  #else
    lcd_fix2_string(VERSION_str);	// if no Battery check, Version .. in row 1
  #endif
  #ifdef WDT_enabled
    //wdt_enable(WDTO_2S);		// Watchdog on
  #endif
  //wait_about1s();			// add more time for reading batterie voltage
  // begin tests
  #ifdef AUTO_RH
    RefVoltage();			// compute RHmultip = f(reference voltage)
  #endif
    if (WithReference) {
      // 2.5V precision reference is checked OK
      if ((mess_count == 0) && (empty_count == 0)) {
        // display VCC= only first time
        lcd_line2();
        lcd_fix_string(VCC_str);			// VCC=
        DisplayValue(ADCconfig.U_AVCC,-3,'V',3);	// Display 3 Digits of this mV units
        //lcd_space();
        //DisplayValue(RRpinMI,-1,LCD_CHAR_OMEGA,4);
        wait_about1s();
  #endif
  #ifdef WITH_VEXT
    // show the external voltage
    while (!(ON_PIN_REG & (1<<RST_PIN))) {
      lcd_line2();
      lcd_clear_line();
      lcd_line2();
      lcd_fix_string(Vext_str);			// Vext=
      ADC_DDR = 0;				// deactivate Software-UART
      trans.uBE[1] = W5msReadADC(TPext);	// read external voltage
      #ifdef WITH_UART
      #endif
      DisplayValue(trans.uBE[1]*10,-3,'V',3);	// Display 3 Digits of this mV units
      wait_about300ms();
  #endif
  lcd_line2();			// LCD position row 2, column 1
  lcd_fix_string(TestRunning);	// String: testing...
  #ifndef DebugOut
  #endif
  #ifdef NOK5110
    lcd.display();
  #endif
  #ifdef OLED096
    display.display();
  #endif
  delay(5);
  EntladePins();		// discharge all capacitors!
  if(PartFound == PART_CELL) {
    lcd_clear();
    lcd_fix_string(Cell_str);	// display "Cell!"
    goto end2;
  #ifdef CHECK_CALL
    AutoCheck();		// check, if selftest should be done
  #endif
  // check all 6 combinations for the 3 pins
  //       High  Low  Tri
  CheckPins(TP1, TP2, TP3);
  CheckPins(TP2, TP1, TP3);
  CheckPins(TP1, TP3, TP2);
  CheckPins(TP3, TP1, TP2);
  CheckPins(TP2, TP3, TP1);
  CheckPins(TP3, TP2, TP1);
  // separate check if is is a capacitor
  if(((PartFound == PART_NONE) || (PartFound == PART_RESISTOR) || (PartFound == PART_DIODE)) ) {
    EntladePins();		// discharge capacities
    // measurement of capacities in all 3 combinations
    cap.cval_max = 0;		// set max to zero
    cap.cpre_max = -12;		// set max to pF unit
    ReadCapacity(TP3, TP1);
    ReadCapacity(TP3, TP2);
    ReadCapacity(TP2, TP1);
      ReadInductance();		// measure inductance
    #endif
  // All checks are done, output result to display
  lcd_clear();
  if(PartFound == PART_DIODE) {
    if(NumOfDiodes == 1) {		// single Diode
      //lcd_fix_string(Diode);		// "Diode: "
        // enough memory to sort the pins
          // the higher test pin number is left side
          if (diodes[0].Anode > diodes[0].Cathode) {
            lcd_testpin(diodes[0].Anode);
            lcd_fix_string(AnKat);          // "->|-"
            lcd_testpin(diodes[0].Cathode);
            lcd_fix_string(KatAn);          // "-|<-"
        #else
          // the higher test pin number is right side
          if (diodes[0].Anode < diodes[0].Cathode) {
        #endif
      #else
        // too less memory to sort the pins
      #endif
        GetIr(diodes[0].Cathode,diodes[0].Anode);
      #endif
      UfOutput(0x70);
        lcd_line3();
      #endif
      // load current of capacity is (5V-1.1V)/(470000 Ohm) = 8298nA
      lcd_fix_string(GateCap_str);			// "C="
      ReadCapacity(diodes[0].Cathode,diodes[0].Anode);	// Capacity opposite flow direction
      DisplayValue(cap.cval,cap.cpre,'F',3);
      goto end;
    } else if(NumOfDiodes == 2) { 	// double diode
      lcd_data('2');
      lcd_fix_string(Diodes);		// "diodes "
      if(diodes[0].Anode == diodes[1].Anode) { //Common Anode
        lcd_testpin(diodes[1].Cathode);
        UfOutput(0x01);
        goto end;
      } else if(diodes[0].Cathode == diodes[1].Cathode) { //Common Cathode
        lcd_testpin(diodes[1].Anode);
        UfOutput(0x01);
        goto end;
      } else if ((diodes[0].Cathode == diodes[1].Anode) && (diodes[1].Cathode == diodes[0].Anode)) {
        // Antiparallel
        UfOutput(0x01);
        goto end;
    } else if(NumOfDiodes == 3) {
      // Serial of 2 Diodes; was detected as 3 Diodes
      trans.b = 3;
      trans.c = 3;
      // Check for any constallation of 2 serial diodes:
      // Only once the pin No of anyone Cathode is identical of another anode.
      // two diodes in series is additionally detected as third big diode.
      if(diodes[0].Cathode == diodes[1].Anode) {
        trans.b = 0;
        trans.c = 1;
      if(diodes[0].Anode == diodes[1].Cathode) {
        trans.b = 1;
        trans.c = 0;
      if(diodes[0].Cathode == diodes[2].Anode) {
        trans.b = 0;
        trans.c = 2;
      if(diodes[0].Anode == diodes[2].Cathode) {
        trans.b = 2;
        trans.c = 0;
      if(diodes[1].Cathode == diodes[2].Anode) {
        trans.b = 1;
        trans.c = 2;
      if(diodes[1].Anode == diodes[2].Cathode) {
        trans.b = 2;
        trans.c = 1;
      #if DebugOut == 4
        lcd_line3();
        lcd_data(':');
        lcd_space();
        lcd_string(utoa(diodes[0].Voltage, outval, 10));
        lcd_space();
        lcd_data(':');
        lcd_space();
        lcd_string(utoa(diodes[1].Voltage, outval, 10));
        lcd_line4();
        lcd_testpin(diodes[2].Anode);
        lcd_data(':');
        lcd_testpin(diodes[2].Cathode);
        lcd_space();
        lcd_string(utoa(diodes[2].Voltage, outval, 10));
        lcd_line1();
      #endif
      if((trans.b < 3) && (trans.c < 3)) {
        lcd_data('3');
        lcd_fix_string(Diodes);			// "Diodes "
        lcd_testpin(diodes[trans.b].Anode);
        lcd_testpin(diodes[trans.b].Cathode);
        lcd_testpin(diodes[trans.c].Cathode);
        UfOutput( (trans.b<<4)|trans.c);
        goto end;
    // end (PartFound == PART_DIODE)
  } else if (PartFound == PART_TRANSISTOR) {
    if(PartReady != 0) {
      if((trans.hfe[0]>trans.hfe[1])) {
        // if the amplification factor was higher at first testr: swap C and E !
        tmp = trans.c;
        trans.c = trans.e;
        trans.e = tmp;
        trans.hfe[0] = trans.hfe[1];
        trans.uBE[0] = trans.uBE[1];
    if(PartMode == PART_MODE_NPN) {
      lcd_fix_string(NPN_str);		// "NPN "
      lcd_fix_string(PNP_str);		// "PNP "
    if( NumOfDiodes > 2) {	// Transistor with protection diode
      #ifdef EBC_STYLE
          // Layout with 321= style
          if (((PartMode == PART_MODE_NPN) && (trans.c < trans.e)) || ((PartMode != PART_MODE_NPN) && (trans.c > trans.e)))
        #else
          // Layout with EBC= style
        #endif
      #else
        // Layout with 123= style
        if (((PartMode == PART_MODE_NPN) && (trans.c > trans.e)) || ((PartMode != PART_MODE_NPN) && (trans.c < trans.e)))
      #endif
      lcd_line2();
    #endif
    PinLayout('E','B','C'); 		// EBC= or 123=...
      lcd_line3();
    #else
      lcd_line2();  // 2 row
    #endif
    lcd_fix_string(hfe_str);		// "B="  (hFE)
    DisplayValue(trans.hfe[0],0,0,3);
    lcd_space();
      lcd_line4();
    #endif
    lcd_fix_string(Uf_str);		// "Uf="
    DisplayValue(trans.uBE[0],-3,'V',3);
    goto end;
    // end (PartFound == PART_TRANSISTOR)
  } else if (PartFound == PART_FET) {	// JFET or MOSFET
    if(PartMode&1) {
      lcd_data('P');			// P-channel
      lcd_data('N');			// N-channel
    lcd_data('-');
    tmp = PartMode/2;
    if (tmp == (PART_MODE_N_D_MOS/2)) {
      lcd_data('D');			// N-D
    if (tmp == (PART_MODE_N_E_MOS/2)) {
      lcd_data('E');			// N-E
    if (tmp == (PART_MODE_N_JFET/2)) {
      lcd_fix_string(jfet_str);         // "JFET"
      lcd_fix_string(mosfet_str);       // "-MOS "
      lcd_line2();
    #endif
    PinLayout('S','G','D'); 		// SGD= or 123=...
    if((NumOfDiodes > 0) && (PartMode < PART_MODE_N_D_MOS)) {
      // MOSFET with protection diode; only with enhancement-FETs
      #ifdef EBC_STYLE
          // layout with 321= style
          if (((PartMode&1) && (trans.c > trans.e)) || ((!(PartMode&1)) && (trans.c < trans.e)))
        #else
          // Layout with SGD= style
          if (PartMode&1)		// N or P MOS
        #endif
      #else
        // layout with 123= style
        if (((PartMode&1) && (trans.c < trans.e)) || ((!(PartMode&1)) && (trans.c > trans.e)))
      #endif
          lcd_data(LCD_CHAR_DIODE1);	// show Diode symbol >|
          lcd_data(LCD_CHAR_DIODE2);	// show Diode symbol |<
      lcd_line3();
    #else
    #endif
    if(PartMode < PART_MODE_N_D_MOS) {		// enhancement-MOSFET
      // Gate capacity
      ReadCapacity(trans.b,trans.e);		// measure capacity
        lcd_line4();
      #endif
      lcd_fix_string(vt_str);			// "Vt="
      lcd_data('I');
      lcd_data('=');
      DisplayValue(trans.uBE[1],-5,'A',2);
        lcd_line4();
      #endif
      lcd_fix_string(Vgs_str);			// " Vgs="
    DisplayValue(gthvoltage,-3,'V',2);
    goto end;
    // end (PartFound == PART_FET)
  } else if (PartFound == PART_THYRISTOR) {
    lcd_fix_string(Thyristor);			// "Thyristor"
    goto gakOutput;
  } else if (PartFound == PART_TRIAC) {
    lcd_fix_string(Triac);			// "Triac"
    goto gakOutput;
  } else if(PartFound == PART_RESISTOR) {
    if (ResistorsFound == 1) {		 	// single resistor
      lcd_testpin(resis[0].rb);			// Pin-number 1
      lcd_fix_string(Resistor_str);
      lcd_testpin(resis[0].ra);			// Pin-number 2
    } else {					// R-Max suchen
      ii = 0;
      if (resis[1].rx > resis[0].rx)
        ii = 1;
      if (ResistorsFound == 2) {
        ii = 2;
        if (resis[2].rx > resis[ii].rx)
          ii = 2;
      char x = '1';
      char y = '3';
      char z = '2';
      if (ii == 1) {
        //x = '1';
        y = '2';
        z = '3';
      if (ii == 2) {
        x = '2';
        y = '1';
        z = '3';
      lcd_data(x);
      lcd_fix_string(Resistor_str);    // "-[=]-"
      lcd_data(y);
      lcd_data(z);
      RvalOut(0);
        if (resis[0].lx != 0) {
          // resistor have also Inductance
            lcd_line3();
          #endif
          lcd_fix_string(Lis_str);				// "L="
          DisplayValue(resis[0].lx,resis[0].lpre,'H',3);	// output inductance
      #endif
      // output resistor values in right order
      if (ii == 0) {
        RvalOut(1);
        RvalOut(2);
      if (ii == 1) {
        RvalOut(0);
        RvalOut(2);
      if (ii == 2) {
        RvalOut(0);
        RvalOut(1);
    goto end;
    // end (PartFound == PART_RESISTOR)
  // capacity measurement is wanted
  } else if(PartFound == PART_CAPACITOR) {
    //lcd_fix_string(Capacitor);
    lcd_testpin(cap.ca);		// Pin number 1
    lcd_fix_string(CapZeich);		// capacitor sign
    lcd_testpin(cap.cb);		// Pin number 2
      GetVloss();			// get Voltage loss of capacitor
      if (cap.v_loss != 0) {
          lcd_line4();
        #endif
        lcd_fix_string(VLOSS_str);	// "  Vloss="
        DisplayValue(cap.v_loss,-1,'%',2);
    #endif
    DisplayValue(cap.cval_max,cap.cpre_max,'F',4);
      cap.esr = GetESR(cap.cb, cap.ca);		// get ESR of capacitor
      if (cap.esr < 65530) {
          lcd_line3();
        #endif
        lcd_fix_string(ESR_str);
        DisplayValue(cap.esr,-2,LCD_CHAR_OMEGA,2);
    #endif
    goto end;
  if(NumOfDiodes == 0) { 		// no diodes are found
    lcd_fix_string(TestFailed1); 	// "No, unknown, or"
    lcd_fix_string(TestFailed2); 	// "damaged "
    lcd_fix_string(Component);		// "part"
    lcd_fix_string(Unknown); 		// " unknown"
    lcd_fix_string(OrBroken); 		// "or damaged "
    lcd_data(NumOfDiodes + '0');
  empty_count++;
  mess_count = 0;
  goto end2;
gakOutput:
  PinLayout(Cathode_char,'G','A'); 	// CGA= or 123=...
end:
  empty_count = 0;		// reset counter, if part is found
  mess_count++;			// count measurements
end2:
  //ADC_DDR = (1<<TPREF) | TXD_MSK;  // switch pin with reference to GND, release relay
  ADC_DDR = TXD_MSK;                 // switch pin with reference to GND, release relay
  goto start;
  while(!(ON_PIN_REG & (1<<RST_PIN)));	// wait ,until button is released
  wait_about200ms();
  // wait 14 seconds or 5 seconds (if repeat function)
  for(gthvoltage = 0;gthvoltage<display_time;gthvoltage+=10) {
    if(!(ON_PIN_REG & (1<<RST_PIN))) {
      // If the key is pressed again...
      // goto start of measurement
      goto start;
    wdt_reset();
    wait_about10ms();
  #ifdef POWER_OFF
    #if POWER_OFF > 127
      #define POWER2_OFF 255
    #else
      #define POWER2_OFF POWER_OFF*2
    #endif
    #if POWER_OFF+0 > 1
      if ((empty_count < POWER_OFF) && (mess_count < POWER2_OFF)) {
        goto start;			// repeat measurement POWER_OFF times
    #endif
    // only one Measurement requested, shut off
    //MCUSR = 0;
    ON_PORT &= ~(1<<ON_PIN);		// switch off power
    // never ending loop
    while(1) {
        // The statement is only reached if no auto off equipment is installed
        goto start;
      wdt_reset();
      wait_about10ms();
  #else
    goto start;  // POWER_OFF not selected, repeat measurement
  #endif
  return;
} // end main
// output of flux voltage for 1-2 diodes in row 2
// bcdnum = Numbers of both Diodes:
// higher 4 Bit  number of first Diode
// lower 4 Bit  number of second Diode (Structure diodes[nn])
// if number >= 3  no output is done
void UfOutput(uint8_t bcdnum) {
  mVOutput(bcdnum >> 4);
  mVOutput(bcdnum & 0x0f);
void mVOutput(uint8_t nn) {
  if (nn < 3) {
    // Output in mV units
    DisplayValue(diodes[nn].Voltage,-3,'V',3);
    lcd_space();
void RvalOut(uint8_t ii) {
  // output of resistor value
    uint16_t rr;
    if ((resis[ii].rx < 100) && (resis[0].lx == 0)) {
      rr = GetESR(resis[ii].ra,resis[ii].rb);
      DisplayValue(rr,-2,LCD_CHAR_OMEGA,3);
      DisplayValue(resis[ii].rx,-1,LCD_CHAR_OMEGA,4);
  #else
  #endif
  lcd_space();
void ChargePin10ms(uint8_t PinToCharge, uint8_t ChargeDirection) {
  // Load the specified pin to the specified direction with 680 Ohm for 10ms.
  // Will be used by discharge of MOSFET Gates or to load big capacities.
