The sketch here used:
Serial1.begin(9600); //bluetooth
Serial2.begin(9600); //gps
any reason they to do this way?
Sure there are lot of 'Serial1' was not declared in this scope
ERRORs, I corrected the code with just 'Serial'
and there is error: 'Serial1' was not declared in this scope
in the libraries again, so now I completely confused, if they used Serial1 in both sketch and library, should there be a reason?
#include "gps.h"
#include "motor.h"
#include "sdCard.h"
#include "ultrasonic.h"
#include "compass.h"
/* Loop timing */
long timeOld = 0;
long dt = 0;
/* Bluetooth */
char blContent[10];
int blIndex = 0;
int angleSetPoint = 0;
int powerSetPoint = 0;
int storeLocation = 0;
int returnToHome = 0;
int navigateToWaypoint = 0;
/* Gps */
gps::geoLocFloat myPos; //struct to store current geolocation in float
gps::geoLocFloat goalPos; //struct to store goal geolocation in float
const int numTrajPoints = 10; //max number of positions that can be stored in the goal array
const float maxGoalDist = 0.5; //distance to goal that is needed before setpoint switch or return to home finished
long posLat[numTrajPoints] = {0}; //storage array for latitude
long posLon[numTrajPoints] = {0}; //storage array for longitude
int storageIndex = 0; //this index is used for storing the geolocations
int averagingIndex = 0; //this index in used to avarage goalocations before storing
int setPointIndex = 0; //this index is used to release new setpoints
bool firstTimeWaypointNav = true;
bool homePosUpdated = false;
float distanceToGoal = 0.0;
float bearing = 0.0;
float bearingOld = 0.0; //Jump detection
float heading = 0.0;
float headingOld = 0.0; //Jump detection
int overflowCounter = 0;
float bearingSP = 0;
float deltaHeading = 0.0;
float deltaHeadingInt = 0.0;
delay(5000); //erstmal warten, damit Bluetooth verbinden kann
motor::setupMotor();
gps::setupGPS();
compass::setupCompass();
//sdCard::setupSdCard();
/* Fix Looptime */
dt = micros() - timeOld;
while(dt<loopTimeMicros){dt = micros() - timeOld;}
timeOld = micros();
getBlCommand(); //read bluetooth commands
if(gps::processGPS()) //new Gps data available (10Hz update rate)
if(storeLocation == 1)
storeCurrentLocation();
myPos.lat = goalPos.lat = gps::gpsData.lat*1e-7; //set myPos and goalPos equal
myPos.lon = goalPos.lon = gps::gpsData.lon*1e-7;
if( returnToHome == 1 //return to home activated
&& storeLocation == 2 //the lat, lon arrays contain data
&& navigateToWaypoint == 0 )
homePosUpdated = true;
goalPos.lat = posLat[0]*1e-7;
goalPos.lon = posLon[0]*1e-7;
if(navigateToWaypoint == 1 //waypoint navigation activated
&& returnToHome == 0 )
if(distanceToGoal < maxGoalDist && firstTimeWaypointNav == false) //switch goal when closer than 1m
Serial1.print("Goalpos["); Serial1.print(setPointIndex); Serial1.println("] reached. Switching to next.");
setPointIndex ++;
int endSetPointIndex = storageIndex;
if(storageIndex == 0){endSetPointIndex = numTrajPoints; }
if(setPointIndex == endSetPointIndex) //begin again when storageIndex is reached.
setPointIndex = 0;
firstTimeWaypointNav = false;
goalPos.lat = posLat[setPointIndex]*1e-7; //use current setpoint as goal
goalPos.lon = posLon[setPointIndex]*1e-7;
distanceToGoal = gps::getDistance(myPos, goalPos);
bearing = gps::getBearing(myPos, goalPos);
if(returnToHome == 1 || navigateToWaypoint == 1 ) //autonomous driving activated
powerSetPoint = 100;
if(distanceToGoal < maxGoalDist && returnToHome == 1 && homePosUpdated == true)
//home position reached
powerSetPoint = 0;
returnToHome = 0;
Serial1.println("Homepos reached."); Serial1.println("Return to home deactivated.");
if(distanceToGoal < 1.5 * maxGoalDist && navigateToWaypoint == 1)
powerSetPoint = 50; //slow nearby the goal
/* PI controller for the angle setpoint */
calcAngleSetPoint();
/* second cascade of direction controller and pwm generation */
motor::drive(powerSetPoint,angleSetPoint); //needs values between [0..100] and [0..359]
void calcAngleSetPoint()
{ //@brief: this function uses heading and bearing to calculate
//the anglesetPoint with an PI-Controller. This is the outer cascade of the direction controller
headingOld = heading;
heading = compass::getHeading();
/* This is to handle the case when bearing and heading jump between -180 and 180 degree.
