Arpeggiating Synthesizer (Mosquito I)
So, I am following this mosquito synth, and really want to add one more pot into the mix, but the code is quite complex for a basic arduino user like me. all I want to do is ad either delay, echo, reverb, or heck even volume as the last pot. I have tried this by using mozzi library examples and adding things in line by line to test, but it usually ends up in the selected pot working and nothing else working. I'll leave the code down below, if someone would like to help add an echo or delay function to this it would be much appriciated!!
/*  Mosquito I
 *   by Tim D...
 *   analog.sketchbook.101@gmail.com
#include <MozziGuts.h>
#include <Oscil.h>
#include <tables/saw8192_int8.h>
#include <tables/smoothsquare8192_int8.h>
#include <EventDelay.h>
#include <mozzi_midi.h>
#include <LowPassFilter.h>
#define CONTROL_RATE 128 // powers of 2 please
Oscil<SAW8192_NUM_CELLS, AUDIO_RATE> oscOne(SAW8192_DATA);       //audio oscillator
Oscil<SMOOTHSQUARE8192_NUM_CELLS, AUDIO_RATE> oscTwo(SMOOTHSQUARE8192_DATA); //audio oscillator
LowPassFilter lpf;                                                               //low pass filter
// for sequencing gain
EventDelay kGainChangeDelay;
char gain = 1;
// analog pins (for control pots)
// Note: Pin assignment is a bit arbitrary. This order worked fine for the way I laid out the pots
//       on my front panel, but you might find you need a different order to help with wire routing,
//       panel layout etc
const int OSC_ONE_PIN = 2;    // pitch
const int OSC_TWO_PIN=3;      // phase
const int MODA_PIN=0;         // rate
const int MODB_PIN=1;         // legato
const int MODC_PIN=4;         // filter
// digital pins
const int ledPin=4;           // LED
const int upButtonPin = 2;    // up push button
const int downButtonPin = 3;  // down push button
// global vars to handle push button functionality and debouncing
int upButtonState;
int lastUpState = LOW;
int downButtonState;
int lastDownState = LOW;
unsigned long lastUpDebounceTime = 0;
unsigned long lastDownDebounceTime = 0;
unsigned long debounceDelay = 50;        // the debounce time; increase if the output flickers
// division constants
// We're doing some common division operations ahead of time so that we can avoid division in the main loops
// which will slow things down when Mozzi is trying to do its thing. Doing the division here allows us to use
// multiplication in the main loop which is much faster
const float DIV1023 = 1.0 / 1023.0; // division constant for pot value range
const float DIV10 = 1.0 / 10.0;     // division constant for division by 10
// global vars for the arpeggiator stuff
int sequence = 0;               // current sequence playing
int note = 0;                   // current note playing
const int numSequences = 21;    // total number of sequences (must match number of sequences in NOTES array)
const int numNotes = 8;         // total number of notes in each sequence (must all be the same and match length of each sequence in NOTES)
// sequences of midi notes to play back
// add new sequences or modify existing ones to suit
// just make sure you update the numSequences and numNotes variables above to match what you've done
const int NOTES[numSequences][numNotes] = {
                        {36,48,36,48,36,48,36,48},                    // up on two
                        {36,36,36,36,36,36,36,36},                    // flat quarters
                        {36,36,36,48,36,36,36,48},                    // up on four
                        {36,36,48,42,36,36,36,48},                    // dum da dum
                        {48,48,36,48,48,36,48,36},                    // two up one down
                        {36,48,36,48,36,48,36,48},                    // up down
                        {36,36,48,36,36,48,36,48},                    // up on three
                        {36,37,38,39,40,41,42,43},                    // chromatic up
                        {43,42,41,40,39,38,37,36},                    // chromatic down
                        {36,38,39,41,43,44,46,48},                    // major up
                        {48,46,44,43,41,39,38,36},                    // major down
                        {36,38,40,43,45,48,50,52},                    // natural minor up
                        {52,50,48,45,43,40,38,36},                    // natural minor down
                        {36,39,41,42,43,46,48,51},                    // major pentatonic up
                        {51,48,46,43,42,41,39,36},                    // major pentatonic down
                        {36,39,41,42,43,46,48,51},                    // blues up
                        {51,48,46,43,42,41,39,36},                    // blues down
                        {36,40,34,45,48,39,38,46},                    // random one
                        {36,38,35,45,37,43,50,41},                    // random two
                        {36,46,44,37,48,35,42,45},                    // random three
                        {36,44,48,38,39,43,44,38}};                   // random four
// global control params
int OSC_ONE_OFFSET = 12;      // amount to offset the original midi note (12 is one octave)
int OSC_TWO_OFFSET = 2;       // amount to offset the second midi note from the osc one's midi note (5 is a fifth, two is a second, etc)
int ARP_RATE_MIN = 32;        // minimum arpeggiator rate (in millisecs)
int ARP_RATE_MAX = 1024;      // maximum arpeggiator rate (in millisecs)
int LEGATO_MIN = 32;          // minimum note length (capping at 32 to avoid rollover artifacts)
int LEGATO_MAX = 1024;        // maximum note length
int LPF_CUTOFF_MIN = 10;      // low pass filter min cutoff frequency
int LPF_CUTOFF_MAX = 245;     // low pass filter max cutoff frequency
void setup(){
  //initialize buttons
  pinMode(upButtonPin, INPUT);
  pinMode(downButtonPin, INPUT);
  pinMode(ledPin,OUTPUT);
  //initialize Mozzi objects
  startMozzi(CONTROL_RATE);
  oscOne.setFreq(48);
  oscTwo.setFreq(51);
  lpf.setResonance(128u);
  kGainChangeDelay.set(1000);
  //Serial.begin(9600); //Serial output can cause audio artifacting so this is commented out by default. Can be uncommented for debugging purposes.