  // Parameters:
  // PinToCharge: specifies the pin as mask for R-Port
  // ChargeDirection: 0 = switch to GND (N-Kanal-FET), 1= switch to VCC(P-Kanal-FET)
  if(ChargeDirection&1) {
    R_PORT |= PinToCharge;	// R_PORT to 1 (VCC)
    R_PORT &= ~PinToCharge; 	// or 0 (GND)
  R_DDR |= PinToCharge;			// switch Pin to output, across R to GND or VCC
  wait_about10ms();			// wait about 10ms
  // switch back Input, no current
  R_DDR &= ~PinToCharge;		// switch back to input
  R_PORT &= ~PinToCharge;		// no Pull up
// first discharge any charge of capacitors
void EntladePins() {
  uint8_t adc_gnd;		// Mask of ADC-outputs, which can be directly connected to GND
  unsigned int adcmv[3];	// voltages of 3 Pins in mV
  unsigned int clr_cnt;		// Clear Counter
  uint8_t lop_cnt;		// loop counter
  // max. time of discharge in ms  (10000/20) == 10s
  #define MAX_ENTLADE_ZEIT  (10000/20)
  for(lop_cnt=0;lop_cnt<10;lop_cnt++) {
    adc_gnd = TXD_MSK;		// put all ADC to Input
    ADC_DDR = adc_gnd;
    ADC_PORT = TXD_VAL;		// ADC-outputs auf 0
    R_PORT = 0;			// R-outputs auf 0
    R_DDR = (2<<(TP3*2)) | (2<<(TP2*2)) | (2<<(TP1*2));  // R_H for all Pins to GND
    adcmv[0] = W5msReadADC(TP1);	// which voltage has Pin 1?
    adcmv[1] = ReadADC(TP2);		// which voltage has Pin 2?
    adcmv[2] = ReadADC(TP3);		// which voltage has Pin 3?
    if ((PartFound == PART_CELL) || (adcmv[0] < CAP_EMPTY_LEVEL)
                                  & (adcmv[1] < CAP_EMPTY_LEVEL)
                                  & (adcmv[2] < CAP_EMPTY_LEVEL)) {
      ADC_DDR = TXD_MSK;		// switch all ADC-Pins to input
      R_DDR = 0;			// switch all R_L Ports (and R_H) to input
      return;				// all is discharged
    // all Pins with voltage lower than 1V can be connected directly to GND (ADC-Port)
    if (adcmv[0] < 1000) {
      adc_gnd |= (1<<TP1);	// Pin 1 directly to GND
    if (adcmv[1] < 1000) {
      adc_gnd |= (1<<TP2);	// Pin 2 directly to GND
    if (adcmv[2] < 1000) {
      adc_gnd |= (1<<TP3);	// Pin 3 directly to  GND
    ADC_DDR = adc_gnd;		// switch all selected ADC-Ports at the same time
    // additionally switch the leaving Ports with R_L to GND.
    // since there is no disadvantage for the already directly switched pins, we can
    // simply switch all  R_L resistors to GND
    R_DDR = (1<<(TP3*2)) | (1<<(TP2*2)) | (1<<(TP1*2));	// Pins across R_L resistors to GND
    for(clr_cnt=0;clr_cnt<MAX_ENTLADE_ZEIT;clr_cnt++) {
      wdt_reset();
      adcmv[0] = W20msReadADC(TP1);	// which voltage has Pin 1?
      if (adcmv[0] < 1300) {
         ADC_DDR |= (1<<TP1);	// below 1.3V , switch directly with ADC-Port to GND
      if (adcmv[1] < 1300) {
         ADC_DDR |= (1<<TP2);	// below 1.3V, switch directly with ADC-Port to GND
      if (adcmv[2] < 1300) {
         ADC_DDR |= (1<<TP3);	// below 1.3V, switch directly with ADC-Port to GND
      if ((adcmv[0] < (CAP_EMPTY_LEVEL+2)) && (adcmv[1] < (CAP_EMPTY_LEVEL+2)) && (adcmv[2] < (CAP_EMPTY_LEVEL+2))) {
    if (clr_cnt == MAX_ENTLADE_ZEIT) {
      PartFound = PART_CELL;		// mark as Battery
      // there is charge on capacitor, warn later!
    for(adcmv[0]=0;adcmv[0]<clr_cnt;adcmv[0]++) {
      // for safety, discharge 5% of discharge  time
      wait1ms();
  }  // end for lop_cnt
#ifdef AUTO_RH
void RefVoltage(void) {
// RefVoltage interpolates table RHtab corresponding to voltage ref_mv .
// RHtab contain the factors to get capacity from load time with 470k for
// different Band gab reference voltages.
// for remember:
// uint16_t RHTAB[] MEM_TEXT = { 954, 903, 856, 814, 775, 740, 707, 676, 648};
  #define Ref_Tab_Abstand 50		// displacement of table is 50mV
  #define Ref_Tab_Beginn 1000		// begin of table is 1000mV
  unsigned int referenz;
  unsigned int y1, y2;
  uint8_t tabind;
  uint8_t tabres;
  #ifdef AUTO_CAL
    referenz = ref_mv + (int16_t)eeprom_read_word((uint16_t *)(&ref_offset));
  #else
    referenz = ref_mv + REF_C_KORR;
  #endif
  if (referenz >= Ref_Tab_Beginn) {
    referenz -= Ref_Tab_Beginn;
    referenz = 0;	// limit to begin of table
  tabind = referenz / Ref_Tab_Abstand;
  tabres = referenz % Ref_Tab_Abstand;
  tabres = Ref_Tab_Abstand-tabres;
  if (tabind > 7) {
    tabind = 7;		// limit to end of table
  // interpolate the table of factors
  y1 = pgm_read_word(&RHtab[tabind]);
  y2 = pgm_read_word(&RHtab[tabind+1]);
  // RHmultip is the interpolated factor to compute capacity from load time with 470k
  RHmultip = ((y1 - y2) * tabres + (Ref_Tab_Abstand/2)) / Ref_Tab_Abstand + y2;
#endif
#ifdef LCD_CLEAR
void lcd_clear_line(void) {
  // writes 20 spaces to LCD-Display, Cursor must be positioned to first column
  unsigned char ll;
  for (ll=0;ll<20;ll++) {
    lcd_space();
#endif
 *   display of values and units
 *  display value and unit
 *  - max. 4 digits excluding "." and unit
 *  requires:
 *  - value
 *  - exponent of factor related to base unit (value * 10^x)
 *    e.g: p = 10^-12 -> -12
 *  - unit character (0 = none)
 *  digits = 2, 3 or 4
void DisplayValue(unsigned long Value, int8_t Exponent, unsigned char Unit, unsigned char digits)
  char OutBuffer[15];
  unsigned int      Limit;
  unsigned char     Prefix;		// prefix character
  uint8_t           Offset;		// exponent of offset to next 10^3 step
  uint8_t           Index;		// index ID
  uint8_t           Length;		// string length
  Limit = 100;				// scale value down to 2 digits
  if (digits == 3) Limit = 1000;	// scale value down to 3 digits
  if (digits == 4) Limit = 10000;	// scale value down to 4 digits
  while (Value >= Limit)
    Value += 5;				// for automatic rounding
    Value = Value / 10;			// scale down by 10^1
    Exponent++;				// increase exponent by 1
  // determine prefix
  Length = Exponent + 12;
  if ((int8_t)Length <  0) Length = 0;	// Limit to minimum prefix
  if (Length > 18) Length = 18;		// Limit to maximum prefix
  Index = Length / 3;
  Offset = Length % 3;
  if (Offset > 0)
      Index++;				// adjust index for exponent offset, take next prefix
      Offset = 3 - Offset;		// reverse value (1 or 2)
  #ifdef NO_NANO
    if (Index == 1)
      { // use no nano
        Index++;			// use mikro instead of nano
        Offset += 3;			// can be 3,4 or 5
  #endif
  Prefix = MEM_read_byte((uint8_t *)(&PrefixTab[Index]));   // look up prefix in table
  // display value
  // convert value into string
  utoa((unsigned int)Value, OutBuffer, 10);
  Length = strlen(OutBuffer);
  // position of dot
  Exponent = Length - Offset;		// calculate position
  if (Exponent <= 0)			// we have to prepend "0."
    // 0: factor 10 / -1: factor 100
    //lcd_data('0');
    lcd_data('.');
    #ifdef NO_NANO
      while (Exponent < 0)
          lcd_data('0');		// extra 0 for factor 10
          Exponent++;
    #else
      if (Exponent < 0) lcd_data('0');	// extra 0 for factor 100
    #endif
  if (Offset == 0) Exponent = -1;	// disable dot if not needed
  // adjust position to array or disable dot if set to 0
  //Exponent--;
  // display value and add dot if requested
  Index = 0;
  while (Index < Length)		// loop through string
    lcd_data(OutBuffer[Index]);		// display char
    Index++;				// next one
    if (Index == Exponent) {
      lcd_data('.');			// display dot
  // display prefix and unit
  if (Prefix != 0) lcd_data(Prefix);
  if (Unit) lcd_data(Unit);
// set the processor to sleep state
// wake up will be done with compare match interrupt of counter 2
void sleep_5ms(uint16_t pause){
  // pause is the delay in 5ms units
  uint8_t t2_offset;
  #define RESTART_DELAY_US (RESTART_DELAY_TICS/(F_CPU/1000000UL))
  // for 8 MHz crystal the Restart delay is 16384/8 = 2048us
  while (pause > 0) {
    #if 3000 > RESTART_DELAY_US
      if (pause > 1) {
        // Startup time is too long with 1MHz Clock!!!!
        t2_offset = (10000 - RESTART_DELAY_US) / T2_PERIOD;	// set to 10ms above the actual counter
        pause -= 2;
        t2_offset = (5000 - RESTART_DELAY_US) / T2_PERIOD;	// set to 5ms above the actual counter
        pause = 0;
      OCR2A = TCNT2 + t2_offset;			// set the compare value
      TIMSK2 = (0<<OCIE2B) | (1<<OCIE2A) | (0<<TOIE2);  // enable output compare match A interrupt
      set_sleep_mode(SLEEP_MODE_PWR_SAVE);
      //set_sleep_mode(SLEEP_MODE_IDLE);
      sleep_mode();
      // wake up after output compare match interrupt
    #else
      // restart delay ist too long, use normal delay of 5ms
      wait5ms();
    #endif
    wdt_reset();
  TIMSK2 = (0<<OCIE2B) | (0<<OCIE2A) | (0<<TOIE2);  // disable output compare match A interrupt
#endif
// show the Pin Layout of the device
void PinLayout(char pin1, char pin2, char pin3) {
  // pin1-3 is EBC or SGD or CGA
  #ifndef EBC_STYLE
    lcd_fix_string(N123_str);			// " 123="
    for (ii=0;ii<3;ii++) {
      if (ii == trans.e)  lcd_data(pin1);	// Output Character in right order
      if (ii == trans.b)  lcd_data(pin2);
      if (ii == trans.c)  lcd_data(pin3);
  #else
      lcd_fix_string(N321_str);			// " 321="
      ii = 3;
      while (ii != 0) {
        ii--;
    #else
      lcd_space();
      lcd_data(pin1);
      lcd_data(pin2);
      lcd_data(pin3);
      lcd_data('=');
      lcd_testpin(trans.e);
      lcd_testpin(trans.b);
      lcd_testpin(trans.c);
    #endif
  #endif
void AutoCheck(void) {
  uint8_t tt;		// number of running test
  uint8_t ww;		// counter for repeating the tests
  int  adcmv[7];
  uint16_t u680;	// 3 * (Voltage at 680 Ohm)
  // define the maximum count of repetitions MAX_REP
  #define MAX_REP 4
  #ifdef AUTO_CAL
    uint8_t cap_found;	// counter for found capacitor
    #ifdef AUTOSCALE_ADC
      int8_t udiff;		// difference between ADC Voltage with VCC or Bandgap reference
      int8_t udiff2;
    #endif
  #endif
  ADC_PORT = TXD_VAL;
  ADC_DDR = TXD_MSK;
  #define RequireShortedProbes
  if (AllProbesShorted() != 3) return;
  lcd_clear();
  lcd_fix_string(SELFTEST);		// "Selftest mode.."
  lcd_line2();
  lcd_fix2_string(R0_str);		// "R0="
  eeprom_write_byte((uint8_t *)(&EE_ESR_ZEROtab[2]), (int8_t)0);	// clear zero offset
  eeprom_write_byte((uint8_t *)(&EE_ESR_ZEROtab[3]), (int8_t)0);	// clear zero offset
  eeprom_write_byte((uint8_t *)(&EE_ESR_ZEROtab[1]), (int8_t)0);	// clear zero offset
  adcmv[0] = GetESR(TP3, TP1);
  adcmv[1] = GetESR(TP3, TP2);
  adcmv[2] = GetESR(TP2, TP1);
  DisplayValue(adcmv[0],-2,' ',3);
  DisplayValue(adcmv[1],-2,' ',3);
  DisplayValue(adcmv[2],-2,LCD_CHAR_OMEGA,3);
  if (adcmv[0] < 60) {
    eeprom_write_byte((uint8_t *)(&EE_ESR_ZEROtab[2]), (int8_t)adcmv[0]);	// fix zero offset
  if (adcmv[1] < 60) {
    eeprom_write_byte((uint8_t *)(&EE_ESR_ZEROtab[3]), (int8_t)adcmv[1]);	// fix zero offset
  if (adcmv[2] < 60) {
    eeprom_write_byte((uint8_t *)(&EE_ESR_ZEROtab[1]), (int8_t)adcmv[2]);	// fix zero offset
  for(tt=0; tt<12; tt++) {
    wait_about500ms();
      // if key is pressed, don't repeat
  }   // end for tt
  #define TEST_COUNT 8
  for(tt=1; tt<TEST_COUNT; tt++) {	// loop for all Tests
    for(ww=0; ww<MAX_REP; ww++) {	// repeat the test MAX_REP times
      lcd_line2();			// Cursor to column 1, row 2
      lcd_clear_line();			// clear total line
      lcd_line1();			// Cursor to column 1, row 1
      lcd_data('T');			// output the Testmode "T"
      lcd_string(utoa(tt, outval, 10));	// output Test number
      lcd_space();
      if (tt == 1) {		// output of reference voltage and factors for capacity measurement
        Calibrate_UR();		// get Reference voltage, Pin resistance
        lcd_fix2_string(URefT);	// "URef="
        DisplayValue(ref_mv,-3,'V',4);
        lcd_fix2_string(RHfakt);		// "RHf="
        lcd_string(utoa(RHmultip, outval, 10));
        ADCconfig.Samples = 190;		// set number of ADC reads near to maximum
      if (tt == 2) { 	// how equal are the RL resistors?
        u680 = ((long)ADCconfig.U_AVCC * (PIN_RM + R_L_VAL) / (PIN_RM + R_L_VAL + R_L_VAL + PIN_RP));
        R_PORT = 1<<(TP1*2);			// RL1 to VCC
        R_DDR = (1<<(TP1*2)) | (1<<(TP2*2));	// RL2 to -
        adcmv[0] -= u680;
        R_DDR = (1<<(TP1*2)) | (1<<(TP3*2));	// RL3 to -
        adcmv[1] = W20msReadADC(TP1);
        adcmv[1] -= u680;
        R_PORT = 1<<(TP2*2);			// RL2 to VCC
        R_DDR = (1<<(TP2*2)) | (1<<(TP3*2));	// RL3 to -
        adcmv[2] = W20msReadADC(TP2);
        adcmv[2] -= u680;
        lcd_fix_string(RLRL);			// "RLRL"
      if (tt == 3) { 	// how equal are the RH resistors
        R_PORT = 2<<(TP1*2);			// RH1 to VCC
        R_DDR = (2<<(TP1*2)) | (2<<(TP2*2));	// RH2 to -
        adcmv[3] = ADCconfig.U_AVCC / 2;
        adcmv[0] -= adcmv[3];
        R_DDR = (2<<(TP1*2)) | (2<<(TP3*2));	// RH3 to -
        adcmv[1] -= adcmv[3];
        R_PORT = 2<<(TP2*2);			// RH2 to VCC
        R_DDR = (2<<(TP2*2)) | (2<<(TP3*2));	// RH3 to -
        adcmv[2] -= adcmv[3];
        lcd_fix_string(RHRH);			// "RHRH"
      if (tt == 4) { 	// Text release probes
        lcd_fix_string(RELPROBE);		// "Release Probes"
        if (AllProbesShorted() != 0) ww = MAX_REP-2;
      if (tt == 5) { 	// can we switch the ADC pins to GND across R_H resistor?
        R_PORT = 0;
        R_DDR = 2<<(TP1*2);		// Pin 1 over R_H to GND
        R_DDR = 2<<(TP2*2);		// Pin 2 over R_H to GND
        adcmv[1] = W20msReadADC(TP2);
        R_DDR = 2<<(TP3*2);		// Pin 3 over R_H to GND
        adcmv[2] = W20msReadADC(TP3);
        lcd_fix_string(RH1L);		// "RH_Lo="
      if (tt == 6) { 	// can we switch the ADC pins to VCC across the R_H resistor?