Its necessery othewise the controller won't work when driving in southern direction */
if(headingOld < -90 && heading > 90){overflowCounter += 1;} //jump from -180 to +180
if(headingOld > 90 && heading < -90){overflowCounter -= 1;} //jump from +180 to -180
if(bearingOld < -90 && bearing > 90){overflowCounter -= 1;} //jump from -180 to +180
if(bearingOld > 90 && bearing < -90){overflowCounter += 1;} //jump from +180 to -180
bearingSP = overflowCounter*360 + bearing;
deltaHeading = bearingSP - heading ;
if(deltaHeading < -89){deltaHeading = -89;}
if(deltaHeading > 89){deltaHeading = 89;}
float uHeading = 1.0*deltaHeading + 0.05*deltaHeadingInt;
deltaHeadingInt += deltaHeading;
if(deltaHeading <= 0.05 && deltaHeading >= -0.05 || //anti-windup
deltaHeading < 0.0 && deltaHeadingInt > 0.0 ||
deltaHeading > 0.0 && deltaHeadingInt < 0.0)
{deltaHeadingInt = 0.0;}
if(deltaHeadingInt>1000){ deltaHeadingInt = 1000; powerSetPoint = 50;}
if(deltaHeadingInt<-1000){ deltaHeadingInt = -1000; powerSetPoint = 50;}
if(uHeading<-89){uHeading = -89;} //only allow forward driving
if(uHeading>89){uHeading = 89;}
angleSetPoint = static_cast<int>(90.0 - uHeading + 0.5); //1...179 and 90 means straight, 0.5 for rounding since always positive
void storeCurrentLocation(void)
{ //@brief: this function stores an average of the current
//location in the position array and increments the storage index
posLat[storageIndex] += gps::gpsData.lat;
posLon[storageIndex] += gps::gpsData.lon;
averagingIndex ++;
if(averagingIndex == 4) //careful, more than 4 won't fit in long
posLat[storageIndex] = posLat[storageIndex]/4;
posLon[storageIndex] = posLon[storageIndex]/4;
storeLocation = 2;
Serial1.print(storageIndex);
Serial1.print("] set to: ");
Serial1.print(posLat[storageIndex]*1e-7, 7); Serial1.print(" ");
Serial1.println(posLon[storageIndex]*1e-7,7);
storageIndex ++;
if(storageIndex == numTrajPoints)
storageIndex = 0;
Serial1.println("End of setpoint array reached.");
Serial1.println("Next one will overwrite home position.");
void getBlCommand(void)
{ //@brief: this function reads bluetooth commands from serial1
while(Serial1.available()) {
blContent[blIndex] = Serial1.read();
blIndex++;
if(blContent[blIndex-1] == ' ') //endcharacter reached
if(blContent[0] == 'a') //angleSetPoint
angleSetPoint = atoi(&blContent[1]); //start with second char and parse for an int
if(blContent[0] == 'p') //powerSetPoint
powerSetPoint = atoi(&blContent[1]); //start with second char and parse for an int
if(blContent[0] == 'g') //store trajectory point
storeLocation = 1;
posLat[storageIndex] = 0;
posLon[storageIndex] = 0;
averagingIndex = 0;
if(blContent[0] == 'r') //activate return to home
if(returnToHome == 0){
returnToHome = 1;
Serial1.println("Return to home activated.");
else{
returnToHome = 0;
powerSetPoint = 0;
if(blContent[0] == 's') //activate waypoint navigation
if(navigateToWaypoint == 0){
navigateToWaypoint = 1;
setPointIndex = 0; //always begin at home
Serial1.println("Waypoint navigation activated.");
else{
powerSetPoint = 0;
Serial1.println("Waypoint navigation deactivated.");
if(blContent[0] == 'd') //print debug info
if(blContent[1] == '0')
Serial1.print("dt: "); Serial1.println(dt);
Serial1.print("overflowCounter: "); Serial1.println(overflowCounter);
Serial1.print("deltaHeading: "); Serial1.println(deltaHeading);
Serial1.print("distGoal: "); Serial1.println(distanceToGoal);
if(blContent[1] == '1')
Serial1.print("myPos: "); Serial1.print(myPos.lat, 7); Serial1.print(" "); Serial1.println(myPos.lon,7);
Serial1.print("goalPos: "); Serial1.print(goalPos.lat, 7); Serial1.print(" "); Serial1.println(goalPos.lon,7);
if(blContent[0] == 'q') //delete goal positions in array and reset
returnToHome = 0;
powerSetPoint = 0;
setPointIndex = 0;
storageIndex = 0;
averagingIndex = 0;
storeLocation = 0;
for (int i = 0; i<numTrajPoints; i++)
posLat[i] = 0;
posLon[i] = 0;
Serial1.println("Goal array reset succesful.");
blIndex = 0;