void updateControl(){
  // read sequence selector buttons and debounce them
  // using mozziMicros() instead of millis() for timing calls because Mozzi disables millis() timer
  int upreading = digitalRead(upButtonPin);
  int downreading = digitalRead(downButtonPin);
  if (upreading != lastUpState){
    lastUpState = mozziMicros();
  if ((mozziMicros() - lastUpDebounceTime) > debounceDelay){
    if (upreading != upButtonState){
      lastUpDebounceTime = mozziMicros();
      upButtonState = upreading;
      if (upButtonState == HIGH){
        sequence += 1;
        if (sequence >= numSequences){
          // if we get to the end of the sequences we'll rollover back to the first sequence
          sequence = 0;
  if (downreading != lastDownState){
    lastDownState = mozziMicros();
  if ((mozziMicros() - lastDownDebounceTime) > debounceDelay){
    if (downreading != downButtonState){
      lastDownDebounceTime = mozziMicros();
      downButtonState = downreading;
      if (downButtonState == HIGH){
        sequence -= 1;
        if (sequence < 0){
          // if we get to the first sequence we'll rollover to the last sequence
          sequence = numSequences - 1;
  // read pot values
  int oscOne_val = mozziAnalogRead(OSC_ONE_PIN);
  int oscTwo_val = mozziAnalogRead(OSC_TWO_PIN);
  int modA_val = mozziAnalogRead(MODA_PIN);
  int modB_val = mozziAnalogRead(MODB_PIN);
  int modC_val = mozziAnalogRead(MODC_PIN);
  // map pot vals
  // These formulas set the range of values coming from the pots to value ranges that work well with the various control functionality.
  // You'll probably only need to mess with these if you want to expand or offset the ranges to suit your own project's needs
  int oscOne_offset = (OSC_ONE_OFFSET*2) * ((oscOne_val * DIV1023)-0.5);                  // offset of original midi note number +/- 1 octave
  float oscTwo_offset = ((oscTwo_val * DIV1023) * DIV10) * OSC_TWO_OFFSET;                // frequency offset for second oscillator +/- 0.2 oscOne freq
  float modA_freq = ARP_RATE_MIN + (ARP_RATE_MAX * (1-(modA_val * DIV1023)));             // arpeggiator rate from 32 millisecs to ~= 1 sec
  float modB_freq = 1-(modB_val * DIV1023);                                               // legato from 32 millisecs to full on (1 sec)
  int modC_freq = LPF_CUTOFF_MIN + (LPF_CUTOFF_MAX *(modC_val * DIV1023));                // lo pass filter cutoff freq ~=100Hz-8k
  // using an EventDelay to cycle through the sequence and play each note
  kGainChangeDelay.set(modA_freq);                                        // set the delay frequency
  if(kGainChangeDelay.ready()){
      if(gain==0){                                                        // we'll make changes to the oscillator freq when the note is off
        if(note >= numNotes){                                             // if we've reached the end of the sequence, loop back to the beginning
            note = 0;
        // turn on the LED on first note of sequence only
        if (note==0){
          digitalWrite(ledPin,HIGH);
        }else{
          digitalWrite(ledPin,LOW);
        // set oscillator notes based on current note in sequence
        float noteOne = mtof(NOTES[sequence][note] + oscOne_offset);      // osc one's freq = note plus any offset from user
        float noteTwo = noteOne + oscTwo_offset;                          // osc two's freq = osc one's freq plus user offset
        oscOne.setFreq(noteOne);
        oscTwo.setFreq(noteTwo);
        note += 1;
        // setting length of note
        gain = 1;
        kGainChangeDelay.set(modA_freq*(1-modB_freq));                    // set length that note is on based on user legato settings
      else{
          gain = 0;
          kGainChangeDelay.set(modA_freq*modB_freq);                      // set length that note is off based on user legato settings
    kGainChangeDelay.start();                                             // execute the delay specified above
  // setting lo pass cutoff freq
  lpf.setCutoffFreq(modC_freq);                                           // set the lo pass filter cutoff freq per user settings
int updateAudio(){
  // calculating the output audio signal as follows:
  // 1. Summing the waveforms from the two oscillators
  // 2. Shifting their bits by 1 to keep them in a valid output range
  // 3. Multiplying the combined waveform by the gain (volume)
  // 4. Passing the signal through the low pass filter
  return (char)lpf.next((((oscOne.next() + oscTwo.next())>>2) * gain));
void loop(){
  audioHook();
Please get used to use code tags. Advice here: How to get the best out of this forum - Using Arduino / IDE 1.x - Arduino Forum
You posted text that's not interesting to read for most helpers.