        R_DDR = 2<<(TP1*2);		// Pin 1 over R_H to VCC
        adcmv[0] = W20msReadADC(TP1) - ADCconfig.U_AVCC;
        R_DDR = 2<<(TP2*2);		// Pin 2 over R_H to VCC
        adcmv[1] = W20msReadADC(TP2) - ADCconfig.U_AVCC;
        R_DDR = 2<<(TP3*2);		// Pin 3 over R_H to VCC
        R_PORT = 2<<(TP3*2);
        adcmv[2] = W20msReadADC(TP3) - ADCconfig.U_AVCC;
        lcd_fix_string(RH1H);		// "RH_Hi="
      if (tt == 7) { 	// can we switch the ADC pins to VCC across the R_H resistor?
        u680 = ((long)ADCconfig.U_AVCC * (PIN_RM + R_L_VAL) / (PIN_RM + R_L_VAL + R_H_VAL*100));
        R_DDR = (2<<(TP1*2)) | (1<<(TP1*2));	// RH1 to +, RL1 to -
        adcmv[0] -= u680;
        R_DDR = (2<<(TP2*2)) | (1<<(TP2*2));	// RH2 to +, RL2 to -
        adcmv[1] -= u680;
        R_PORT = 2<<(TP3*2);			// RH3 to VCC
        R_DDR = (2<<(TP3*2)) | (1<<(TP3*2));	// RH3 to +, RL3 to -
        adcmv[2] -= u680;
        lcd_fix_string(RHRL);			// "RH/RL"
      if (tt > 1) {	// output 3 voltages
        lcd_string(itoa(adcmv[0], outval, 10));	// output voltage 1
        lcd_space();
        lcd_string(itoa(adcmv[1], outval, 10));	// output voltage 2
        lcd_space();
        lcd_string(itoa(adcmv[2], outval, 10));	// output voltage 3
        ADC_DDR =  TXD_MSK;		// all-Pins to Input
        ADC_PORT = TXD_VAL;		// all ADC-Ports to GND
        R_DDR = 0;			// all R-Ports to Input
        R_PORT = 0;
      wait_about500ms();
      wait_about500ms();
    }  // end for ww
    wait_about1s();
  }  // end for tt
  lcd_clear();
  lcd_fix_string(RIHI);				// "RiHi="
  DisplayValue(RRpinPL,-1,LCD_CHAR_OMEGA,3);
  lcd_line2();
  lcd_fix_string(RILO);				// "RiLo="
  DisplayValue(RRpinMI,-1,LCD_CHAR_OMEGA,3);
  wait_about2s();
  //measure Zero offset for Capacity measurement
  adcmv[3] = 0;
  adcmv[5] = (unsigned int) cap.cval_uncorrected.dw;	// save capacity value of empty Pin 1:3
  adcmv[6] = (unsigned int) cap.cval_uncorrected.dw;	// save capacity value of empty Pin 2:3
  adcmv[2] = (unsigned int) cap.cval_uncorrected.dw;	// save capacity value of empty Pin 1:2
  ReadCapacity(TP1, TP3);
  adcmv[1] = (unsigned int) cap.cval_uncorrected.dw;	// save capacity value of empty Pin 3:1
  ReadCapacity(TP2, TP3);
  adcmv[4] = (unsigned int) cap.cval_uncorrected.dw;	// save capacity value of empty Pin 3:2
  ReadCapacity(TP1, TP2);
  adcmv[0] = (unsigned int) cap.cval_uncorrected.dw;	// save capacity value of empty Pin 2:1
  lcd_clear();
  lcd_fix_string(C0_str);			// output "C0 "
  DisplayValue(adcmv[5],0,' ',3);		// output cap0 1:3
  DisplayValue(adcmv[6],0,' ',3);		// output cap0 2:3
  DisplayValue(adcmv[2],-12,'F',3);		// output cap0 1:2
  #ifdef AUTO_CAL
    for (ww=0;ww<7;ww++) {
      if (adcmv[ww] > 70) goto no_c0save;
      // write all zero offsets to the EEprom
      (void) eeprom_write_byte((uint8_t *)(&c_zero_tab[ww]),adcmv[ww]+(COMP_SLEW1 / (CC0 + CABLE_CAP + COMP_SLEW2)));
    lcd_line2();
    lcd_fix_string(OK_str);		// output "OK"
no_c0save:
  #endif
  wait_about2s();
  #ifdef AUTO_CAL
    // Message C > 100nF
    cap_found = 0;
    for (ww=0; ww<64; ww++) {
      lcd_clear();
      lcd_data('1');
      lcd_fix_string(CapZeich);		// "-||-"
      lcd_data('3');
      lcd_fix2_string(MinCap_str);	// " >100nF!"
      // measure  offset Voltage of analog Comparator for Capacity measurement
      ReadCapacity(TP3, TP1);		// look for capacitor > 100nF
      while (cap.cpre < -9) {
        cap.cpre++;
        cap.cval /= 10;
      if ((cap.cpre == -9) && (cap.cval > 95) && (cap.cval < 22000)) {
        cap_found++;
        cap_found = 0;		// wait for stable connection
      if (cap_found > 1) {
        // value of capacitor is correct
        (void) eeprom_write_word((uint16_t *)(&ref_offset), load_diff);	// hold zero offset + slew rate dependend offset
        lcd_clear();
        lcd_fix2_string(REF_C_str);			// "REF_C="
        lcd_string(itoa(load_diff, outval, 10));	// output REF_C_KORR
        #if 0
          // Test for switching level of the digital input of port TP3
          for (ii=0;ii<8;ii++) {
            ADC_PORT =  TXD_VAL;		// ADC-Port 1 to GND
            ADC_DDR = 1<<TP1 | TXD_MSK;		// ADC-Pin  1 to output 0V
            R_PORT = 2<<(TP3*2);		// Pin 3 over R_H to VCC
            while (1) {
              wdt_reset();
              if ((ADC_PIN&(1<<TP3)) == (1<<TP3)) break;
            R_DDR = 0;				// Pin 3 without current
            R_PORT = 0;
            adcmv[0] = ReadADC(TP3);
            lcd_line3();
            DisplayValue(adcmv[0],-3,'V',4);
            while (1) {
              wdt_reset();
              if ((ADC_PIN&(1<<TP3)) != (1<<TP3)) break;
            lcd_line4();
            wait_about1s();
        #endif
          do {
          } while (adcmv[0] > 980);
          R_DDR = 0;				// all Pins to input
          ADCconfig.U_Bandgap = 0;		// do not use internal Ref
          adcmv[0] = ReadADC(TP3);  		// get cap voltage with VCC reference
          adcmv[1] = ReadADC(TP3);		// get cap voltage with internal reference
          adcmv[2] = ReadADC(TP3);  		// get cap voltage with VCC reference
          udiff = (int8_t)(((signed long)(adcmv[0] + adcmv[2] - adcmv[1] - adcmv[1])) * ADC_internal_reference / (2*adcmv[1]))+REF_R_KORR;
          lcd_line2();
          lcd_fix2_string(REF_R_str);		// "REF_R="
          udiff2 = udiff + (int8_t)eeprom_read_byte((uint8_t *)(&RefDiff));
          (void) eeprom_write_byte((uint8_t *)(&RefDiff), (uint8_t)udiff2);	// hold offset for true reference Voltage
          lcd_string(itoa(udiff2, outval, 10));	// output correction voltage
        #endif
        wait_about4s();
      lcd_line2();
      DisplayValue(cap.cval,cap.cpre,'F',4);
      wait_about200ms();			// wait additional time
    }  // end for ww
  #endif
  ADCconfig.Samples = ANZ_MESS;		// set to configured number of ADC samples
  lcd_clear();
  lcd_line2();
  lcd_fix2_string(VERSION_str);		// "Version ..."
  lcd_line1();
  lcd_fix_string(ATE);			// "Selftest End"
  #ifdef FREQUENCY_50HZ
    //#define TEST_SLEEP_MODE		// only select for checking the sleep delay
    lcd_fix_string(T50HZ);		// " 50Hz"
    ADC_PORT = TXD_VAL;
    ADC_DDR = 1<<TP1 | TXD_MSK;		// Pin 1 to GND
    R_DDR = (1<<(TP3*2)) | (1<<(TP2*2));
    for(ww=0;ww<30;ww++) {		// repeat the signal up to 30 times (1 minute)
      for (ii=0;ii<100;ii++) {		// for 2 s generate 50 Hz
        R_PORT = (1<<(TP2*2));		// Pin 2 over R_L to VCC, Pin 3 over R_L to GND
        #ifdef TEST_SLEEP_MODE
          sleep_5ms(2); 		// test of timing of sleep mode call
        #else
          wait10ms();			// normal delay
        #endif
        R_PORT = (1<<(TP3*2));		// Pin 3 over R_L to VCC, Pin 2 over R_L to GND
        #else
        #endif
        wdt_reset();
  #endif
  wait_about1s();
#endif
#ifdef RequireShortedProbes
 *  check for a short circuit between two probes
 *  from Markus R.
 *  requires:
 *  - ID of first probe (0-2)
 *  - ID of second probe (0-2)
 *  returns:
 *  - 0 if not shorted
 *  - 1 if shorted
uint8_t ShortedProbes(uint8_t Probe1, uint8_t Probe2)
  uint8_t           Flag1 = 0;  // return value
  unsigned int      U1; 	// voltage at probe #1 in mV
  unsigned int      U2; 	// voltage at probe #2 in mV
  unsigned int      URH;	// half of reference voltage
  // Set up a voltage divider between the two probes:
  // - Probe1: Rl pull-up
  // - Probe2: Rl pull-down
  R_PORT = pgm_read_byte(&PinRLtab[Probe1]);
  R_DDR = pgm_read_byte(&PinRLtab[Probe1]) | pgm_read_byte(&PinRLtab[Probe2]);
  // read voltages
  U1 = ReadADC(Probe1);
  U2 = ReadADC(Probe2);
  // We expect both probe voltages to be about the same and
  // to be half of Vcc (allowed difference +/- 20mV).
  URH = ADCconfig.U_AVCC / 2;
  if ((U1 > URH - 20) && (U1 < URH + 20))
    if ((U2 > URH - 20) && (U2 < URH + 20))
      Flag1 = 1;
  // reset port
  R_DDR = 0;
  return Flag1;
 *  check for a short circuit between all probes
 *  from Markus R.
 *  returns:
 *  - 0 if no probes are short-circuited
 *  - number of probe pairs short-circuited (3 = all)
uint8_t AllProbesShorted(void)
  uint8_t Flag2;      // return value
  // check all possible combinations
  Flag2 = ShortedProbes(TP1, TP2);
  Flag2 += ShortedProbes(TP1, TP3);
  Flag2 += ShortedProbes(TP2, TP3);
  return Flag2;
#endif
void CheckPins(uint8_t HighPin, uint8_t LowPin, uint8_t TristatePin) {
  Function for checking the characteristic of a component with the following pin assignment
  parameters:
  HighPin: Pin, which will be switched to VCC at the beginning
  LowPin: Pin, which will be switch to GND at the beginning
  TristatePin: Pin, which will be undefined at the beginning
  TristatePin will be switched to GND and VCC also .
  struct {
    unsigned int lp_otr;
    unsigned int hp1;
    unsigned int hp2;
    unsigned int hp3;
    unsigned int lp1;
    unsigned int lp2;
    unsigned int tp1;
    unsigned int tp2;
  } adc;
  uint8_t LoPinRL;		// mask to switch the LowPin with R_L
  uint8_t LoPinRH;		// mask to switch the LowPin with R_H
  uint8_t TriPinRL;		// mask to switch the TristatePin with R_L
  uint8_t TriPinRH;		// mask to switch the TristatePin with R_H
  uint8_t HiPinRL;		// mask to switch the HighPin with RL
  uint8_t HiPinRH;		// mask to switch the HighPin with R_H
  uint8_t HiADCp;		// mask to switch the ADC port High-Pin
  uint8_t LoADCp;		// mask to switch the ADC port Low-Pin
  uint8_t HiADCm;		// mask to switch the ADC DDR port High-Pin
  uint8_t LoADCm;		// mask to switch the ADC DDR port Low-Pin
  uint8_t PinMSK;
  uint8_t ii;			// temporary variable
  #ifdef COMMON_EMITTER
    unsigned int tmp16;		// temporary variable
  #else
    #warning "without common emitter hFE"
  #endif
    int udiff;
  #endif
    unsigned long c_hfe;	// amplification factor for common Collector (Emitter follower)
  #endif
  struct resis_t *thisR;
  unsigned long lrx1;
  unsigned long lirx1;
  unsigned long lirx2;
    switch HighPin directls to VCC
    switch R_L port for LowPin to GND
    TristatePin remains switched to input , no action required
  wdt_reset();
  //#ifdef AUTO_CAL
  //  uint16_t resis680pl;
  //  uint16_t resis680mi;
  //  resis680pl = eeprom_read_word(&R680pl);
  //  resis680mi = eeprom_read_word(&R680mi);
  //  #define RR680PL resis680pl
  //  #define RR680MI resis680mi
  //#else
  //  #define RR680PL (R_L_VAL + PIN_RP)
  //  #define RR680MI (R_L_VAL + PIN_RM)
  //#endif
  LoPinRL = pgm_read_byte(&PinRLtab[LowPin]);		// instruction for LowPin R_L
  LoPinRH = LoPinRL + LoPinRL;				// instruction for LowPin R_H
  TriPinRL = pgm_read_byte(&PinRLtab[TristatePin]);	// instruction for TristatePin R_L
  TriPinRH = TriPinRL + TriPinRL;			// instruction for TristatePin R_H
  HiPinRL = pgm_read_byte(&PinRLtab[HighPin]);		// instruction for HighPin R_L
  HiPinRH = HiPinRL + HiPinRL;				// instruction for HighPin R_H
  HiADCp = pgm_read_byte(&PinADCtab[HighPin]);		// instruction for ADC High-Pin
  LoADCp = pgm_read_byte(&PinADCtab[LowPin]);		// instruction for ADC Low-Pin
  HiADCm = HiADCp | TXD_MSK;
  HiADCp |= TXD_VAL;
  LoADCm = LoADCp | TXD_MSK;
  LoADCp |= TXD_VAL;
  // setting of Pins
  R_PORT = 0;				// resistor-Port outputs to 0
  R_DDR = LoPinRL;			// Low-Pin to output and across R_L to GND
  ADC_DDR = HiADCm;			// High-Pin to output
  ADC_PORT = HiADCp;			// High-Pin fix to Vcc
  // for some MOSFET the gate (TristatePin) must be discharged
  ChargePin10ms(TriPinRL,0);		// discharge for N-Kanal
  adc.lp_otr = W5msReadADC(LowPin);	// read voltage of Low-Pin
  if (adc.lp_otr >= 977) {		// no current now?
    ChargePin10ms(TriPinRL,1);	 	// else: discharge for P-channel (Gate to VCC)
    adc.lp_otr = ReadADC(LowPin);	// read voltage of Low-Pin again
  #if DebugOut == 5
    lcd_line2();
    lcd_clear_line();
    lcd_line2();
  #endif
  //if(adc.lp_otr > 92) {  // there is some current without TristatePin current
  if(adc.lp_otr > 455) {   // there is more than 650uA current without TristatePin current
    #if DebugOut == 5
      lcd_testpin(LowPin);
      lcd_data('F');
      lcd_testpin(HighPin);
      lcd_space();
      wait_about1s();
    #endif
PART 2
    // Test if N-JFET or if self-conducting N-MOSFET
    R_DDR = LoPinRL | TriPinRH;		// switch R_H for Tristate-Pin (probably Gate) to GND
    adc.lp1 = W20msReadADC(LowPin);	// measure voltage at the assumed Source
    adc.tp1 = ReadADC(TristatePin);	// measure Gate voltage
    R_PORT = TriPinRH;			// switch R_H for Tristate-Pin (probably Gate) to VCC
    adc.lp2 = W20msReadADC(LowPin);	// measure voltage at the assumed Source again
    // If it is a self-conducting MOSFET or JFET, then must be: adc.lp2 > adc.lp1
    if (adc.lp2>(adc.lp1+488)) {
      if (PartFound != PART_FET) {
        // measure voltage at the  Gate, differ between MOSFET and JFET
        ADC_PORT = TXD_VAL;
        ADC_DDR = LoADCm;		// Low-Pin fix to GND
        R_DDR = TriPinRH | HiPinRL;	// High-Pin to output
        R_PORT = TriPinRH | HiPinRL;	// switch R_L for High-Pin to VCC
        adc.lp2 = W20msReadADC(TristatePin); // read voltage of assumed Gate
        if (adc.lp2>3911) {  		// MOSFET
          PartFound = PART_FET;		// N-Kanal-MOSFET
          PartMode = PART_MODE_N_D_MOS; // Depletion-MOSFET
        } else {  // JFET (pn-passage between Gate and Source is conducting )
          PartFound = PART_FET;		// N-Kanal-JFET
          PartMode = PART_MODE_N_JFET;
        #if DebugOut == 5
          lcd_data('N');
          lcd_data('J');
        #endif
        //if ((PartReady == 0) || (adc.lp1 > trans.uBE[0]))
        // there is no way to find out the right Source / Drain
        trans.uBE[0] = adc.lp1;
        gthvoltage = adc.lp1 - adc.tp1;	// voltage GS (Source - Gate)
        trans.uBE[1] = (unsigned int)(((unsigned long)adc.lp1 * 1000) / RR680MI);  // Id 0.01mA
        trans.b = TristatePin;		// save Pin numbers found for this FET
        trans.c = HighPin;
        trans.e = LowPin;
    ADC_PORT = TXD_VAL;		// direct outputs to GND
    // Test, if P-JFET or if self-conducting P-MOSFET
    ADC_DDR = LoADCm;			// switch Low-Pin (assumed Drain) direct to GND,
					// R_H for Tristate-Pin (assumed Gate) is already switched to VCC
    R_PORT = TriPinRH | HiPinRL;	// High-Pin across R_L to Vcc
    adc.hp1 = W20msReadADC(HighPin);	// measure voltage at assumed Source
    R_PORT = HiPinRL;			// switch R_H for Tristate-Pin (assumed Gate) to GND
    adc.hp2 = W20msReadADC(HighPin);	// read voltage at assumed Source again
    // if it is a self-conducting P_MOSFET or P-JFET , then must be:  adc.hp1 > adc.hp2
    if (adc.hp1>(adc.hp2+488)) {
        // read voltage at the Gate , to differ between MOSFET and JFET
        ADC_PORT = HiADCp;		// switch High-Pin directly to VCC
        ADC_DDR = HiADCm;		// switch High-Pin to output
        adc.tp2 = W20msReadADC(TristatePin); //read voltage at the assumed Gate
        if (adc.tp2<977) { 		// MOSFET
          PartFound = PART_FET;		// P-Kanal-MOSFET
          PartMode = PART_MODE_P_D_MOS; // Depletion-MOSFET
        } else { 			// JFET (pn-passage between Gate and Source is conducting)
          PartFound = PART_FET;		// P-Kanal-JFET
          PartMode = PART_MODE_P_JFET;
        #if DebugOut == 5
          lcd_data('P');
          lcd_data('J');
        #endif
        gthvoltage = adc.tp1 - adc.hp1;		// voltage GS (Gate - Source)
        trans.uBE[1] = (unsigned int)(((unsigned long)(ADCconfig.U_AVCC - adc.hp1) * 1000) / RR680PL); // Id 0.01mA
        trans.c = LowPin;
        trans.e = HighPin;
  }  // end component has current without TristatePin signal
    // Test circuit with common collector (Emitter follower) PNP
    ADC_PORT = TXD_VAL;
    ADC_DDR = LoADCm;			// Collector direct to GND
    R_PORT = HiPinRL;			// switch R_L port for HighPin (Emitter) to VCC
    R_DDR = TriPinRL | HiPinRL;		// Base resistor  R_L to GND
    adc.hp1 = ADCconfig.U_AVCC - W5msReadADC(HighPin);	// voltage at the Emitter resistor
    adc.tp1 = ReadADC(TristatePin);	// voltage at the base resistor
    if (adc.tp1 < 10) {
      R_DDR =  TriPinRH | HiPinRL;	// Tripin=RH-
      adc.tp1 = ReadADC(TristatePin);	// voltage at base resistor
      #ifdef LONG_HFE
        c_hfe = ((unsigned long)adc.hp1 * (unsigned long)(((unsigned long)R_H_VAL * 100) /
                (unsigned int)RR680PL)) / (unsigned int)adc.tp1;
      #else
        c_hfe = ((adc.hp1 / ((RR680PL+500)/1000)) * (R_H_VAL/500)) / (adc.tp1/500);
      #endif
      c_hfe = (unsigned long)((adc.hp1 - adc.tp1) / adc.tp1);
  #endif
  // set Pins again for circuit with common Emitter PNP
  R_DDR = LoPinRL;		// switch R_L port for Low-Pin to output (GND)
  R_PORT = 0;			// switch all resistor ports to GND
  ADC_PORT = HiADCp;		// switch High-Pin to VCC
  wait_about5ms();
  if (adc.lp_otr < 977) {
    // if the component has no connection between  HighPin and LowPin
    #if DebugOut == 5
      lcd_data('P');
      lcd_space();
      wait_about1s();
    #endif
    // Test to PNP
    R_DDR = LoPinRL | TriPinRL;		// switch R_L port for Tristate-Pin to output (GND), for Test of PNP
    adc.lp1 = W5msReadADC(LowPin);	// measure voltage at LowPin
    if (adc.lp1 > 3422) {
      // component has current => PNP-Transistor or equivalent
      // compute current amplification factor in both directions
      R_DDR = LoPinRL | TriPinRH;	// switch R_H port for Tristate-Pin (Base) to output (GND)
      adc.lp1 = W5msReadADC(LowPin);	// measure voltage at LowPin (assumed Collector)
      adc.tp2 = ReadADC(TristatePin);	// measure voltage at TristatePin (Base)
      // check, if Test is done before
      if ((PartFound == PART_TRANSISTOR) || (PartFound == PART_FET)) {
         PartReady = 1;
        trans.uBE[PartReady] = ReadADC(HighPin) - adc.tp2;	// Base Emitter Voltage
        // compute current amplification factor for circuit with common Emitter
        // hFE = B = Collector current / Base current
        if(adc.tp2 < 53) {
          #if DebugOut == 5
            lcd_data('<');
            lcd_data('5');
            lcd_data('3');
          #endif
          adc.tp2 = 53;
        tmp16 = adc.lp1;
        if (tmp16 > adc.lp_otr) {
          tmp16 -= adc.lp_otr;
        #ifdef LONG_HFE
          trans.hfe[PartReady] = ((unsigned int)tmp16 * (unsigned long)(((unsigned long)R_H_VAL * 100) /
                                 (unsigned int)RR680MI)) / (unsigned int)adc.tp2;
        #else
          trans.hfe[PartReady] = ((tmp16 / ((RR680MI+500)/1000)) * (R_H_VAL/500)) / (adc.tp2/500);
        #endif
      #endif
      #ifdef COMMON_COLLECTOR
        // current amplification factor for common  Collector (Emitter follower)
        // c_hFE = (Emitter current - Base current) / Base current
          if (c_hfe > trans.hfe[PartReady]) {
        #endif
            trans.hfe[PartReady] = c_hfe;
            trans.uBE[PartReady] = ADCconfig.U_AVCC - adc.hp1 - adc.tp1;	// Base Emitter Voltage common collector
        #endif
      #endif
      if (PartFound != PART_THYRISTOR) {
        if (adc.tp2 > 977) {
          // PNP-Transistor is found (Base voltage moves to VCC)
          PartFound = PART_TRANSISTOR;
          PartMode = PART_MODE_PNP;
          if ((adc.lp_otr < 97) && (adc.lp1 > 2000)) {
            // is flow voltage low enough in the closed  state?
