I wanted to add an external analog reference to provide a precision voltage reference for my application. I noticed that when I am plugged into USB, my analog value read is very accurate when checked against a volt-meter. However, when I un-plug usb and use an external power supply, the analog reading is way off.
Ive confirmed the following:
(a) My analog reference is in fact 5 volts constantly (through external volt meter)
(b) My analog signal Im reading is in fact 4.84 voltage (through external volt meter)
(c) I get this same behavior on two different mega 2560 boards
Aruino Read Voltage:
With USB plugged in: 4.84 Volts
Wihtout USB plugged in: 1.48-1.54 Voltage (floating)
Since I can confirm that the voltages are correct using my volt meter, Im assuming theres something wrong in by code? Anyone seen something similiar?
When powering externally, how are you doing this? What is the voltage of the Arduino 5V pin
when powered this way?
Are you ensuring the AREF pin is never pulled higher than the Arduino 5V at any time (this will fry the pin) - normally you would derive AREF from a voltage reference powered from
5V rail, so this can never happen. You seem to have some external source of 5V reference maybe not
derived from the Arduino 5V, which is why I wonder about this.
All the pins on any logic chip must always be kept within the supply rails at all times (unless the
datasheet says different), this applies to AREF as much as any other signal pin.
Using an external Aref can be unhealthy for your Arduino.
Make sure it always stays within the voltage range of the MCU supply.
That means the Arduino can't be off while there is voltage on Aref.
Why don't you use the inbuild bandgap reference voltage.
The Mega has two.
A 1.1volt Aref and a 2.56volt Aref.
Safe, and very stable.
I have a 5.0V precision voltage reference im using for my external reference. Its rock steady at 5.0V so I dont think its the reference.
When not usng USB, im connecting my power to the arduino via Vin. I notice that the Arduino's 5V drops to 4V when I disconnect the USB so I think thats a red flag. Am I connecting power incorrectly perhaps?
I have a custom built shield and I didnt plan on using the power jack unless I have to.
Ahh good call.... I was using +5V to power the arduino over Vin. I have to use my 12V source. Once I did that I got the same reading on both USB and External power, and my External reference is working correctly.
Thanks for you help, your questions pointed me in the correct direction.
The secret volmeter you linked to is using 1.1volt Aref.
That is rock solid, but not factory trimmed.
It could be as low as 1volt, and as high as 1.2volt.
So you have to calibrate the readout by changing the voltage in the maths line to the actual voltage of Aref.
Try this sketch. I already changed it for a Mega.
Leo..
0 - ~16volt voltmeter for 3.3volt and 5volt Arduinos
uses the stable internal 1.1volt reference
6k8 resistor from A0 to ground, and 100k resistor from A0 to +batt
100n capacitor from A0 to ground for stable readings
(100k + 6k8) / 6k8 = 15.70588 | used in formula
float Aref = 1.075; // ***calibrate here*** | change this to the actual Aref voltage of ---YOUR--- Arduino
unsigned int total; // holds 64 readings
float voltage; // converted to volt
analogReference(INTERNAL1V1); // use the internal ~1.1volt reference | change (INTERNAL) to (INTERNAL1V1) for a Mega
Serial.begin(9600); // set serial monitor to this value
for (int x = 0; x < 64; x++) // multiple analogue readings for averaging
total = total + analogRead(A0); // add each value to a total
voltage = (total / 64) * 15.70588 * Aref / 1024 ; // convert readings to volt
// print to serial monitor
if (total == (1023 * 64))
Serial.print("voltage too high"); // if overflow
Serial.print("The battery is ");
Serial.print(voltage);
Serial.println(" volt");
total = 0; // reset value
delay(1000); // one second between measurements