Posting documentation about the existing build would make things more clear.
@jsutts4507
Use this to help yourself format the code, please.
Direct link to the code formatting: How to get the best out of this forum
Thanks
Thanks. That's a more direct link. I'll try to keep it.
Does this library example directory have the function you seek:
Yeah I've had a look through most of those. The only one related to 'echo' is the Control_Echo_Theremin example. I tried adding this in line by line to my existing code, with pin 5 being the 'echo pot'. it all compiled fine for every line, although the pot wasn't actually doing anything. it wasn't until I got to this line:
`AudioOutput updateAudio(){
  return MonoOutput::fromAlmostNBit(12,
    3*((int)aSin0.next()+aSin1.next()+(aSin2.next()>>1)
    +(aSin3.next()>>2))
After this one went in it switched from everything working (except the echo pot), to only the echo pot working (no note sequences were playing, buttons did nothing, and no other pots worked)
tricky tricky
This is the example:
/*  Example of a simple light-sensing theremin-like
    instrument with long echoes,
    using Mozzi sonification library.
    Demonstrates ControlDelay() for echoing control values,
    and smoothing an analog input from a sensor
    signal with RollingAverage().
    The circuit:
    Audio output on digital pin 9 on a Uno or similar, or
    DAC/A14 on Teensy 3.1, or
    check the README or http://sensorium.github.io/Mozzi/
    Light dependent resistor (LDR) and 5.1k resistor on analog pin 1:
    LDR from analog pin to +5V (3.3V on Teensy 3.1)
    5.1k resistor from analog pin to ground
   Mozzi documentation/API
   https://sensorium.github.io/Mozzi/doc/html/index.html
   Mozzi help/discussion/announcements:
   https://groups.google.com/forum/#!forum/mozzi-users
   Copyright 2012-2024 Tim Barrass and the Mozzi Team
   Mozzi is licensed under the GNU Lesser General Public Licence (LGPL) Version 2.1 or later.
#define MOZZI_CONTROL_RATE 64
#include <Mozzi.h>
#include <Oscil.h> // oscillator template
#include <tables/sin2048_int8.h> // sine table for oscillator
#include <RollingAverage.h>
#include <ControlDelay.h>
#define INPUT_PIN 0 // analog control input
unsigned int echo_cells_1 = 32;
unsigned int echo_cells_2 = 60;
unsigned int echo_cells_3 = 127;
ControlDelay <128, int> kDelay; // 2seconds
// oscils to compare bumpy to averaged control input
Oscil <SIN2048_NUM_CELLS, MOZZI_AUDIO_RATE> aSin0(SIN2048_DATA);
Oscil <SIN2048_NUM_CELLS, MOZZI_AUDIO_RATE> aSin1(SIN2048_DATA);
Oscil <SIN2048_NUM_CELLS, MOZZI_AUDIO_RATE> aSin2(SIN2048_DATA);
Oscil <SIN2048_NUM_CELLS, MOZZI_AUDIO_RATE> aSin3(SIN2048_DATA);
// use: RollingAverage <number_type, how_many_to_average> myThing
RollingAverage <int, 32> kAverage; // how_many_to_average has to be power of 2
int averaged;
void setup(){
  kDelay.set(echo_cells_1);
  startMozzi();
  int bumpy_input = mozziAnalogRead<10>(INPUT_PIN); // request reading at 10-bit resolution, i.e. 0-1023
  averaged = kAverage.next(bumpy_input);
  aSin0.setFreq(averaged);
  aSin1.setFreq(kDelay.next(averaged));
  aSin2.setFreq(kDelay.read(echo_cells_2));
  aSin3.setFreq(kDelay.read(echo_cells_3));
    +(aSin3.next()>>2))
void loop(){
  audioHook();
Which board are you using? Looks like Arduino Uno/Nano (10 bit ADC).
Using an UNO.
Use the library's simplest example and learn (1) how it works, (2) how you can adjust it, (3) how you can break it.
a. Define your new button/knob.
b. Configure the button/knob to setup()
c. Add the button/knob to updateControl() so its value is read every loop.
d. Add the equation the new button/knob effects to updateControl().
e. Add the results of the equation to updateAudio()
As long as updateAudio() is called every loop, you should hear the changes made to the knobs and buttons.
A drawing from the mosquito library for adding a button or knob...