            // (since D-Mode-FET would be by mistake detected as E-Mode )
            PartFound = PART_FET;		// P-Kanal-MOSFET is found (Basis/Gate moves not to VCC)
            PartMode = PART_MODE_P_E_MOS;
            // measure the Gate threshold voltage
            // Switching of Drain is monitored with digital input
            // Low level is specified up to 0.3 * VCC
            // High level is specified above 0.6 * VCC
            PinMSK = LoADCm & 7;
            ADMUX = TristatePin | (1<<REFS0);	// switch to TristatePin, Ref. VCC
            gthvoltage = 1;			// round up ((1*4)/9)
            for(ii=0;ii<11;ii++) {
              wdt_reset();
              R_DDR = LoPinRL | TriPinRH;		// switch R_H for Tristate-Pin (Basis) to GND
              while (!(ADC_PIN&PinMSK));		// Wait, until the MOSFET switches and Drain moves to VCC
                      			// 1 is detected with more than 2.5V (up to 2.57V) with tests of mega168 and mega328
              R_DDR = LoPinRL;
              ADCSRA |= (1<<ADSC);		// Start Conversion
              while (ADCSRA&(1<<ADSC));		// wait
              gthvoltage += (1023 - ADCW);	// Add Tristatepin-Voltage
            gthvoltage *= 4;		// is equal to 44*ADCW
            gthvoltage /= 9;		// gives resolution in mV
        trans.c = LowPin;
        trans.e = HighPin;
      }  // end if PartFound != PART_THYRISTOR
    }  // end component has current => PNP
      // Low-Pin=RL- HighPin=VCC
      R_PORT = TriPinRL;			// TriPin=RL+  NPN with common Collector
      adc.lp1 = W5msReadADC(LowPin);		// voltage at Emitter resistor
      adc.tp1 = ADCconfig.U_AVCC - ReadADC(TristatePin);	// voltage at Base resistor
      if (adc.tp1 < 10) {
        R_PORT = TriPinRH;			// Tripin=RH+
        #ifdef LONG_HFE
          c_hfe = ((unsigned long)adc.lp1 * (unsigned long)(((unsigned long)R_H_VAL * 100) /
                  (unsigned int)RR680MI)) / (unsigned int)adc.tp1;
        #else
          c_hfe = ((adc.lp1 / ((RR680MI+500)/1000)) * (R_H_VAL/500)) / (adc.tp2/500);
        #endif
        c_hfe = (adc.lp1 - adc.tp1) / adc.tp1;
      #if DebugOut == 5
        lcd_line4();
        lcd_clear_line();
        lcd_line4();
        lcd_data('L');
        lcd_data('P');
        lcd_string(utoa(adc.lp1,outval,10));
        lcd_space();
        lcd_data('T');
        lcd_data('P');
        lcd_string(utoa(adc.tp1,outval,10));
        wait_about1s();
      #endif
    #endif
    // Tristate (can be Base) to VCC, Test if NPN
    ADC_DDR = LoADCm;			// Low-Pin to output 0V
    ADC_PORT = TXD_VAL;			// switch Low-Pin to GND
    R_DDR = TriPinRL | HiPinRL;		// RL port for High-Pin and Tristate-Pin to output
    R_PORT = TriPinRL | HiPinRL;	// RL port for High-Pin and Tristate-Pin to Vcc
    adc.hp1 = W5msReadADC(HighPin);	// measure voltage at High-Pin  (Collector)
    if (adc.hp1 < 1600) {
      // component has current => NPN-Transistor or somthing else
      #if DebugOut == 5
        lcd_data('N');
        lcd_space();
        wait_about1s();
      #endif
      if (PartReady==1) {
        goto widmes;
      // Test auf Thyristor:
      // Gate discharge
      ChargePin10ms(TriPinRL,0);	// Tristate-Pin (Gate) across R_L 10ms to GND
      adc.hp3 = W5msReadADC(HighPin);	// read voltage at High-Pin (probably Anode) again
                                        // current should still flow, if not,
                                        // no Thyristor or holding current to low
      R_PORT = 0;			// switch R_L for High-Pin (probably Anode) to GND (turn off)
      wait_about5ms();
      R_PORT = HiPinRL;			// switch R_L for High-Pin (probably Anode) again to VCC
      adc.hp2 = W5msReadADC(HighPin);	// measure voltage at the High-Pin (probably Anode) again
      if ((adc.hp3 < 1600) && (adc.hp2 > 4400)) {
        // if the holding current was switched off the thyristor must be switched off too.
        // if Thyristor was still swiched on, if gate was switched off => Thyristor
        PartFound = PART_THYRISTOR;
        // Test if Triac
        R_DDR = 0;
        R_PORT = 0;
        ADC_PORT = LoADCp;		// Low-Pin fix to VCC
        wait_about5ms();
        R_DDR = HiPinRL;		// switch R_L port HighPin to output (GND)
        if(W5msReadADC(HighPin) > 244) {
          goto savenresult;		// measure voltage at the  High-Pin (probably A2); if too high:
                                  	// component has current => kein Triac
        R_DDR = HiPinRL | TriPinRL;	// switch R_L port for TristatePin (Gate) to output (GND) => Triac should be triggered
        if(W5msReadADC(TristatePin) < 977) {
          goto savenresult; 		// measure voltage at the Tristate-Pin (probably Gate) ;
                                	// if to low, abort
        if(ReadADC(HighPin) < 733) {
          goto savenresult; 		// component has no current => no Triac => abort
        R_DDR = HiPinRL;		// TristatePin (Gate) to input
        if(W5msReadADC(HighPin) < 733) {
          goto savenresult; 		// component has no current without base current => no Triac => abort
        R_PORT = HiPinRL;		// switch R_L port for HighPin to VCC => switch off holding current
        wait_about5ms();
        R_PORT = 0;			// switch R_L port for HighPin again to GND; Triac should now switched off
          goto savenresult;		// measure voltage at the High-Pin (probably A2) ;
                                  	// if to high, component is not switched off => no Triac, abort
        PartFound = PART_TRIAC;
        PartReady = 1;
        goto savenresult;
      // Test if NPN Transistor or MOSFET
      //ADC_DDR = LoADCm;		// Low-Pin to output 0V
      R_DDR = HiPinRL | TriPinRH;	// R_H port of Tristate-Pin (Basis) to output
      R_PORT = HiPinRL | TriPinRH;	// R_H port of Tristate-Pin (Basis) to VCC
      wait_about50ms();
      adc.hp2 = ADCconfig.U_AVCC - ReadADC(HighPin);		// measure the voltage at the collector resistor
      adc.tp2 = ADCconfig.U_AVCC - ReadADC(TristatePin);	// measure the voltage at the base resistor
      #if DebugOut == 5
        lcd_line3();
        lcd_clear_line();
        lcd_line3();
        lcd_data('H');
        lcd_data('P');
        lcd_string(utoa(adc.hp2,outval,10));
        lcd_space();
        lcd_data('T');
        lcd_data('P');
        lcd_string(utoa(adc.tp2,outval,10));
      #endif
      if((PartFound == PART_TRANSISTOR) || (PartFound == PART_FET)) {
        PartReady = 1;		// check, if test is already done once
        trans.uBE[PartReady] = ADCconfig.U_AVCC - adc.tp2 - ReadADC(LowPin);
        // compute current amplification factor for common Emitter
        if (adc.tp2 < 53) {
          #if DebugOut == 5
            lcd_data('<');
            lcd_data('5');
            lcd_data('3');
          #endif
          adc.tp2 = 53;
        tmp16 = adc.hp2;
        #ifdef LONG_HFE
                                 (unsigned int)RR680PL)) / (unsigned int)adc.tp2;
        #else
          trans.hfe[PartReady] = ((tmp16 / ((RR680PL+500)/1000)) * (R_H_VAL/500)) / (adc.tp2/500);
        #endif
      #endif
        // compare current amplification factor for common Collector (Emitter follower)
        // hFE = (Emitterstrom - Basisstrom) / Basisstrom
        #endif
            trans.uBE[PartReady] = ADCconfig.U_AVCC - adc.lp1 - adc.tp1;
        #endif
      #endif
      if(adc.tp2 > 2557) {		// Basis-voltage R_H is low enough
        PartFound = PART_TRANSISTOR;	// NPN-Transistor is found (Base is near GND)
        PartMode = PART_MODE_NPN;
      } else {				// Basis has low current
        if((adc.lp_otr < 97) && (adc.hp2 > 3400)) {
          // if flow voltage in switched off mode low enough?
          // (since D-Mode-FET will be detected in error as E-Mode )
          PartFound = PART_FET;		// N-Kanal-MOSFET is found (Basis/Gate will Not be pulled down)
          PartMode = PART_MODE_N_E_MOS;
          #if DebugOut == 5
            lcd_line3();
            lcd_clear_line();
            lcd_line3();
            lcd_data('N');
            lcd_data('F');
            wait_about1s();
          #endif
          PinMSK = HiADCm & 7;
          // measure Threshold voltage of Gate
          ADMUX = TristatePin | (1<<REFS0);	// measure TristatePin, Ref. VCC
            wdt_reset();
            ChargePin10ms(TriPinRL,0);	// discharge Gate 10ms with RL
            R_DDR = HiPinRL | TriPinRH;	// slowly charge Gate
            while ((ADC_PIN&PinMSK));	// Wait, until the MOSFET switch and Drain moved to low
                                        // 0 is detected with input voltage of 2.12V to 2.24V (tested with mega168 & mega328)
            R_DDR = HiPinRL;		// switch off current
            ADCSRA |= (1<<ADSC);		// start ADC conversion
            while (ADCSRA&(1<<ADSC));	// wait until ADC finished
            gthvoltage += ADCW;		// add result of ADC
          gthvoltage *= 4;	// is equal to 44 * ADCW
          gthvoltage /= 9;	// scale to mV
savenresult:
      trans.b = TristatePin;	// save Pin-constellation
      trans.c = HighPin;
      trans.e = LowPin;
    }  // end component conduct => npn
    ADC_DDR = TXD_MSK;		// switch all ADC-Ports to input
    ADC_PORT = TXD_VAL;		// switch all ADC-Ports to 0 (no Pull up)
    // Finish
    // end component has no connection between HighPin and LowPin
    goto widmes;
  // Test if Diode
  ADC_PORT = TXD_VAL;
  for (ii=0;ii<200;ii++) {
    ADC_DDR = LoADCm | HiADCm;   	// discharge by short of Low and High side
    wait_about5ms();             	// Low and Highpin to GND for discharge
    ADC_DDR = LoADCm;            	// switch only Low-Pin fix to GND
    adc.hp1 = ReadADC(HighPin);  	// read voltage at High-Pin
    if (adc.hp1 < (150/8)) break;
    It is possible, that wrong Parts are detected without discharging, because
    the gate of a MOSFET can be charged.
    The additional measurement with the big resistor R_H is made, to differ antiparallel diodes
    from resistors.
    A diode has a voltage, that is nearly independent from the current.
    The voltage of a resistor is proportional to the current.
  #if 0
    // first check with higher current (R_L=680)
    // A diode is found better with a parallel mounted capacitor,
    // but some capacitors can be detected a a diode.
    R_DDR = HiPinRL;              	// switch R_L port for High-Pin to output (VCC)
    R_PORT = HiPinRL;
    ChargePin10ms(TriPinRL,1);    	// discharge of P-Kanal-MOSFET gate
    adc.lp_otr = W5msReadADC(HighPin) - ReadADC(LowPin);
    R_DDR = HiPinRH;              	// switch R_H port for High-Pin output (VCC)
    R_PORT = HiPinRH;
    adc.hp2 = W5msReadADC(HighPin);     // M--|<--HP--R_H--VCC
    R_PORT = HiPinRL;
    ChargePin10ms(TriPinRL,0);    	// discharge for N-Kanal-MOSFET gate
    adc.hp1 = W5msReadADC(HighPin) - W5msReadADC(LowPin);
    R_DDR = HiPinRH;              	// switch R_H port for High-Pin to output (VCC)
    R_PORT = HiPinRH;
    adc.hp3 = W5msReadADC(HighPin);     // M--|<--HP--R_H--VCC
    if(adc.lp_otr > adc.hp1) {
      adc.hp1 = adc.lp_otr;		// the higher value wins
      adc.hp3 = adc.hp2;
  #else
    // check first with low current (R_H=470k)
    // With this method the diode can be better differed from a capacitor,
    // but a parallel to a capacitor mounted diode can not be found.
    R_PORT = HiPinRH;
    // check with higher current (R_L=680)
    R_PORT = HiPinRL;
    adc.hp1 = W5msReadADC(HighPin) - ReadADC(LowPin);
    ChargePin10ms(TriPinRL,1);		// discharge for N-Kanal-MOSFET gate
    R_PORT = HiPinRH;
      adc.hp3 = adc.hp2;
  #endif
  #if DebugOut == 4
    lcd_line3();
    lcd_clear_line();
    lcd_line3();
    lcd_data('D');
    lcd_space();
    lcd_data('h');
    lcd_string(utoa(adc.hp3,outval,10));
    lcd_space();
    lcd_data('L');
    lcd_string(utoa(adc.hp1,outval,10));
    lcd_space();
    lcd_data('H');
    lcd_space();
    wait_about1s();
  #endif
  //if((adc.hp1 > 150) && (adc.hp1 < 4640) && (adc.hp1 > (adc.hp3+(adc.hp3/8))) && (adc.hp3*8 > adc.hp1)) {
  if((adc.hp1 > 150) && (adc.hp1 < 4640) && (adc.hp2 < adc.hp1) && (adc.hp1 > (adc.hp3+(adc.hp3/8))) && (adc.hp3*16 > adc.hp1)) {
    // voltage is above 0,15V and below 4,64V => Ok
    if((PartFound == PART_NONE) || (PartFound == PART_RESISTOR)) {
      PartFound = PART_DIODE;	// mark for diode only, if no other component is found
                                // since there is a problem with Transistors with a protection diode
      #if DebugOut == 4
        lcd_data('D');
      #endif
    diodes[NumOfDiodes].Anode = HighPin;
    diodes[NumOfDiodes].Cathode = LowPin;
    diodes[NumOfDiodes].Voltage = adc.hp1;	// voltage in Millivolt
    NumOfDiodes++;
  }  // end voltage is above 0,15V and below 4,64V
  #if DebugOut == 4
    lcd_data(NumOfDiodes+'0');
  #endif
widmes:
  if (NumOfDiodes > 0) goto clean_ports;
  // resistor measurement
  wdt_reset();
  // U_SCALE can be set to 4 for better resolution of ReadADC result
  #if U_SCALE != 1
    ADCconfig.U_AVCC *= U_SCALE;	// scale to higher resolution, mV scale is not required
    ADCconfig.U_Bandgap *= U_SCALE;
  #endif
  #if R_ANZ_MESS != ANZ_MESS
    ADCconfig.Samples = R_ANZ_MESS;	// switch to special number of repetitions
  #endif
  #define MAX_REPEAT (700 / (5 + R_ANZ_MESS/8))
  ADC_PORT = TXD_VAL;
  ADC_DDR = LoADCm;		// switch Low-Pin to output (GND)
  R_PORT = HiPinRL;
  #if FLASHEND > 0x1fff
    adc.hp2 = 0;
    for (ii=1;ii<MAX_REPEAT;ii++) {
      // wait until voltage is stable
      adc.tp1 = W5msReadADC(LowPin);		// low-voltage at Rx with load
      adc.hp1 = ReadADC(HighPin);		// voltage at resistor Rx with R_L
      udiff = adc.hp1 - adc.hp2;
      if (udiff < 0) udiff = -udiff;
      if (udiff < 3) break;
      adc.hp2 = adc.hp1;
      wdt_reset();
    if (ii == MAX_REPEAT) goto testend;
  #else
  #endif
  if (adc.tp1 > adc.hp1) {
    adc.tp1 = adc.hp1;
  R_PORT = 0;
  R_DDR = HiPinRH;			// switch R_H port for High-Pin to output (GND)
  adc.hp2 = W5msReadADC(HighPin);	// read voltage, should be down
  if (adc.hp2 > (20*U_SCALE)) {
    // if resistor, voltage should be down
    #if DebugOut == 3
      lcd_line3();
      lcd_clear_line();
      lcd_line3();
      lcd_data('U');
      lcd_data('A');
      lcd_string(utoa(adc.hp1, outval, 10));
      lcd_data('B');
      lcd_string(utoa(adc.hp2, outval, 10));
      lcd_space();
    #endif
    goto testend;
  R_PORT = HiPinRH;			// switch R_H for High-Pin to VCC
  adc.hp2 = W5msReadADC(HighPin);	// voltage at resistor Rx with R_H
  R_PORT = 0;
  R_DDR = LoPinRL;			// switch R_L for Low-Pin to GND
    adc.lp2 = 0;
      adc.tp2 = W5msReadADC(HighPin);	// high voltage with load
      adc.lp1 = ReadADC(LowPin);	// voltage at the other end of Rx
      udiff = adc.lp1 - adc.lp2;
      adc.lp2 = adc.lp1;
      wdt_reset();
  #else
  #endif
  if (adc.tp2 < adc.lp1) {
    adc.tp2 = adc.lp1;
  R_DDR = LoPinRH;			// switch R_H for Low-Pin to GND
  adc.lp2 = W5msReadADC(LowPin);
  if((adc.hp1 < (4400*U_SCALE)) && (adc.hp2 > (97*U_SCALE))) {
    //voltage break down isn't insufficient
    #if DebugOut == 3
      lcd_data('F');
    #endif
    goto testend;
  //if ((adc.hp2 + (adc.hp2 / 61)) < adc.hp1)
  if (adc.hp2 < (4972*U_SCALE)) {
    // voltage breaks down with low test current and it is not nearly shorted  => resistor
    //if (adc.lp1 < 120) { 		// take measurement with R_H
    if (adc.lp1 < (169*U_SCALE)) {  	// take measurement with R_H
      ii = 'H';
      if (adc.lp2 < (38*U_SCALE)) {
        // measurement > 60MOhm to big resistance
        goto testend;
      // two measurements with R_H resistors (470k) are made:
      // lirx1 (measurement at HighPin)
      lirx1 = (unsigned long)((unsigned int)R_H_VAL) * (unsigned long)adc.hp2 / (ADCconfig.U_AVCC - adc.hp2);
      // lirx2 (measurement at LowPin)
      lirx2 = (unsigned long)((unsigned int)R_H_VAL) * (unsigned long)(ADCconfig.U_AVCC - adc.lp2) / adc.lp2;
      #define U_INT_LIMIT (990*U_SCALE)		// 1V switch limit in ReadADC for atmega family
        #define FAKT_LOW 2		// resolution is about twice as good
      #else
        #define FAKT_LOW 4		// resolution is about four times better
      #endif
        if (adc.hp2 < U_INT_LIMIT) {
          lrx1 = (lirx1*FAKT_LOW + lirx2) / (FAKT_LOW+1);	// weighted average of both R_H measurements
        } else if (adc.lp2 < U_INT_LIMIT){
          lrx1 = (lirx2*FAKT_LOW + lirx1) / (FAKT_LOW+1);	// weighted average of both R_H measurements
        } else
      #endif
          lrx1 = (lirx1 + lirx2) / 2;	// average of both R_H measurements
      lrx1 *= 100;
      lrx1 += RH_OFFSET;		// add constant for correction of systematic error
      ii = 'L';
      // two measurements with R_L resistors (680) are made:
        adc.hp1 = adc.tp1;		// diff negativ is illegal
      lirx1 =(unsigned long)RR680PL * (unsigned long)(adc.hp1 - adc.tp1) / (ADCconfig.U_AVCC - adc.hp1);
        adc.lp1 = adc.tp2;		// diff negativ is illegal
      // lirx2 (Measurement at LowPin)
      lirx2 =(unsigned long)RR680MI * (unsigned long)(adc.tp2 -adc.lp1) / adc.lp1;
      //lrx1 =(unsigned long)R_L_VAL * (unsigned long)adc.hp1 / (adc.hp3 - adc.hp1);
        if (adc.hp1 < U_INT_LIMIT) {
          lrx1 = (lirx1*FAKT_LOW + lirx2) / (FAKT_LOW+1);	// weighted average of both R_L measurements
        } else if (adc.lp1 < U_INT_LIMIT) {
          lrx1 = (lirx2*FAKT_LOW + lirx1) / (FAKT_LOW+1);	// weighted average of both R_L measurements
        } else
      #endif
          lrx1 = (lirx1 + lirx2) / 2;	// average of both R_L measurements
    // lrx1  is tempory result
    #if 0
      // The zero resistance is in 0.01 Ohm units and usually so little, that correction for resistors above 10 Ohm
      // is not necassary
      ii = eeprom_read_byte(&EE_ESR_ZEROtab[LowPin+HighPin]) / 10;  // Resistance offset in 0,1 Ohm units
      if (ii < lrx1) {
        lrx1 -= ii;
        lrx1 = 0;
    #endif
    #if DebugOut == 3
      lcd_line3();
      lcd_clear_line();
      lcd_line3();
      lcd_data(ii);
      lcd_space();
      if (ii == 'H') {
        lcd_data('X');
        DisplayValue(lirx1,1,LCD_CHAR_OMEGA,4)
        lcd_space();
        lcd_data('Y');
        DisplayValue(lirx2,1,LCD_CHAR_OMEGA,4)
        lcd_space();
        lcd_data('x');
        DisplayValue(lirx1,-1,LCD_CHAR_OMEGA,4)
        lcd_space();
        lcd_data('y');
        DisplayValue(lirx2,-1,LCD_CHAR_OMEGA,4)
      lcd_space();
      lcd_line4();
      lcd_clear_line();
      lcd_line4();
      lcd_space();
      lcd_line2();
    #endif
    if((PartFound == PART_DIODE) || (PartFound == PART_NONE) || (PartFound == PART_RESISTOR)) {
      for (ii=0; ii<ResistorsFound; ii++) {
        // search measurements with inverse polarity
        thisR = &resis[ii];
        if (thisR->rt != TristatePin) continue;
        // must be measurement with inverse polarity
        // resolution is 0.1 Ohm, 1 Ohm = 10 !
        lirx1 = (labs((long)lrx1 - (long)thisR->rx) * 10) / (lrx1 + thisR->rx + 100);
        if (lirx1  > 0) {
          #if DebugOut == 3
            lcd_data('R');
            lcd_data('!');
            lcd_data('=');
            DisplayValue(thisR->rx,-1,LCD_CHAR_OMEGA,3)
            lcd_space();
            DisplayValue(lirx1,-1,LCD_CHAR_OMEGA,3)
            lcd_space();
          #endif
          goto testend;  // <10% mismatch
        PartFound = PART_RESISTOR;
        goto testend;
      }  // end for
      // no same resistor with the same Tristate-Pin found, new one
      thisR = &resis[ResistorsFound];	// pointer to a free resistor structure
      thisR->rx = lrx1;			// save resistor value
        thisR->lx = 0;			// no inductance
      #endif
        thisR->ra = LowPin;		// save Pin numbers
        thisR->rb = HighPin;
        thisR->rt = TristatePin;	// Tristate is saved for easier search of inverse measurement
        ResistorsFound++;		// 1 more resistor found
      #if DebugOut == 3
        lcd_data(ResistorsFound+'0');
        lcd_data('R');
      #endif
testend:
  #if U_SCALE != 1
    ADCconfig.U_AVCC /= U_SCALE;	// scale back to mV resolution
    ADCconfig.U_Bandgap /= U_SCALE;
  #endif
    ADCconfig.Samples = ANZ_MESS;	// switch back to standard number of repetition
  #endif
  #ifdef DebugOut
    #if DebugOut < 10
      wait_about2s();
    #endif
  #endif
clean_ports:
  ADC_DDR = TXD_MSK;		// all ADC-Pins Input
  ADC_PORT = TXD_VAL;		// all ADC outputs to Ground, keine Pull up
  R_DDR = 0;			// all resistor-outputs to Input
  R_PORT = 0;			// all resistor-outputs to Ground, no Pull up
}  // end CheckPins()
// Get residual current in reverse direction of a diode
void GetIr(uint8_t hipin, uint8_t lopin) {
  unsigned int u_res;			// reverse voltage at 470k
  unsigned int ir_nano;
  //unsigned int ir_micro;
  uint8_t LoPinR_L;
  uint8_t HiADC;
  HiADC = pgm_read_byte(&PinADCtab[hipin]);
  ADC_PORT = HiADC | TXD_VAL;			// switch ADC port to high level
  ADC_DDR = HiADC | TXD_MSK;			// switch High Pin direct to VCC
  LoPinR_L = pgm_read_byte(&PinRLtab[lopin]);  	// R_L mask for LowPin R_L load
  R_PORT = 0;					// switch R-Port to GND
  R_DDR = LoPinR_L + LoPinR_L;			// switch R_H port for LowPin to output (GND)
  u_res = W5msReadADC(lopin);		// read voltage
  if (u_res == 0) return;		// no Output, if no current in reverse direction
  #if defined(NOK5110) || defined(OLED096)
    lcd_line4();
  #endif
  lcd_fix_string(Ir_str);		// output text "  Ir="
  #ifdef WITH_IRMICRO
    if (u_res < 2500) {
  #endif
      // R_H_VAL has units of 10 Ohm, u_res has units of mV, ir_nano has units of nA
      ir_nano = (unsigned long)(u_res * 100000UL) / R_H_VAL;
      DisplayValue(ir_nano,-9,'A',2);	// output two digits of current with nA units
  #ifdef WITH_IRMICRO
      R_DDR = LoPinR_L;			// switch R_L port for LowPin to output (GND)
      ir_nano = 0xffff;			// set to max
      // RR680MI has units of 0.1 Ohm, u_res has units of mV, ir_micro has units of uA
      ir_micro = (unsigned long)(u_res * 10000UL) / RR680MI;
      DisplayValue(ir_micro,-6,'A',2);	// output two digits of current in uA units
  #endif
  ADC_DDR = TXD_MSK;			// switch off
  ADC_PORT = TXD_VAL;			// switch off
  R_DDR = 0;				// switch off current
  return;
extern struct ADCconfig_t{
  uint8_t Samples;              // number of ADC samples to take
  uint8_t RefFlag;              // save Reference type VCC of IntRef
  uint16_t U_Bandgap;           // Reference Voltage in mV
  uint16_t U_AVCC;		// Voltage of AVCC
} ADCconfig;
#ifdef INHIBIT_SLEEP_MODE
  //#define StartADCwait() ADCSRA = (1<<ADSC) | (1<<ADEN) | (1<<ADIF) | AUTO_CLOCK_DIV; /* enable ADC and start */
  #define StartADCwait() ADCSRA = StartADCmsk; /* Start conversion */\
  while (ADCSRA & (1 << ADSC))  /* wait until conversion is done */
#else
  #define StartADCwait() ADCSRA = (1<<ADEN) | (1<<ADIF) | (1<<ADIE) | AUTO_CLOCK_DIV; /* enable ADC and Interrupt */\
  set_sleep_mode(SLEEP_MODE_ADC);\
  sleep_mode();	/* Start ADC, return, if ADC has finished */
#endif
unsigned int ReadADC (uint8_t Probe) {
  unsigned int U; 		// return value (mV)
  uint8_t Samples; 		// loop counter
  unsigned long Value; 		// ADC value
  Probe |= (1 << REFS0); 	// use internal reference anyway
sample:
  #endif
  ADMUX = Probe; 	// set input channel and U reference
    // if voltage reference changes, wait for voltage stabilization
    if ((Probe & (1 << REFS1)) != 0) {
      // switch to 1.1V Reference
      #ifdef NO_AREF_CAP
        wait100us(); 		// time for voltage stabilization
      #else
        wait_about10ms(); 	// time for voltage stabilization
      #endif
  #endif
  // allways do one dummy read of ADC, 112us
  StartADCwait();		// start ADC and wait
  // sample ADC readings
  Value = 0UL; 			// reset sampling variable
  Samples = 0; 			// number of samples to take
  while (Samples < ADCconfig.Samples) {		// take samples
    Value += ADCW; 				// add ADC reading
      // auto-switch voltage reference for low readings
      if ((Samples == 4) && (ADCconfig.U_Bandgap > 255) && ((uint16_t)Value < 1024) && !(Probe & (1 << REFS1))) {
        Probe |= (1 << REFS1); 		// select internal bandgap reference
        #if PROCESSOR_TYP == 1280
          Probe &= ~(1 << REFS0);	// ATmega640/1280/2560 1.1V Reference with REFS0=0
        #endif
        goto sample; 	// re-run sampling
    #endif
    Samples++; 		// one more done
    // convert ADC reading to voltage - single sample: U = ADC reading * U_ref / 1024
    // get voltage of reference used
    if (Probe & (1 << REFS1)) U = ADCconfig.U_Bandgap; 	// bandgap reference
    else U = ADCconfig.U_AVCC; 	// Vcc reference
  #else
  #endif
  // convert to voltage
  Value *= U; 		// ADC readings * U_ref
  Value /= 1023; 	// / 1024 for 10bit ADC
  // de-sample to get average voltage
  Value /= ADCconfig.Samples;
  U = (unsigned int)Value;
  return U;
  //return ((unsigned int)(Value / (1023 * (unsigned long)ADCconfig.Samples)));
unsigned int W5msReadADC (uint8_t Probe) {
  wait_about5ms();
  return (ReadADC(Probe));
unsigned int W10msReadADC (uint8_t Probe) {
  wait_about10ms();
unsigned int W20msReadADC (uint8_t Probe) {
  wait_about20ms();
// new code by K.-H. Kubbeler
// ReadCapacity tries to find the value of a capacitor by measuring the load time.
// first of all the capacitor is discharged.
// Then a series of up to 500 load pulses with 10ms duration each is done across the R_L (680Ohm)
// resistor.
// After each load pulse the voltage of the capacitor is measured without any load current.
// If voltage reaches a value of more than 300mV and is below 1.3V, the capacity can be
// computed from load time and voltage by a interpolating a build in table.
// If the voltage reaches a value of more than 1.3V with only one load pulse,
// another measurement methode is used:
// The build in 16bit counter can save the counter value at external events.
// One of these events can be the output change of a build in comparator.
// The comparator can compare the voltage of any of the ADC input pins with the voltage
// of the internal reference (1.3V or 1.1V).
// After setting up the comparator and counter properly, the load of capacitor is started
// with connecting the positive pin with the R_H resistor (470kOhm) to VCC and immediately
// the counter is started. By counting the overflow Events of the 16bit counter and watching
// the counter event flag  the total load time of the capacitor until reaching the internal
// reference voltage can be measured.
// If any of the tries to measure the load time is successful,
// the following variables are set:
// cap.cval = value of the capacitor
// cap.cval_uncorrected = value of the capacitor uncorrected
// cap.esr = serial resistance of capacitor,  0.01 Ohm units
// cap.cpre = units of cap.cval (-12==pF, -9=nF, -6=uF)
// ca   = Pin number (0-2) of the LowPin
// cb   = Pin number (0-2) of the HighPin
void ReadCapacity(uint8_t HighPin, uint8_t LowPin) {
  // check if capacitor and measure the capacity value
  unsigned int tmpint;
  unsigned int adcv[4];
    unsigned int ovcnt16;
  #endif
  uint8_t HiPinR_L, HiPinR_H;
  uint8_t LoADC;
  uint8_t ii;
    unsigned int vloss;		// lost voltage after load pulse in 0.1%
  #endif
  #ifdef AUTO_CAL
    pin_combination = (HighPin * 3) + LowPin - 1;	// coded Pin combination for capacity zero offset
  #endif
  LoADC = pgm_read_byte(&PinADCtab[LowPin]) | TXD_MSK;
  HiPinR_L = pgm_read_byte(&PinRLtab[HighPin]);		// R_L mask for HighPin R_L load
  HiPinR_H = HiPinR_L + HiPinR_L;			// double for HighPin R_H load
  #if DebugOut == 10
    lcd_line3();
    lcd_clear_line();
    lcd_line3();
    lcd_data('C');
    lcd_space();
  #endif
    #if DebugOut == 10
      lcd_data('R');
      wait_about2s();
    #endif
    return;	// We have found a resistor already
  for (ii=0;ii<NumOfDiodes;ii++) {
    if ((diodes[ii].Cathode == LowPin) && (diodes[ii].Anode == HighPin) && (diodes[ii].Voltage < 1500)) {
      #if DebugOut == 10
        lcd_data('D');
        wait_about2s();
      #endif
      return;
    cap.esr = 0;			// set ESR of capacitor to zero
    vloss = 0;				// set lost voltage to zero
  #endif
  cap.cval = 0;				// set capacity value to zero
  cap.cpre = -12;			// default unit is pF
  EntladePins();			// discharge capacitor
  ADC_PORT = TXD_VAL;			// switch ADC-Port to GND
  ADC_DDR = LoADC;			// switch Low-Pin to output (GND)
  R_DDR = HiPinR_L;			// switch R_L port for HighPin to output (GND)
  adcv[0] = ReadADC(HighPin);		// voltage before any load
  // ******** should adcv[0] be measured without current???
  adcv[2] = adcv[0];			// preset to prevent compiler warning
  for (ovcnt16=0; ovcnt16<500; ovcnt16++) {
    R_PORT = HiPinR_L;			// R_L to 1 (VCC)
    R_DDR = HiPinR_L;			// switch Pin to output, across R to GND or VCC
    wait10ms();				// wait exactly 10ms, do not sleep
    R_DDR = 0;				// switch back to input
    R_PORT = 0;				// no Pull up
    wait500us();			// wait a little time
    wdt_reset();
    // read voltage without current, is already charged enough?
    adcv[2] = ReadADC(HighPin);
    if (adcv[2] > adcv[0]) {
      adcv[2] -= adcv[0];		// difference to beginning voltage
      adcv[2] = 0;			// voltage is lower or same as beginning voltage
    if ((ovcnt16 == 126) && (adcv[2] < 75)) {
      // 300mV can not be reached well-timed
      break;		// don't try to load any more
    if (adcv[2] > 300) {
      break;		// probably 100mF can be charged well-timed
  // wait 5ms and read voltage again, does the capacitor keep the voltage?
  //adcv[1] = W5msReadADC(HighPin) - adcv[0];
  //wdt_reset();
  #if DebugOut == 10
    DisplayValue(ovcnt16,0,' ',4);
    DisplayValue(adcv[2],-3,'V',4);
  #endif
  if (adcv[2] < 301) {
    #if DebugOut == 10
      lcd_data('K');
      lcd_space();
      wait1s();
    #endif
    //if (NumOfDiodes != 0) goto messe_mit_rh;
    goto keinC;		// was never charged enough, >100mF or shorted
  // voltage is rised properly and keeps the voltage enough
  if ((ovcnt16 == 0 ) && (adcv[2] > 1300)) {
    goto messe_mit_rh;		// Voltage of more than 1300mV is reached in one pulse, too fast loaded
  // Capacity is more than about 50uF
  #ifdef NO_CAP_HOLD_TIME
    ChargePin10ms(HiPinR_H,0);		// switch HighPin with R_H 10ms auf GND, then currentless
    adcv[3] = ReadADC(HighPin) - adcv[0];  // read voltage again, is discharged only a little bit ?
    if (adcv[3] > adcv[0]) {
      adcv[3] -= adcv[0];		// difference to beginning voltage
      adcv[3] = 0;			// voltage is lower to beginning voltage
    #if DebugOut == 10
      lcd_data('U');
      lcd_data('3');
      lcd_data(':');
      lcd_string(utoa(adcv[3],outval,10));
      lcd_space();
      wait_about2s();
    #endif
    if ((adcv[3] + adcv[3]) < adcv[2]) {
      #if DebugOut == 10
        lcd_data('H');
        lcd_space();
        wait_about1s();
      #endif
      if (ovcnt16 == 0 )  {
        goto messe_mit_rh;		// Voltage of more than 1300mV is reached in one pulse, but not hold
      goto keinC;  // implausible, not yet the half voltage
    cap.cval_uncorrected.dw = ovcnt16 + 1;
    cap.cval_uncorrected.dw *= getRLmultip(adcv[2]);	// get factor to convert time to capacity from table
  #else
    // wait the half the time which was required for loading
    adcv[3] = adcv[2];			// preset to prevent compiler warning
    for (tmpint=0; tmpint<=ovcnt16; tmpint++) {
      wait5ms();
      adcv[3] = ReadADC(HighPin);	// read voltage again, is discharged only a little bit ?
      wdt_reset();
      adcv[3] = 0;			// voltage is lower or same as beginning voltage
    if (adcv[2] > adcv[3]) {
      // build difference to load voltage
      adcv[3] = adcv[2] - adcv[3];	// lost voltage during load time wait
      adcv[3] = 0;			// no lost voltage
      // compute equivalent parallel resistance from voltage drop
      if (adcv[3] > 0) {
        // there is any voltage drop (adcv[3]) !
        // adcv[2] is the loaded voltage.
        vloss = (unsigned long)(adcv[3] * 1000UL) / adcv[2];
    #endif
    if (adcv[3] > 100) {
      // more than 100mV is lost during load time
      #if DebugOut == 10
        lcd_data('L');
        lcd_space();
        wait_about1s();
      #endif
      goto keinC;			// capacitor does not keep the voltage about 5ms
    // compute factor with load voltage + lost voltage during the voltage load time
    cap.cval_uncorrected.dw *= getRLmultip(adcv[2]+adcv[3]);	// get factor to convert time to capacity from table
  #endif
  cap.cval = cap.cval_uncorrected.dw;	// set result to uncorrected
  cap.cpre = -9;			// switch units to nF
  Scale_C_with_vcc();
  // cap.cval for this type is at least 40000nF, so the last digit will be never shown
  cap.cval *= (1000 - C_H_KORR);	// correct with C_H_KORR with 0.1% resolution, but prevent overflow
  cap.cval /= 100;
  #if DebugOut == 10
    lcd_line3();
    lcd_clear_line();
    lcd_line3();
    lcd_data('C');
    lcd_space();
    lcd_space();
    lcd_string(utoa(ovcnt16,outval,10));
    wait_about3s();
  #endif
  goto checkDiodes;
// Measurement of little capacity values
messe_mit_rh:
  // little capacity value, about  < 50 uF
  // measure with the R_H (470kOhm) resistor
  R_PORT = 0;		// R_DDR ist HiPinR_L
  ADC_DDR = (1<<TP1) | (1<<TP2) | (1<<TP3) | (1<<TxD);	// switch all Pins to output
  ADC_PORT = TXD_VAL;		// switch all ADC Pins to GND
  R_DDR = HiPinR_H;   		// switch R_H resistor port for HighPin to output (GND)
  // setup Analog Comparator
  ADC_COMP_CONTROL = (1<<ACME);			// enable Analog Comparator Multiplexer
  ACSR =  (1<<ACBG) | (1<<ACI)  | (1<<ACIC);	// enable, 1.3V, no Interrupt, Connect to Timer1
  ADMUX = (1<<REFS0) | HighPin;			// switch Mux to High-Pin
  ADCSRA = (1<<ADIF) | AUTO_CLOCK_DIV; 		// disable ADC
  wait200us();					// wait for bandgap to start up
  // setup Counter1
  ovcnt16 = 0;
  TCCR1A = 0;			// set Counter1 to normal Mode
  TCNT1 = 0;			// set Counter to 0
  TI1_INT_FLAGS = (1<<ICF1) | (1<<OCF1B) | (1<<OCF1A) | (1<<TOV1);	// clear interrupt flags
  #ifndef INHIBIT_SLEEP_MODE
    TIMSK1 = (1<<TOIE1) | (1<<ICIE1);	// enable Timer overflow interrupt and input capture interrupt
    unfinished = 1;
  #endif
  R_PORT = HiPinR_H;           	// switch R_H resistor port for HighPin to VCC
  if(PartFound == PART_FET) {
    // charge capacitor with R_H resistor
    TCCR1B = (1<<CS10);	//Start counter 1MHz or 8MHz
    ADC_DDR = (((1<<TP1) | (1<<TP2) | (1<<TP3) | TXD_MSK) & ~(1<<HighPin));	// release only HighPin ADC port
    TCCR1B =  (1<<CS10);	// start counter 1MHz or 8MHz
    ADC_DDR = LoADC;		// stay LoADC Pin switched to GND, charge capacitor with R_H slowly
    while(1) {
      // Wait, until  Input Capture is set
      ii = TI1_INT_FLAGS;	// read Timer flags
      if (ii & (1<<ICF1))  {
      if((ii & (1<<TOV1))) {		// counter overflow, 65.536 ms @ 1MHz, 8.192ms @ 8MHz
        TI1_INT_FLAGS = (1<<TOV1);	// Reset OV Flag
        wdt_reset();
        ovcnt16++;
        if(ovcnt16 == (F_CPU/5000)) {
          break; 			// Timeout for Charging, above 12 s
    TCCR1B = (0<<ICNC1) | (0<<ICES1) | (0<<CS10);  // stop counter
    TI1_INT_FLAGS = (1<<ICF1);		// Reset Input Capture
    tmpint = ICR1;			// get previous Input Capture Counter flag
    // check actual counter, if an additional overflow must be added
    if((TCNT1 > tmpint) && (ii & (1<<TOV1))) {
      // this OV was not counted, but was before the Input Capture
      ovcnt16++;
  #else
    while(unfinished) {
      sleep_mode();    			// wait for interrupt
      wdt_reset();
    TIMSK1 = (0<<TOIE1) | (0<<ICIE1);	// disable Timer overflow interrupt and input capture interrupt
    if (TCNT1 < tmpint) {
      ovcnt16--;			// one ov to much
  #endif
  ADCSRA = (1<<ADEN) | (1<<ADIF) | AUTO_CLOCK_DIV;	 // enable ADC
  R_DDR = 0;					// switch R_H resistor port for input
  R_PORT = 0;					// switch R_H resistor port pull up for HighPin off
  adcv[2] = ReadADC(HighPin);   		// get loaded voltage
  load_diff = adcv[2] + REF_C_KORR - ref_mv;	// build difference of capacitor voltage to Reference Voltage
  if (ovcnt16 >= (F_CPU/10000)) {
    #if DebugOut == 10
      lcd_data('k');
      wait_about1s();
    #endif
    goto keinC;	// no normal end
  //cap.cval_uncorrected = CombineII2Long(ovcnt16, tmpint);
  cap.cval_uncorrected.w[1] = ovcnt16;
  cap.cval_uncorrected.w[0] = tmpint;
  cap.cpre = -12;			// cap.cval unit is pF
  if (ovcnt16 > 65) {
    cap.cval_uncorrected.dw /= 100;	// switch to next unit
    cap.cpre += 2;			// set unit, prevent overflow
  cap.cval_uncorrected.dw *= RHmultip;		// 708
  cap.cval_uncorrected.dw /= (F_CPU / 10000);	// divide by 100 (@ 1MHz clock), 800 (@ 8MHz clock)
  cap.cval = cap.cval_uncorrected.dw;		// set the corrected cap.cval
  Scale_C_with_vcc();
  if (cap.cpre == -12) {
    #if COMP_SLEW1 > COMP_SLEW2
      if (cap.cval < COMP_SLEW1) {
        // add slew rate dependent offset
        cap.cval += (COMP_SLEW1 / (cap.cval+COMP_SLEW2 ));
    #endif
    #ifdef AUTO_CAL
      // auto calibration mode, cap_null can be updated in selftest section
      tmpint = eeprom_read_byte(&c_zero_tab[pin_combination]);	// read zero offset
      if (cap.cval > tmpint) {
        cap.cval -= tmpint;		// subtract zero offset (pF)
        cap.cval = 0;			// unsigned long may not reach negativ value
    #else
      if (HighPin == TP2) cap.cval += TP2_CAP_OFFSET;	// measurements with TP2 have 2pF less capacity
      if (cap.cval > C_NULL) {
        cap.cval -= C_NULL;		// subtract constant offset (pF)
    #endif
  #if DebugOut == 10
    R_DDR = 0;			// switch all resistor ports to input
    lcd_line4();
    lcd_clear_line();
    lcd_line4();
    lcd_data('c');
    lcd_space();
    wait_about3s();
  #endif
  R_DDR = HiPinR_L; 		// switch R_L for High-Pin to GND
  #if F_CPU < 2000001
    if(cap.cval < 50)
  #else
    if(cap.cval < 25)
  #endif
      // cap.cval can only be so little in pF unit, cap.cpre must not be testet!
      #if DebugOut == 10
        lcd_data('<');
        lcd_space();
        wait_about1s();
      #endif
      goto keinC;  // capacity to low, < 50pF @1MHz (25pF @8MHz)
  // end low capacity
checkDiodes:
  if((NumOfDiodes > 0)  && (PartFound != PART_FET)) {
    #if DebugOut == 10
      lcd_data('D');
      lcd_space();
      wait_about1s();
    #endif
    // nearly shure, that there is one or more diodes in reverse direction,
    // which would be wrongly detected as capacitor
    PartFound = PART_CAPACITOR;		// capacitor is found
    if ((cap.cpre > cap.cpre_max) || ((cap.cpre == cap.cpre_max) && (cap.cval > cap.cval_max))) {
      // we have found a greater one
      cap.cval_max = cap.cval;
      cap.cpre_max = cap.cpre;
        cap.v_loss = vloss;		// lost voltage in 0.01%
      #endif
      cap.ca = LowPin;		// save LowPin
      cap.cb = HighPin;		// save HighPin
keinC:
  // discharge capacitor again
  //EntladePins();		// discharge capacitors
  // ready
  // switch all ports to input
  ADC_DDR =  TXD_MSK;		// switch all ADC ports to input
  ADC_PORT = TXD_VAL;		// switch all ADC outputs to GND, no pull up
  R_PORT = 0; 			// switch all resistor outputs to GND, no pull up
  return;
}  // end ReadCapacity()
unsigned int getRLmultip(unsigned int cvolt) {
  // interpolate table RLtab corresponding to voltage cvolt
  // Widerstand 680 Ohm          300   325   350   375   400   425   450   475   500   525   550   575   600   625   650   675   700   725   750   775   800   825   850   875   900   925   950   975  1000  1025  1050  1075  1100  1125  1150  1175  1200  1225  1250  1275  1300  1325  1350  1375  1400  mV
  //uint16_t RLtab[] MEM_TEXT = {22447,20665,19138,17815,16657,15635,14727,13914,13182,12520,11918,11369,10865,10401, 9973, 9577, 9209, 8866, 8546, 8247, 7966, 7702, 7454, 7220, 6999, 6789, 6591, 6403, 6224, 6054, 5892, 5738, 5590, 5449, 5314, 5185, 5061, 4942, 4828, 4718, 4613, 4511, 4413, 4319, 4228};
  #define RL_Tab_Abstand 25     // displacement of table 25mV
  #define RL_Tab_Beginn 300     // begin of table ist 300mV
  #define RL_Tab_Length 1100    // length of table is 1400-300
  unsigned int uvolt;
  uint8_t tabind;
  uint8_t tabres;
  if (cvolt >= RL_Tab_Beginn) {
    uvolt = cvolt - RL_Tab_Beginn;
    uvolt = 0;			// limit to begin of table
  tabind = uvolt / RL_Tab_Abstand;
  tabres = uvolt % RL_Tab_Abstand;
  tabres = RL_Tab_Abstand - tabres;
  if (tabind > (RL_Tab_Length/RL_Tab_Abstand)) {
    tabind = (RL_Tab_Length/RL_Tab_Abstand);	// limit to end of table
  y1 = MEM_read_word(&RLtab[tabind]);
  y2 = MEM_read_word(&RLtab[tabind+1]);
  return ( ((y1 - y2) * tabres + (RL_Tab_Abstand/2)) / RL_Tab_Abstand + y2); // interpolate table
void Scale_C_with_vcc(void) {
  while (cap.cval > 100000) {
    cap.cval /= 10;
    cap.cpre ++;			// prevent overflow
  cap.cval *= ADCconfig.U_AVCC;		// scale with measured voltage
  cap.cval /= U_VCC;			// Factors are computed for U_VCC
// Interrupt Service Routine for timer1 Overflow
ISR(TIMER1_OVF_vect, ISR_BLOCK)
  ovcnt16++;				// count overflow
// Interrupt Service Routine for timer1 capture event (Comparator)
ISR(TIMER1_CAPT_vect, ISR_BLOCK)
  unfinished = 0;			// clear unfinished flag
#endif
// The 680 Ohm resistor (R_L_VAL) at the Lowpin will be used as current sensor
// The current with a coil will with (1 - e**(-t*R/L)), where R is
// the sum of Pin_RM , R_L_VAL , Resistance of coil and Pin_RP.
// L in the inductance of the coil.
void ReadInductance(void) {
  // check if inductor and measure the inductance value
  unsigned int umax;
  unsigned int total_r;		// total resistance of current loop
  unsigned int mess_r;		// value of resistor used for current measurement
  unsigned long inductance[4];	// four inductance values for different measurements
  union t_combi{
  unsigned long dw;     // time_constant
  uint16_t w[2];
  } timeconstant;
  uint16_t per_ref1,per_ref2;	// percentage
  uint8_t LoPinR_L;	// Mask for switching R_L resistor of low pin
  uint8_t HiADC;	// Mask for switching the high pin direct to VCC
  uint8_t ii;
  uint8_t count;	// counter for the different measurements
  //uint8_t found;	// variable used for searching resistors
  #define found 0
  uint8_t cnt_diff;     // resistance dependent offset
  uint8_t LowPin;	// number of pin with low voltage
  uint8_t HighPin;	// number of pin with high voltage
  int8_t ukorr;		// correction of comparator voltage
  uint8_t nr_pol1;	// number of successfull inductance measurement with polarity 1
  uint8_t nr_pol2;	// number of successfull inductance measurement with polarity 2
  if(PartFound != PART_RESISTOR) {
    return;	// We have found no resistor
  if (ResistorsFound != 1) {
    return;	// do not search for inductance, more than 1 resistor
  //for (found=0;found<ResistorsFound;found++) {
  //  if (resis[found].rx > 21000) continue;
  if (resis[found].rx > 21000) return;
  // we can check for Inductance, if resistance is below 2100 Ohm
  for (count=0; count<4; count++) {
    // Try four times (different direction and with delayed counter start)
    if (count < 2) {
      // first and second pass, direction 1
      LowPin = resis[found].ra;
      HighPin = resis[found].rb;
      // third and fourth pass, direction 2
      LowPin = resis[found].rb;
      HighPin = resis[found].ra;
    HiADC = pgm_read_byte(&PinADCtab[HighPin]);
    LoPinR_L = pgm_read_byte(&PinRLtab[LowPin]);	// R_L mask for HighPin R_L load
    // Measurement of Inductance values
    R_PORT = 0;			// switch R port to GND
    if ((resis[found].rx < 240) && ((count & 0x01) == 0)) {
      // we can use PinR_L for measurement
      mess_r = RR680MI - R_L_VAL;			// use only pin output resistance
      ADC_DDR = HiADC | (1<<LowPin) | TXD_MSK;		// switch HiADC and Low Pin to GND,
      R_DDR = LoPinR_L;   		// switch R_L resistor port for LowPin to output (GND)
      ADC_DDR = HiADC | TXD_MSK;	// switch HiADC Pin to GND
      mess_r = RR680MI;			// use 680 Ohm and PinR_L for current measurement
    // Look, if we can detect any current
    for (ii=0;ii<20;ii++) {
      // wait for current is near zero
      umax = W10msReadADC(LowPin);
      total_r =  ReadADC(HighPin);
      if ((umax < 2) && (total_r < 2)) break;	// low current detected
    ADMUX = (1<<REFS0) | LowPin;			// switch Mux to Low-Pin
    // setup Counter1
    timeconstant.w[1] = 0;	// set ov counter to 0
    TI1_INT_FLAGS = (1<<ICF1) | (1<<OCF1B) | (1<<OCF1A) | (1<<TOV1);	// reset TIFR or TIFR1
    HiADC |= TXD_VAL;
    if ((count & 0x01) == 0 ) {
      // first start counter, then start current
      TCCR1B =  (1<<ICNC1) | (0<<ICES1) | (1<<CS10);	// start counter 1MHz or 8MHz
      ADC_PORT = HiADC;					// switch ADC-Port to VCC
      // first start current, then start counter with delay
      // parasitic capacity of coil can cause high current at the beginning
      #if F_CPU >= 8000000UL
        wait3us();		// ignore current peak from capacity
      #else
        wdt_reset();		// delay
      #endif
    while(1) {
        wdt_reset();
        timeconstant.w[1]++;		// count one OV
        if(timeconstant.w[1] == (F_CPU/100000UL)) {
          break; 			// Timeout for Charging, above 0.13 s
    timeconstant.w[0] = ICR1;		// get previous Input Capture Counter flag
    if((TCNT1 > timeconstant.w[0]) && (ii & (1<<TOV1))) {
      timeconstant.w[1]++;			// count one additional OV
    #define CNT_ZERO_42 6
    #define CNT_ZERO_720 7
    //#if F_CPU == 16000000UL
    //  #undef CNT_ZERO_42
    //  #undef CNT_ZERO_720
    //  #define CNT_ZERO_42 7
    //  #define CNT_ZERO_720 10
    //#endif
    total_r = (mess_r + resis[found].rx + RRpinMI);
    //cnt_diff = 0;
    //if (total_r > 7000) cnt_diff = 1;
    //if (total_r > 14000) cnt_diff = 2;
    cnt_diff = total_r / ((14000UL * 8) / (F_CPU/1000000UL));
    // Voltage of comparator in % of umax
    #ifdef AUTO_CAL
      tmpint = (ref_mv + (int16_t)eeprom_read_word((uint16_t *)(&ref_offset))) ;
    #else
      tmpint = (ref_mv + REF_C_KORR);
    #endif
    if (mess_r < R_L_VAL) {
      // measurement without 680 Ohm
      cnt_diff = CNT_ZERO_42;
      if (timeconstant.dw < 225) {
        ukorr = (timeconstant.w[0] / 5) - 20;
        ukorr = 25;
      tmpint -= (((REF_L_KORR * 10) / 10) + ukorr);
      // measurement with 680 Ohm resistor
      // if 680 Ohm resistor is used, use REF_L_KORR for correction
      cnt_diff += CNT_ZERO_720;
      tmpint += REF_L_KORR;
    if (timeconstant.dw > cnt_diff) timeconstant.dw -= cnt_diff;
    else timeconstant.dw = 0;
    if ((count&0x01) == 1) {
      // second pass with delayed counter start
      timeconstant.dw += (3 * (F_CPU/1000000UL))+10;
    if (timeconstant.w[1] >= (F_CPU/100000UL)) timeconstant.dw = 0;  // no transition found
    if (timeconstant.dw > 10) {
      timeconstant.dw -= 1;
    // compute the maximum Voltage umax with the Resistor of the coil
    umax = ((unsigned long)mess_r * (unsigned long)ADCconfig.U_AVCC) / total_r;
    per_ref1 = ((unsigned long)tmpint * 1000) / umax;
    //per_ref2 = (uint8_t)MEM2_read_byte(&LogTab[per_ref1]);	// -log(1 - per_ref1/100)
    per_ref2 = get_log(per_ref1);				// -log(1 - per_ref1/1000)
    #if 0
      if (count == 0) {
        lcd_line3();
        DisplayValue(count,0,' ',4);
        DisplayValue(timeconstant.dw,0,'+',4);
        DisplayValue(cnt_diff,0,' ',4);
        DisplayValue(total_r,-1,'r',4);
        lcd_space();
        DisplayValue(per_ref1,-1,'%',4);
        lcd_line4();
        DisplayValue(tmpint,-3,'V',4);
        lcd_space();
        DisplayValue(umax,-3,'V',4);
        lcd_space();
        DisplayValue(per_ref2,-1,'%',4);
        wait_about4s();
        wait_about2s();
    #endif
    // lx in 0.01mH units, L = Tau * R
    per_ref1 = ((per_ref2 * (F_CPU/1000000UL)) + 5) / 10;
    inductance[count] = (timeconstant.dw * total_r ) / per_ref1;
    if (((count&0x01) == 0) && (timeconstant.dw > ((F_CPU/1000000UL)+3))) {
      // transition is found, measurement with delayed counter start is not necessary
      inductance[count+1] = inductance[count];	// set delayed measurement to same value
      count++;					// skip the delayed measurement
    wdt_reset();
  }  // end for count
  ADC_PORT = TXD_VAL;		// switch ADC Port to GND
  wait_about20ms();
  #if 0
    if (inductance[1] > inductance[0]) {
      resis[found].lx = inductance[1];		// use value found with delayed counter start
      resis[found].lx = inductance[0];
    if (inductance[3] > inductance[2]) inductance[2] = inductance[3];		// other polarity, delayed start
    if (inductance[2] < resis[found].lx) resis[found].lx = inductance[2];	// use the other polarity
  #else
    nr_pol1 = 0;
    if (inductance[1] > inductance[0]) { nr_pol1 = 1; }
    nr_pol2 = 2;
    if (inductance[3] > inductance[2]) { nr_pol2 = 3; }
    if (inductance[nr_pol2] < inductance[nr_pol1]) nr_pol1 = nr_pol2;
    resis[found].lx = inductance[nr_pol1];
    resis[found].lpre = -5;					// 10 uH units
    if (((nr_pol1 & 1) == 1) || (resis[found].rx >= 240)) {
      // with 680 Ohm resistor total_r is more than 7460
      resis[found].lpre = -4;					// 100 uH units
      resis[found].lx = (resis[found].lx + 5) / 10;
  #endif
  //} // end loop for all resistors
#endif
  return;
}  // end ReadInductance()
// get_log interpolate a table with the function -log(1 - (permil/1000))
uint16_t get_log(uint16_t permil) {
// for remember:
// uint16_t LogTab[] PROGMEM = {0, 20, 41, 62, 83, 105, 128, 151, 174, 198, 223, 248, 274, 301, 329, 357, 386, 416, 446, 478, 511, 545, 580, 616, 654, 693, 734, 777, 821, 868, 916, 968, 1022, 1079, 1139, 1204, 1273, 1347, 1427, 1514, 1609, 1715, 1833, 1966, 2120, 2303, 2526 };
  #define Log_Tab_Distance 20           // displacement of table is 20 mil
  uint16_t y1, y2;			// table values
  uint16_t result;			// result of interpolation
  uint8_t tabind;			// index to table value
  uint8_t tabres;			// distance to lower table value, fraction of Log_Tab_Distance
  tabind = permil / Log_Tab_Distance;	// index to table
  tabres = permil % Log_Tab_Distance;	// fraction of table distance
  // interpolate the table of factors
  y1 = pgm_read_word(&LogTab[tabind]);		// get the lower table value
  y2 = pgm_read_word(&LogTab[tabind+1]); 	// get the higher table value
  result = ((y2 - y1) * tabres ) / Log_Tab_Distance + y1;  // interpolate
  return(result);
#endif
#define MAX_CNT 255
/* The sleep mode for ADC can be used. It is implemented for 8MHz and 16MHz operation */
/* But the ESR result is allways higher than the results with wait mode. */
/* The time of ESR measurement is higher with the sleep mode (checked with oszilloscope) */
/* The reason for the different time is unknown, the start of the next ADC measurement */
/* should be initiated before the next ADC-clock (8 us). One ADC takes 13 ADC clock + 1 clock setup. */
/* The setting to sleep mode takes 10 clock tics, the wakeup takes about 24 clock tics, but 8us are 64 clock tics. */
/* I have found no reason, why a reset of the ADC clock divider should occur during ESR measurement. */
//#define ADC_Sleep_Mode
//#define ESR_DEBUG
#ifdef ADC_Sleep_Mode
  //#define StartADCwait() ADCSRA = (1<<ADEN) | (1<<ADIF) | (1<<ADIE) | AUTO_CLOCK_DIV; /* enable ADC and Interrupt */
  //#define StartADCwait() set_sleep_mode(SLEEP_MODE_ADC);
  //sleep_mode()		/* Start ADC, return if ADC has finished */
  #define StartADCwait() sleep_cpu()
#else
#endif
/* Predefine the wait time for switch off the load current for big caps */
//         wdt_reset();		// with wdt_reset the timing can be adjusted,
				// when time is too short, voltage is down before SH of ADC
				// when time is too long, capacitor will be overloaded.
				// That will cause too high voltage without current.
            // Interrupt mode, big cap
  #if F_CPU == 8000000UL
    #define DelayBigCap() wait10us();	/* 2.5 ADC clocks = 20us */ \
            wait5us();		/*  */ \
            wait2us();	/* with only 17 us delay the voltage goes down before SH */ \
            /* delay 17us + 3 clock tics (CALL instead of RCALL) = 17.375 us @ 8 MHz */ \
            /* + 21 clock tics delay from interrupt return, +2.625us = 20.0 */	\
            wdt_reset();	/* 20.125 us  */ \
            wdt_reset()		/* 20.250 us  */
  #endif
    #define DelayBigCap() us500delay(18);	/* 2.5 ADC clocks = 20us */ \
            /* with only 18 us delay the voltage goes down before SH */ \
            /* delay 18us 500ns + 1 clock tics (CALL instead of RCALL) = 18.5625 us */ \
            /* + 21 clock tics delay from interrupt return, +1.3125us = 19.8750 */ \
            wdt_reset(); 	/* 19.9375 us  */ \
            wdt_reset(); 	/* 20.0000 us  */ \
            wdt_reset(); 	/* 20.0625 us  */ \
            wdt_reset(); 	/* 20.1250 us  */ \
            wdt_reset(); 	/* 20.1875 us  */ \
            wdt_reset() 	/* 20.2500 us  */
  #endif
#else
            // Polling mode, big cap
            wait5us();		/*  */ \
            wait4us();	/* pulse length 19.375 us */
            /* delay 19us + 3 clock tics (CALL instead of RCALL) = 19.375 us @ 8 MHz */
            /* + 7 clock tics delay from while loop, +0.875us  = 20.250 */
//            wdt_reset()	/* 20.375 us + */
  #endif
    #define DelayBigCap() delayMicroseconds(20)
//    #define DelayBigCap() us500delay(19);	/* 2.5 ADC clocks = 20us */ \
//            /* with only 18 us delay the voltage goes down before SH */ \
//            /* delay 19us 500ns + 1 clock tics (CALL instead of RCALL) = 19.5625 us */ \
//            /* + 7 clock tics delay from "while (ADCSRA&(1<<ADSC))" loop = 20.0000 */ \
//            wdt_reset(); 	/* 20.0625 us  */ \
//            wdt_reset(); 	/* 20.1250 us  */ \
//            wdt_reset(); 	/* 20.1875 us  */ \
//            wdt_reset() 	/* 20.2500 us  */
  #endif
#endif
/* Predefine the wait time for switch off the load current for small caps */
      	// SH at 2.5 ADC clocks behind start = 5 us
            // Interrupt mode, small cap
    #define DelaySmallCap() wait2us();	/* with only 4 us delay the voltage goes down before SH */ \
            /* delay 2us + 1 clock tics (CALL instead of RCALL) = 2.125 us @ 8 MHz */ \
            /* + 21 clock tics delay from interrupt return, +2.625us = 4.75 */ \
            wdt_reset();	/* 4.875 us   */ \
            wdt_reset();	/* 5.000 us   */ \
            wdt_reset()		/* 5.125 us   */
  #endif
    #define DelaySmallCap() us500delay(3);	/* with only 18 us delay the voltage goes down before SH */ \
            /* delay 3us 500ns + 1 clock tics (CALL instead of RCALL) = 3.5625 us */ \
            /* + 21 clock tics delay from interrupt return, +1.3125us = 4.875 */ \
            wdt_reset();	/* 4.9375 us  */ \
            wdt_reset(); 	/* 5.0000 us  */ \
            wdt_reset();	/* 5.0625 us  */ \
            wdt_reset()		/* 5.1250 us  */
  #endif
#else
            // Polling mode, small cap
    #define DelaySmallCap() wait4us();	/* with only 4 us delay the voltage goes down before SH */ \
            /* delay 4us + 1 clock tics (CALL instead of RCALL) = 4.125 us @ 8 MHz */ \
            /* + 7 clock tics delay from while loop, +0.875us  = 5.000 */ \
  #endif
    #define DelaySmallCap() us500delay(4);	/* with only 4 us delay the voltage goes down before SH */ \
            /* delay 4us 500ns + 1 clock tics (CALL instead of RCALL) = 4.5625 us */ \
            /* + 7 clock tics delay from "while (ADCSRA&(1<<ADSC))" loop, +0.4375 = 5.0000 */ \
  #endif
#endif
uint16_t GetESR(uint8_t hipin, uint8_t lopin) {
  // measure the ESR value of capacitor
  unsigned int adcv[4];		// array for 4 ADC readings
  unsigned long sumvolt[4];	// array for 3 sums of ADC readings
  unsigned long cap_val_nF;
  uint16_t esrvalue;
  uint8_t HiPinR_L;		// used to switch 680 Ohm to HighPin
  uint8_t HiADC;		// used to switch Highpin directly to GND or VCC
  uint8_t LoPinR_L;		// used to switch 680 Ohm to LowPin
  uint8_t LoADC;		// used to switch Lowpin directly to GND or VCC
  uint8_t ii,jj;		// tempory values
  uint8_t StartADCmsk;		// Bit mask to start the ADC
  uint8_t SelectLowPin,SelectHighPin;
  uint8_t big_cap;
  int8_t esr0;			// used for ESR zero correction
  big_cap = 1;
  if (PartFound == PART_CAPACITOR) {
    ii = cap.cpre_max;
    cap_val_nF = cap.cval_max;
    while (ii < -9) { 		// set cval to nF unit
      cap_val_nF /= 10;		// reduce value by factor ten
      ii++;			// take next decimal prefix
    if (cap_val_nF < (1800/18)) return(0xffff);		// capacity lower than 1.8 uF
    //if (cap_val_nF > (1800/18)) {
    // normal ADC-speed, ADC-Clock 8us
      StartADCmsk = (1<<ADEN) | (1<<ADIF) | (1<<ADIE) | AUTO_CLOCK_DIV;  // enable ADC and Interrupt
      ADCSRA = StartADCmsk;		// enable ADC and Interrupt
    #else
      StartADCmsk =  (1<<ADSC) | (1<<ADEN) | (1<<ADIF) | AUTO_CLOCK_DIV;  // enable and start ADC
    #endif
    //} else {
    // fast ADC-speed, ADC-Clock 2us
      //StartADCmsk = (1<<ADEN) | (1<<ADIF) | (1<<ADIE) | FAST_CLOCK_DIV;  // enable ADC and Interrupt
      //ADCSRA = StartADCmsk;		// enable ADC and Interrupt
      //SMCR = (1 << SM0) | (1 <<SE);	// set ADC Noise Reduction and Sleep Enable
    #else
      //StartADCmsk =  (1<<ADSC) | (1<<ADEN) | (1<<ADIF) | FAST_CLOCK_DIV;  // enable and start ADC
    #endif
    //big_cap = 0;
  LoADC = pgm_read_byte(&PinADCtab[lopin]) | TXD_MSK;
  HiADC = pgm_read_byte(&PinADCtab[hipin]) | TXD_MSK;
  HiPinR_L = pgm_read_byte(&PinRLtab[hipin]);		// R_L mask for HighPin R_L load
    SelectLowPin = (lopin | (1<<REFS1) | (0<<REFS0));	// switch ADC to LowPin, Internal Ref.
    SelectHighPin = (hipin | (1<<REFS1) | (0<<REFS0));	// switch ADC to HighPin, Internal Ref.
  #else
    SelectLowPin = (lopin | (1<<REFS1) | (1<<REFS0));	// switch ADC to LowPin, Internal Ref.
    SelectHighPin = (hipin | (1<<REFS1) | (1<<REFS0));	// switch ADC to HighPin, Internal Ref.
  #endif
  // Measurement of ESR of capacitors AC Mode
  sumvolt[0] = 1;		// set sum of LowPin voltage to 1 to prevent divide by zero
  sumvolt[2] = 1;		// clear sum of HighPin voltage with current
                                // offset is about (x*10*200)/34000 in 0.01 Ohm units
  sumvolt[1] = 0;		// clear sum of HighPin voltage without current
  sumvolt[3] = 0;		// clear sum of HighPin voltage without current
  ADMUX = SelectLowPin;		// set Mux input and Voltage Reference to internal 1.1V
  #ifdef NO_AREF_CAP
  #else
    wait_about10ms();		// time for voltage stabilization with 100nF
  #endif
  // start voltage must be negativ
  ADC_DDR = HiADC;			// switch High Pin to GND
  R_PORT = LoPinR_L;			// switch R-Port to VCC
  R_DDR = LoPinR_L;			// switch R_L port for HighPin to output (VCC)
  wait10us();
  wait2us();
  R_PORT = 0;
  StartADCwait();			// set ADCSRA Interrupt Mode, sleep
  // Measurement frequency is given by sum of ADC-Reads < 680 Hz for normal ADC speed.
  // For fast ADC mode the frequency is below 2720 Hz (used for capacity value below 3.6 uF).
  // ADC Sample and Hold (SH) is done 1.5 ADC clock number after real start of conversion.
  // Real ADC-conversion is started with the next ADC-Clock (125kHz) after setting the ADSC bit.
  for(ii=0;ii<MAX_CNT;ii++) {
    R_DDR = LoPinR_L;			// switch R_L port for LowPin to output (VCC)
    adcv[0] = ADCW;			// Voltage LowPin with current
    ADMUX = SelectHighPin;
    //if (big_cap != 0) {
    StartADCwait();			// ADCSRA = (1<<ADEN) | (1<<ADIF) | (1<<ADIE) | AUTO_CLOCK_DIV;
    ADCSRA = (1<<ADSC) | (1<<ADEN) | (1<<ADIF) | AUTO_CLOCK_DIV; // enable ADC and start with ADSC
    wait4us();
    R_PORT = HiPinR_L;			// switch R-Port to VCC
    R_DDR = HiPinR_L;			// switch R_L port for HighPin to output (VCC)
    DelayBigCap();			// wait predefined time
    //} else {
    //  StartADCwait();			// ADCSRA = (1<<ADEN) | (1<<ADIF) | (1<<ADIE) | AUTO_CLOCK_DIV;
    //  R_PORT = HiPinR_L;		// switch R-Port to VCC
    //  R_DDR = HiPinR_L;		// switch R_L port for HighPin to output (VCC)
    //  ADCSRA = (1<<ADSC) | (1<<ADEN) | (1<<ADIF) | FAST_CLOCK_DIV;  // enable ADC and start with ADSC
    //                   		// SH at 2.5 ADC clocks behind start = 5 us
    //  DelaySmallCap(); 		// wait predefined time
    R_DDR = 0;				// switch current off,  SH is 1.5 ADC clock behind real start
    R_PORT = 0;
    while (ADCSRA&(1<<ADSC));		// wait for conversion finished
    adcv[1] = ADCW;			// Voltage HighPin with current
    #endif
    wdt_reset();
    // ******** Reverse direction, connect High side with GND ********
    wdt_reset();
    adcv[2] = ADCW;			// Voltage HighPin with current
    wait4us();
    R_PORT = LoPinR_L;
    R_DDR = LoPinR_L;			// switch LowPin with 680 Ohm to VCC
    //} else {
    //  StartADCwait();			// set ADCSRA Interrupt Mode, sleep
    //  R_PORT = LoPinR_L;
    //  R_DDR = LoPinR_L;		// switch LowPin with 680 Ohm to VCC
    //                     		// 2.5 ADC clocks = 5 us
    R_PORT = 0;
    adcv[3] = ADCW;			// Voltage LowPin with current
    #endif
    sumvolt[0] += adcv[0];		// add sum of both LowPin voltages with current
    sumvolt[1] += adcv[1];		// add  HighPin voltages with current
    sumvolt[2] += adcv[2];		// add  LowPin voltages with current
    sumvolt[3] += adcv[3];		// add  HighPin voltages with current
  } // end for
  sumvolt[0] += sumvolt[2];
  #ifdef ESR_DEBUG
    lcd_testpin(hipin);
    lcd_testpin(lopin);
    lcd_data(' ');
    DisplayValue(sumvolt[0],0,'L',4);	// LowPin 1
    lcd_line3();
    DisplayValue(sumvolt[1],0,'h',4);	// HighPin 1
    lcd_data(' ');
    DisplayValue(sumvolt[3],0,'H',4);	// LowPin 2
    lcd_line4();
  #endif
  if ((sumvolt[1] + sumvolt[3]) > sumvolt[0]) {
    sumvolt[2] = (sumvolt[1] + sumvolt[3]) - sumvolt[0];	// difference HighPin - LowPin Voltage with current
    sumvolt[2] = 0;
    sumvolt[2] -= (1745098UL*MAX_CNT) / (cap_val_nF * (cap_val_nF + 19));
  #ifdef ESR_DEBUG
    DisplayValue(sumvolt[2],0,'d',4);	// HighPin - LowPin
    lcd_data(' ');
  #endif
  esrvalue = (sumvolt[2] * 10 * (unsigned long)RRpinMI) / (sumvolt[0]+sumvolt[2]);
  esrvalue += esrvalue / 14;					// esrvalue + 7%
  esr0 = (int8_t)pgm_read_byte(&EE_ESR_ZEROtab[hipin+lopin]);
  if (esrvalue > esr0) {
    esrvalue -= esr0;
    esrvalue = 0;
    SMCR = (0 << SM0) | (0 << SE);	// clear ADC Noise Reduction and Sleep Enable
  #endif
  return (esrvalue);
#else
  return (0);
#endif
void us500delay(unsigned int us)  // = delayMicroseconds(us) + 500ns
#if F_CPU >= 20000000L
  __asm__ __volatile__ (
    "nop" "\n\t"
    "nop");              // just waiting 2 cycles
  if (--us == 0) return;
  us = (us<<2) + us;     // x5 us
#elif F_CPU >= 16000000L
  us <<= 2;
#else
  us <<= 1;
#endif
    "1: sbiw %0,1" "\n\t"            // 2 cycles
    "brne 1b" : "=w" (us) : "0" (us) // 2 cycles
void GetVloss() {
  // measure voltage drop after load pulse
  union t_combi{
  unsigned long dw;     // capacity value  in 100nF units
  uint16_t w[2];
  } lval;
  uint8_t ii;
  uint8_t HiPinR_L;
  uint8_t LoADC;
  if (cap.v_loss > 0) return;		// Voltage loss is already known
  LoADC = pgm_read_byte(&PinADCtab[cap.ca]) | TXD_MSK;
  HiPinR_L = pgm_read_byte(&PinRLtab[cap.cb]);		// R_L mask for HighPin R_L load
  adcv[0] = ReadADC(cap.cb);		// voltage before any load
  if (cap.cpre_max > -9) return;	// too much capacity
  lval.dw = cap.cval_max;
  //for (ii=cap.cpre_max+12;ii<5;ii++) {
  for (ii=cap.cpre_max+12;ii<4;ii++) {
    lval.dw = (lval.dw + 5) / 10;
  //if ((lval.dw == 0) || (lval.dw > 500)) {
  if ((lval.dw == 0) || (lval.dw > 5000)) {
    // capacity more than 50uF, Voltage loss is already measured
    return;
  for (tmpint=0; tmpint<lval.w[0]; tmpint+=2) {
    //wait50us();		// wait exactly 50us
    wait5us();			// wait exactly 5us
  //wait10us();			// wait a little time
  wdt_reset();
  ADCconfig.Samples = 5;	// set ADC to only 5 samples
  adcv[2] = ReadADC(cap.cb);
  // wait 2x the time which was required for loading
  for (tmpint=0; tmpint<lval.w[0]; tmpint++) {
    //wait50us();
    wait5us();
  adcv[3] = ReadADC(cap.cb);		// read voltage again, is discharged only a little bit ?
  ADCconfig.Samples = ANZ_MESS;		// set ADC back to configured No. of samples
  wdt_reset();
    adcv[1] = adcv[2] - adcv[3];	// lost voltage during load time wait
    adcv[1] = 0;			// no lost voltage
  // compute voltage drop as part from loaded voltage
  if (adcv[1] > 0) {
    // there is any voltage drop (adcv[1]) !
    cap.v_loss = (unsigned long)(adcv[1] * 500UL) / adcv[2];
  #if 0
    lcd_line3();
    DisplayValue(adcv[2],0,' ',4);
    DisplayValue(adcv[1],0,' ',4);
    lcd_line4();
    DisplayValue(lval.w[0],0,'x',4);
  #endif
  // ready
#endif
  return;
}  // end GetVloss()
void Calibrate_UR(void) {
  // get reference voltage, calibrate VCC with external 2.5V and
  // get the port output resistance
  #ifdef AUTO_CAL
    uint16_t sum_rm;	// sum of 3 Pin voltages with 680 Ohm load
    uint16_t sum_rp;	// sum of 3 Pin voltages with 680 Ohm load
    uint16_t u680;	// 3 * (Voltage at 680 Ohm)
  #endif
  ADCconfig.U_AVCC = U_VCC;     // set initial VCC Voltage
  ADCconfig.Samples = 190;	// set number of ADC reads near to maximum
    ADC_PORT = TXD_VAL;                 // switch to 0V
    ADC_DDR = (1<<TPREF) | TXD_MSK;     // switch pin with 2.5V reference to GND
    wait1ms();
    ADC_DDR =  TXD_MSK;   		// switch pin with reference back to input
    trans.uBE[1] = W5msReadADC(TPREF); 	// read voltage of 2.5V precision reference
    if ((trans.uBE[1] > 2250) && (trans.uBE[1] < 2750)) {
      // precision voltage reference connected, update U_AVCC
      WithReference = 1;
      ADCconfig.U_AVCC = (unsigned long)((unsigned long)ADCconfig.U_AVCC * 2495) / trans.uBE[1];
  #endif
  #ifdef WITH_AUTO_REF
    (void) ReadADC(MUX_INT_REF);	// read reference voltage
    ref_mv = W5msReadADC(MUX_INT_REF);	// read reference voltage
    RefVoltage();			// compute RHmultip = f(reference voltage)
  #else
    ref_mv = DEFAULT_BAND_GAP;    	// set to default Reference Voltage
  #endif
  ADCconfig.U_Bandgap = ADC_internal_reference; // set internal reference voltage for ADC
  #ifdef AUTO_CAL
    // measurement of internal resistance of the ADC port outputs switched to GND
    ADC_DDR = 1<<TP1 | TXD_MSK;		// ADC-Pin  1 to output 0V
    R_PORT = 1<<(TP1*2);		// R_L-PORT 1 to VCC
    R_DDR = 1<<(TP1*2);			// Pin 1 to output and over R_L to VCC
    sum_rm = W5msReadADC(TP1);
    ADC_DDR = 1<<TP2 | TXD_MSK;		// ADC-Pin 2 to output 0V
    R_PORT =  1<<(TP2*2);		// R_L-PORT 2 to VCC
    R_DDR = 1<<(TP2*2);			// Pin 2 to output and over R_L to VCC
    sum_rm += W5msReadADC(TP2);
    ADC_DDR = 1<<TP3 | TXD_MSK;		// ADC-Pin 3 to output 0V
    R_PORT =  1<<(TP3*2);		// R_L-PORT 3 to VCC
    R_DDR = 1<<(TP3*2);			// Pin 3 to output and over R_L to VCC
    sum_rm += W5msReadADC(TP3);		// add all three values
    // measurement of internal resistance of the ADC port output switched to VCC
    R_PORT = 0;				// R-Ports to GND
    ADC_PORT = 1<<TP1 | TXD_VAL;	// ADC-Port 1 to VCC
    R_DDR = 1<<(TP1*2);			// Pin 1 to output and over R_L to GND
    sum_rp = ADCconfig.U_AVCC - W5msReadADC(TP1);
    ADC_PORT = 1<<TP2 | TXD_VAL;	// ADC-Port 2 to VCC
    R_DDR = 1<<(TP2*2);			// Pin 2 to output and over R_L to GND
    sum_rp += ADCconfig.U_AVCC - W5msReadADC(TP2);
    ADC_PORT = 1<<TP3 | TXD_VAL;	// ADC-Port 3 to VCC
    R_DDR = 1<<(TP3*2);			// Pin 3 to output and over R_L to GND
    sum_rp += ADCconfig.U_AVCC - W5msReadADC(TP3);
    u680 = ((ADCconfig.U_AVCC * 3) - sum_rm - sum_rp);	// three times the voltage at the 680 Ohm
    pin_rmi = (unsigned long)((unsigned long)sum_rm * (unsigned long)R_L_VAL) / (unsigned long)u680;
    //adcmv[2] = pin_rm;	// for last output in row 2
    pin_rpl = (unsigned long)((unsigned long)sum_rp * (unsigned long)R_L_VAL) / (unsigned long)u680;
    resis680pl = pin_rpl + R_L_VAL;
    resis680mi = pin_rmi + R_L_VAL;
  #endif
  ADCconfig.Samples = ANZ_MESS; 	// set to configured number of ADC samples
// Interfacing a HD44780 compatible LCD with 4-Bit-Interface mode
#ifdef STRIP_GRID_BOARD
  #warning "strip-grid-board layout selected!"
#endif
void lcd_set_cursor(uint8_t row, uint8_t col)
  #ifdef LCD1602
    int row_offsets[] = { 0x00, 0x40, 0x14, 0x54 };
    if ( row >= 2 ) {
      row = 1;
    lcd.command(CMD_SetDDRAMAddress | (col + row_offsets[row]));
  #endif
  #ifdef NOK5110
    lcd.setCursor(6*col, 10*row);
  #endif
  #ifdef OLED096
    display.setCursor(6*col, 10*row);
  #endif
  uart_newline();
void lcd_string(char *data) {
  while(*data) {
    lcd_data(*data);
    data++;
void lcd_pgm_string(const unsigned char *data) {
  unsigned char cc;
  while(1) {
    cc = pgm_read_byte(data);
    if((cc == 0) || (cc == 128)) return;
    lcd_data(cc);
    data++;
void lcd_pgm_custom_char(uint8_t location, const unsigned char *chardata) {
  #ifdef LCD1602
    location &= 0x7;
    lcd.command(CMD_SetCGRAMAddress | (location << 3));
    for(uint8_t i=0;i<8;i++) {
      lcd.write(pgm_read_byte(chardata));
      chardata++;
  #endif
// sends numeric character (Pin Number) to the LCD
// from binary 0 we send ASCII 1
void lcd_testpin(unsigned char temp) {
  lcd_data(temp + '1');
// send space character to LCD
void lcd_space(void) {
  lcd_data(' ');
void lcd_fix_string(const unsigned char *data) {
  unsigned char cc;
  while(1) {
    cc = MEM_read_byte(data);
    lcd_data(cc);
    data++;
// sends data byte to the LCD
void lcd_data(unsigned char temp1) {
  #ifdef LCD1602
    lcd.write(temp1);
  #endif
  #ifdef NOK5110
    lcd.write(temp1);
  #endif
  #ifdef OLED096
    display.write(temp1);
  #endif
  switch(temp1) {
    case LCD_CHAR_DIODE1: {
      uart_putc('>'); uart_putc('|'); break;
    case LCD_CHAR_DIODE2: {
      uart_putc('|'); uart_putc('<'); break;
    case LCD_CHAR_CAP: {
      uart_putc('|'); uart_putc('|'); break;
    case LCD_CHAR_RESIS1: {
      uart_putc('['); uart_putc('='); break;
    case LCD_CHAR_RESIS2: {
      uart_putc(']'); break;
    case LCD_CHAR_U: {		// micro
      uart_putc('u');		// "u"
    case LCD_CHAR_OMEGA: {	// omega
      uart_putc('o');           // "ohm"
      uart_putc('h');
      uart_putc('m'); break;
    default: {
      uart_putc(temp1);
void lcd_clear(void) {
  #ifdef LCD1602
    lcd.clear();
  #endif
  #ifdef NOK5110
    lcd.clearDisplay();
  #endif
  #ifdef OLED096
    display.clearDisplay();
  #endif
  uart_newline();
void uart_putc(uint8_t data) {
  Serial.write(data);
  delay(2);
That's right.
In this case I would start by creating an empty sketch and connect only the display to an Arduino, and then writing text and numbers to the display. Try all kind of text that you imagine your application requires. If that works, integrate it into the larger project.
A sketch/setup like that is small, it's easy to show here on the forum and it puts people in a good position to help you if you have any problems. Moreover, isolating the problem this will will help you to figure out the problem on your own, much of the time, so it's an endeavor that's worth it in many ways.
i wonder if that could be issued by the screen. i see my text on the screen doesnt fill whole screen. i still have a lone or two empty. how do i fill it up?
im sorry im still new to the arduino and coding is not my strong side
Start with just putting text on the screen and nothing else, as suggested above. Have you tried this?
Yes , i found out that screen cant show the ohm-symbol
With the Adafruit_SSD1306 library, using the default font, the ohm symbol should be either 0xE9 or 0xEA.
Ok, good. If that's the case and the advice of @david_2018 above doesn't pan out, you can replace it with "R", or simply divide the outcome by 1000 and call it 'k'. Maybe not make things any more complicated than they need to be!
I just dont know where to put your changes or davids,
